Eraser war und ist eines der leistungsfähigsten Freeware-Tools zum sicheren Löschen von Daten unter Windows-Betriebssystemen. Über zweieinhalb Jahre nach Erscheinen der letzten Version 5.7 hat <a href="http://www.heidi.ie/" target="b">Heidi Computers</a> nach langer Zeit nun Eraser in der Version 5.8 veröffentlicht, die folgende Änderungern beinhaltet.
<ul><li><i>Option to erase first and last 2k of a file i.e. a ultra quick erase</i></li><li><i>Option to password protect the app from unauthorised usage.</i></li><li><i>Erase files on reboot.</i></li><li><i>Secure moving of files.</i></li><li><i>When erasing recycle bin also erase Norton unerase files.</i></li><li><i>Option to shutdown or reboot after finishing the erase process</i></li></ul>
Eraser 5.8 bietet u.a. folgende Möglichkeiten:
<ul><li><i>Works with Windows 95, 98, ME, NT, 2000, XP and DOS. It works with any drive including IDE, SCSI and RAID. Also CD-RW's.</i></li><li><i>Uses the Guttmann (Default), Pseudorandom Data and US DoD 5220-22.M methods.</i></li><li><i>Erases Files and Folders.</i></li><li><i>Erases Files/Folders that were only previously 'deleted'.</i></li><li><i>Erases all hard drives using 'Darik's Boot and Nuke' method.</i></li><li><i>Erases Index.dat on Reboot</i></li><li><i>Erases Encrypted Files and Drives.</i></li><li><i>Erases FreeSpace on 95, 98, ME, NT, 2000, XP and DOS.</i></li><li><i>Erases contents of the Recycle Bin.</i></li><li><i>Erases Compressed Files and Drives.</i></li><li><i>Erases Network Files, Floppy Disks, CD-RW, DVD-RAM, DVD-RW.</i></li><li><i>Erases Windows Temporary Files.</i></li><li><i>Erases Internet Cookies.</i></li><li><i>Erases Paging (swap) file.</i></li><li><i>Erases Internet Cache.</i></li><li><i>Appears as an 'Erase' option on the Context Menu of Windows Explorer and Recycle Bin.</i></li><li><i>Comes with an Eraser Scheduler that allows you to create user-defined tasks.</i></li><li><i>Defeats File Recovery software applications Hardware tools.</i></li><li><i>Supports FAT32 and NTFS Files Systems.</i></li><li><i>Eraser is easy to use and comes with a dedicated support network.</i></li></ul>
<b>Download:</b> <a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20060403111753">Eraser 5.8 [Windows]</a>
<b>Links zum Thema:</b> <a href="http://www.heidi.ie/eraser/historyfile.php" target="b">Changelog</a>
