Download ATI Catalyst 9.8 nun ganz offiziell
- Ersteller pipin
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- 2x 16 GB DDR4 3200
- GeForce GTX 1650
- 27 Zoll Acer + 24 Zoll DELL
- Samsung 980 Pro 256 GB
- diverse
- Fractal Design R5
- Logitech Cordless Desktop
- Logitech G502
- Firefox, Vivaldi
- ▼250 MBit ▲40 MBit
Nachdem AMD den Catalyst 9.8 bereits vorab im Rahmen der QuakeCon zum Download <a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=2&id=1250328372">bereitgestellt hatte</a>, sind nun auch die offiziellen Downloadseiten auf game.amd.com aktualisiert worden. Voraussetzung für das CATALYST Control Center (CCC) ist unter Windows XP ein installiertes Microsoft .NET Framework. Eine aktuelle Version des .NET Framework kann man über die Microsoft Windows Update Seite beziehen.
<blockquote><b><font size="3">New Features </font></b><br>
<b>OpenGL™ 3.1 extension support </b>
This release of ATI Catalyst™ provides OpenGL™ 3.1 extension support. The
following is a list of OpenGL™ 3.1 features and extensions added in Catalyst 9.8:
<ul><li>Support for OpenGL Shading Language 1.30 and 1.40 </li><li>Instanced rendering with a per-instance counter accessible to vertex shaders (GL ARB draw instanced) </li><li>Data copying between buffer objects (GL EXT copy buffer) </li><li>Primitive restart (NV primitive restart). Because client enable/disable no longer exists in OpenGL 3.1, the PRIMITIVE RESTART state has become server state, unlike the NV extension where it is client state. As a result, the numeric values assigned to PRIMITIVE RESTART and PRIMITIVE RESTART INDEX differ from the NV versions of those tokens </li><li>At least 16 texture image units must be accessible to vertex shaders, in addition to the 16 already guaranteed to be accessible to fragment shaders</li><li>Texture buffer objects (GL ARB texture buffer object) </li><li>Rectangular textures (GL ARB texture rectangle) </li><li>Uniform buffer objects (GL ARB uniform buffer object) </li><li>SNORM texture component formats</li> </ul>
<b><font size="3">Performance Improvements </font></b><br>
The following performance gains are noticed with this release of Catalyst™ 9.8:
<ul><li>Battleforge DirectX 10/DirectX 10.1 - performance improves up to 15-50% in CPU limited settings with the largest gains in CrossfireX configurations </li><li>Company of Heroes DirectX 10 - performance improves by up to 10-77% in CPU limited settings </li><li>Crysis DirectX 10 - Dual CrossfireX performance improves as much as 10% and Quad CrossfireX performance improves as much as 34% in CPU limited settings </li><li>Crysis Warhead DirectX 10 - Dual CrossfireX performance improves as much as 7% and Quad CrossfireX performance improves as much as 69% in CPU limited settings </li><li>Far Cry 2 DirectX 10 - Dual CrossfireX performance improves as much as 50% and Quad CrossfireX performance improves as much as 88% in CPU limited settings </li><li>Tom Clancy’s H.A.W.X. DirectX 10/DirectX 10.1 - Dual CrossfireX performance improves up to 40% in CPU limited settings with Quad CrossfireX performance improving up to 60% in CPU limited settings </li><li>UnigineTropics OpenGL - performance improves 5-20% </li><li>UnigineTropics DirectX 10 - Quad CrossfireX performance improves 5-20% in CPU limited settings </li><li>World in Conflict DirectX 10 - performance improves by 5-10% </li></ul></blockquote>
Die Download-Links führen zu den Game.AMD.com Support-Seiten, wo man die Treiberpakete einzeln (Windows XP) oder aber komplett (Windows XP & Vista) inkl. CATALYST Control Center (CCC*) beziehen kann.
