Error Code 161 und 47
- Ersteller Piloboy
Piloboy
- /home/piloboy
- Alles
- Einstein@Home LHC@Home
- FX4100
- Asus EEE
- AMD FX4100
- MSI 970A-G43
- Scythe Mine Rev.B+Enermax UC12-AEBS
- 2x 4GB Geil DDR3-1600 enhace Corsa
- Nvidia 8600GT
- NEC MultiSync LCD1850X
- Samsung 250GB
- Thermaltake Mozart TX
- Enermax Liberty 400
- Gentoo
Erhalte öfters den Error Code 161 und 47.
Hat jemand eine Idee woran es liegt
Ab und an habe ich auch den Code 47
Code:
<core_client_version>5.8.15</core_client_version>
<![CDATA[
<stderr_txt>
worker_proxy() called.
about to call amolqc_init().
survived amolqc_init().
About to call worker function, bye.
freeglut ERROR: Function <glutTimerFunc> called without first calling 'glutInit'.
</stderr_txt>
<message>
<file_xfer_error>
<file_name>last_224_peptidexp.1116_0_1</file_name>
<error_code>-161</error_code>
</file_xfer_error>
</message>
Code:
<![CDATA[
<message>
process exited with code 47 (0x2f)
</message>
<stderr_txt>
forrtl: severe (47): write to READONLY file, unit 9, file /var/lib/boinc/slots/1/../../projects/qah.uni-muenster.de/last_357_peptidexp.13613_2_0
Image PC Routine Line Source
Amolqc-preRC1exp- 080FE664 Unknown Unknown Unknown
Amolqc-preRC1exp- 080FE15C Unknown Unknown Unknown
Amolqc-preRC1exp- 080DD44D Unknown Unknown Unknown
Amolqc-preRC1exp- 080AE464 Unknown Unknown Unknown
Amolqc-preRC1exp- 080AE907 Unknown Unknown Unknown
Amolqc-preRC1exp- 080CF4B7 Unknown Unknown Unknown
Amolqc-preRC1exp- 08082230 Unknown Unknown Unknown
Amolqc-preRC1exp- 0807FE1C Unknown Unknown Unknown
Amolqc-preRC1exp- 0809FE9F Unknown Unknown Unknown
Amolqc-preRC1exp- B7C85163 Unknown Unknown Unknown
libpthread.so.0 B7E5B4AB Unknown Unknown Unknown
libc.so.6 B7DC6ABE Unknown Unknown Unknown
</stderr_txt>
EselTreiber
- Hirschberg, BaWü
- Einstein@home
- arxtr: 3960X+RX550+3080 arx03: 1920X+1030GT arx02: Xeon 2697 v3 full Turbo arx04: 3900X+RX580
- HP ProBook 6460b
- AMD 3960X - 200W
- AsRock TRX40 Creator
- Watercool HK IV TR
- 4 x 16 GB G.Skill 3800 15-15-8-12-30
- RTX 3080
- Benq BL2710T, 2560x1440
- Samsung 251 512GB, Samsung 970 Evo plus 512GB, Samsung 830 256GB
- Western Digital Green 1.5 TB
- Onboardzeugs
- Fractal Define S
- Fractal Design Ion+ 660W
- Manjaro
- S.M.S.L. Tripath Class-D Amp, Lautsprecherbau.de BluesBox PC 15
Da wüsste ich auch gerne ne Antwort drauf. Denn auch auf unübertakteten Rechnern die für meinen Account rechnen, benkomme ich neuerdings auch öfters Fehler und WU-Abbrüche. Vor allem *_anthracen_ WUs.
Piloboy
- /home/piloboy
- Alles
- FX4100
- Asus EEE
- AMD FX4100
- MSI 970A-G43
- Nvidia 8600GT
- Samsung 250GB
- Gentoo
Ja genau, auch bei mir ist das der Fall. Hatte auch erst das OC in Verdacht, jedoch auch ohne OC gibts Fehler genug.
Für den Code 161 habe ich folgendes im QMC Forum gefunden
http://qah.uni-muenster.de/forum_thread.php?id=547
Wenn ich das da richtig verstanden habe, solls an den BOINC Clienten selbst liegen.
