AVM Fritz!Box 5690 Pro die Fritz!Box mit Wifi 7 und 6 Ghz Band und DSL/Glasfaser Untertützung
NWA130BE V7.30 Patch 2 Firmware
[Release Note] Zyxel BE Series Access Point - V7.30 Patch 2 firmware has been released
New Features and Enhancements​
1. Captive Portal Security: Enables Two-Factor Authentication (2FA) for Captive Portal logins using the Nebula Cloud Authentication Server (NCAS).
Note: This feature currently does not support External Portal configurations.
2. Dynamic Bandwidth Control: Administrators can now apply client rate limits dynamically using RADIUS attributes.
Bug Fix​
C=Cloud mode, M=Managed, S=Standalone mode
Bug fixCMS
1. [eITS: 250900997, 250601432 ] [Symptom] Wi-Fi 7 AP experiences unexpected reboot or hang due to kernel panic.VVV
2. [eITS: 251200910 ] [Symptom] Wireless service interruption on NWA130BE due to system memory usage reaching 90%.VVV
3. [eITS: 251100079 ] [Symptom] Ethernet-connected devices cannot access the repeater or its clients in a standalone WDS mesh (2.4 GHz & 5 GHz).--V
4. [eITS: 251101963] [Symptom] After rebooting the USG FLEX H series, managed access points may incorrectly display a “VLAN Conflict” status in the AP list, even though the VLAN configuration is correct.-V-
5. [eITS: 251100237] [Symptom] DNS and gateway communication failure occurs when the 6 GHz band is disabled and Layer-2 isolation (Guest Network mode) is enabled without gateway MAC addresses in the allow list. V--
6. [eITS=251001732,251001918] [Symptom] Microsoft Entra authentication failed because the AP did not replace the certificate after receiving the updated certificate from NCC.V--
7.[eITS=250901312,250901486,250901395,251000631] [Symptom] Wireless service interruption on WBE530/NWA130BE/WBE660S due to restart hostapd process.V--
8. [SPRID: 250402043] [Symptom] When an MLO client connects to the SSID, the authentication field of client page does not display voucher.V--
9. [SPRID: 250402050] [Symptom] Under this configuration combination : Sign-on with my RADIUS enabled along with MAC authentication fallback. The behavior of MLO clients after connecting may not be as expected:
a. Traffic does not pass through (no connectivity).
b. Client remains online after reconnecting, even without re- authentication.
c. After completing MAC authentication, the client is redirected to the captive portal.
V--
10. [SPRID: 250627398] [Symptom] 5G radio is 11be mode + MLO enabled + security is enhance open, after wireless client which support enhance open security connected the SSID field of client list will show SSID name(transition mode).VVV
11. [SPRID: 250714115] [Symptom] After the wireless STA connects to the initial SSID, the AP's web GUI is accessible, but pinging the AP's IP address fails.VVV
12. [RMID: 62239] [Symptom] The access point may reboot unexpectedly when the 2.4GHz radio is configured in BE mode. To prevent this, the 2.4GHz radio mode has been converted to AX mode.VVV
13. [RMID: 65019] [Symptom] Abnormal display of loading status for 2.4 GHz — 2.4 GHz always shows as -.-V-
14. [RMID: 64436] [topology] mlo root )))((( mlo repeater
[Symptom] When a tri-band WiFi 7 repeater is manually configured to use a dual-band WiFi 7 root as its uplink, it can only connect to one band.
V--
15. [RMID:64381 ] [Symptom] If all radios on the repeater are operating in ax mode and it successfully connects to the uplink, the indicator icon on Nebula will show a solid green light.V--
16. [RMID: 64099] [Application Visibility] [Symptom] All AP models with MLO supported have this issue. Real-time bandwidth limitation changes — STA connection actual test not restricted.
[Steps]
1. Add the AP to a site.
2. Enable Application Visibility.
3. Set File Sharing to be limited to 1 Mbps.
4. Connect a wireless station and test FTP upload/download. → Upload and download are correctly limited to 1 Mbps.
5. Keep the wireless station connected, then change the File Sharing limit to 15 Mbps.
6. Test FTP upload/download again.
[Result] FTP upload and download are not limited; to resolve this issue, the wireless station needs to reconnect.
V--
17. [RMID: 63816] [Symptom] When an MLO client connects to the AP using both 2.4 GHz and 5 GHz links, you will see two entries for the same client on the WLAN Clients page.-V-
18. [RMID: 63221] [Symptom] [IAP500BE] When a new AP is opened from the box and powered on via PoE but fails to obtain an IP address, it automatically switches to repeater mode. During its attempt to connect to the uplink, a system hang occurs. The AP must be rebooted and should be able to obtain an IP address to provide the service. V--
Known Issue​
Known IssueCMS
1. [SPRID: 240913082] [Symptom] Stations cannot authenticate when an SSID is configured with MLO (2.4G+5G bands) and the security mode is set to WPA3 with MAC Authentication via RADIUS.V--
2. [SPRID: 241216264] [Symptom] When the WAC5302D-Sv2 model is used as the Root in a Mesh setup, and WiFi 7 series models with firmware versions 7.00 & 7.10 are used as Repeaters, the Mesh connection cannot be established. V--
3. [RMID: 66894] [Symptom] When the WBE665S is in Standalone mode, configuration changes may not be applied when using the Wizard.--V
4. [RMID: 66666] [Symptom] When the WBE665S operates in Standalone mode with Indoor mode enabled, rebooting the AP may trigger an ERROR related to system-log suppression, causing the AP to apply lastgood.conf.--V
5. [RMID: 66414] [Symptom] Proxy ARP function not working for MLO STA connected on 5 GHz.--V
6. [RMID: 65938] [Symptom] [Dynamic VLAN] The STA connects to an AP and obtains an IP address via a dynamic VLAN. STA traffic is not passing after the STA triggers roaming.V--
7. [RMID: 64372] [Symptom] When using an SNMP MIB tool to perform an SNMP SET operation on the sysName OID, the SET request reports success; however, the System Name is not updated in the GUI. --V
8. [RMID: 64164] [Symptom] AP status show vlan conflict when Force Overwrite VLAN Config is enabled
[Steps]
a. AP MGMT > AP Group > Edit Group
b. Force Overwrite VLAN Config: Enable MGMT VALN ID: 10
c. As Native VLAN: Enable
[Result] AP MGMT > Mgmt. AP List AP show vlan conflict and Mgnt. VLAN ID(AC/AP) show 10/1
-V-
Limitation of Settings​
LimitationCMS
1. [SPRID: 241203097] [Symptom] When the Mesh topology consists of a non-supported MLO Root combined with MLO Repeater Hop1 and Hop2, it may affect the Repeater's downlink and cause issues with the service VAP lacking MLO functionality.V--
Wusste gar nicht das sich Labor auch automatisch updatet, dachte das muss man immer manuell anstoßen:
Na zu der Zeit logisch das ich das nicht mitbekommen habe.
