Download Display Driver Uninstaller (DDU) V18.0.6.8
- Ersteller pipin
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- 2x 16 GB DDR4 3200
- GeForce GTX 1650
- 27 Zoll Acer + 24 Zoll DELL
- Samsung 980 Pro 256 GB
- diverse
- Fractal Design R5
- Logitech Cordless Desktop
- Logitech G502
- Firefox, Vivaldi
- ▼250 MBit ▲40 MBit
pipin hat Display Driver Uninstaller (DDU) mit einem neuen Updateeintrag aktualisiert:
Display Driver Uninstaller (DDU) V18.0.5.4
Lies den Rest der Aktualisierung…
Changelog:
All: Fixed "Installer\UpgradeCodes" section that was not cleaning up.
Intel: Removal of the IGN folder.
SHA1: F120AF86ACBD26B061BDA0774157A76EEC76BF0E
FritzB
- Märkisch Kongo
- WCG, GPUGrid, SiDock
- gute Frage
- 4x Ryzen 7950X, 4800H, 5600G, 2x RTX 4070 Ti, RTX 3080, GTX 1650 Ti, RTX 4090
- 7950X, 5600G
- jeweils eins
- ganz viel DDR4 und DDR5
- GeForce 4090, 4070 Ti, 3080
- LG UltraGear 27GP850-B
- diverse
- hatter
- Corsair, Seasonic, BQ...
Es gibt eine neue Version:
Display Driver Uninstaller (DDU) V18.0.5.5 Released.
ChangeLog:
AMD : additional files and registry cleanup (pnplockdownfiles region).
Nvidia: additional files and registry cleanup (pnplockdownfiles region).
ChangeLog:
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Changelog:
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Display Driver Uninstaller (DDU) V18.0.5.6
Changelog:
- Intel: Additional registry key removal for "Intel Arc Control".
- Intel: Additional file removal in the windows prefetch folder.
- Translation: Russian.xml update
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Display Driver Uninstaller (DDU) V18.0.5.7
Changelog:
- Intel: Fixed ARP (Add/Remove Programs) for Intel ARC, entry could be gray out.
- Intel: leftover removal with recent driver.
- Nvidia: Additional registry removal within (pnplockdownfiles)
- Translation update: Turkish.xml
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Display Driver Uninstaller (DDU) V18.0.5.8
Changelog:
- Intel: Fixed specific Arc ARP gray out entry for already affected system.(driver 3490 & 3790 only)
- Nvidia: additional audio driver files removal.
- Nvidia: Additional driverfiles.cfg entries.
- AMD: Try to remove AMDKMPFD only when removing AMD GPUs drivers.
- Translation update: Dutch.xml
SHA1: 065FE3A04FE1F98415CCAFBAE86B8CC5EFFF23D9
SHA-256: 6E4E49AC2C3F2281FCB929EEEBC27E2CE2860802357C9EC879BBD8F37BC4E1C7
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Display Driver Uninstaller (DDU) V18.0.5.9
Changelog:
- Intel: Additional removal for "CTA" and "Intel(R) Niagara Falls I2C" drivers
- Intel: Additional removal of registry region "CLSID", "Pnplockdownfiles"
- Driver Store: Additional removal for "CTA" and "Extension" drivers for intel.
- All: HKCR, "Installer\Dependencies" and "package cache" folders cleanup.
- All: Warn the user if they are not at least on .NET Framework 4.8 and close DDU.
- Translations : Hungarian.xml
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Display Driver Uninstaller (DDU) V18.0.6.0
Changelog:
- New DDU installer.
- Intel : Registry Power Settings CleanUP.
- The moment that some DDU messages box appear make more sense now. Thanks to a user feedback.
- There is a new button on the safe mode dialog window that allow to set Windows update search for drivers to default. Thanks to a user feedback.
