ATI CATALYST 7.5
- Ersteller Nero24
ATI hat sein CATALYST Grafikkarten- und Chipsatz-Treiberpaket in der Version 7.5 zum Download freigegeben. Voraussetzung für das CATALYST Control Center (CCC*) ist unter Windows XP ein installiertes Microsoft .NET Framework. Eine aktuelle Version des .NET Framework kann man über die Microsoft Windows Update Seite beziehen. Hinweise zu den Release Notes für den Windows XP & Vista Treiber finden sich im <a href="http://www.planet3dnow.de/vbulletin/showthread.php?p=3200761#post3200761">Kommentar-Bereich</a>.<ul><i>New Features
This release of Catalyst™ introduces the following new features:
* DirectX 10 driver support for the Radeon™ HD 2900 XT (single card and CrossFire™ configurations) for Windows Vista
* Second Generation ATI Theater™ 650
This release of Catalyst™ introduces the ATI DirectX 10 driver for the Radeon™ HD 2900 XT, for both single cards and CrossFire™ configurations. The ATI DirectX 10 driver used in combination with the Radeon™ HD 2900 XT (and an application designed to take advantage of the power of the DirectX 10 API) delivers incredible graphics effects never seen before on the PC.
This release of Catalyst™ introduces the second generation ATI Theater™ 650. This product will provide support for the new MCE 2006 requirements such as DRM support. Further, it will include features to support ATI All-In-Wonder products. It will also provide improved TV quality and Broadcast Flag support which enables full US terrestrial DTV support.
Performance Improvements
OpenGL performance is improved on the ATI Radeon™ X1950 XTX at high resolutions (1920x1200 or greater) with anti-aliasing and anisotropic filtering enabled. Doom 3 and Quake 4 improves as much as 13-18%, and Prey improves at least 15.6%. The ATI Radeon™ X1950 Pro and X1650 XT also sees improvements in Doom 3 and Quake 4 of up to 14.1% at higher resolutions with anti-aliasing and anisotropic filtering enabled. </i></ul>Die Download-Links führen zu den ATI-Support-Seiten, wo man die Treiberpakete einzeln (Windows XP) oder aber komplett (Windows XP & Vista) inkl. CATALYST Control Center (CCC*) beziehen kann.
<b>Download:</b><ul><li><a href="http://ati.amd.com/support/drivers/vista32/common-vista32.html" TARGET="_blank">ATI Catalyst 7.5 Display Driver [Windows Vista 32-Bit]</a></li><li><a href="http://ati.amd.com/support/drivers/vista64/common-vista64.html" TARGET="_blank">ATI Catalyst 7.5 Display Driver [Windows Vista 64-Bit]</a></li><li><a href="http://ati.amd.com/support/drivers/xp/radeonx-xp.html" TARGET="_blank">ATI Catalyst 7.5 Display Driver [Windows XP 32-Bit / MCE]</a></li><li><a href="http://ati.amd.com/support/drivers/xp64/radeonx-xp64.html" TARGET="_blank">ATI Catalyst 7.5 Display Driver [Windows XP 64-Bit]</a></li>
<li><a href="http://ati.amd.com/support/drivers/xp/mobility-xp.html" TARGET="_blank">ATI Catalyst 7.5 Mobility [Windows XP 32-Bit]</a></li><li><a href="http://ati.amd.com/support/drivers/xp/mobility-xp.html" TARGET="_blank">ATI CATALYST 7.5 Mobility Kompatibilitätsprüfung</a></li>
<li><a href="http://ati.amd.com/support/drivers/vista32/integrated-vista32.html" TARGET="_blank">ATI Catalyst 7.5 Mainboard/IGP/Southbridge [Windows Vista 32-Bit]</a></li><li><a href="http://ati.amd.com/support/drivers/vista64/integrated-vista64.html" TARGET="_blank">ATI Catalyst 7.5 Mainboard/IGP/Southbridge [Windows Vista 64-Bit]</a></li><li><a href="http://ati.amd.com/support/drivers/xp/integrated-xp.html" TARGET="_blank">ATI Catalyst 7.5 Mainboard/IGP/Southbridge [Windows XP 32-Bit / MCE]</a></li><li><a href="http://ati.amd.com/support/drivers/xp64/integrated-xp64.html" TARGET="_blank">ATI Catalyst 7.5 Mainboard/IGP/Southbridge [Windows XP 64-Bit]</a></li>
