Download Bei Boinc schlägts 7 !
User-News
Von Crashtest
Die Entwicklung von BOINC hat nunmehr die Version 7.0.2 erreicht !
Changelog
- Mac installer: There can now be multiple instances of the Manager
running, so shut them all down.
- client/scheduler:
If the file "client_opaque.txt" exists on the client,
include its contents in scheduler request messages.
On the scheduler, parse this into SCHEDULER_REQUEST::client_opaque,
where it can be used by the customizable scheduler functions.
- Mgr: Don't call Simple View specific periodic RPCs when BOINC is
hidden or minimized.
- client: show error messages (as notices) when get an error
parsing cc_config.xml
- client: if an <exclude_cpu> element in cc_config.xml
specifies a nonexistent app, show an error msg with
a list of existing app names
- client: improve messages for the above
- Mgr: In CSimpleTaskPanel, change name of Update() to UpdatePanel()
to fix compiler warning about overloading wxWindow::Update().
- MGR: Limit change of 9 November to only Debug builds: accept and
ignore command line argument "-NSDocumentRevisionsDebugMode=YES"
- client: add some missing items to CONFIG::parse_options_client().
- MGR: use wxBitmapComboBox insert() and append() calls without
client data argument instead of passing NULL.
Remove include of boinc_cl.h from parse.h; it is no longer needed.
Remove Mac Availability Macro and weak-link support from cl_boin.ch
as it prevented building BOINC libraries under OS 10.5.
- MGR: Fix button font sizes in Simple View Projects panel.
- client: on network_available() GUI RPC,
clear project-level upload and download backoffs,
as well as RPC and individual xfer backoffs.
This was an oversight.
- MGR: Hide slideshow subpanel if no slides for current task.
- MGR: In Simple View, draw Mac progress bar on white background for
better visibility; adjust red New Notices ring for new button
shapes if on Mac OS 10.7.
- MGR: const fixes for platform bitmaps.
(From: Steffen M?ller)
- MGR: Add trace statements to help track down RemoveAt bug
- MGR: Remove static var guard, may not be needed with the SetDlgOpen()
routines blocking timer based updates. If there is a buffer overrun
hopefully it'll manifest itself in a detectable way.
- MGR: Prevent crash, check returned pointer of menu entry.
- MGR: Fix bad asserts.
- MGR: Fix bad transparency in default project icon.
- MGR: The asserts were correct; fix minor errors in calling code.
- MGR: In Simple View, if deleting a task above the current selection,
decrement the index of the current selection.
- MGR: In Simple View, reload slide show when task selection changed.
- MGR: In Simple View, sort Project Selection Control; make sorting of
Project and Task Selection controls case-insensitive, fix bugs in
MacBitmapComboBox.cpp.
- GUI RPC client lib: change setsockopt() for receive timeout
to work on Windows. From Fred.
- default screensaver: fix divide-by-zero; code cleanup
- client: fix errors in transferring RAM info between CAL and OpenCL.
(bytes vs MB units, local/global terminology issue).
From Oliver Bock>
- default screensaver: fix build breaks caused by code cleanup above.
- MGR: In Simple View, if task has no slide show, then display the
institution, science area and description.
This is in progress: not yet finished.
- MGR: Continue work on Simple View to display the description if
task has no slide show.
Change all occurrences of "<sup>n</sup>" to "^n"
- MGR: Complete work on Simple View to display the description if
- MGR: Better sizing of Simple View description text box.
- Mac installer: revert to using a wrapper application around installer
package to require a system restart if creating users and groups.
- Mac installer: for files in projects and slots directories, if the
executable-by-owner permission is set, ensure that the
executable-by-group bit is also set.
Homepage : http://boinc.berkeley.edu
Download der Testversion (Betaversion)
Windows 32Bit oder 64Bit
Linux 32Bit oder 64Bit
MacOSX
mehr unter http://boinc.berkeley.edu/dl/?C=M;O=D
bzw auch unter http://boinc.berkeley.edu/download_all.php
Hinweis - hierbei handelt es sich noch um eine Testversion die unter Umständen sehr viele Probleme mit sich bringen kann.