22.01.2604:27:24FRITZ!OS auf 8.10-128131 aktualisiert. Die bisher verwendete Version war 8.10-127904. Das Update erfolgte automatisch über die Auto-Updatefunktion. In Ihrer FRITZ!Box ist eingestellt, dass Updates automatisch installiert werden sollen.
8.20 liegt seid gerade auf dem FTP von Fritz!
Die Update-Datei "FRITZ.Box_5690_Pro-xx.xx.image" enthält das aktuelle FRITZ!OS (Firmware) für die FRITZ!Box 5690 Pro.
**Achtung:** Diese Update-Datei ist nur für FRITZ!Box 5690 Pro geeignet!
Beachten Sie die Hinweise zur Durchführung des Updates am Ende dieser Datei.
Produkt: FRITZ!Box 5690 Pro
Version: FRITZ!OS 08.20
Sprache: Deutsch, Englisch, Französisch, Italienisch, Niederländisch, Polnisch, Spanisch
Release-Datum: 05.02.2026
**Neue Features:**
- Der neue Online-Monitor zeigt die Internetnutzung der Top-Verbraucher und ausgewählter Heimnetzgeräte übersichtlich grafisch an
- Mesh-Optimierung - für höhere Stabilität und besseren Datendurchsatz wählen FRITZ!Repeater selbständig die optimale Verbindung im Mesh
- Mehr Möglichkeiten im Smart-Home für das Auslösen von Routinen und zahlreiche weitere interessante Neuigkeiten
- Die neue, einfach benutzbare FRITZ!NAS-Freigabe ermöglicht das Teilen eines Datei-Ordners, z. B. um Fotos nach einer Familienfeier zu sammeln und teilen
- Vereinfachte Benutzerführung bei der Kindersicherung - Zugangsprofile und ihre zugehörigen Heimnetzgeräte werden jetzt übersichtlich dargestellt
- Schutz vor Ausfall der Internetverbindung: FRITZ! Failsafe wechselt automatisch auf eine Ersatzverbindung, z.B. Mobilfunk
- Energieverbrauch der FRITZ!Box senken mit EEE (Energy Efficient Ethernet). Nun separat einstellbar für den WAN- oder die LAN-Anschlüsse
Im Folgenden finden Sie die komplette Liste der neuen Funktionen des aktuellen FRITZ!OS, deren Beschreibung im Detail und eine Liste weiterer Verbesserungen in dieser Version.
# Neue Funktionen und Verbesserungen in FRITZ!OS 8.20
## Internet:
- **NEU** Anzeige der Auslastung des Netzsegments, in dem sich der eigene Teilnehmeranschluss befindet, durch die eigene und die benachbarte Nutzung
- **NEU** FRITZ!Box bleibt über den neuen Internet-Ausfallschutz immer online: fällt die Internetverbindung aus, wird eine alternative Internetverbindung über ein Zugangsgerät hergestellt, z. B. über Mobilfunk mit FRITZ!Box 6820 LTE oder USB-Mobilfunk-Sticks
- **NEU** Anzeige der Netzwerkgeräte mit der höchsten Auslastung der Internetverbindung im Online-Monitor (Top-Verbraucher)
- **NEU** Der Online-Monitor für "Einzelne Geräte" zeigt zusätzlich die Gesamtauslastung von Geräten, die nicht einzeln ausgewählt wurden
- **NEU** Vereinfachte Benutzerführung auf den Seiten "Filter" (Kindersicherung)
- **Verbesserung** Im Online-Monitor ist für die Anzeige der Auslastung der Internetverbindung neben dem Zeitraum von einem Tag oder zwei Monaten auch ein Intervall von 2 Wochen auswählbar
- **Verbesserung** Geräteauswahl für die Anzeige und Datenerfassung im Online-Monitor vereinfacht
- **Verbesserung** Grafiken und Farben im Online-Monitor wurden überarbeitet
- **Verbesserung** Online-Monitor: Überarbeitete Darstellung in den Diagrammen für die Auslastung der Internetverbindung
- **Verbesserung** Für den Internetanbieter 1&1 Telecom GmbH wird unter "Internet > Zugangsdaten" eine Umschaltmöglichkeit auf den Internetzugang über WAN angeboten
- **Verbesserung** Stabilität bei vielen gleichzeitigen Anfragen an Internetdienste erhöht
- **Verbesserung** Telekom-Easy-Support: Vereinfachte Einrichtung am Telekom-Glasfaser- oder -DSL-Anschluss für Internetzugang und Rufnummern aktiviert
- **Verbesserung** Bei der Priorisierung der Netzwerkanwendung "Surfen" wird Port 443 (HTTPS, QUIC) berücksichtigt
- **Verbesserung** In den Zugangsprofilen der Kindersicherung kann man jetzt auswählen, ob Netzwerkanwendungen gesperrt oder zugelassen werden
- **Verbesserung** Ticketanzahl zur Verlängerung der Online-Zeit für durch die Kindersicherung gesperrte Geräte wurde von 10 auf 12 erhöht
- **Verbesserung** In der Kindersicherung kann eine beschränkte Online-Zeit für ein Netzwerkgerät jetzt auch einfach um 45 Minuten verlängert werden
- **Verbesserung** Interoperabilität verbessert in Zusammenhang mit ICMP v4 Fehlerbehadlung an MAP-T-Anschlüssen
## Mesh:
- **NEU** Automatische Erkennung des Gerätetyps (z. B. Smartphone, Computer oder Drucker) bei Geräten, die in der Mesh-Übersicht angezeigt werden
- **NEU** Intelligente Vernetzung: FRITZ!-Produkte im Mesh bewerten und optimieren die Verbindung untereinander
- **NEU** Vereinfachte Anmeldung an Mesh Repeatern über die Mesh-Übersicht des Mesh Masters
## Telefonie:
- **NEU** Für den integrierten Anrufbeantworter können die Anruferansagen nun auch als Text eingegeben werden (Text-zu-Sprache)
- **Verbesserung** Unterstützung für den Vodafone-IP-Anlagen-Anschluss
## DECT/FRITZ!Fon:
- **Verbesserung** Podcasts können nach Unterbrechung auch nach längerer Zeit automatisch an der letzten Stelle fortgesetzt werden
- **Verbesserung** Überarbeitung von Menüfolgen und Dialogen in der FRITZ!Fon-Benutzeroberfläche
## Heimnetz:
- **NEU** Energiesparen im Heimnetz: EEE (Energy Efficient Ethernet) kann nun separat für jeden WAN-/LAN-Anschluss eingestellt werden