<b>Download:</b><ul><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=VideoCard/win7-32-suite" target="b">ATI Catalyst 9.8 Display Driver [Windows 7 32-Bit]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=VideoCard/win7-64-suite" target="b">ATI Catalyst 9.8 Display Driver [Windows 7 64-Bit]</a></li>
<li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=vista32/common-vista32" target="b">ATI Catalyst 9.8 Display Driver [Windows Vista 32-Bit]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=vista64/common-vista64" target="b">ATI Catalyst 9.8 Display Driver [Windows Vista 64-Bit]</a></li>
<li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp" target="b">ATI Catalyst 9.8 Display Driver [Windows XP 32-Bit / MCE]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp64/radeonx-xp64" target="b">ATI Catalyst 9.8 Display Driver [Windows XP 64-Bit]</a></li></ul><ul><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/mobility-xp" target="b">ATI Catalyst 9.8 Mobility Kompatibilitätsprüfung</a></li></ul><ul><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=VideoCard/win7-32-components" target="b">ATI Catalyst 9.8 Mainboard/IGP [Windows 7 32-Bit]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?driver=VideoCard/win7-64-components" target="b">ATI Catalyst 9.8 Mainboard/IGP [Windows 7 64-Bit]</a></li>
<li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=vista32/integrated-vista32" target="b">ATI Catalyst 9.8 Mainboard/IGP/Southbridge [Windows Vista 32-Bit]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=vista64/integrated-vista64" target="b">ATI Catalyst 9.8 Mainboard/IGP/Southbridge [Windows Vista 64-Bit]</a></li>
<li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/integrated-xp" target="b">ATI Catalyst 9.8 Mainboard/IGP/Southbridge [Windows XP 32-Bit / MCE]</a></li><li><a href="http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp64/integrated-xp64" target="b">ATI Catalyst 9.8 Mainboard/IGP/Southbridge [Windows XP 64-Bit]</a></li></ul>
<b>Links zum Thema:</b><ul><li><a href="http://www.planet3dnow.de/vbulletin/attachment.php?attachmentid=16030&stc=1&d=1250536174" target="b">Release Notes Catalyst 9.8</a></li>
<li><a href="http://www.microsoft.com/downloads/details.aspx?familyid=AB99342F-5D1A-413D-8319-81DA479AB0D7&displaylang=de" target="b">Microsoft .NET Framework 3.5 SP1</a></li></ul>
cpushreder
- Hannover
- QuadCore Intel Core 2 Quad Q6600, 3510 MHz (9 x 390)
- Gigabyte GA-P35-DS3R
- EK Waterblock Plexi
- 2x G Skill F2-6400CL5-2GBPQ
- ATI Radeon HD 5770 (1024 MB) (Asus CuCore)
- Medion 23.6 Tft Akoya P55005 | Samsung SyncMaster 940NW [19" WS LCD]
- 2x SAMSUNG HD103SI (1TB) 2x SAMSUNG HD103SJ (1TB)
- HL-DT-ST DVD-RAM GH22NS30; TSSTcorp DVD-ROM SH-D163B
- Creative X-fi Titanium
- NZXT Whisper
- Nitrox 500w
- WIN7 x64
- Firefox V3.6
gibt es schon irgendwo tests?
Dr@
- Baden-Württemberg
- Collatz Conjecture
- Zacate E-350 APU
- E35M1-I DELUXE
- DVD-Brenner
- Firefox 13
http://www.computerbase.de/artikel/hardware/grafikkarten/2009/bericht_ati_catalyst_98/
Wie bei jedem neuen Catalyst
Der Test wurde aber scheinbar mit heißer Nadel gestrickt -> viele Tippfehler
Crashtest
- Leipzig
- Collatz, yoyo, radac
- yoyo
- Lenovo IdeaPad 5 14ALC05
- Ryzen 7950X / Ryzen 4750G
- ASRock B650M PGRT / X570D4U
- 27" Samsung LF27T450F
- KINGSTON SNVS2000G
- onboard HD?
- zu kleines für die GPU
- CHERRY SECURE BOARD 1.0
- Logitech RX250
- Edge 120.0.2210.121
- U320 SCSI-Controller !!!!
- ▼1000 MBit ▲82 MBit
Leider funktioniert CAL bei XP und XP64 immer noch nicht - MW gestartet kommen VPU-Recoveries ohne Ende....
cpushreder
- Hannover
- NZXT Whisper
- Nitrox 500w
- WIN7 x64
- Firefox V3.6
@ Dr@: danke
der link zum ccc 9.8 (vista&XP) ist nich vorhanden, bzw n. n. aktualisiert bei game.amd.
"mit downloadmanager, zB FDM gehts"
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/9-8_vista32-64_ccc_lang2.exe
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/9-8_xp32-64_ccc_lang2.exe
dl von Avivo Video Converter gelang mir ebenfalls, wie letztes mal schon nicht mehr mit IE.
"frag mich nun allerd ob das Problem nur bei mir, oder wie auch immer, warum bei IE dl nun auftritt"
PuckPoltergeist
Wieso gebt ihr eigentlich nicht die Linux-Treiber mit an, wenn AMD sich schon die Mühe macht, das gleichzeitig zu pflegen und bereit zu stellen?
badcip
- Lenovo R60e
- Phenom II X4 955 BE
- ASRock M3A790GXH/128M
- Scythe Mugen 2
- 2x 2 GB Kingston DDR3, PC1333
- Powercolor HD 4770
Ich habe Probleme bei Battefield 2 im Panzer
Das liegt wohl an AMD selber. Die pflegen es eben nicht gleichzeitig. Linux-Links werden immer zuletzt eingefuegt oder aktualisiert.
Terminatrix
- Hamburg
Gibt doch meistens 1-2 Tage später ne extra News für die Linux-Treiber.
