7+ Taskbar Tweaker
Download 7+ Taskbar Tweaker v5.15.1
pipin
Administrator
Teammitglied
16.10.2000
24.369
9.694
East Fishkill, Minga, Xanten
  • SIMAP Race
  • QMC Race
  • RCN Russia
  • Spinhenge ESL
  • Docking@Home
  • BOINC Pentathlon 2019
  • SETI@Home Intel-Race II
  • THOR Challenge 2020
  • BOINC Pentathlon 2021
  • BOINC Pentathlon 2023
pipin aktualisierte 7+ Taskbar Tweaker mit einem neuen Updateeintrag:
7+ Taskbar Tweaker v5.10
v5.10 (October 30, 2020)
  • Added support for Windows 10 version 20H2 (October 2020 Update, build 19042).
  • Fixed the incompatibility caused by update KB4580364 of Windows 10 version 2004.
  • Fixed the incompatibility caused by update KB4580386 of Windows 10 version 1909.
  • Improved support for UWP apps, now settings such as grouping are applied immediately, no need to restart the apps.
  • Fixed: closing a UWP window could cause the app to re-open.
  • Fixed: if more than one...
Lese den Rest der Aktualisierung...
7+ Taskbar Tweaker v5.10.0.2 Beta
v5.10.0.2 (March 5, 2021)
  • Added the sndvol_step advanced option which allows to control how much the volume changes with each mouse wheel notch.
  • Fixed an incompatibility with the "Don't combine grouped buttons" option caused by update KB4601382 of Windows 10 versions 2004 and 20H2.
  • Fixed opening the correct help file when the program language is Spanish.
pipin hat 7+ Taskbar Tweaker mit einem neuen Updateeintrag aktualisiert:
7+ Taskbar Tweaker v5.10.1
v5.10.1 (May 12, 2021)
  • Fixed the incompatibility caused by update KB5001391 of Windows 10 versions 2004 and 20H2.
  • Made the "Reserve empty space on taskbar" option work on secondary monitors.
  • Improved volume...
Lies den Rest der Aktualisierung…
7+ Taskbar Tweaker v5.11.2
v5.11.2 (June 10, 2021)
  • Fixed the incompatibility caused by update KB5003212 of Windows 10 version 1909.
  • Fixed the incompatibility caused by update KB5003214 of Windows 10 versions 2004, 20H2 and 21H1.
  • Added the sndvol_no_auto_mute_toggle advanced option which turns off automatic change to the device mute status when controlling the volume.
  • Added a Russian help file, by Roman Yarovoy (Роман Яровой).
7+ Taskbar Tweaker v5.11.3.1 Beta
v5.11.3.1 (October 9, 2021)
  • Added support for Windows 11 (build 22000) with the old taskbar.
    For details, see 7+ Taskbar Tweaker on Windows 11 with Windows 10's taskbar.
    If there are any issues, please let me know.
  • Improved the disable_taskbar_transparency advanced option for Windows 10.
  • Improved the "Drag within/between groups using right mouse button" option by reducing the...
7+ Taskbar Tweaker v5.12
v5.12 (October 22, 2021)
  • Added support for Windows 10 version 21H2 (November 2021 Update, build 19044).
  • Improved the "Drag within/between groups using right...
7+ Taskbar Tweaker v5.13
v5.13 (June 18, 2022)
  • A notice regarding Windows 11: 7+ Taskbar Tweaker doesn't support the Windows 11 taskbar, but some of the tweaks are available in Windows 11 as Windhawk mods. Check out the list of mods, and vote for missing mods that you'd like to see implemented:
    Windhawk mods for the Windows 11 taskbar.
  • Added support for Windows 11 version 22H2 (build 22621) with the old taskbar.
    For...
7+ Taskbar Tweaker v5.14
v5.14 (October 15, 2022)
  • Added support for Windows 10 version 22H2 (October 2022 Update, build 19045)...
7+ Taskbar Tweaker v5.14.1
v5.14.1 (December 22, 2022)
  • Fixed the 32-bit-only incompatibility caused by update KB5020030 of Windows...
7+ Taskbar Tweaker v5.14.2
v5.14.2 (August 24, 2023)
  • Fixed the incompatibility caused by update KB5029331 of Windows 10 version...
P3D-Bot hat 7+ Taskbar Tweaker mit einem neuen Updateeintrag aktualisiert:
7+ Taskbar Tweaker v5.14.3
v5.14.3 (September 15, 2023)
  • Fixed the incompatibility caused by update KB5030219 of Windows 11 version...
  • Added support for Windows 11 version 23H2 (build 22631) with the old taskbar.
    For details, see...