- **Verbesserung** Komplette Überarbeitung der Netzwerkeinstellungen zur Verbesserung der Benutzerfreundlichkeit
## Smart Home
- **NEU** Auf der FRITZ!Box-Benutzeroberfläche des Mesh Masters kann die Anmeldung von Smart-Home-Geräten an einer anderen FRITZ!Box oder einem FRITZ!Smart Gateway gestartet werden
- **NEU** Die vom FRITZ!Smart Energy 250 ausgelesenen Daten des Einspeisezählwerks werden über das Menü "Smart Home > Geräte und Gruppen" dargestellt
- **NEU** Mit FRITZ!Smart Control 440 können jetzt auch folgende Funktionen gesteuert werden: die Boost- und Frostschutz-Funktion für Heizkörperregler, die Farb- und Farbtemperatur für Lampen, die Aktivierung und Deaktivierung von Routinen und die Anzeige des QR-Codes für das WLAN
- **NEU** Routinen können zusätzlich durch einen Telefonanruf, durch eine erreichte Soll-Temperatur oder durch die Boost- und Frostschutz-Aktivierung sowie durch wichtige Ereignisse der FRITZ!Box ausgelöst werden
- **NEU** Vorlagen und Routinen können verzögert ausgelöst werden
- **Verbesserung** Die Zeitschaltung für den Heizkörperregler kann deaktiviert werden, ohne dass der eingerichtete Zeitplan verloren geht
- **Verbesserung** Temperatur- und Luftfeuchtigkeitsdaten von Zigbee-Geräten werden im Heimnetz angezeigt und können für die Automatisierung genutzt werden
- **Verbesserung** Rollläden können jetzt auch in Gruppen zusammengefasst werden
- **Verbesserung** Farb- und Helligkeitsübergänge bei der Steuerung von Zigbee-Lampen wurden optimiert
## Speicher/NAS:
- **NEU** Upload-Freigabe: Über fritz.nas kann ein Ordner geteilt werden, in dem Nutzer mit einem Freigabe-Link Inhalte hoch- und herunterladen können, z. B. um Fotos nach einer Familienfeier zu sammeln
- **Verbesserung** Verbesserte Interoperabilität zu FTP-Anwendungen (z. B. Filezilla) durch Unterstützung des MFMT-Kommandos
- **Verbesserung** Vereinfachte Erstellung von Freigabe-Links für den Zugriff auf Dateien, die in FRITZ!NAS gespeichert sind
## Sicherheit:
- **Verbesserung** Benachrichtigung zu Anmeldungen von FRITZ!Apps jetzt auch über Push Mail
## System:
- **Verbesserung** Dateinamen für gesicherte Einstellungen um den individuellen FRITZ!Box-Namen erweitert
- **Verbesserung** Die Seite "Diagnose > Funktion" zeigt jetzt Hinweise bei Problemen mit der Zeitsynchronisation per NTP an
- **Verbesserung** Bei Ausfall der konfigurierten/provisionierten Zeitserver wird automatisch auf öffentliche Server ausgewichen
- **Verbesserung** Einrichtung der "Kennwort vergessen"-Funktion des Push Services ist jetzt mit frei wählbarem Empfänger möglich
- **Verbesserung** Funktionsdiagnose wurde um einen Hinweis erweitert, wenn der Zugriff für Apps (TR-064) in den Heimnetzfreigaben deaktiviert ist
- **Verbesserung** Seiten der Update-Funktionen unter "System > Update" wurden überarbeitet
- **Verbesserung** Benutzerführung für das Sichern bzw. Wiederherstellen von Einstellungen überarbeitet
- **Verbesserung** Warnung auf der Übersichtsseite bei Störungen des Push Service
- **Verbesserung** Der Energiemonitor zeigt nun die Leistungsaufnahme auf weiteren FRITZ!Box-Modellen an
- **Verbesserung** E-Mails des Push Service unterscheiden jetzt klar zwischen Funktions- und Sicherheitsdiagnose durch spezifische Betreffzeilen, angepasste E-Mail-Texte und Dateinamen
- **Verbesserung** Unterstützung der Barrierefreiheit (gem. BFSGV) für FRITZ!Box, FRITZ!Mesh Set Master und FRITZ!Fon
# Weitere Verbesserungen im FRITZ!OS 8.20
## Internet:
- **Änderung** FRITZ!-Produkte im Heimnetz, z. B. FRITZ!Repeater, werden nicht mehr in der Kindersicherung und Priorisierung angeboten, sie haben immer unbeschränkten Internetzugang mit normaler Priorität
- **Änderung** Private IPv4-Adressen (RFC 1918) werden nicht mehr über MyFRITZ!Net (DNS) veröffentlicht, wenn eine öffentlich erreichbare IPv6-Adresse verfügbar ist
- **Änderung** Wenn VPN-Verbindungen aktiv sind, bei denen der gesamte Netzwerkverkehr über die VPN-Verbindung geroutet wird ("Full Tunnel"), wird das Gastnetz hiervon ausgenommen und über die normale Internetverbindung geroutet
- **Änderung** Anzahl der Netzwerkgeräte, für die das Speichern der Internet-Datenraten aktiviert werden kann, wurde auf 40 erhöht
- **Behoben** Aktivierung des UPnP-Filters hatte keine Auswirkungen für IPv6
- **Behoben** Bei Anbietern ohne Unterstützung von IPv6 wurden im Online-Zähler keine Verbrauchswerte gezählt, solange IPv6 in den Zugangsdaten der FRITZ!Box aktiviert war
- **Behoben** Bei Nutzung einer großen Filterliste für gesperrte Internetseiten waren Internetausfälle möglich
- **Behoben** Bei ausschließlich über IPv6 betriebenen FRITZ!-Produkten erfolgte unter Umständen keine Abfrage auf neue FRITZ!OS-Versionen (Updates)
- **Behoben** Das Anlegen neuer WireGuard®-VPN-Verbindungen konnte scheitern, wenn bereits viele WireGuard®-VPN-Verbindungen angelegt worden waren
- **Behoben** Ein ausschließlich über IPv6 betriebenes FRITZ!-Produkt konnte unter Umständen keine Systemzeit über das Network Time Protocol beziehen
- **Behoben** In der Tarif-Information im Online-Zähler wurde das Ende des Abrechnungszeitraums falsch berechnet