<li><a href="http://ati.amd.com/support/drivers/linux/linux-radeon.html" TARGET="_blank">ATI Proprietary Linux x86 Display Driver 8.37.6</a></li><li><a href="http://ati.amd.com/support/drivers/linux64/linux64-radeon.html" TARGET="_blank">ATI Proprietary Linux x86_64 Display Driver 8.37.6</a></li></ul><b>Links zum Thema:</b><ul><li><a href="http://www.guru3d.com/article/atitraytools/189/" TARGET="_blank">CCC* Alternative : Ray Adams' ATI Tray Tools</a></li><li><a href="http://www.microsoft.com/downloads/details.aspx?displaylang=de&FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5" TARGET="_blank">Microsoft .NET Framework 2.0 x86</a></li><li><a href="http://www.microsoft.com/downloads/details.aspx?displaylang=de&FamilyID=b44a0000-acf8-4fa1-affb-40e78d788b00" TARGET="_blank">Microsoft .NET Framework 2.0 x64</a></li></ul><font size="1">*) CCC = CATALYST Control Center; Erläuterung siehe <a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=2&id=1094139055">hier</a>.</font>
Danke Plasson für den Hinweis
AMD Product Support
The Catalyst™ Vista driver for both the 32bit and 64bit versions of the Microsoft Windows Vista operating system is supported on the following ATI Radeon™ products.
AMD Desktop Product Family Support for both Windows Vista and XP ATI Radeon™ HD 2900 XT
ATI Radeon™ X800 series
ATI Radeon™ X1950 series
ATI Radeon™ X700 series
ATI Radeon™ X1900 series
ATI Radeon™ X600 series
ATI Radeon™ X1800 series
ATI Radeon™ X550 series
ATI Radeon™ X1650 series
ATI Radeon™ X300 series
ATI Radeon™ X1600 series
ATI Radeon™ 9800 series
ATI Radeon™ X1550 series
ATI Radeon™ 9700 series
ATI Radeon™ X1300 series
ATI Radeon™ 9600 series
ATI Radeon™ X1050 series
ATI Radeon™ 9500 series
ATI Radeon™ X850 series
AMD Multimedia Family Product Support for both Windows Vista and XP ATI All-in-Wonder® X1900 Series
ATI All-in-Wonder™ X600 Series
ATI All-in-Wonder® X1800 Series
ATI Theater™ 550 PRO
ATI All-in-Wonder® 2006 Edition
ATI All-in-Wonder® 9800 Series
ATI All-in-Wonder™ X800 Series
ATI All-in-Wonder™ 9600 Series
Note: ATI All-In-Wonder™ and VIVO variants listed above are supported in the display driver only under the Windows Vista operating system.
Note: The capture driver for these products installed on systems running Windows Vista is not being updated at this time
AMD Chipset Product Support ATI Radeon™ Xpress 1250 Series
ATI Radeon™ Xpress 1150 Series
ATI Radeon™ X1250 Series
ATI Radeon™ Xpress 1100 Series
ATI Radeon™ X1200 Series
ATI Radon™ Xpress 200 Series
Operating systems supported
The latest version of the Catalyst™ software suite is designed to support the following Microsoft Windows platforms:
* Windows Vista (32 and 64 bit versions)
* Windows XP Professional
* Windows XP Home Edition
* Windows XP Media Center Edition (graphics driver support only)
Note: When installing the Catalyst™ Vista driver for Windows Vista, the user must logged on as an Administrator or have Administrator rights in order to successfully complete the installation of the Catalyst™ Vista driver.
Caution: Once the driver installation is completed under the Vista operating system (32 and 64 bit), the driver log file may report that the ATI T200 Unified AVStream Driver failed to install. A reboot of the operating system resolves the issue.
New Features
ATI's Folding@Home
Folding@Home is a distributed computing project designed by the Stanford University. The application performs intensive simulations of protein folding. This simulation will help researchers uncover how certain diseases develop. Folding@Home uses distributed computing to simulate protein folding, the workload is broken up into small work units and distributed across hundreds of thousands of computers over the internet. You can help find the cure to many different diseases! To join Folding@Home, follow these steps:
1. Download ATI's Catalyst™ software suite
2. Download the Folding@Home GPU client application
Note: If you do not have an ATI Radeon™ X1600 or higher, then download the CPU client.