Die aktuelle "Stableversion" ist 6.12.34 - Download über http://boinc.berkeley.edu/download.php
Es gibt auch schon ein Projekt welches Boinc 7 zwingend erwartet:
Albert@Home sofern man die ATI-OpenCL testen möchte. Sobald die Betreiber von Albert zufrieden sind erhält das große Bruderprojekt Einstein@Home ATI/AMD Support !
Was ist BOINC eigentlich:
BOINC dient seit 2002 als plattformübergreifendes Basissystem für Verteiltes Rechnen und ermöglicht so fast jedem Benutzer an wissenschaftlichen Projekten teilzunehmen.
Dies wird zur Krebsforschung, gegen Alzheimer, DNA und RNA-Analyse, für mathematischen, physikalischen und anderen Problemlösungen eingesetzt. So können auch kleinere Universitäten durch haushaltsübliche Computer durch ihre große Anzahl selbst Supercomputer in den Schattenstellen.
Wer kann alles BOINC nutzen:
Grundsätzlich kann jeder BOINC nutzen :
- der einen PC hat auf dem Windows XP oder neuer; ein aktuelles Linux oder Mac OSX läuft.
- man die für die Installtion benötigten Rechte hat (Administrator oder vergleichbar)
- und eine Internetverbindung für die Projekte hat
Aber da BOINC Opensource ist kann man es auf sehr viele verschiedene Systeme portieren zB Playstation3
Mehr dazu im hier im Forum
Beispiel von meinem AMD C-50
03.12.2011 00:31:17 | | No config file found - using defaults
03.12.2011 00:31:18 | | Starting BOINC client version 7.0.2 for windows_x86_64
03.12.2011 00:31:18 | | This a development version of BOINC and may not function properly
03.12.2011 00:31:18 | | log flags: file_xfer, sched_ops, task
03.12.2011 00:31:18 | | Libraries: libcurl/7.21.6 OpenSSL/1.0.0d zlib/1.2.5
03.12.2011 00:31:18 | | Data directory: D:\BOINC.DATA
03.12.2011 00:31:18 | | Running under account Boss
03.12.2011 00:31:18 | | Processor: 2 AuthenticAMD AMD C-50 Processor [Family 20 Model 1 Stepping 0]
03.12.2011 00:31:18 | | Processor: 512.00 KB cache
03.12.2011 00:31:18 | | Processor features: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 htt pni ssse3 cx16 syscall nx lm svm sse4a ibs skinit wdt page1gb rdtscp
03.12.2011 00:31:18 | | OS: Microsoft Windows 7: Home Premium x64 Edition, Service Pack 1, (06.01.7601.00)
03.12.2011 00:31:18 | | Memory: 3.61 GB physical, 7.21 GB virtual
03.12.2011 00:31:18 | | Disk: 135.23 GB total, 21.10 GB free
03.12.2011 00:31:18 | | Local time is UTC +1 hours
03.12.2011 00:31:18 | | VirtualBox version: 4.1.6
03.12.2011 00:31:18 | | ATI GPU 0: AMD Radeon HD 6250/6310 (Wrestler) (CAL version 1.4.1607, 384MB, 351MB available, 88 GFLOPS peak)
03.12.2011 00:31:18 | | OpenCL: ATI GPU 0: Loveland (driver version CAL 1.4.1607 (VM), device version OpenCL 1.1 AMD-APP-SDK-v2.5 (793.1), 768MB)
03.12.2011 00:31:18 | | ATI GPU is OpenCL-capable
03.12.2011 00:31:18 | | Config: GUI RPC allowed from:
03.12.2011 00:31:18 | | Config: 192.168.0.50
03.12.2011 00:31:18 | | Version change (6.12.34 -> 7.0.2)
Heißt das OpenCL unter Linux unterstützt wird ohne irgend welche Umwege?
Linux nutze ich nicht sodass ich dazu nix sagen kann.
