Download AMD Radeon Software Crimson ReLive Edition 17.1.2 WHQL verfügbar.
- Ersteller eratte
User-News
Von eratte
Hinweis: Diese "User-News" wurde nicht von der Planet 3DNow! Redaktion veröffentlicht, sondern vom oben genannten Leser, der persönlich für den hier veröffentlichten Inhalt haftet.Release Notes & Download
Radeon Software Crimson ReLive Edition 17.1.2 Highlights
Support For
Conan® Exiles Beta
Tom Clancy's Ghost Recon® Wildlands Beta
Fixed Issues
Changing memory clocks with Radeon WattMan with more than one display connected may cause memory clocks to intermittently become stuck at their minimum setting or switch between min and max ranges intermittently causing display flickering.
Diablo®III May experience smoke or lighting effects may appear corrupted when using DirectX®9 API.
Some applications may experience an intermittent or random runtime crash in atidxx64.dll.
FIFA®17 may experience a black screen on launch when using Hybrid Graphics or AMD PowerXpress system configurations.
Watch_Dogs®2 may experience an intermittent game crash after extended periods of play on some Radeon RX 300 series products.
Paragon™ may experience flickering in profile or store preview pages after changing graphics settings when using Multi GPU.
Forza Horizon 3 may experience a crash or application hang with the Blizzard Mountain DLC on some select Radeon GCN products.
Known Issues
A small amount of apps may still experience issues with Borderless Fullscreen mode and AMD FreeSync™ technology if other applications or game launchers are running on the primary screen in the background.
Counter-Strike™: Global Offensive and World of Warcraft™ may experience flickering or performance issues the first time the game is launched on a system boot with AMD FreeSync™ technology enabled. Workarounds include exiting and restarting the application or task switching (alt+tab) in and out of the game to fix the issue.
Radeon RX 400 series products may experience scaling issues for some applications when using the display scaling feature.
Deus Ex: Mankind Divided™ may experience an application hang when running in Multi GPU with DirectX®12 and performing a task switch.
Mouse cursor corruption may be intermittently experienced on Radeon RX 480.
Counter-Strike™: Global Offensive has incorrect default slider values with Radeon Chill enabled. Users can modify these values to suit the experience they want.
Known Issues for Radeon ReLive
The XBOX™ DVR application may cause conflicts with Radeon ReLive, users are suggested to disable XBOX™ DVR if Radeon ReLive is experiencing issues.
Radeon ReLive may fail to install on AMD APU Family products or experience a system hang or failure to record when using the recording feature on AMD APU Family products.
Radeon ReLive may stop working after hot unplugging of a secondary display.
Battlefield™1 may experience UI flickering and/or performance drops when recording gameplay with Radeon ReLive on graphics products with 4GB or less of VRAM.
Radeon ReLive recordings or overlay may experience flicker when creating a single recording for many hours.
Radeon ReLive may experience minor graphical corruption for the first few recorded frames when launching UWP applications.
Radeon ReLive will not allow recording settings to change with Instant Replay enabled. A workaround is to disable Instant Replay and change settings then enable Instant Replay.
Vulkan™ applications may experience a game hang when using Radeon ReLive to record.
Radeon ReLive will not notify an end user of low disk space during recording.
DayZ may experience an application crash when Radeon ReLive Instant Replay/Recording is active or the feature may not work as expected.
Package Contents
The Radeon Software Crimson ReLive Edition 17.1.2 installation package contains the following:
Radeon Software Crimson ReLive Edition 17.1.2 Driver Version 16.50.2711 (Windows Driver Store Version 21.19.413.0)
Radeon Product Compatibility
Radeon Software Crimson ReLive Edition 17.1.2 is compatible with the following AMD Radeon products.
Note that AMD Radeon™ R9 Fury, Radeon™ Pro Duo, and Radeon™ RX 400 Series graphics are only supported by Radeon Software Crimson ReLive Edition on Windows 7/8.1/10 64-bit.