If you have an ATI Radeon™ X1600 or higher, download the GPU client (either console or GUI version) not to be confused with the CPU "Graphical client".
3. Enter the ATI team number 51394 and start folding!
For more information on Folding@Home visit: http://ati.amd.com/technology/streamcomputing/folding.html
Resolved Issues for the Windows Vista Operating System
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows Vista. These include:
* Doom3/Quake 4: Setting the in game options for Video Quality to Medium and Screen Size to 1024x768 no longer results in display corruption being noticed when setting AA to 4x. Further details can be found in topic number 737-25802
* IL2 Sturmovik->Forgotten Battles: Setting the in-game hardware options to custom and landscape detail to perfect no longer results in the water textures appearing corrupt when playing the game under the Windows Vista operating system. Further details can be found in topic number 737-26687
* Lego Star Wars II: Starting a new game and walking outside through any of the doors available no longer results in flickering/flashing being noticed during the fade transition. Further details can be found in topic number 737-27454
* Quake 4/Serious Sam: Attempting to launch the games with AA set to 2x or higher and the Catalyst™ Control Center->Advanced View->3D preview running in the background no longer results in the operating system failing to respond. Further details can be found in topic number 737-26690
* A Fatal Uninstall Error of ATI Catalyst™ Install Manager is no longer experienced on some hardware configurations running Vista. Further details can be found in topic number 737-27083
* Catalyst™ Control Center: The Content Viewing selection for Component Video is no longer blank in the Basic view when using only an HDMI display device. Further details can be found in topic number 737-27084
* CrossFire™: The text and buttons found in the CrossFire™ disable warning message are no longer cropped in all supported languages excluding English. Further details can be found in topic number 737-27085
* Switching between users with Catalyst™ Control Center->Color aspect open, no longer incorrectly enables the Reactivate ATI Color controls button on some hardware configurations. Further details can be found in topic number 737-27086
* In the Catalyst™ Control Center, a blank page is no longer seen in the basic view when changing extended desktop to clone mode with CRT and SDTV connected on some ASIC families. Further details can be found in topic number 737-27088
* In the Catalyst™ Control Center the localization "Select a Skin" window page is now localized with the appropriate languages on some hardware configurations. Further details can be found in topic number 737-27087
* Enabling CrossFire™ no longer automatically enables 'Triple Buffering' and disables 'Support DXT texture format' in 3D->More Settings. Further details can be found in topic number 737-27090
* The position of the TV as reported by the Catalyst™ Control Centre when switching from underscan to overscan no longer differs between the operating systems Windows XP and Windows Vista. Further details can be found in topic number 737-27079
* Mode changes including extending the desktop is no longer observed to be extremely slow with two monitors attached and enabled on the ATI Radeon™ X1800 series of products. Further details can be found in topic number 737-27080
* Overlay Theater Mode no longer fails under the conditions that the desktop is extended to a secondary display on ATI Radeon™ X1300/X1550 series of products. Further details can be found in topic number 737-27082
* On some hardware configurations the Catalyst™ Control Center "Content Viewing selection for Component Video" page is no longer blank in the Basic view when using only an HDMI display device. Further details can be found in topic number 737-27452
* Switching between users with Catalyst™ Control Center->Color aspect open, no longer incorrectly enables the "Reactivate ATI Color controls" button on some hardware configurations. Further details can be found in topic number 737-27086
* An error message is no longer displayed when disabling CrossFire™ under the Windows Vista operating system. Further details can be found in topic number 737-27453
* Catalyst™ Control Center: Attempting to change the Core clock settings within the Overdrive™ aspect no longer results in the new setting failing to be applied. Further details can be found in topic number 737-27455
* WinDVD8: Enabling hardware acceleration no longer results in corruption being noticed during video playback. Further details can be found in topic number 737-27616
* Using Windows Media Player 11 to play an MPEG file using HDMI audio on a system running Windows Vista no longer results in file not playing properly if swapping the primary and secondary display devices. Further details can be found in topic number 737-27617
* Mode changes including extending the desktop is no longer observed to be extremely slow with two monitors attached and enabled on the ATI Radeon™ X1800 series of products. Further details can be found in topic number 737-27456
* Playing HD DVD content followed by attempting to hot unplug a display device and then hot-plugging the same display device to a different port no longer results in the HD DVD playback failing to resume. Further details can be found in topic number 737-27618
Resolved Issues for the Windows XP Operating System
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows XP. These include:
* Call of Duty: An error message no longer appears when task switching between the game and the Windows desktop. This issue may also be experienced under the Windows Vista operating system. Further details can be found in topic number 737-26750
* Just Cause: The game no longer fails to run cinematic at 1600x1200 game resolution on ATI Radeon™ X1200/1250/1270 series of products. Further details can be found in topic number 737-27093
* Installing an ATI Radeon™ X1900 CrossFire™ Master and X1900 slave under Windows XP no longer results in AA settings failing to be retained when rebooting the system. This issue may also be experienced under the Windows Vista operating system. Further details can be found in topic number 737-25808
* Uninstalling the graphics drivers no longer results in some of the files and folder failing to be removed in the Program File folder. Further details can be found in topic number 737-23715
* When operated from the Start Menu->All Programs->Catalyst™ Control Center, the Catalyst™ Control Center no longer fails to display the expected choices Catalyst™ Control Center->Wizard and Catalyst™ Control Center->Advanced on some hardware configurations. Further details can be found in topic number 737-27096
Known Issues Under the Windows Vista Operating System
This section provides information on known issues associated with the ATI Catalyst™ Vista RTM driver for both the 32bit and 64bit versions of the Microsoft Windows Vista operating system. These include:
* Homeworld2: Setting the game options to default and starting a single player game may result in display corruption being noticed. Further details can be found in topic number 737-26692
* Never Winter Nights->Undrentide: Enter the Advanced Video Options within the game may result in the inability to enable the Shiny Water option. Further details can be found in topic number 737-27462
* NHL 07: The in-game display settings may fail to be applied when playing the game under the Windows Vista operating system when using a supported ATI Radeon™ product. Further details can be found in topic number 737-23549
* X-Plane: Playing the game under the Windows Vista operating system may result in display corruption being noticed when using an ATI Radeon™ X1900/1950 series of product. Further details can be found in topic number 737-25522
* In the Catalyst™ Control Center, the Help buttons drop down box appear towards left side of the window instead of right side for some languages on certain hardware configurations. Further details can be found in topic number 737-27089
* Playing a DVD under the Windows Vista operating system using the Windows Media Player may result in the DVD failing to play when switching between display devices using the hot-key function. Further details can be found in topic number 737-24472. Fixed in 8.39
* Resuming from an S3 state may result in a longer than expected time for the Windows Vista operating system to resume. Further details can be found in topic number 737-25798
* Hot-plugging a CRT to a system running Windows Vista and containing an ATI Radeon™ X1100/1150 series of product may result in extended desktop mode failing to be applied. Further details can be found in topic number 737-25801
* The desktop shortcut to the Catalyst™ Control Center may disappear after performing a Windows Anytime Upgrade on some hardware configurations running Vista. Further details can be found in topic number 737-27078
* On some hardware configurations the CIM video driver installer lists The Catalyst™ Install Manager and Microsoft Visual C++ among components of the Component Selection Menu whereas these should not appear since they are mandatory and not optional. Further details can be found in topic number 737-27081
* Enabling CrossFire™ followed by disconnecting and then reconnecting the CRT display device may result in duplicate video options being seen within the Catalyst™ Control Center. Further details can be found in topic number 737-27457
* Catalyst™ Control Center->OverDrive™: The OverDrive™ setting are not retained for individual accounts. This issue may also be experienced under the Windows Vista operating system. Further details can be found in topic number 737-25805
* The OverDrive™ clocks may fail to revert back to the default settings and the Apply and Discard buttons may not become enabled when changing the clock settings for both the primary and secondary display devices. Further details can be found in topic number 737-27619
* Enabling CrossFire™ followed by setting AA to 14x and AF to 16x may result in the AA showing a setting of 0x level when disabling CrossFire™ and unchecking the AA option in the 3D aspect. Further details can be found in topic number 737-27458
* Making changes to the Color aspect found in the Catalyst™ Control Center without applying the changes may result in the Reactivate ATI color controls button remaining active after the Catalyst™ Control Center is closed and then re-launched. Further details can be found in topic number 737-27459
