ALi Integrated Treiber 2.05 und USB-Treiber 1.52
Nero24
Administrator
Teammitglied
01.07.2000
24.058
10.440
  • BOINC Pentathlon 2019
  • BOINC Pentathlon 2020
  • BOINC Pentathlon 2018
  • BOINC Pentathlon 2021
Chipsatz-Hersteller ALi (AcerLabs Inc.) hat für seine Chipsätze, darunter z.B. ALi MAGiK 1 und ALi Aladdin V, neue Treiber veröffentlicht.
Zum einen ein neues All-in-One Paket der Version 2.05. Es beinhaltet folgende Komponenten:<ul><i> This integrated driver integrates
1. AGP driver 2.01 for Win95 OSR2.1/Win98/Win98SE/WinME/Win2K/WinXP.
2. IDE Cache Utility 1.06 for Win95 OSR2.1/Win98/Win98SE/WinME.
3. Mini-IDE driver 1.5.1.0 for Win2K/WinXP(WHQL).
4. FIR driver 1.150 for Win98(WHQL)/Win98SE(WHQL). FIR driver 1.141 for WinME(WHQL)
FIR driver 2.01 for Win2K(WHQL)/WinXP(WHQL).
5. Audio M5451 WDM driver 5.12.01.5260 for Win98SE/WinME(WHQL)/Win2K(WHQL)/WinXP(WHQL).
6. Audio M5455 WDM driver 5.12.01.7005 for Win98SE/WinME/Win2K/WinXP(WHQL).
7. Memory Stick driver 1.32.1018 for Win98SE/WinME,and 1.32.1030 for Win2000/WinXP.
8. SD/MMC driver 1.10.1018 for Win98SE/WinME,and 1.10.1030 for Win2000/WinXP.
9. LAN driver 5.1.2600.0130 for WinXP(WHQL) and 5.1.2600.0132 for Win98SE/Me/2000.
10.USB 1.1 controller 1.03 for Win95 OSR2.1.
11.M7101 Patch 1.01 for Win95.
12.IRQ Miniport driver 0.1 for Windows95
13.USB 2.0 controller 1.13 for Win98SE/WinME/Win2K/WinXP.
14.AGP driver 8.104 for M1687 chipset in Win98SE/WinME/Win2000/WinXP.</i></ul>Folgende Punkte wurden gegenüber der letzten offiziellen Version 1.091 gefixt:<ul><i>v2.05
1.Update ALi AUDIO(M5451) WDM driver from version 5250 to 5260.
2.Update ALi USB 2.0 Host Controller driver from version 1.05 to 1.13.
3.Update ALi LAN driver from version 5.1.2600.0120 to version 5.1.2600.0130 for WinXP and
from version 5.1.2600.0120 to version 5.1.2600.0132 for Win98SE/Me/2000.
4.Update ALi AGP driver from version 8.04 to 8.104 for M1687 chipset in Win98SE/WinME/Win2000/WinXP.
v2.04
1.Update ALi AGP driver from version 2.00 to 2.01.
2.Update ALi USB 2.0 Host Controller driver from version 1.03 to 1.05.
3.Update ALi Mini-IDE driver from 1.5.0.0 to 1.5.1.0 for Win2K/XP.
v2.03
1.Update ALi AUDIO(M5455) WDM driver from version 7004 to 7005.
2.Update ALi USB 2.0 Host Controller driver from version 1.02 to 1.03.
3.Update ALi FIR driver from version 1.26 for Win 2000 to 2.01 for Win 2000/XP.
4.Replace ALi Ultra-IDE 4.0.0.7 with Mini-IDE 1.5.0.0 for Win2K/XP.
v2.02
1.Update ALi AGP driver from version 1.93 to 2.00.
2.Add AGP driver 8.04 for M1687 chipset in Win98SE/WinME/Win2000/WinXP.
3.Update ALi AUDIO(M5451) WDM driver from version 5220 to 5250.
4.Update ALi LAN driver from version 5.1.2600.0105 to version 5.1.2600.0120 for Win98SE/WinME
/Win2000/WinXP.
5.Add ALi USB 2.0 Host Controller driver 1.02 for Win98SE/WinME/Win2000/WinXP.
v2.01
1.Update ALi AUDIO(M5455) WDM driver from version 7003 to 7004.
2.Update ALi Memory Stick driver from version 0601 to 1.32.1018 for Win98SE/WinME.
3.Update ALi Memory Stick driver from version 0801 to 1.32.1030 for Win2000/WinXP.
4.Update ALi SD MMC driver from version 0601 to version 1.10.1016 for Win98SE/WinME.
5.Update ALi SD MMC driver from version 0801 to version 1.10.1030 for Win2000/WinXP.
6.Update ALi LAN driver from version 0103 to version 5.1.2600.0105 for Win98SE/WinME
/Win2000/WinXP.
7.Fix issue that M1681 chipset motherboard can't install AGP driver successfully.
v2.00
1.Update ALi AUDIO(M5451) WDM driver from version 5210 to 5220.
2.Support ALi AUDIO(M5455) WDM driver version 7003 for Win98SE/WinME/Win2000/WinXP.
3.Support ALi Memory Stick driver version 0601 for Win98SE/WinME
4.Support ALi Memory Stick driver version 0801 for Win2000/WinXP.
5.Support ALi SD MMC driver version 0601 for Win98SE/WinME.
6.Support ALi SD MMC driver version 0801 for Win2000/WinXP.
7.Support ALi LAN driver version 0103 for Win98SE/WinME/Win2000/WinXP.
v1.10
Update ALi AGP driver from version 1.91 to 1.93.