Unter Windows mit ATI/AMD GPU läuft es so:
- man benötigt nen aktuellen Catalyst + OpenCL Runtime oder das Stream SDK 2.x
- Boinc lädt CAL und "fertigt" ein COPROC_ATI
- Boinc lädt OpenCL (was den AMD OpenCL Treiber nachlädt) und fertigt danach innerhalb des COPROC_ATI ein COPROC_OPENCL
- bei nVIDIA läufts ähnlich - halt nen aktuellen Forceware verwenden
in der Client-State sieht's so aus
Code:
<host_info>
    <timezone>3600</timezone>
    <domain_name>Fussi</domain_name>
    <ip_addr>192.168.0.20</ip_addr>
    <host_cpid>ENTFERNT</host_cpid>
    <p_ncpus>2</p_ncpus>
    <p_vendor>AuthenticAMD</p_vendor>
    <p_model>AMD C-50 Processor [Family 20 Model 1 Stepping 0]</p_model>
    <p_features>fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 htt pni ssse3 cx16 syscall nx lm svm sse4a ibs skinit wdt page1gb rdtscp</p_features>
    <p_fpops>770865414.821429</p_fpops>
    <p_iops>1764843202.495944</p_iops>
    <p_membw>500000000.000000</p_membw>
    <p_calculated>1322868716.560694</p_calculated>
    <m_nbytes>3870965760.000000</m_nbytes>
    <m_cache>524288.000000</m_cache>
    <m_swap>7740039168.000000</m_swap>
    <d_total>145198415872.000000</d_total>
    <d_free>20878196736.000000</d_free>
    <os_name>Microsoft Windows 7</os_name>
    <os_version>Home Premium x64 Edition, Service Pack 1, (06.01.7601.00)</os_version>
    <virtualbox_version>4.1.6</virtualbox_version>
    <coprocs>
<coproc_ati>
   <count>1</count>
   <name>AMD Radeon HD 6250/6310 (Wrestler)</name>
   <available_ram>368050176.000000</available_ram>
   <have_cal>1</have_cal>
   <have_opencl>1</have_opencl>
   <peak_flops>88000000000.000000</peak_flops>
   <CALVersion>1.4.1607</CALVersion>
   <target>14</target>
   <localRAM>384</localRAM>
   <uncachedRemoteRAM>1653</uncachedRemoteRAM>
   <cachedRemoteRAM>1653</cachedRemoteRAM>
   <engineClock>275</engineClock>
   <memoryClock>533</memoryClock>
   <wavefrontSize>32</wavefrontSize>
   <numberOfSIMD>2</numberOfSIMD>
   <doublePrecision>0</doublePrecision>
   <pitch_alignment>256</pitch_alignment>
   <surface_alignment>4096</surface_alignment>
   <maxResource1DWidth>16384</maxResource1DWidth>
   <maxResource2DWidth>16384</maxResource2DWidth>
   <maxResource2DHeight>16384</maxResource2DHeight>
    <atirt_detected/>
   <coproc_opencl>
      <name>Loveland</name>
      <vendor>Advanced Micro Devices, Inc.</vendor>
      <vendor_id>4098</vendor_id>
      <available>1</available>
      <half_fp_config>0</half_fp_config>
      <single_fp_config>62</single_fp_config>
      <double_fp_config>0</double_fp_config>
      <endian_little>1</endian_little>
      <execution_capabilities>1</execution_capabilities>
      <extensions>cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_gl_sharing cl_amd_device_attribute_query cl_amd_vec3 cl_amd_printf cl_amd_media_ops cl_amd_popcnt cl_khr_d3d10_sharing </extensions>
      <global_mem_size>402653184</global_mem_size>
      <local_mem_size>32768</local_mem_size>
      <max_clock_frequency>275</max_clock_frequency>
      <max_compute_units>2</max_compute_units>
      <opencl_platform_version>OpenCL 1.1 AMD-APP-SDK-v2.5 (793.1)</opencl_platform_version>
      <opencl_device_version>OpenCL 1.1 AMD-APP-SDK-v2.5 (793.1)</opencl_device_version>
      <opencl_driver_version>CAL 1.4.1607 (VM)</opencl_driver_version>
   </coproc_opencl>
</coproc_ati>
    </coprocs>
</host_info>
Sofern das Boincprojekt ein aktuellen Boincserver betreibt und eine entsprechende OpenCL-App hat, sollte es funktionieren ...