* The Record function currently fails to work when using an ATI All-In-Wonder X1300 and time shifting is enabled. Further information can be found in topic number 737-22014
* A blank screen may be displayed after unchecking all the Component Video formats except when the 480i30 custom mode is applied. Further details can be found in topic number 737-27620
* Enabling CrossFire™ followed by setting the Overdrive™ clocks to their maximum settings may result in the Catalyst™ Control Center failing to accurately report the requested Overdrive™ values. Further details can be found in topic number 737-27621
* Connecting a secondary display device and enabling extended desktop mode may result in changes being made to the secondary display device being reflected on the primary display device. Further details can be found in topic number 737-27460
* After installing the ATI display driver and Catalyst™ Control Center the display driver may not be listed in the installed components. Further details can be found in topic number 737-27461
* A green or black screen may be displayed when configuring MCE to ATSC mode. Further details can be found in topic number 737-27622
* Playing a DVD using either WinDVD or PowerDVD may result in corruption being noticed if the players is rotated to any position other than landscape. Further details can be found in topic number 737-27463
* Setting the Avivo Video De-interlacing setting to auto, motion adaptive or vector adaptive may result in certain DVDs, menu videos and some special features failing to benefit from the options. Further details can be found in topic number 737-27196
* Installing the display driver under the Windows Vista operating system may result in the display resolutions of 1680x1050, 1800x1440, 1920x1080 and 1920x1200 not being available when using an analog CRT display device. Further details can be found in topic number 737-27464
* Running through the un-install of the ATI display driver may result in the display driver failing to be completely removed. Further details can be found in topic number 737-27466
Known Issues Under the Windows XP Operating System
The following section provides a summary of open issues in the latest version of Catalyst™. These include:
* Armed Assault: Handle count leak maybe noticed during game play in Task Manager. Further details can be found in topic number 737-27467
* Homeworld 2: The application may fail to run when CrossFire™ is enabled and an Anti-Aliasing setting of greater than 2 is selected on certain ATI Radeon™ X1800 series of products. Further details can be found in topic number 737-27094
* Neverwinter Nights: Shadows of Undrentide may show dithering corruption on the loading screen(s) with Anisotropic Filtering enabled on certain graphics families. Further details can be found in topic number 737-27095
* Starwars Knights of the Old Republic II: The Sith Lords: Setting the in-game display option to low settings may result in corruption being noticed within the game. Further details can be found in topic number 737-25173
* Enabling CrossFire™ may result in display corruption being noticed when playing a DVD or media clip using either WinDVD 7, Windows Media Player or PowerDVD 6. Further details can be found in topic number 737-22806
* Catalyst™ Control Center->Overdrive™: The OverDrive™ setting are not retained for individual accounts. This issue may also be experienced under the Windows Vista operating system. Further details can be found in topic number 737-25805
* Launching the release notes under the Japanese or Chinese version of Windows may result in the release notes displaying a blank page. This issue may also be experienced under the Windows Vista operating system. Further details can be found in topic number 737-26749. Planned Release 8.39
* Some pixilated corruption may be observed while running the game Prey while hovering over the health packs from a distance on some hardware configurations running Win XP. Further details can be found in topic number 737-27091
* The system may become unresponsive and require a reboot while randomly moving Video Player window from primary to extended desktop under certain hardware configurations where the second adapter is an ATI Radeon™ X1200/1250/1270 series of product. Further details can be found in topic number 737-27092. Planned Release 8.38
* Connecting two display devices to an ATI Radeon™ X1600 series product may result in the device manager failing to detect the secondary display device. Further information may be found in topic number 737-21266
* Corruption may be noticed when playing certain DVD titles when hardware acceleration is enabled on ATI Radeon™ HD 2900 XT product. Further details can be found in topic number 737-27624
For further information and general help on software driver installation, game issues, and more, visit ATI Customer Care.
New Features
ATI's Folding@Home
gast_003
Ah sehr schön! endlich mal ein offizieller treiber für die 2900 XT.
Testen kann ich den aber leider frühestens morgen, da der Rechenknecht grad kein Netzteil hat und windows neu aufgespielt werden muss (falsche software installiert)...
war ich wohl etwas zu schnell für die x64 Version des Treibers.