</i></ul>Ferner hat ALi auch einen neuen USB-Treiber veröffentlicht. Dessen Fixliste ist im Augenblick nicht verfügbar. Sobald der Server wieder up ist, werden wir die Fixliste nachreichen.
<b>Download:</b><br><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20030725124557">ALi Integrated All-in-One Treiber 2.05 (Mirror 1)</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20030725124558">ALi Integrated All-in-One Treiber 2.05 (Mirror 2)</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20030725124559">USB-Treiber 1.52 (Mirror 1)</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20030725124560">USB-Treiber 1.52 (Mirror 2)</a></li>
THX Denniss für den Hinweis
:o Weihnachten bei ALi? Sie haben doch tatsache diesen "Ultra-IDE-Driver" wieder abgschafft und bieten jetzt 'nen "Mini-IDE Driver" an :D :)
Hab das ganze mal getestet, also es macht alles einen guten Eindruck (performance-mäßig) Ich hab jetzt aber leider keine Vergleichswerte...
Neo
mein alter AMD K6-2 450Mhz macht jetzt mit dem neuen Triber 34 fps statt 29 fps im Vergleich zum alten AGP-Treiber 1.9 ( MoBo MSI 5169 )
Gruß Mathias
Ich habe ein Asus P5A Rev 1.06 mit einem K5-2 500MHz und habe die Ali Integrated 2.05 unter Win 2000 installiert. Beim rebooten gab es einen Bluescreen.
HD neu formatiert Wind 2000 installiert und gleich danach wieder die Treiber vom Ali installiert. Wieder Bluescreen.
Wer hat mir da noch einen Tip?
Hi!
Also Du solltest unter Win2k/XP auf keinen fall die IDE-Treiber installieren! Gilt für ALiMagik1 sowie auch für den ALiAladdin V
echt? hab auch nen problem mit dem ALI V (Asus P5a-b) und w2k. Das CD-Rom (LG 8522B von 2001; 40-fach) will nur in PIO4-Mode. DMA geht nix. dachte das könnte man umgehen, wenn die Ali-IDE Treiber installiert werden.
weil DMA-2 bzw. UDMA-2 müsste son rel. neues CD-Rom doch eigentlich können?
ALI-V und DMA soll ja problemartig sein...
und jetzt les ich, dass die Ali eigenen Treiber auch nix bringen?
ratlos
acqua
Also soweit ich mich noch erinnern kann lag das an 'nem Prob vom Windows... Haste mal WindowsUpdate ausgeführt?!
hmm,
fahr hier w2k-sp3, det müsste doch eigentlich die probleme (welche?) behoben haben?
oder erst sp4?
was ich bisher nicht als notwendig empfand, draufzuspielen.
sollte das gemacht werden?
thx,
acqua
Lösch mal die IDE-Treiber aus dem Gerätemanager und start den Rechner neu, danach sollte er die Treiber neu installieren. Ich hab hier im Forum gelesen das danach das umstellen von PIO auf DMA ging (allerdings bei Aladdin..)
jep,
allet bereits probiert. keine änderung.
werd wohl auch mal testen, ob das CD-Rom (LG CRD-8552B; Baujahr 2001) überhaupt DMA-fähig ist.
Der Treiber für den ALI M5229-PCI-Bus-Master-IDE-Controller is von MS (5.0.2195.5438; 23.07.2002).
Am ersten IDE hängt ne FP, die ohne Murren UDMA-2 macht (mehr gibt das P5A-B nicht her).
Am 2. IDE hängt das CD-Rom, da kommt nur PIO4 raus.
mitm bios auch probiert, keine änderungen.
merkwürdig...
wobei, hab grad drhardware 2004 befragt, und dort steht, dass der onboard E/IDE-Controller keinen DMA für CD-Rom unterstützt (wenns das denn stimmt).
gibts sowas?!?
erstaunt,
acqua
Also mein P5A (OHNE "-B") konnte damals für beide CD-Laufwerke DMA. Auch unter XP, gings irgendwann mal, da war's aber Treiberabhängig...
Ich hab grad mal meine Festplatte durchstöbert: Ich hab hier noch eine gewisse "ALi_ide_w2k_142.exe". Soll ich die Dir mal mailen zum testen?
wenns nicht zuu groß ist (da modem), schiebs ma rüber; mal schaun, obs weiterhilft.
thx,
acqua
8)
genau,
beides bereits auf http://www.aliusa.com/ entdeckt und runtergeladen.
wobei, "ide_util105.exe" is für w9x, also nix w2k und die "ide_w2k_142.exe" hab ich probehalber installiert, ergebnis: bluescreen.
und wieder wech damit.
die ali-ide-treiber solln ja wohl bekannt dafür sein, rumzuzicken; was sie bei mir dann ja auch getan haben.
werd die 9x-treiber noch probieren; ansonsten muss das problem (kein wirkliches) anders behoben werden.
dank für die hilfe,
acquairo
p.s.: (grad probiert) der "ide_util105.exe" is nicht zu installiern, da nicht für w2k...
Tja..., Win2k schonmal komplett neu installiert?!
hmm, hab w2k nach mainboardwechsel extra nicht neu installiert, sondern nach anleitung der w2k-faq, F28 erst neuinstall., dann rep-install. gewählt.
erspart n bissi arbeit, und da alles problemlos läuft...?!!
nur das cd-rom am zwooten ide zickt rum (nix dma). wobei mich der "hinweis" von dr.hardware erstaunt, dass der ide-controller kein dma für cd-rom unterstützt.
ich lass ihn gezz auf pio4, wenn ganz viel zeit is, werd ich mal ne neuinstall probiern.
und das ergebnis dann verraten...
acqua
MB-Wechsel OHNE neuinstall, das geht bei ALi selten gut :-[, selbst beim Magik1 (leider)
