EVGA X570 Dark
- Ersteller LordNord
Gelistet seit:
– Letztes Update:
- Name:
- EVGA X570 Dark
- Hersteller:
- EVGA
- Formfaktor:
- E-ATX
- Sockel:
- AM4
- Chipsatz:
- AMD X570
- AGESA-Version:
- Combo-AM4v2Pi 1.2.0.7
- TDP:
- 105 W
- Lüfteranschlüsse:
- 6 (6 vierpolig)
- Speichergeschwindigkeit:
- DDR4-3200
- Speicherbänke:
- 2x DDR4
- Integrierter Audio-Chip:
- Realtek ALC1220
- Audio-Ausgänge:
- 7.1
- PCIe-Slots (3):
- PCIe 4.0 x16
- PCIe 4.0 x16, elektrisch x8
- PCIe x4
- SATA-Anschlüsse:
- 8x SATA 6 Gbit/s
- M.2-Anschlüsse (M-Key):
- 2
- 2x PCIe
- RAID-Modus:
- 0/1/10
- LAN-Anschlüsse:
- 2x 2,5Gb LAN
- Primärer LAN-Chip:
- Intel I225V
- Sekundärer LAN-Chip:
- Intel I225-V
- WLAN und Bluetooth:
- Bluetooth 5.2, WLAN 802.11a/b/g/n/ac/ax
- USB-Anschlüsse außen:
- 5x USB 3.2 (Gen 2, 10 Gbit/s)
- Davon Typ C:
- 2
- USB-Anschlüsse innen:
- 1x USB 3.2 (Gen 2, 10 Gbit/s)
- 4x USB 2.0
LordNord
- S-H
- AMD Ryzen 9 3900X
- ASUS TUF Gaming B550-Plus
- be quiet! Dark Rock 4
- 2x16GB Crucial DDR4 3200
- AOC Q3279VWFD8
- 8TB extern
- Be quiet! Pure Power 9 600W
- Win 10 64Bit
▼200
▲200
Fortsetung Sonstige:
Header Beleuchtung: 2x 4-Pin RGB (+12V/G/R/B, max. 3A), 2x 3-Pin ARGB (+5V/DATA/GND, max. 3A)
BIOS Versionen
1.09 (29.12.2022)Adds advanced Smart Fan control to BIOS and control via ELEET X1.
Fixes issue where 5800X3D can't run 45 multiplier.
Fixes issue where some XMP 3800 modules may show 3733. -
1.08 (05.05.2022)- Update to AGESA 1.2.0.7
- Improves FCLK compatibility for 5000 series CPU
- Adds support for 5600 and 5700X processors
- Improves dual rank memory compatibility for 4000 ~ 4200 MHz memory.
- Adds 4800MHz memory OC profile for 5000 series APU. -
1.07 (30.03.2022)Supports upcoming AMD processors including NPU series and 5800X3D.
Improves PBO Curve Optimizer control (PB02) -
1.04 (01.03.2022)Adds PBO Curve Optimizer control
