Download erweiterte Browserrunde: Pale Moon, Vivaldi, Otter, Seamonkey
User-News
Von Unbekannter Krieger
Pale Moon 27.9.0
(2018-04-17)
Pale Moon ist in eine vorübergehende ESR-Phase eingetreten – wie Seamonkey und traditioneller Firefox zuvor.
Alle 27.9.x-Ausgaben werden ESR-Charakter haben, bis mit Version 28 eine neue Basis für Pale Moon etabliert wird.
This is the last major development update for the v27 milestone (codenamed "Tycho").
After this, we will be focusing our efforts for new features entirely on UXP and the new v28 milestone building on it. We will continue to support v27.9 with security and stability updates for a while, but no major new features will be added from this point forward.
Liste der Änderungen:
Changes/fixes:
  • Fixed a number of spec compliance issues in our media subsystem.
  • Added a trailing slash to referrers when policy is set to fix some web compatibility issues.
  • Fixed the property order in Object.getOwnPropertyNames(string) and others for web compatibility.
  • Updated RegExp(RegExp object, flags) to the ES6 standard specification.
  • Changed the embedded font from the no longer free EmojiOne to the open-licensed Twemoji (with additional fixes). This also further extends unicode support to Unicode 10 emoji(s). Please note that as a result, color emoji(s) will look different than before.
  • Adjusted some things in our memory allocator code to provide, among other things, better allocation alignment on Windows.
  • Made the attempt to migrate people from the old sync server domain name to the current one more aggressive. We will be retiring the old pmsync.palemoon.net Sync server address shortly to remove the need for us to maintain a security certificate for it; this preference migration should automatically put everyone on the correct server address (pmsync.palemoon.org) when upgrading.
  • Made reading of the sessionstore synchronous, to speed up startup and prevent the homepage from being loaded when restoring a session.
  • Added a fix to switch to the correct window/tab when a web notification is clicked.
  • Changed the placeholder text to not include "Search" when all search functions from the address bar are disabled.
  • Enabled the use of Skia for canvas on Linux and OSX.
  • Worked around a potential cause for some non-standard bitmapped fonts ending up with incorrect line heights (I'm looking at you, Noto fonts!).
  • Added a workaround for incorrectly-encoded JPEG-XR images with planar alpha. Ultimately, the jxrlib reference implementation should be fixed to encode according to spec.
  • Aligned XCTO:nosniff allowed script MIME types with the updated spec.
  • Improved the logic for storing vector images in the surface cache.
  • Fixed character set handling for XMLHttpRequests.
https://palemoon.org/releasenotes.shtml
Wie immer werden Windows ab 7 und Linux-Distributionen, jeweils in x64- und x86-Fassung, unterstützt.
https://linux.palemoon.org/download/mainline/
https://palemoon.org/palemoon-win64.shtml
https://palemoon.org/palemoon-win32.shtml
https://addons.palemoon.org/language-packs/
https://palemoon.org/palemoon-portable.shtml
Experimentelle oder eher inoffizielle Ausgaben für macOS gibt es ebenfalls:
https://forum.palemoon.org/viewforum.php?f=41&sid=247fca2d81e0548967cf9ba47552eec7
Otter 0.9.98 weekly 224
(2018-04-16)
Nach (PRE) RC 7 und einigen Wochenausgaben sind wir bei Build 224 angekommen.
https://otter-browser.org/
https://sourceforge.net/projects/otter-browser/files/otter-browser-weekly224/
Most important changes since RC 6:
  • added initial version of Links panel;
  • some minor optimizations.
Ich greife diesmal zum Paket otter-browser-win64-weekly224.7z oder otter-browser-win64-weekly224-qtwebengine.7z.
Vivaldi 1.15.1147.36
(2018-04-25)
Vivaldi ist mit einer neuen Hauptversion am Start.
Our new version 1.15 has arrived – giving you even more control over the appearance and functionality of the browser.
Changelog from 1.14 to 1.15
New features
  • Possibility of having an image as window background (VB-36937)
  • “Bookmarks” in the main menu (VB-7980)
  • Access individual panels and toolbars in full screen mode via keyboard shortcuts or quick commands (VB-37039)
Platform
  • [Linux] Pinned icon (GNOME favourites) does not start Vivaldi (VB-36741)
  • [Linux] Save password dialog does not show up (VB-38805)
  • [Mac] Default shortcuts for next/previous tab changed to “?+?+[Arrow]” — used to be “?+?+[Arrow]” (VB-18300)
  • [Mac] Shortcut for emoji not working on Mac OS X in the UI (VB-18960)
  • [Windows] Session lost when restarting Vivaldi before the existing process has fully exited: added “Vivaldi is exiting” dialog (VB-28359)
Media
  • Broken sound from online radio and mp3 files (VB-30381))
  • Slow AAC audio (VB-36469)
Bookmarks
  • Add Bookmark dialog cut off in popup windows (VB-38858)
  • Add option to Delete separator from the context menu (VB-38602)
  • Add possibility to add Separator from blank space (VB-38604)
  • Bookmark indicator does not always update (VB-37274)
  • Cannot create a new bookmark from the context menu (VB-38781)
  • Description may disappear when refreshing thumbnail (VB-37621)
  • Folder menu cover the bookmarks bar item when the bar is on the bottom (VB-10288)
  • It takes a long time to open V-menu with a big set of bookmarks (VB-38162)
  • Main folders from Speed dials are not highlighted (VB-38574)
Downloads
  • Download panel uses incorrect date format (VB-28395)
  • Focus lost when deleting download item (VB-35705)
Notes