- **Behoben** Kindersicherung: Das Einlösen von Tickets zur Verlängerung der Onlinezeit konnte in bestimmten Szenarien scheitern
- **Behoben** Mögliche fehlerhafte Anzeige im Online-Zähler zum Verbrauch des Datenvolumens im Abrechnungszeitraum
- **Behoben** Internetzugriff (Fernzugriff) auf die FRITZ!Box konnte nur eingerichtet werden, während die FRITZ!Box mit dem Internet verbunden war
- **Behoben** Manueller Verbindungsaufbau der Internetverbindung über "Neu verbinden" im Online-Monitor dauerte unter Umständen sehr lange
## WLAN:
- **Behoben** Hinweistext "Bitte warten" bei deaktiviertem 2,4-GHz-Band
## Heimnetz:
- **Behoben** In seltenen Fällen kam die Information zu einem neuen Netzwerkgerät im Heimnetz zu spät ins Ereignisprotokoll bzw. in die Änderungsnotiz
- **Behoben** In speziellen Szenarien war es möglich, dass für einen Repeater im Heimnetz statt dessen eigener IP-Adresse die 192.168.178.1 angezeigt wurde
- **Behoben** "Seite Heimnetz > Netzwerkverbindungen" wurde nicht angezeigt (leere Seite), wenn eine FRITZ!Box Internet-Gateway und als Mesh-Repeater eingerichtet war
## System:
- **Behoben** Der Push Service hatte den Passwort-vergessen-Link von Geräten, die als IP-Client eingerichtet waren, mit der falschen IP-Adresse versandt
- **Behoben** Trotz entsprechender Tarifeinstellung blinkte die LED "Info" nicht bei aufgebrauchtem Online-Volumen
- **Behoben** Vorschau des persönlichen Betreffs vom Push Service zeigt die vorgeschlagenen Klammern nur noch an, wenn diese tatsächlich eingegeben wurden
- **Behoben** In der FRITZ!OS-Oberfläche wurde unter "Netzwerkverbindungen" der Punkt "verbunden mit FRITZ!Repeater" teilweise doppelt angezeigt
Vorherige Release Versionen:
FRITZ!OS 08.03
**Neue Features:**
- Benutzeroberfläche: Grafische Darstellung des FRITZ!Box-Verbindungsstatus' auf der Übersicht (Startseite)
- Neuer Online-Monitor informiert zur Auslastung der Internetverbindung und zur Auslastung durch einzelne Netzwerkgeräte
- Internet: Auch IPv6-Daten können nun über einen Wireguard®-VPN-Tunnel übertragen werden
- Mesh: Grafische Übersicht mit neuem Design und zusätzlichen Funktionen
- DECT: Die Anzahl gleichzeitig möglicher DECT-Telefonate wurde von drei auf fünf erhöht
- Push Service: überarbeitetes Design und mehr Komfort
- Vereinfachte Einrichtung bei Anschluss an einem Glasfasermodem (ONT)
- Geschwindigkeit zwischen LAN 1/WAN und dem vorgeschalteten Gerät (z. B. Glasfasermodem) wird auf der Übersichtsseite angezeigt
- Viele Detailverbesserungen und Fehlerkorrekturen
Mit jedem neuen FRITZ!OS-Update aktualisiert FRITZ! auch die Sicherheitsfunktionen und empfiehlt daher grundsätzlich für alle Geräte, das Update durchzuführen.
# Neue Funktionen in FRITZ!OS 8.01
## Internet:
- **NEU** Auch IPv6-Daten können nun über einen WireGuard®-VPN-Tunnel übertragen werden (neue WireGuard®-Verbindung erforderlich, keine Weiterleitung von IPv6-Daten ins Internet)
- **NEU** Durch die Kindersicherung begrenzte Online-Zeit um 45 Minuten verlängern - direkt in den Detail-Einstellungen des Netzwerkgeräts
- **NEU** Neuer grafischer Online-Monitor mit erweiterten Informationen zur Auslastung der Internetverbindung durch einzelne Netzwerkgeräte
## WLAN:
- **NEU** Visualisierung der WLAN-Nutzung im Heimnetz für die jeweils letzten 7 Tage auf "WLAN > Funkkanal" hinzugefügt
## Mesh:
- **NEU** Für Geräte, die den Gastzugang nutzen, können eigene Namen und ein Symbol in der Mesh-Übersicht vergeben werden
- **NEU** Für Heimnetzgeräte können eigene Namen und ein Symbol in der Grafik der Mesh-Übersicht vergeben werden (Tooltip für Heimnetzgerät)
## Heimnetz:
- **NEU** Auch für Geräte, die den Gastzugang nutzen, können jetzt eigene Namen vergeben werden
- **NEU** Mehr Übersicht durch individuelle Symbole für Netzwerkgeräte
## Smart Home:
- **NEU** Auf der Geräteseite des Fenstersensors FRITZ!DECT 350 in der FRITZ!Box-Benutzeroberfläche kann die Fenster-auf-Erkennung für die ausgewählten Heizkörperregler eingerichtet werden
- **NEU** Die Vorlagen ermöglichen zusätzlich die Einstellung der Soll-Temperatur für Heizkörperregler, der Helligkeit, Sättigung und Farbe für Lampen sowie der Position für Rollläden in Prozentschritten
- **NEU** Die für Heizkörperregler einstellbare Temperatur kann durch Festlegen einer Maximal- und einer Minimal-Temperatur begrenzt werden (ab Software-Version 5.20 für FRITZ!DECT 301 und FRITZ!DECT 302)
- **NEU** Routinen können zusätzlich durch eine voreingestellte oder eine astronomisch vorgegebene Uhrzeit ausgelöst werden
## Powerline:
- **NEU** Änderung des Kennworts für alle Geräte des Powerline-Netzwerks mit einem Klick
# Weitere Verbesserungen im FRITZ!OS 8.03
## Internet:
- **Behoben** Bei Nutzung bestimmter Mobilfunksticks hat der Fallback auf Mobilfunk im Erweiterten Ausfallschutz nicht funktioniert
- **Behoben** Manchmal wurden E-Mails über den Push Service oder MyFRITZ!Net mit leeren Anmelde-Informationen versendet
## Telefonie:
- **Behoben** In Österreich (Country Code 43) war die Anwahl der Rufnummerngassen 12, 13 und 14 nur mit Blockwahl möglich
- **Verbesserung** Stabilität von Telefonaten erhöht
