ASRock A320M-HDV Rev. 3.0
- Ersteller pipin
Gelistet seit:
– Letztes Update:
- Name:
- ASRock A320M-HDV Rev. 3.0
- Hersteller:
- ASRock
- Formfaktor:
- mATX
- Sockel:
- AM4
- Chipsatz:
- AMD A320
- AGESA-Version:
- Combo-AM4v2Pi 1.2.0.8
- TDP:
- 65 W
- Lüfteranschlüsse:
- 3 (2 vierpolig)
- Speichergeschwindigkeit:
- DDR4-2667
- Speicherbänke:
- 2x DDR4
- Video-Ausgänge:
- VGA + DVI + HDMI
- Integrierter Audio-Chip:
- Realtek ALC887
- Audio-Ausgänge:
- 2.1
- PCIe-Slots (2):
- PCIe 3.0/3.1 x16
- PCIe x1
- SATA-Anschlüsse:
- 4x SATA 6 Gbit/s
- M.2-Anschlüsse (M-Key):
- 1
- 1x PCIe + SATA
- LAN-Anschlüsse:
- 1x 1Gb LAN
- Primärer LAN-Chip:
- Realtek RTL8111GR
- USB-Anschlüsse außen:
- 4x USB 2.0
- USB-Anschlüsse innen:
- 4x USB 2.0
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- 2x 16 GB DDR4 3200
- GeForce GTX 1650
- 27 Zoll Acer + 24 Zoll DELL
- Samsung 980 Pro 256 GB
- diverse
- Fractal Design R5
- Logitech Cordless Desktop
- Logitech G502
- Firefox, Vivaldi
- ▼250 MBit ▲40 MBit
BIOS Versionen
L8.01 (14.02.2023)Update AMD AM4 AGESA Combo V2 PI 1.2.0.8
7.30 (08.11.2022)1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.7
2. Support Renoir, Vermeer, and Cezanne CPU
3. Remove Bristol Ridge(AMD A-series/Athlon X4 series) CPU support.
4. Improve GPU compatibility for GeForce RTX 40 series. -
6.20 (14.08.2020)1. Update AMD AGESA Combo-AM4 PI 1.0.0.6
2. Supports 3RD Gen AMD Ryzen XT series CPU -
6.10 (04.02.2020)Update AMD AGESA Combo-AM4 1.0.0.4 Patch B
*ASRock do NOT recommend updating this BIOS if Pinnacle, Raven, Summit or Bristol Ridge CPU is being used on your system.
*Before updating this BIOS, please also read the description in previous BIOS version.