SnakePlisken
Kann man den jetzt auf Kernel > 2.6.29 loslassen? Die releasesnotes sind ja wohl noch nicht auf zu treiben.
Alex84
- Bielefeld (ursprünglich Oberfranken)
- ASUS VivoBook U38DT
- AMD FX-8320@ 4,2Ghz
- MSI Gaming 970
- Scythe Yasya
- 16GB Adata 1866Mhz DDR3
- Sapphire R9 290X 8GB
- 19" LG
- 640GB Seagate Barracuda
- DVD-Brenner, LG, IDE
- Realtek onboard
- AeroCool
- Coba Nitrox 7750 SG
- Windows 7 64
Weiß jemand, ob die Fehler bei "Ultra"-Settings in Company of Heroes gefixt wurden? Man findet nichts in den Release notes zu Bugfixes für CoH, nur Performance-Steigerungen.
-Alex
-Alex
Dr@
- Baden-Württemberg
- Zacate E-350 APU
- E35M1-I DELUXE
- DVD-Brenner
- Firefox 13
There never will be a AVIVO video converter for my radeon 2400 that runs under Windows XP x64.
Nor might there be any "soon" again.
Für XP sollte es auch nie einen geben ...
PuckPoltergeist
Ja, kann man. 2.6.29 und 2.6.30 werden jetzt auch unterstützt, 2.6.31 geht noch nicht. Die liegt die Hoffnung aber auf Catalyst-9.10, welcher hoffentlich auch das neue Ubuntu unterstützt.
Linux-Link ist aktuell.
SnakePlisken
Fein
Wobei seltsamer Weise meine Darstellung auf dem Desktop nach nem Update auf KDE 4.3 sich von alleine rapide verbesserte.
hawk2206
- Dannenberg
- Intel Q9550 (E0) 2.83 GHz
- MSI P45 Neo-F
- boxed
- 4x 2GB PC6400 A-Data DDR2
- PowerColor PCS+ HD4870 1GB GDDR5
- LG 227WT
- Samsung Spinpoint 1TB
- Samsung SH-S223F
- Antec Sonata III 500 ATX
- Windows Vista Home Premium 64bit
- Opera 10
Echt traurig, das... Hat schon jemand Erfahrung mit Vista x64, den 9.8er und MW gemacht?
spacemanneke
weiß einer ob die treiber auch mit einer x800xt funktionieren?
Dr@
- Baden-Württemberg
- Zacate E-350 APU
- E35M1-I DELUXE
- DVD-Brenner
- Firefox 13
nein tut er nicht
siehe release notes
Der letzte Treiber, der deine GPU unterstützt, ist der 9.3 ausm März.
MfG @
siehe release notes
MfG @
nein tut er nicht
siehe release notes
MfG @
Egentlich nicht nachvollziehbar, den eigentlich sollten "legacy" gpu´s alle 3 Monate aktuallisiert werden. Eigentlich wäre das spätestens mit dem 9.7 soweit gewesen. (X.1;X.4;X.7;X.10)
PuckPoltergeist
Das passiert bestimmt nicht mit dem Catalyst sondern dann mit einem separaten legacy-Treiber. Sonst würde die eingeschränkte Unterstützung überhaupt keine Sinn machen, wenn man die komplette Codebasis nach wie vor mitschleppen muss.
Edit meint, es gibt auch den Catalyst 9.3.1 vom 6.7.2009, welcher entsprechende Fixes enthält. Einen neuen Catalyst wird es nicht für diese Karten geben.
Dr@
- Baden-Württemberg
- Zacate E-350 APU
- E35M1-I DELUXE
- DVD-Brenner
- Firefox 13
Ja ich weiß! Ich bin selbst betroffen -> siehe "Mein System"
MfG @
Edit:
Der legacy-Treiber ist aber stand heute noch immer der CCC 9.3
Bei der letzten Stellungnahme zum Thema wurde gesagt, dass nur bei schweren Fehlern ein Update vorgenommen wird.
MfG @
Edit:
PuckPoltergeist
MfG @
Edit:
siehe meinen Beitrag über dir
http://support.amd.com/us/gpudownlo...px?type=2.4.1&product=2.4.1.3.13&lang=English
da gibts den 9.3.1er auch
Dr@
- Baden-Württemberg
- Zacate E-350 APU
- E35M1-I DELUXE
- DVD-Brenner
- Firefox 13
Den gibts bereits seit Juli.
Ist aber nur ein neuer WDM-Treiber
Der Rest hat immer noch den Stand von März!
PuckPoltergeist
Halt das, was gefixt wurde. Und sollten weitere größere Fehler zu finden sein, gibts dort auch nochmal Fixes. Aber das passiert alles auf dem 9.3er. Etwas neueres wird es nicht geben. Eventuell bringen sie noch Anpassungen für Windows 7. Mehr macht keinen Sinn.
