Adobe Reader 9.0
cruger
Senior Moderator
Teammitglied
25.05.2002
29.389
1.579
  • QMC Race
  • BOINC Pentathlon 2014
Adobe hat eine neue Version seines kostenlosen PDF Betrachters veröffentlicht. Die Version 9 des Adobe Reader bietet folgende Neuerungen:
<blockquote cite="http://www.adobe.com/products/reader/reasons_to_upgrade/"><i>Adobe® Reader® 9 software adds much new functionality, especially relating to collaboration, PDF file creation, security, and an enhanced user experience.
<b>Improved launch speeds</b>
Looking for faster launch speeds? Adobe has enhanced general performance and, in particular, has reduced launch times with Adobe Reader 9. Try it: You'll notice the difference.
<b>PDF Portfolios</b>
Packages, introduced in Adobe Reader 8, have been greatly enhanced and renamed. Portfolios provide easy navigation when you work with multiple PDF documents and other document types. They also enable you to work with a collection of materials such as drawings, e-mail messages, spreadsheets, and videos as a single file, which makes distribution, storage, retrieval, and collaboration easy for end users.
<b>Native Adobe Flash® support</b>
Adobe Reader 9 can natively display rich media content, which you'll notice immediately with Portfolios. Interested in viewing SWF and FLV files? Adobe Reader 9 is the answer.
<b>Acrobat.com (beta)</b>
Included with Adobe Reader 9 is Acrobat.com (beta), an exciting new set of online services from Adobe. With Acrobat.com, you can create PDF files online; create and coauthor documents with others; host live web meetings; upload and share PDF files and other types of documents and control who has access to them; and even embed a rich, interactive preview of your document in a web page. All of these services and more are provided online, so you can access them from anywhere. And you'll find easy access points from within Reader 9. As an added convenience, Acrobat.com leverages Adobe AIR™, so you can interact with Acrobat.com from your desktop. Acrobat.com on Adobe AIR is a small application that is included with your download of Adobe Reader 9. Available in select languages. <a href="http://www.adobe.com/acom/" target="b">Learn more &gt;</a>
<b>Improved CAD and geospatial functionality</b>
CAD and geospatial functionality have been greatly enhanced in Adobe Reader 9. For instance, CAD designs or geospatial maps that have been converted to PDF offer Adobe Reader users access to CAD features, such as dimensions, or map features, such as longitude and latitude, for powerful collaboration and interaction.
<b>PDF Standards Pane</b>
When a PDF/A or PDF/X standard compliant file is opened, a Standards Pane appears and provides important file details.
<b>Security enhancements</b>
Adobe Reader 9 provides new digital signature functionality for an improved user experience. The new version also adds support for 256-bit AES encryption.
<b>Accessibility enhancements</b>
Adobe Reader 9 significantly improves the viewing of XFA forms for accessibility, while providing greater screen reader support.
<b>Adobe Reader 9 MUI</b>
Adobe Reader 9 MUI is Adobe's Multilingual User Interface version. This product is capable of installing any combination of supported languages. So, for example, you can install French, German, and Spanish simultaneously and then have the capability to switch among those languages within Adobe Reader. The user interface changes to the appropriate language on the fly.
</i></blockquote>
<b>Download:</b><ul><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20080702010954">Adobe Reader 9.0 [Windows] (26,3 MB)</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20080702010955">Adobe Reader [Mac OS] (29,9 MB)</a></li></ul>
<b>Links zum Thema:</b><ul><li>Alternativer PDF-Betrachter: <a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=2&id=1211551497">Foxit Reader</a></li></ul>
Löblich, dass gleich auf den Foxit hingewiesen wird :)
Seit Version 6 fehlt mir einfach die Zeit zu warten, bis sich der Acrobat komplett aufgeklappt hat :P ( Da ist ja OpenOffice dreimal schneller)
Mmoe
Toll gerade den AR8 deinst (127MB) und was ist beim 9er 237MB, menno wenn der FoxIt doch nur mit Stampit zusammen arbeiten würde, wäre alles toll.
Aber so ist man auf den AR angewiesen :(
Hm, liefern die ne komplette Linux Distribution, inkl. Sourcen, mit?
Oder etwa OOo?
Das ist doch nicht mehr normal, was manche Programme so an Speicherplatz belegen.
Die neuste Nero Version, wenn ich mich richtig erinnere, über 1GB!
Wow, das Teil ist richtig flott!
Toll gerade den AR8 deinst (127MB) und was ist beim 9er 237MB, ...
Der Programmordner von Foxit belegt bei mir grad mal 11,6MB
Woran hapert es denn, dass Foxit nicht mit Stampit arbeitet?