Radeon Desktop Product Family Compatibility
Radeon™ RX 400 Series Graphics
AMD Radeon™ R7 300 Series Graphics
AMD Radeon™ Pro Duo
AMD Radeon™ R7 200 Series Graphics
AMD Radeon™ R9 Fury Series Graphics
AMD Radeon™ R5 300 Series Graphics
AMD Radeon™ R9 Nano Series Graphics
AMD Radeon™ R5 200 Series Graphics
AMD Radeon™ R9 300 Series Graphics
AMD Radeon™ R9 200 Series Graphics
AMD Radeon™ HD 7700 - HD 7900 Series Graphics
AMD Radeon™ HD 8500 - HD 8900 Series Graphics
Mobility Radeon™ Family Compatibility
Radeon Software Crimson ReLive Edition 17.1.2 is a notebook reference graphics driver with limited support for system vendor specific features.
Radeon Mobility Product Family Compatibility
AMD Radeon™ R9 M300 Series Graphics
AMD Radeon™ R7 M200 Series Graphics
AMD Radeon™ R7 M300 Series Graphics
AMD Radeon™ R5 M200 Series Graphics
AMD Radeon™ R5 M300 Series Graphics
AMD Radeon™ R9 M200 Series Graphics
AMD Radeon™ HD 7700M - HD 7900M Series Graphics
AMD Radeon™ HD 8500M - HD 8900M Series Graphics
Compatible Operating Systems
Radeon Software Crimson ReLive Edition 17.1.2 is designed to support the following Microsoft® Windows® platforms. Operating System support may vary depending on your specific AMD Radeon product.
Windows® 10 (32 & 64-bit version)
Windows 8.1 (32 & 64-bit version)
Windows 7 (32 & 64-bit version with SP1 or higher)
Support For
Conan® Exiles Beta
Fixed Issues
Known Issues
Package Contents
AMD Radeon™ Pro Duo
maikrosoft
- germany
- AMD Ryzen 7 7800x 3d
- ASUS ROG STRIX B650-A Gaming
- Thermalright Peerless Assassin 120 SE ARGB white
- 2 x 16 GB Corsair Vengeance 5600MHz CL 36
- ASUS GeForce RTX 4060 Ti OC white
- LG UltraGear 27GP850-B
- Samsung 970 EVO Plus 2TB, Western Digital SN550, Crucial MX500 1TB m.2, Silicon Power Ace A55 1TB
- Soundblaster AE-5 PLUS - DT-990pro
- BeQuiet Silentbase 802
- Seasonic Core GM 650W
- Sharkoon SGK 60
- Gigabyte M3
- Windows 11 pro x64 / Manjaro
- AUKEY Large mousepad gaming xxl
Soll ichs sagen?
AMD hats wieder nicht geschissen bekommen mit dem neuen Treiber. WOT und WOWs stürzen einfach ab. Same shit @ every ReLive Crap....
Funktioniert wenigsten der letzte WHQL ?Soll ichs sagen?
Ist ja grausam so langsam...
maikrosoft
- germany
- Sharkoon SGK 60
- Gigabyte M3
Hallo Windhund, 16.11.5 ist der letzte Treiber welcher stabil mit meiner RX 470 läuft.
LG
LG
Ok, welche build Version hat dein Windows 10 Pro x64?
Hast du evt. die Windows Auto Updates deaktiviert? evt. fehlt da nur ein PCI-Bridge Treiber.
Kennst du noch jemand mit dem Problem und selber Hardware?
maikrosoft
- germany
- Sharkoon SGK 60
- Gigabyte M3
Version 1607, Build 14393.693. Autoupdate ist aktiviert.
Ich kenne aus dem CB Forum einen User mit einer RX 480 und aus dem offi AMD Support Forum auch ein paar, alle mit RX Karten und diesem Problem.
Edit: Hier was aus dem englischen WOT Forum, natürlich RX Karten...
http://forum.worldoftanks.eu/index....es-my-graphics-card-while-no-other-game-does/
Nun auch mit WHQL-Zertifikat.
Zu erkennen am Dateinamen z.B. : whql-win10-64bit-radeon-software-crimson-relive-17.1.2-feb6.exe
Sonst keine Änderungen, Link aus Post 1 bleibt gültig.