- Updated LICENSE
- Translation : Swedish.xml
SHA1: 4D3133288F52F9FA1D7C49465B22CF9CD21AAE05
SHA-256: 390F263A4B65AF6A81521E6D5998055E117571DE96FE2C25B6CE6B9CAB513827
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Display Driver Uninstaller (DDU) V18.0.6.1
Changelog:
- NVIDIA: Added an option to prevent the removal of the NVIDIA Control Panel Global / Programs Settings
- All: small optimizations.
- Languages updates: Hungarian.xml, PortugueseBrazil.xml
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Display Driver Uninstaller (DDU) V18.0.6.2
Changelog:
- NVIDIA: Fixed NV Broadcast not working after using DDU and preventing Broadcast to be removed.
- Languages : Hungarian and Russian updates.
SHA1: 2A0F650A2697C9E5951AA5B0DE17ECDA2EA5D64C
SHA-256: 92D37A7C3F74044D454F2F2C653795956FB46D9DC2B2A591B482B0ACD341814D
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Display Driver Uninstaller (DDU) V18.0.6.3
Changelog:
- AMD: Additional registry key removal.
- Intel: Additional registry removal "XeSDK"
- Translation: Bulgarian.xml, Italian.xml, Ukrainian.xml
Known issues:
-Version still show 18.0.6.2 in the application. (fixed, redownload)
SHA1: EEE8F52C21D9263EDCF7E21D921BFA13496D92AA
SHA-256: 21A3E918C263E000EBEE990B16F64117277599FA3734CCA79E6A886A83F7ECF0
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Display Driver Uninstaller (DDU) V18.0.6.4
Changelog:
- AMD: Remove the AMDKMPFD driver from the driver store when applicable.
- DDU: Added new command line arguments: -removemonitors, -removenvidiadirs, -removeamddirs, -remove3dtvplay, -removecrimsoncache, -cleanallgpus
- Language: Swedish.xml
Note: The -cleanallgpus command efficiently cleans all GPUs from all vendors by utilizing maximum cleaning options.
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- GeForce GTX 1650
- diverse
- Fractal Design R5
- Logitech G502
- Firefox, Vivaldi
Display Driver Uninstaller (DDU) V18.0.6.5
Changelog:
-Intel: Added the service removal of : Intel_NF_I2C
-AMD: changed process kill order.
-Translation update: German.xml , Latvian.xml, Spanish.xml, Korean.xml
Known issues:
SHA1: 490A26D6D6767F0B64648A05D928C0297621F0F3
SHA-256: E24D7BE0ECF018516B8DADE396336299CBEDD8449E28C4357FEEDFF2CC1DDB05
P3D-Bot
Bot von P3D
P3D-Bot hat Display Driver Uninstaller (DDU) mit einem neuen Updateeintrag aktualisiert:
Driver Uninstaller (DDU) V18.0.6.6
-Nvidia: Added the removal of lxss (WSL) related files.
-Nvidia: Added the removal of removal of the "streamline" folder.
-Intel: Changed the order of service removal / process kill. This change helps with Arc Control removal in normal mode.
-All: Files removal enhancements.
P3D-Bot
Bot von P3D
Display Driver Uninstaller (DDU) V18.0.6.7
Changelog:
- Intel: Enhanced DriverStore cleanup.
- AMD: Enhanced removal related to AMD OpenCL, AMD-Window component and AMD Noise Suppression.
- All: Reduced the risk of null exception.
- Translation update: Italian.xml
Known issues:
SHA1: E569B43EFE159119506940A172EA7C4703C2A187
SHA-256: C4D12EC1F275609E1DAB7ED1320D03E33B45C468DB5342242FD6569D6B25434B
P3D-Bot
Bot von P3D
Changelog:
-Enhanced the registry cleanup process for better performance.
-Conducted code cleanup to optimize the registry-related operations.
-Specifically addressed the removal of 'nvrtxaudcapxxv' files, improving the overall cleanup process.
-Nvidia: Added the removal of the "OptixCache" folder.
-Monitors: Now automatically remove monitor configurations upon removal.
-All: "UnitedVideo" cleanup enhancements in the registry.
Known issues:
