v1.4.1 (January 17th, 2019)
Added a window with information about the minimum voltage for SOC
Major updated presets for : samsung b-die , samsung d/e-die , hynix cjr , hynix mfr , hynix cjr (timings, voltages)
Minor updated other presets (timings)
Some corrections for debug profile
Other corrections/bug fixes
Nuances
In some presets tRC a multiple of tRFC (better stability and performance)
Hynix MFR V2 profile has been deleted (many users had difficulty choosing the right profile)
tWR's basic recommendation is now 12 (this high timing timing adversely affects stability)
RTT_NOM . Newer BIOS versions should not always have RZQ / 7 (34ohm), sometimes the RZQ/6(40ohm) or disabled has better stability
CAD_BUS. AddrCMDDrvStr slightly increases with the frequency of the RAM, 24-30(ohm) are the optimal value.
New bios allow a slight decrease in SOC voltage (that's why I created a window with information about the minimum voltage