Hast du etwas gemerkt das die AMD Graks schneller rechnen?
Wie schneller rechnet ?
Hat idR nix mit Boinc zu tun sondern mit Treiber und Projektapp - ob da ne Boincinstanz läuft ist eigentlich egal immerhin laufen die Projektapp auch ohne Boinc ...
Bei AMD war bisher OpenCL langsamer als CAL - insb. wenn CAL & Brook extrem handoptimiert (zB von Gispel) sind ;)
Hoffentlich haben sie jetzt endlich Support für Domänen Controller eingebaut!!! Ist ja ärmlich, dass man immer noch mit der 5er Version rumkrebsen muss, wenn man auf nem ADDC auch n bisschen rechnen möchte!
Häh - mein Rechner "Thor" ist ein PDC mit Windows Server 2003 R2.
Ok "offiziel" lässt es sich nicht installieren aber wenn man's per Administratoreninstallation (msiexec /a boinc.msi) installiert - läufts ;)
Jedoch hab ich es bisher noch nicht mit dem 7er Boinc ausprobiert ...
1. ps - http://boinc.berkeley.edu/trac/ticket/652
2. ps - Boinc installiere ich nicht mehr - darauf - ich "überschreib" einfach alle Dateien mit welchen von einer Windows 7 Boinckiste
Hällst du das für eine gute Idee, BOINC auf einem DC laufen zu lassen, auf einem RODC vielleicht...?
Ist der Meldungsraider bei Version 7 wieder drin?
Meldungen ist weiterhin raus aus dem Boinc Manager (nur übers Menü) - jedoch kann man auch weiterhin den guten alten Boinc Manager 6.10.xx verwenden - einfach boinc.dll und boincmgr.exe sichern und bei bedarf die 7er damit überschreiben.
OpenCL & Co Neuerungen sind in der Boinc.exe !
Warum soll ich Boinc nicht auf meinem Mini-Domäny laufen lassen - da läuft doch eh nur Boinc, Datenserver & Co.
- keine Webdienste, kein DFS, kein DHCP, kein DNS, kein Routing etc ... halt nur die Profilverteilung an alle meine Boinckisten sowie die Verwaltung ... ist doch keine
Produktionsumgebung
Nachtrag:
Es geht weiter mit 7.1.X
http://boinc.berkeley.edu/svn/trunk/boinc/checkin_notes
Code:
    - Bump the version number to the next developmental release cycle
      [COLOR="Red"]7.1.x[/COLOR]
        configure.ac
        version.h
Nachtrag 2:
mmm es ist doch schon ein paar Jahre her, dass die von Berkeley den Sprung von Boinc 5 auf Boinc 6 gemacht haben !
Das erste freigegebene Boinc 6 war 6.1.0 vom 30.08.2007 - hat es doch tatsächlich über 4 Jahre für den "Sprung" von 6 auf 7 gedauert ....
Boinc 7.0.2 wird Stabile !
Message: 1
Date: Mon, 5 Dec 2011 11:17:51 -0500
Subject: [boinc_alpha] BOINC 7.0.2 released for all platforms
To: "BOINC Alpha Mailing List" <boinc_alpha@ssl.berkeley.edu>
Message-ID:
<B643B937F068A947882996E585BD9517318C1A@romw-exchange.romwnet.org>
Content-Type: text/plain; charset="iso-8859-1"
Howdy Folks,
Here is the first of the 7.0 clients to be released. That means we are really close to declaring a new stable release and releasing it to the public.
Please go through the client software and report test results for as many test areas as you can.
As always, report bugs here and report test results to http://boinc.berkeley.edu/alpha/.
Thanks in advance.
----- Rom
Update des Startposting mit off. Changelog im Spoiler
Danke für den Tipp. Funktioniert 1A! Und ja, ich halte es für sinnvoll, denn die DCs sind die Server, die sich am meisten langweilen. Morgens n bisschen Anmeldekram, über den Tag verteilt n bisschen DNS und das wars dann schon. Daher eigentlich die idealen Server, die massenhaft Last vertragen können, v.a. da die NICs eigene CPUs haben.
Das Problem liegt zwischen boinccas.dll welche die Boinc User & Gruppen erstellt und Windows SAM - die wollen einfach nicht in nem DC funktionieren.
Aber wenn man etwas Handarbeit verwendet dh per Hand die Sicherheitseinstellungen auf dem DC macht - gehts einwandfrei :)
Was bedeutet denn die Zeile:
Erkennt Boinc nun die Installation von VirtualBox und kann es auch nutzen?
Japp - BOINC erkennt, wenn Oracle VirtualBox 4 installiert ist und kann diese zB bei LHC 2.0 verwenden, da dieses als VM läuft
http://boinc01.cern.ch/test4theory/
Join Test4Theory
•Read our Code of Conduct
•Unsere Regeln und Grundsätze
•Before Attaching to us you must first have an up to date installed version of the VIRTUAL BOX software package. To download Virtual Box if needed see instructions here.
•This project uses BOINC. If you're already running BOINC, select Add Project. If not, download BOINC.
•When prompted, enter
http://lhcathome2.cern.ch/test4theory/
•If you're running a command-line version of BOINC, create an account first.
•If you have any problems, get help here or visit the Forums and Q&A.
ein paar kleine Bugs tauchen auf ..
etwa bei AMD GPUs:
Dank OpenCL werden die GPU-Namen "versaut" zB:
"Loveland" statt "AMD Radeon HD 6250/6310"
oder
"Cypress" statt "AMD Radeon HD 5800 series"
Weiterhin fragt Boinc derzeit recht "spät" nach neuer Arbeit .?!
Auch wenn Boinc 7 noch nicht "stable" ist, wird es schon zwingend benötigt:
Alle AMD/ATI User die Einstein@Home Beta (Albert@Home) testen wollen benötigen zwingend BOINC 7 !
Updated OpenCL requirements
The minimum BOINC client version for OpenCL tasks got raised to 7.0.1 (get it here) as it fixes an important bug.
Links:
Albert@Home
OpenCL-ATI-Info für Albert
Werde da alle ATI/AMD karten unterstützt?
So jetzt hab ich den 7er Boinc aber ich kann mich nirgend wo anmelden. Jedes mal bekomme ich die Meldung Benutzername od. Kennwort ist falsch.
Albert@Home OpenCL App für ATI/AMD läuft auf Radeon ab RV6xx wobei besser RV7xx !
Aufgrund der Laufzeiten sollte es schon eine Radeon HD 57xx, 58xx, 59xx, 67xx, 68xx oder 69xx sein.
Achtung: wegen eines Bugs sollte nur eine GPU aktiv sein - sonst steigt der CPU-Verbrauch gen 100% ... mehr dazu im Fred oder im Albert-Forum
Also Anmeldung klappt bei mir ohne Probleme ... ?!
Gestern hat Berkeley die 7.0.6 auf den Server gelassen - so weit nix "besonderes" ??
Aber seit jenem 7.0.6 gibt es neben den normalen Windowsversionen ( 32 Bit und 64 Bit ) nun auch Versionen gebündelt mit Virtual Box ( 32 Bit und 64 Bit )
Die VBox Varianten erwarten zwingend Oracles Virtualbox 4.1.18 und liefern es gleich mit. Die "normale" Version geht auch ohne !!!!
Mehr dazu im BOINC-Entwicklungsfred
Und ehe dieses Jahr in Germanistan endet - hier noch das Jahresende aka 7.0.7 ;)
Windows 32 und 64 Bit (normal - bisher keine VBox-Variante)
Linux 32 und 64 Bit
und den Rest per http://boinc.berkeley.edu/dl/?C=M;O=D
Bisher gabs nur eine Windowsversion als VBox-Bündle aber keine Linux oder Mac *noahnung* - evtl. war es nur ein Test. Aber bisher gab es dazu auch noch keine Info von Rom W. oder David A. ?!
Auf http://boinc.berkeley.edu/download_all.php sind bisher nur die 7.0.3er oder zum Teil nur die 7.0.2er verlinkt.
So und nu is Ende für dieses Jahr - gutn Rutsch nach 2012 ;)