# Weitere Verbesserungen im FRITZ!OS 8.01
## DSL:
- **Verbesserung** Bestimmung der Leitungseigenschaften für manche ADSL2+-Gegenstellen optimiert
## Internet:
- **NEU** Internet: Auch IPv6-Daten können nun über einen WireGuard®-VPN-Tunnel übertragen werden
- **NEU** Neuer Online-Monitor informiert zur Auslastung der Internetverbindung und zur Auslastung durch einzelne Netzwerkgeräte
- **Behoben** Der bevorzugte Benutzer zur Vorbelegung der Anmeldung auf der FRITZ!Box beim MyFRITZ!-Internetzugriff wurde nicht an MyFRITZ!Net übermittelt
- **Behoben** Fehlerhafter Eintrag für den NTP-Server im DHCPv6-Reply der FRITZ!Box führte dazu, dass IPv6-Heimnetzgeräte keine gültige Zeit beziehen konnten
- **Behoben** IPv6-Freigaben als "Exposed Host" von Geräten mit delegiertem IPv6-Präfix wurden unter Umständen gelöscht
- **Behoben** OpenWrt-Geräte, die hinter einer FRITZ!Box betrieben wurden, bekamen unter Umständen keine IPv6-Verbindung zum Internet
- **Behoben** Selbstständige Portfreigaben (UPnP) für denselben Port an verschiedenen Heimnetzgeräten funktionierten unter Umständen nicht
- **Behoben** Unter Umständen waren IPSec-VPN-Verbindungen mit der Option, den gesamten Datenverkehr über diese Verbindung zu leiten, nicht funktional
- **Behoben** Unter Umständen wurde Netzwerkverkehr einer angeschlossenen Telefonanlage nicht über ein speziell eingerichtetes VoIP-Interface geroutet
- **Behoben** Unter Umständen wurden E-Mails über den Push Service oder MyFRITZ!Net mit leeren Anmelde-Informationen versendet
- **Behoben** Unter Umständen wurden aktive WireGuard®-Verbindungen beim Hinzufügen oder Löschen von WireGuard®-Verbindungen unterbrochen
- **Behoben** VPN-Verbindungen über WireGuard® waren nicht bei mehreren (kommaseparierten) Domains als Endpunkt-Eintrag möglich
- **Behoben** keine Internetverbindung nach Update auf FRITZ!OS 8.00 bei fehlendem Kennwort in den Zugangsdaten
- **Behoben** Änderungen des Gerätenamens eines Heimnetzgerätes wurden nicht an MyFRITZ!Net übertragen
- **Verbesserung** Auswahl der automatisch fairen Bandbreitenverteilung im Heimnetz einschließlich Ingress-Shaping als eigene Option in den Priorisierungseinstellungen
- **Verbesserung** Bei Freigabe des Internetzugriffs auf FRITZ!Box-Dienste kann eine zusätzliche IP-Sperrliste von AVM verwendet werden
- **Verbesserung** Bei VPN-Netzwerkkopplungen über WireGuard® erfolgt die Auflösung der Domain "fritz.box" im gesamten gekoppelten Netzwerk
- **Verbesserung** Bei VPN-Netzwerkkopplungen über WireGuard® ist die Angabe von Domains der Gegenstelle zur DNS-Auflösung möglich
- **Verbesserung** Detailverbesserungen bei der Ersteinrichtung hinter einem Glasfasermodem (ONT)
- **Verbesserung** EDNS0-Erweiterung für lokale Domains (fritz,box) zur Verbesserung der Interoperabilität mit Linux-System (systemd-resolved) bei Verwendung von DNS-SEC
- **Verbesserung** Genauere Erklärungen bei Fehlern während der Einrichtung von WireGuard®-Verbindungen
- **Verbesserung** Hinweis auf ein mögliches Risiko bei Portfreigaben für Port 80 oder 443 ergänzt
- **Verbesserung** Vorauswahl des einfachsten Einrichtungswegs für die Internetanbieter Telekom, Vodafone und EWE bei der Ersteinrichtung am Glasfaseranschluss
- **Verbesserung** Wenn die Systemzeit nicht über die eingerichteten Zeitserver ermittelt werden kann, wird die Systemzeit von einem öffentlichen Zeitserver bezogen
- **Änderung** Bei VPN-Verbindungen über IPSec wird der Hash-Algorithmus MD5 sowie der Verschlüsselungsalgorithmus 3DES aus Sicherheitsgründen nicht mehr unterstützt
- **Änderung** Die IPv6-Option "ULA (Unique Local Address) zuweisen, solange keine IPv6-Internetverbindung besteht (empfohlen)" entfällt
- **Änderung** Im PPPoE-Passthrough-Betrieb der FRITZ!Box werden DNS-"Root Queries" über UDP nicht mehr gefiltert
- **Änderung** In VPN-Verbindungen über IPSec wird AES-192 als Verschlüsselungsalgorithmus in den Sicherheitsverbindungen (SA) der Phase 2 nicht mehr unterstützt
## WLAN:
- **Behoben** Nach Änderung der SSID am mesh-Master ist der WLAN-Gastzugang an per LAN verbundenen mesh-clients im 5 GHz und 6 GHz Band nicht mehr nutzbar
- **Behoben** Repeater, die am Gastzugang angemeldet waren, wurden nicht als "WLAN-Gäste" gekennzeichnet
- **Behoben** Unnötig langes Blinken der WLAN-LED nach Änderung einer WLAN-Einstellung, wenn kein Gastzugang aktiv ist
- **Verbesserung** Interoperabilität zu div. WLAN-Geräten auf 2.4 GHz verbessert
- **Änderung** Hinweistext bei Auswahl der WLAN-Verschlüsselung "WPA2+WPA3" wurde entfernt
## Mesh:
- **NEU** Mesh: Grafische Übersicht in neuem Design und mit zusätzlichen Funktionen
- **Verbesserung** Details der LAN-Verbindungen zwischen FRITZ!-Produkten werden in der Grafik der Mesh-Übersicht angegeben (Tooltip)
- **Verbesserung** Grafische Darstellung der Mesh-Übersicht erneuert
## Telefonie:
- **Behoben** Bei bestehenden Telefonaten brach die Sprachübertragung unter bestimmten Bedingungen nach einiger Zeit ab
- **Behoben** Registrierung von Rufnummern scheiterte in bestimmten Konstellationen
- **Behoben** Telekom CompanyFlex SIP-Trunk - Abgehende Rufe mit unterdrückter Rufnummer scheiterten