EselTreiber
- Hirschberg, BaWü
- Einstein@home
- HP ProBook 6460b
- AMD 3960X - 200W
- RTX 3080
- Onboardzeugs
- Fractal Define S
- Manjaro
arghs... jetzt sind sogar 2 riesen-WUs bei 70% auf 2 laptops mit Pentium-M abgeschmiert, die völlig ohne OC und super-kalt laufen. Ich werd bekloppt... das war mit Sicherheit ne Woche Rechnerbetrieb für die Katz'
Piloboy
- /home/piloboy
- Alles
- FX4100
- Asus EEE
- AMD FX4100
- MSI 970A-G43
- Nvidia 8600GT
- Samsung 250GB
- Gentoo
Mit welchen Codes wurden die denn abgebrochen?
EselTreiber
- Hirschberg, BaWü
- Einstein@home
- HP ProBook 6460b
- AMD 3960X - 200W
- RTX 3080
- Onboardzeugs
- Fractal Define S
- Manjaro
Biddeschön:
und einmal:
Also 2 mal die 161. Crap sach ich nur. Und der eine Client weigert sich jetzt strikt, neue Arbeit zu holen. Ich werd hier noch zum Elch...
Code:
stderr out
<core_client_version>5.10.20</core_client_version>
<![CDATA[
<stderr_txt>
Skipping SetThreadName(...)
scene_init() called.
Scene initialized.
Scene initialized.
Scene initialized.
Scene initialized.
</stderr_txt>
<message>
<file_xfer_error>
<file_name>two_agm_anthracene.2578_0_1</file_name>
</file_xfer_error>
</message>
und einmal:
Code:
<![CDATA[
<stderr_txt>
Scene initialized.
Scene initialized.
Scene initialized.
Scene initialized.
Scene initialized.
Scene initialized.
Scene initialized.
Scene initialized.
Scene initialized.
</stderr_txt>
<message>
<file_xfer_error>
<file_name>one2_ad_anthracene.10350_0_1</file_name>
</file_xfer_error>
</message>
Piloboy
- /home/piloboy
- Alles
- FX4100
- Asus EEE
- AMD FX4100
- MSI 970A-G43
- Nvidia 8600GT
- Samsung 250GB
- Gentoo
Manni hat nen Thread bei QMC gestartet, möchte den mal auch hier erwähnen.
http://qah.uni-muenster.de/forum_thread.php?id=596
Und ich selbst frage mal nach dem Code 161 nach.
http://qah.uni-muenster.de/forum_thread.php?id=600
Edit
Überprüft mal ob ihr in den BOINC Einstellungen folgendes auf "yes" gesetzt habt
Es könnte ein Problem sein beim switchen zwischen den Applikationen, wenn ihr mehrer Projekte am laufen habt, oder der PC wurde herunter gefahren (Checkpointing).
Ferner resettet das Projekt vorher einmal und testet dann nochmal.
Edit
Code:
Leave applications in memory while suspended?
(suspended applications will consume swap space if 'yes')
EselTreiber
- Hirschberg, BaWü
- Einstein@home
- HP ProBook 6460b
- AMD 3960X - 200W
- RTX 3080
- Onboardzeugs
- Fractal Define S
- Manjaro
Gut, das werd ich mal ausprobieren bei den Lappys. Dann besuch ich morgen mach die Nachbarn und spiel an den Lappys rum. Dann schreib ich hier wenns was neues gibt.
Piloboy
- /home/piloboy
- Alles
- FX4100
- Asus EEE
- AMD FX4100
- MSI 970A-G43
- Nvidia 8600GT
- Samsung 250GB
- Gentoo
Hast du neue Ergebnisse und hattest du bei den Errors noch andere Projekte mit drin zum rechnen?
EselTreiber
- Hirschberg, BaWü
- Einstein@home
- HP ProBook 6460b
- AMD 3960X - 200W
- RTX 3080
- Onboardzeugs
- Fractal Define S
- Manjaro
nee.. nur QMC. bis jetzt auch noch keine Errors wieder gehabt.