Edith sagt:
Hab mal gesucht hier im Forum gab's das schon mal:
StampIt von der Post?
hm, geht das nicht über Java?
Dafür gibts ein PlugIn für Foxit, schon mal probiert?
zu finden auch über die integrierte Updatefunktion.
Also einfach das Java Plugin über die Updatefunktion hinzufügen und es sollte funktionieren.
Direkter Download ist auch möglich: FoxitReader JavaScript Support
Andy
Gibt es keinen brauchbaren Open Source PDF Reader?
Der ist aber wirklich schnell
Schneller als der Foxit Reader?
Wenn ja, steige ich wohl wieder um auf den AR. ;)
Ja, er ist genauso schnell. :)
Der Foxit Reader oder der AR 9 scheint Darstellungsfehler zu haben. So hab ich mit dem AR 9 einige Wörter (Überschriften) fett gedruckt, die im Foxit nicht fett angezeigt werden.
Wenn das PDF von Adobe kommt/entwickelt wird, liegt es doch eigentlich nahe, dass der Adobe Reader die Sache korrekter darstellt, oder? Der Meinung bin ich jedenfalls, alles andere wäre ja eine Schande für den Hersteller ...
Auf den Rechnern unserer FH war eine Zeit lang auch der Foxit Reader installiert und einige Studenten haben sich darüber aufgeregt, u.a. weil er wohl des öfteren PDFs fehlerhaft anzeigte.
So, hab den Foxit Reader gekickt. Ist mir zu fehlerhaft in der Darstellung und da der Adobe Reader wieder richtig schön schnell ist, sehe ich keinen Zweck mehr für den Foxit Reader. ;)
Hab den neuen Reader auf Arbeit gleich installiert und muss sagen, deutlich schneller! (wir drucken alles in PDF) Das beschleunigt auch die Arbeit deutlich!
Nun hab ich grad die .exe von hier gezogen und AntiVir meldet mir einen Trojaner?! :o
Muss ich da bedenken haben? :-/
Hab auch Antivir und ebenfalls von hier gezogen. Keine Meldung. Wahrscheinlich hast du dein Antivir zu empfindlich eingestellt. Auch gerade bei der Heuristik gibt der schon dann öfters mal ne Fehlermeldung.
Ist der Adobe Reader so schnell, weil er sich mal wieder in den Autostart eingeklinkt hat und im Hintergrund permanent Speicher belegt, oder ist er auch ohne diese Tricks so schnell wie der Foxit Reader?
Andy
Ich kann nichts vom AR im Autostart finden, an keiner Stelle...
Mmoe
Jaja, immer die gleiche Leier. Überhaupt schonmal ne neue Version probiert? AR8 und 9 gehen bei mir in < 1 Sek. auf -- weiß nicht was man da noch meckern kann.
Die hohe Geschwindigkeit von Adobe Reader 9.0 kann ich bestätigen, läuft hier 1A und sogar noch schneller als die Vorgängerversion 8.1.2
:o Wow, kein Vergleich zur lahmen 7er und 8er Version.
Den 8er als er frisch war... Und unter msconfig die "ich-zieh-mich-mal-gleich halb-hoch"-Einträge deaktiviert und dann kannste nach dem Doppelklick erstmal ganz geruhsam Kaffeekochen gehen !
Mmoe
Mmoe
Kann ich absolut nicht nachvollziehen. Konnte ich aber auch beim 7er schon nicht. Höchstens unter Linux.
EiRoGGe und rob2k, habt ihr mal mit msconfig geguckt, ob der Adobe Reader sich nicht doch wieder in den Autostart eingeklinkt hat?
Und mit Autostart meine ich nicht den Ordner im Startmenü, sondern den Eintrag in der Registry unter HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
Foxit braucht keinen PreLoader, um schnell zu sein.
Wie sieht es mit mit Adobe aus?
Ich will nämlich nicht die ganze Zeit diverse DLLs und den PreLoader im Speicher haben, nur weil ich alle paar Tage mal ein PDF angucken möchte.
Übrigens wollte ich mal den AdobeReader installieren, um es selbst zu testen aber der Installer bringt mir nur das Config-Tool meines WLAN-Adapters in den Vordergrung und verabschiedet sich dann ohne jegliche Meldung. Eine Installation nicht möglich.
Macht nix, ich bleib bei Foxit. :D
Andy
Bei msconfig setzt er einen Eintrag, was mir allerdings egal ist, da ich auch ein Fehlen des Eintrags sowieso nicht bemerken würde.