- **Verbesserung** Aufzeichnungen auf dem Anrufbeantworter haben eine höhere Sprachqualität (HD-Audio)
- **Verbesserung** Für den Anbieter "Drillisch GmbH" wird die Option "Verschlüsselte Telefonie aktiveren" angeboten
- **Verbesserung** Für den Anbieter Telekom wurde die Liste der Sprach-Codecs für die Telefonie überarbeitet
- **Verbesserung** In der Anrufliste wird das Land bzw. bei Anrufen aus Deutschland der Ort angezeigt, aus dem der Anruf kommt
- **Verbesserung** Rufnummernreihenfolge in Einträgen des Telefonbuches leichter änderbar
## DECT/FRITZ!Fon:
- **Verbesserung** Anzeige der WLAN-Zugangsdaten kann jetzt für jedes FRITZ!Fon an- oder ausgeschaltet werden
- **Verbesserung** Leichteres Löschen mehrerer E-Mails über die Option "mehrere löschen"
- **Verbesserung** Startbildschirm "Wetter" jetzt in mehreren Ländern nutzbar (Deutschland, Dänemark, Polen, Tschechien, Österreich, Schweiz, Frankreich, Luxemburg, Belgien, Niederlande, Italien, Liechtenstein)
## Heimnetz:
- **Verbesserung** Detaileinstellungen eines Geräts auf der Seite "Heimnetz > Netzwerkverbindungen" wurden neu gestaltet
- **Verbesserung** Fehlerbehandlung und Einstellungen der Geschwindigkeiten für WAN/LAN-Anschlüsse überarbeitet
- **Verbesserung** Zufällige Berechnung der Unique Local Address (ULA, IPv6) nach RFC 4193
## Smart Home:
- **Behoben** Verknüpfung für eine automatische Offset-Anpasssung zwischen einem externen Temperatursensor und einem Heizkörperregler ging bei einem Neustart der FRITZ!Box verloren
- **Verbesserung** Anmeldung von Smart-Home-Geräten über die FRITZ!Box-Benutzeroberfläche vereinfacht
## System:
- **NEU** Push Service: Überarbeitetes Design und mehr Komfort
- **Behoben** Beim Zugang zur FRITZ!Box-Benutzeroberfläche über das Internet (https) fehlten sporadisch einzelne Elemente oder Seiten
- **Behoben** Der Push Service auf Mesh-Repeatern mit Einstellungsübernahme konnte keine Mails versenden
- **Behoben** Die Schaltfläche "Live-TV" für das Magenta TV-Streaming fehlte in der Benutzeroberfläche bei Auflösungen für Smartphone und Tablet
- **Behoben** Nach dem Versand von Ergebnissen der Funktionsdiagnose wurde fälschlicherweise eine Ereignismeldung über geänderte FRITZ!Box-Einstellungen angezeigt
- **Behoben** Nach einem fehlgeschlagenen Download eines FRITZ!OS-Updates wurden unter Umständen keine weiteren Update-Anfragen ausgeführt
- **Behoben** Neustart der FRITZ!Box über die Benutzeroberfläche unter Umständen nicht erfolgreich
- **Behoben** in der Push Service Mail "FRITZ!Box-Info" war der Status der Portfreigaben immer inaktiv
- **Behoben** obwohl der Push Service funktionierte, scheiterte der Versand der Testmail zum Anbieter GMX, wenn der Absendername Umlaute enthielt
- **Verbesserung** Ein persönlicher Betreff für den Push Service kann festgelegt werden
- **Verbesserung** Einrichtung des Push Service überarbeitet
- **Verbesserung** Kommunikation zu allen AVM- Diensten für die FRITZ!Box (Update etc.) bevorzugt über IPv6, alternativ über IPv4
- **Verbesserung** Link zum Zurücksetzen des Kennworts in der E-Mail "Kennwort vergessen" robuster
- **Verbesserung** Mit "Diagnose > Funktion" werden die Dienste für das Network Time Protocol geprüft und bei Fehlern entsprechende Hinweise angezeigt
- **Verbesserung** Vereinfachte Adressänderungen im Push Service durch den neuen Standardempfänger, der unabhängig vom Absender festgelegt werden kann
- **Änderung** Der vom Push Service "Kennwort vergessen" erzeugte Link in der E-Mail ist 20 Minuten lang gültig
## Mobilfunk:
- **Verbesserung** Antennenausrichthilfe visualisiert bei 5G-NSA-Verbindungen die Werte der jeweils ersten 5G- und 4G-Zelle
- **Verbesserung** Unterstützung für Notrufe via VoLTE in Anbieternetzen mit speziellem Notruf/SOS-APN
## USB:
- **Behoben** In manchen Konstellationen war der Zugriff auf FRITZ!NAS-Inhalte per Download-Link nicht möglich
- **Verbesserung** Energiesparfunktion funktioniert nun auch mit USB-Speichern im Green Mode (USB 2.0)
- **Verbesserung** Von fritz.nas heruntergeladene Datenpakete beinhalten nun zur leichteren Zuordnung den Namen des jeweiligen FRITZ!Box-Modells und einen Zeitstempel im Dateinamen
## Repeater:
- **Verbesserung** Auch auf FRITZ!Repeatern kann ein persönlicher Betreff für den Push Service festgelegt werden
## Verbesserungen in FRITZ!OS 7.62
## Internet:
- **Verbesserung** Umgang mit VLAN-Markierungen an Glasfaseranschlüssen optimiert
## WLAN:
- **Behoben** Anzeige für Zero-Wait-DFS-Funktion auf der Seite "WLAN > Funkkanal > 5 GHz" war bei laufender Untersuchung der Kanäle nicht korrekt
- **Verbesserung** Integration des 6GHz-WLANs auf der Benutzeroberfläche verbessert
## System:
- **Verbesserung** Systemstabilität angehoben
Hinweis: Anleitungen zur Einrichtung und Nutzung der Mesh-Funktionen finden Sie auf https://fritz.com/pages/mesh-mit-fritz
**Hinweise zur Durchführung des Updates:**
Führen Sie das Update über die in der Benutzeroberfläche angebotene Aktualisierungs-Funktion durch. Diese bietet Ihnen automatisch das richtige FRITZ!OS an. Klicken Sie auf "Assistenten", wählen Sie "Update" und folgen Sie den Hinweisen auf dem Bildschirm.