File not found.
Bernieserver
Da gebe ich Dir Recht, du hast wirklich falsche Software installiert.
Aber machst Du dann nicht gerade den gleichen Fehler?
gast_003
Damit war nicht der Treiber gemeint.
Hatte nen Tool zur Überwachung von CnQ installiert, welches sich beim ACPI Treiber mit reingehackt hat und seither startet der Rechner nimmer.
War wohl nicht mit der x64 Version kompatibel...
Shinzon
- Österreich, PITMON
- Folding@Home
- Folding@Home
- Ryzen 5 2600, 16GB DDR4 3400, Windows 10 Pro x64
- Ryzen 5 2600
- Asus TUF B450M-PLUS GAMING
- Arctic Cooling Freezer AIO
- 2x 8GB Crucial Tactical Tracer 3000@3400
- Asus Arez Strix Vega 56 OC
- HP 27x Curved
- Sandisk NVMe Extreme Pro 500GB
- Creative Sound Blaster Omni Surround 5.1
- Thermaltake Core V21
- BeQuiet 750W
- Windows 10 Pro x64
- Vivaldi 64Bit
Ist in diesem Treiber der Steam-Client schon integriert?
Habe auf Fudzilla oder Inquirer gelesen, dass AMD mit ATI wieder einen Vertrag geschlossen hat und die Käufer von HD2900XT Karten drei oder vier Source basierte Spiele freischalten können und allen anderen ATI Besitzern HL2 Multiplayer und noch ein anderes zur Verfügung steht. Ist da was dran?
Ole
Auch eine interessante Frage. Der Treiber bietet jedenfalls 3 Optionen beim installieren an, die ich mangels Informationen, was das denn überhaupt sei abgewählt habe.
Steam bot mir nichts neues (Ausser Orchestra Riesenupdate *freu*) an. Es war auch nichts zu finden, was auf dieses Angebot hindeutete. Die Umsonstsoftware würd ich mir allerdings trotzdem gerne mal angucken und spielen. Das wäre das erste, was von HL2 auf meinen Rechner kommen würde.
AMD-Hammer
- Bornheim (Rheinland)
- Lenovo IBM Thinkpad X301
- AMD Athlon 64 X2 "Manchester" 3800+
- EPoX 9NPA+ SLi
- Zalman CNPS 7700-Cu
- 4x 1GB G.Skill CL3 F1-3200PHU2-2GBNT
- XFX GeForce 7600 GT
- 2x 17 Zoll TFT LG Flatron L1710S
- Hitachi 1TB HDT721010SLA360, Samsung 160GB 1614N, Samsung 200GB 2014N, IBM Hitachi GXP180 120 GB
- LG GSA 4163A
- Coolermaster CAV-T03
- Seasonic S12 600 Watt
- Debian GNU/Linux 5.0.1 AMD64
Hallo Leute,
sagt mal hat vielleicht einer den neuen ATI Treiber für Linux im Dual Head Modus laufen? In den letzten Versionen war das nicht stabil möglich und ich hab eigentlich keine Lust das jetzt wieder zu installieren, wenns nachher nur probleme gibt
psychocyberdisc
- Mystery Lake
- ASUS ROG Zephyrus G14 (GA402RJ-L8116X) // 14 Zoll
- Details zu meinem Laptop
- AMD Ryzen 7 6800HS (Rembrandt, 3200 MHz, bis zu 4700 MHz, 4 MB L2-Cache, 16 MB L3-Cache)
- ASUS GA402RJ (BIOS 319)
- 8 GB verlötet sowie 1 × Samsung M425R4GA3BB0-CQK (insges. 40 GB, DDR5-4800)
- AMD Radeon 680M (RDNA 2), AMD Radeon RX 6700S (Navi 23, bis zu 105 Watt mittels AMD SmartShift)
- 2560 × 1600 Bildpunkte, 500 cd/m², 120 Hz // HP EliteDisplay E273q (1FH52AA#ABB)
- Samsung SSD 990 PRO (2 TB, Firmware 8B2QJXD7) // Samsung Portable SSD T7 (2 TB)
- ASUS ROG Zephyrus G14 (2022) mit AniMe Matrix
- 240 Watt
- CHERRY G80-3000 (G80-3000LPCDE-2)
- Microsoft Pro IntelliMouse auf Func Surface 1030² XL
- Microsoft Windows 11 Pro (Version 26H2)
- Microsoft Edge mit uBlock Origin Lite
- HP USB-C Dock G5 (5TW10AA#ABB), beyerdynamic MMX 300 Manufaktur, FRITZ! FRITZ!Box 6690 Cable
▼100 Mbit/s
▲50 Mbit/s
Man hätte hier vielleicht noch erwähnen sollen, dass zeitgleich mit diesen Grafiktreibern auch ein gänzlich neuer RAID-Treiber für die SB600 erschienen ist. Er trägt die Versionsnummer 2.2.1540.29 und scheint zu jedem Windows XP und Vista kompatibel zu sein.
