ASUS Prime X670-P WIFI
- Ersteller LordNord
Gelistet seit:
– Letztes Update:
- Name:
- ASUS Prime X670-P WIFI
- Hersteller:
- ASUS
- Formfaktor:
- ATX
- Sockel:
- AM5
- Chipsatz:
- AMD X670
- AGESA-Version:
- Combo-AM5Pi 1.1.0.2B
- TDP:
- 170 W
- Lüfteranschlüsse:
- 5 (5 vierpolig)
- Speichergeschwindigkeit:
- DDR5-5200
- Speicherbänke:
- 4x DDR5
- Video-Ausgänge:
- HDMI + Displayport
- Integrierter Audio-Chip:
- Realtek ALC897
- Audio-Ausgänge:
- 7.1
- PCIe-Slots (4):
- PCIe 4.0 x16
- PCIe 4.0 x16, elektrisch x4
- PCIe x1
- SATA-Anschlüsse:
- 6x SATA 6 Gbit/s
- M.2-Anschlüsse (M-Key):
- 3
- 3x PCIe
- RAID-Modus:
- 0/1/10
- LAN-Anschlüsse:
- 1x 2,5Gb LAN
- Primärer LAN-Chip:
- Realtek RTL8125BG
- WLAN und Bluetooth:
- Bluetooth 5.2, WLAN 802.11a/b/g/n/ac/ax
- USB-Anschlüsse außen:
- 1x USB 3.2 (Gen 2x2, 20 Gbit/s)
- 3x USB 3.2 (Gen 2, 10 Gbit/s)
- 2x USB 2.0
- Davon Typ C:
- 2
- USB-Anschlüsse innen:
- 5x USB 3.2 (Gen 1, 5 Gbit/s)
- 4x USB 2.0
Buttons/Switches: USB BIOS Flashback (extern), Header Beleuchtung: 2x 4-Pin RGB (+12V/G/R/B, max. 3A), 3x 3-Pin ARGB (+5V/DATA/GND, max. 3A, ASUS Gen2)
LordNord
- S-H
- AMD Ryzen 9 3900X
- ASUS TUF Gaming B550-Plus
- be quiet! Dark Rock 4
- 2x16GB Crucial DDR4 3200
- AOC Q3279VWFD8
- 8TB extern
- Be quiet! Pure Power 9 600W
- Win 10 64Bit
▼200
▲200
BIOS Versionen
2413 (07.02.2024)Disable STAPM of AM5 Ryzen™ 8000 processors to improve system performance.
2412 (30.01.2024)Update AGESA version to Combo AM5 PI 1.1.0.2b
2214 (04.01.2024)1. Update AGESA version to Combo AM5 PI 1.1.0.1
2. Improve system stability
3. This update includes the patch for the LogoFAIL vulnerabilities
4. Support graphics card with M.2 storage -
1811 (16.10.2023)Improve system stability
1808 (11.10.2023)Update AGESA version to Combo AM5 PI 1.0.8.0 to support upcoming CPU
1654 (28.08.2023)1. Update AGESA version to Combo AM5 PI 1.0.0.7c
2. Improve system performance -
1636 (04.08.2023)1. Update AGESA version to Combo AM5 PI 1.0.0.7b
2. Improve memory compatibility -
1616 (16.05.2023)1. Update AGESA version to Combo AM5 PI 1.0.0.7.a
2. Support 48/24GB high-density DDR5 memory module.
3. Memory QVL amended to account for AMD 1.3V SoC voltage limit.
4. EXPO/XMP prompt notice removed. -
1413 (27.04.2023)SoC voltage for Ryzen 7000X3D series limited to a maximum of 1.30V to protect the CPU and motherboard.
1409 (21.04.2023)1. Update AGESA version to ComboAM5PI 1.0.0.6
2. TPM 2.0 security update
3. Recommended for optimum performance with AMD Ryzen™ 7000X3D series processors