© FRITZ! GmbH 2004 - 2026. Alle Rechte vorbehalten.
Das vorliegende FRITZ! Firmware-Paket enthält Dateien, die unter verschiedenen Lizenzen verbreitet werden, insbesondere unter FRITZ-proprietärer Lizenz oder unter einer Open Source Lizenz (nämlich GNU General Public License, GNU Lesser General Public License oder FreeBSD License). Einzelheiten zu verschiedenen Lizenzen enthält die Datei "license.txt" (https://download.avm.de/fritzbox/license.txt). Der Source Code der als Open Source verbreiteten Dateien kann schriftlich angefordert werden über fritzbox_info@avm.de.
FRITZ! räumt das nicht ausschließliche Recht ein, dieses FRITZ! Firmware-Paket zu nutzen, welches ausschließlich im Object
Code Format überlassen wird. Der Lizenznehmer darf von der Software nur eine Vervielfältigung erstellen, die ausschließlich für Sicherungszwecke verwendet werden darf (Sicherungskopie).
FRITZ! behält sich alle Rechte vor, die nicht ausdrücklich eingeräumt werden. Ohne vorheriges schriftliches Einverständnis
und außer in den gesetzlich gestatteten Fällen darf dieses FRITZ! Firmware-Paket insbesondere weder
- vervielfältigt, verbreitet oder in sonstiger Weise öffentlich zugänglich gemacht werden, noch
- bearbeitet, disassembliert, reverse engineered, übersetzt, dekompiliert oder in sonstiger Weise ganz oder teilweise "geöffnet" und in der Folge weder vervielfältigt, verbreitet noch in sonstiger Weise öffentlich zugänglich gemacht werden.
HKR20260205
Update manuell per Datei eingespielt ohne Probleme - Rest muss sich zeigen.
Hat fast genau ein Jahr gedauert
FRITZ.Box_5690_Pro-08.03.image 05-Feb-2026 13:58 53483520
FRITZ.Box_5690_Pro-08.20.image 05-Feb-2026 13:58 56176640
Richtig war aber bei 1 2025
Hm, war ja der Hoffnung, dass mit der 8.20 mein Pixel 6 sich jetzt mal von allein per 6 Ghz mit der Box verbindet...nö.
Das Einzige, was für mich nützliches dazugekommen ist, ist die Übersicht des Energieverbrauchs der Box und die erweiterten Funktionen des 440ers.
Ich denke das liegt eher an dem Pixel was es da bevorzugt, meine Smartphones haben leider keine WiFi 6e oder 7.
Notebooks nutzen 6 Ghz aktuell zuverlässig.
Betrifft wohl hauptsächlich am Glasfaseranschluß - an DSL merke ich nichts. Wird hoffentlich bald gefixed.
Krass, hatte ich noch nichts von gemerkt, die Box läuft an meinem AON Anschluß absolut stabil.
Der Fritz-Repeater 6700 Pro wird Fritz' schnellster Repeater (heise)
Der Fritz-Repeater 6700 Pro ist der erste WLAN-Repeater von Fritz, der über Wi-Fi 7 im 6-GHz-Band funkt. Insgesamt vier Funkmodule stecken im Gerät: je eins für die 6- und 2,4-GHz-Bänder sowie zwei für 5 GHz.
Das passt dann ja auf den 1. Blick zur 5690 Pro - wenn er POE hätte würde ich drüber nach denken.
Für Kabelverbindungen stellt der Fritz-Repeater 6700 Pro zwei Ethernet-Anschlüsse mit maximalen Übertragungsraten von 10 und 2,5 Gbit/s bereit.
FRITZ! auf dem MWC 2026 (Presseinformation)
8.22 ist raus:
# Neue Funktionen und Verbesserungen in FRITZ!OS 08.22
## Internet:
- **Behoben** Bei Nutzung eines externen Modems konnte es zu einem Interoperabilitätspunkt auf Ethernet-Ebene und daraus resultierend zu einer Performance-Veränderung kommen
- **Behoben** Bei aktivierter Paketbeschleunigung konnte es nach längerer Laufzeit zu Performance-Veränderungen kommen
Update durchgeführt aber ich war ja mit DSL nicht betroffen bisher.
Zyxel NWA130BE - V7.30(ACIL.3)C0
N/A
Bug Fix​
Bug fixCMS
1. [RMID: 67335] [Symptom] The 6 GHz capability is not available when the device operates as a WDS or Smart Mesh repeater.VVV
Known Issue​
Known IssueCMS
1. [SPRID: 240913082] [Symptom] Stations cannot authenticate when an SSID is configured with MLO (4G+5G bands) and the security mode is set to WPA3 with MAC Authentication via RADIUS.V--
2. [SPRID: 241216264] [Symptom] When the WAC5302D-Sv2 model is used as the Root in a Mesh setup, and WiFi 7 series models with firmware versions 00 & 10 are used as Repeaters, the Mesh connection cannot be established.V--
7. [RMID: 64372] [Symptom] When using an SNMP MIB tool to perform an SNMP SET operation on the sysName OID, the SET request reports success; however, the System Name is not updated in the GUI.--V
8. [RMID: 64164] [Symptom] AP status show vlan conflict when Force Overwrite VLAN Config is enabled [Steps] a. AP MGMT > AP Group > Edit Group b. Force Overwrite VLAN Config: Enable MGMT VALN ID: 10 c. As Native VLAN: Enable [Result] AP MGMT > Mgmt. AP List AP show vlan conflict and Mgnt. VLAN ID(AC/AP) show 1-V-
1. [SPRID: 241203097] [Symptom] When the Mesh topology consists of a non-supported MLO Root combined with MLO Repeater Hop1 and Hop2, it may V - - affect the Repeater's downlink and cause issues with the service VAP lacking MLO functionality.
Frisch aus der Entwicklung (Fritz!)