Weiterhin wurde der Treiber wohl in Zusammenarbeit mit Promise Technology entwickelt:
Nutzt ihn schon jemand?
klein van
- Raum Hessen
- Spinhenge@home
- Spinhenge
- i7-860, Q6600, Q6600, E6600, T7400, Athlon4000, i5-560M
- Lenovo R60
- Intel i7-860
- GA-P55A-UD6
- Noctua P12 mit 2x120/35
- 2x2GB DDR3 1600 OCZ
- ATI HD6850
- 19 TFT
- 1xWDC15 als System; 2x500er Samsung
- GGC-H20L, LG GSA-H55N
- Chieftec Mesh LCX-01BL-BL-B, blau
- Enermax 485W Noisetaker (EG495AX-VE(W)-SFMA)
- Windows7 Ultimate 64 bit
- IE8, FireFox3.6xx
Hey, es gibt auch einen neuen Avivo Paket 20,9 MB 7.5 31. Mai 2007
Avivo-Videoumwandler*
*Avivo-Videoumwandler funktioniert nur
mit Produkten der X1000-Serie
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/7-5_vista_xcode_46757.exe
Gruß "klein van"
Gruß "klein van"
psychocyberdisc
- Mystery Lake
- 240 Watt
▼100 Mbit/s
▲50 Mbit/s
Davon gibt es ebenfalls monatlich eine neue Version. Sie erscheint immer zeitgleich mit dem Grafiktreiber.
Stefan Payne
Liegt wohl daran, das die S-ATA Ports in der SB600 von Promise sind
Habs auf meinem DFI ICFX3200 mal vergleichen können, SB600 und der Promisechip verhalten sich exakt gleich, sind auch ansonsten ziemlich identisch, nur der Name unterscheidet sich etwas.
und das ist mit sicherheit nicht die schlechteste wahl[3DC]Payne;3213325 schrieb:Liegt wohl daran, das die S-ATA Ports in der SB600 von Promise sind
Stefan Payne
Im RAID/AHCI Mode nervt die Bezeichnung der Festplatten schon sehr.
Aber besser was etabliertes/funktionierendes 'borgen' als irgendeinen Schrott selbst hinpfuschen...
Freu|Freulein
- amd x2 4400@5200
- DFI Crossfire 3200
- CoolerFreezer 64 CPU, 3 Gehäuselüfter am Netzteil
- 2 gb MDT DDR SDRAM
- Diamond 2900XT
- CRT Samsung SyncMaster 757dfx
- 2*HDT722520DLAT80 (186 GB, IDE)
- PHILIPS DVDRW1208 (DVD+RW:2.4x/8x, CD:12x/10x/32x DVD+RW) TSSTcorp DVD-ROM TS-H352A (16x/48x DVD-ROM
- Creative SB0350 Audigy 2 ZS Sound Card
- Chieftec
- BeQuit P5
- Vista x64
- Opera, IE 7
Bitteschön, http://www.tweaktown.com/articles/1123/ati_catalyst_7_6_performance_analysis/index.htmlFalls jemand einen Test des Treibers mit einer HD2900er findet (am besten auch noch unter XP) wäre ich dankbar, wenn das hier verlinkt werden könnte.![]()
Ole
Dankeschön.
Allerdings bezweifle ich die Aussagekraft dieses Tests ein bisschen.
Er wirkt ziemlich amateurhaft. Ein kompletter Test wie beim erscheinen nur eben mit den neuen Treibern wäre wünschenswert, aber das hat sich ATi ja durch die miserablen Starttreiber selbst versaut.