FRITZ!Box 5690 Pro
Download-Informationen:
Version: 8.24-130064
Datum: 04.03.2026
# Verbesserungen innerhalb FRITZ!OS 08.24-1300064
## System:
- **NEU** Slowenisch als Sprache aufgenommen
## Internet:
- **Behoben** Bei gesperrtem Standardprofil in der Kindersicherung konnte es vorkommen, dass sich berechtigte Geräte nicht mehr automatisch im WLAN anmeldeten
- **Behoben** Die Option "Feste Reservierung von Bandbreite für das Heimnetz" war teilweise unwirksam
- **Behoben** Fehlerbehandlung beim Speichern von Priorisierungsregeln war nicht korrekt
- **Behoben** Im Online-Monitor war bei den Verbindungsdetails der Status der WAN-Verbindung unter Umständen trotz einer aktiven Internetverbindung inaktiv
- **Behoben** In der Zusammenfassung individueller Zugangsprofile der Kindersicherung wurde trotz einschränkender Einstellungen "Keine Beschränkung" angezeigt
- **Verbesserung** Bedienung von Zeitplänen in der Kindersicherung für kleine Displays (Handy, Tablets) überarbeitet
- **Verbesserung** Detailliertere Abbildung des Ausfallschutzes im Online-Monitor
- **Verbesserung** Interoperabilität mit neueren Browserversionen verbessert
- **Verbesserung** Unterstützung der IPv6-Konfiguration für den Ausfallschutz
- **Verbesserung** Unterstützung des Ausfallschutzes auch für primäre Internetverbindungen mit fester IP-Konfiguration
- **Änderung** Stammzertifikat für SSL.com für DNS over TLS hinzugefügt
## Telefonie:
- **Änderung** Stammzertifikat für SSL.com für verschlüsseltes VoIP hinzugefügt
## Heimnetz:
- **Behoben** Aktive Geräte mit statischen IP-Adressen wurden unter Umständen als inaktiv angezeigt und umgekehrt
- **Behoben** In der Netzwerkübersicht wurden in bestimmten Szenarien unnötige Einträge für Switches (FA:CE:...) im Abschnitt ungenutzte Verbindungen angezeigt
- **Behoben** Namen von Heimnetzgeräten wurden unter Umständen falsch zugeordnet
## System:
- **Behoben** Bei sehr langsamer Internetanbindungen konnte es vorkommen, dass ein FRITZ!OS-Update über die Benutzeroberfläche vorzeitig abgebrochen wurde
- **Verbesserung** Fehlerbehandlung bei der Updatesuche robuster
- **Verbesserung** Vereinfachte Einrichtung: Bei der Einrichtung internationaler Produkte ist kein Neustart nach Auswahl von Land und Sprache mehr nötig
## DSL:
- **Behoben** Mögliche Probleme beim Aufbau der PPPoE-Sitzung an problematischen DSL-Anschlüssen
## Internet:
- **Behoben** Anzeige der DNS-Server in den Verbindungsdetails des Online-Monitors war in bestimmten Szenarien nicht komplett
- **Behoben** Online-Zähler blieb bei Verbindungen über Mobilfunk auf 0
- **Verbesserung** Tooltips im Online-Monitor übersichtlicher durch Ausblenden von Einträgen mit 0 Mbit/s
## WLAN:
- **Behoben** Inaktive WLANs wurden nicht auf der Übersichtsseite angezeigt
- **Behoben** Verschiedene Anmeldeprobleme mit WLAN-Geräten
## System:
- **Behoben** Aktualisierungen innerhalb einiger Seiten erfolgten nicht mehr automatisch
## USB:
- **Behoben** Unter Umständen zeigte die Benutzeroberfläche eine leere Seite
Zusätzliches Feedback zum FRITZ!OS
Neben dem direkten Feedback in unserem Labor-Bereich fritz.com/fritz-labor gibt es
in der Benutzeroberfläche Ihrer FRITZ!Box drei zusätzliche Feedbackfunktionen,
deren Informationen wir automatisiert verarbeiten können.
1) WLAN-Feedback =>> WLAN/Funknetz/Feedback-Symbol hinter den Clients
2) VoIP-Feedback =>> Telefonie/Eigene Rufnummern/Sprachübertragung - Spalte Sonstiges: Feedback-Symbol hinter dem Telefonat
Laborversion gestern Nachmittag eingespielt, bisher keine Auffälligkeiten mit meinem Setup an DSL.
Also nicht umsonst wird beim dem Video "Dauerwerbesendung" angezeigt, es fehlt komplett das nennen von Alternativen zu Fritz! wenn der
Anbieter einem ein Glasfasermodem stellt. Persönlich würde ich da auf keinen Router mehr von Fritz! setzen.
Guten Morgen
"Persönlich würde ich da auf keinen Router mehr von Fritz! setzen."
Warum würdest Du auf keinen Router mehr von Fritz! setzen?
Gibt es denn sehr gute alternativen? Hast Du persöhnliche Erfahrung und was würdest Du empfehlen?
Nun das hängt von den eigenen Ansprüchen ab, mir sind aktuell schnelle LAN Ports und WiFi 7 mit 6 Ghz Band wichtig.
Und da bietet Fritz! aktuell nichts, die 5690 Pro die ich aktuell habe disqualifiziert sich hinter einem Glasfasermodem dadurch
das dann der einzige 2,5 GB Port als WAN Port weg ist. Für WLAN in das lokale Netz bleiben dann nur 1 GB Ports über.
Alle andere Fritz! Boxen bieten kein 6 Ghz Band. Das ist nicht nur schneller bei der Datenübertrauung sondern es entfällt
auch die Radarunterbrechungen/ZWDFS wie im 5 Ghz Band.
Eigene Erfahrungen bisher nicht mit aktuellen Geräten - der Zyxel NWA130BE ist ja nur ein Accespoint mit dem ich allerdings
sehr zufrieden bin.
Ich denke es würde wohl ein ASUS Router mit entsprechender Ausstattung werden (Triband mit 2,4, 5 und 6 Ghz und 10G LAN Ports).
Die Konfigmöglichen die ich in Reviews gesehen habe sind umfangreich und es gibt keine ABO-Fallen wie bei TP-Link, Netgear oder anderen.
Welcher genau würde ich dann entschieden sollte das aktuell werden und was ich ausgeben möchte.
Sollte ich dann das Fritzfon und die DECT Telefone weiter benutzen wollen könnte dann eine vorhandene auch ältere Fritz!Box dienen.
Oder ich spare mir das weil eh kaum genutzt. SmartHome nutzte ich nicht und ist auch nicht geplant.
Wie geschrieben hängt auch von den eigenen Ansprüchen ab.
Vielen Dank für die Info. Über dieses Thema können wir auch später noch mal sprechen (schreiben) :D