  • Add Markdown code highlighting and style improvements (VB-21043)
  • Creating an invalid Markdown Task List causes the notes panel to break (VB-37137)
  • Support display of To-do in notes Markdown: without saved state (VB-36974)
  • Wrong focus styling on buttons and avoid jumping text (VB-38922)
Quick Commands
  • Certain keys do not work on Quick command with US layout keyboard (VB-37119)
  • Make Alt + up / down jump to next / previous section (VB-37005)
  • Make tab cycle through quick commands (VB-38505)
  • Rounded corners on Quick Commands (VB-38719)
  • Always open pages in new tab (VB-28863)
Search Engines
  • Prevent removal of default search engine (VB-38379)
  • Restore buttons overflow (VB-33519)
  • Search engine list scroll on keyboard navigation (VB-36813)
  • Unchecking private search engine does nothing (VB-37671)
Settings
  • Keep UI zoom control in view (VB-32501)
  • Mouse Gestures don’t paint after settings search (VB-38396)
  • Use both columns in Search Settings (VB-38239)
  • Various issues with closing of a settings window (VB-29091)
  • https:// in the welcome page can’t be removed (VB-37146)
Speed Dials
  • Ghost processes after SD reload (VB-38677)
  • Pending thumbnail updates displayed incorrectly in status bar (VB-38918)
  • Tiled SD links open in wrong tile (VB-38891)
  • Update causes timeout (VB-38725)
Themes
  • Improved transparent tabs with background image (VB-37818)
  • Minimum light contrast (VB-26062)
  • Set scheduled theme on window open (VB-36292)
  • When schedule is changed, set theme to schedule (VB-36392)
  • With rounded corners cut part of characters typed in the search field (VB-38752)
Address bar
  • Context menu covers the address bar item when the bar on the bottom (VB-38866)
  • Make tab cycle through address bar results (VB-38616)
  • Update Refresh and Home icons (VB-38767)
Other fixes
  • Capture setting in Status Bar menu should persist after browser restart (VB-37626)
  • Crash dialog isn’t localized (VB-4572)
  • Google Chat is not supported in Vivaldi (VB-39030)
  • Handle before unloading events on tab close in the UI (VB-3984)
  • Handle duplicate keyboard shortcuts more gracefully (VB-5535)
  • Keyboard selection of saved sessions is impossible (VB-35341)
  • Lower default mouse gesture sensitivity (VB-33980)
  • Mark active page in cycler (VB-11010)
  • New window sizing is incorrect (VB-33735)
  • No UI with some –user-agent command line switches (VB-29162)
  • Pinned tabs are lost on multi-windows/monitors scenarios (VB-18997)
  • Popup windows with long titles overlap window controls (VB-35897)
  • Rapid clicks to close tabs resize window (VB-30351)
  • Should use page title when creating desktop shortcut via drag to desktop (VB-18811)
  • Show tab stacks in window menu (VB-38093)
  • Tab count is wrong in the Window Panel (VB-38441)
  • Text for search results on Keyboard Cheat Sheet is misaligned (VB-37872)
  • Visual tab switcher cycling improvement (VB-38565)
  • History: Date range in header of List view not updated to current range (VB-27125)
  • F8 should show the address field when in chrome less or fullscreen modes (VB-34820)
  • Upgraded translations (and added Slovenian)
  • Selected (applicable) security Chromium patches from v66
  • Upgraded Chromium to 65.0.3325.183
https://vivaldi.com/blog/vivaldi-1-15-just-better/
https://vivaldi.com/download/
Pale Moon 27.9.1
(2018-05-07)
Die zweite Veröffentlichung nach Art einer ESR steht im Flur.
This is a maintenance release.
Changes/fixes:
  • Removed the unused/incomplete places protocol handler.
  • Worked around an issue with MSE media without a Track ID. This should help with the playability of some live streams.
  • Ported across jemalloc improvements from UXP.
  • Ported across cairo mutex improvements from UXP.
  • Added support for FFmpeg 4.0/libavcodec 58.
  • Added a fix for Windows 10's "isAlpha()" not being what one would expect in v1803.
Otter 0.9.99 weekly 227
(2018-05-07)
Nach einer Wochenversion und (PRE) RC 8 sind wir bei Build 227 angelangt.
https://sourceforge.net/projects/otter-browser/files/otter-browser-weekly227/
Listen der Änderungen:
  • initial work on feeds reader (not user visible yet);
  • content blocking dialog got status icons.
  • added keyboard shortcut for activating typed history drodown;
  • storage now uses UTC date time and converts it to local time for display purposes;
  • added initial support for global browsing history in QtWebEngine backend (might cause crashes).
  • several enhancements in experimental backend for QtWebEngine (Blink):
  • initial work on global history support;
  • added support for alternative stylesheets;
  • added support for fetching lists of search engines, feeds and links;
  • initial work on Feeds Reader;
  • several bug fixes and some minor optimizations.
  • new action to take page screenshot.
Ich griffe diesmal zum Paket otter-browser-win64-weekly227.7z oder otter-browser-win64-weekly227-qtwebengine.7z.
Vivaldi 1.15.1147.42
(2018-05-15)
Ein Fehlerbehebungs-Update wurde ins Freie entlassen.
Today we release a minor update to 1.15 to address a long-standing Reddit video freeze and some issues present in the initial 1.15 stable release.
The following improvements were made since the initial 1.15 stable release:
  • Regression] Grey Screen with Vivaldi Icon (VB-39738)
  • [Regression] Mouse exit (onmouseleave) events being ignored in Vivaldi UI (VB-38880)
  • [Regression] Search engine dropdown list blocked IME text selection (VB-37068)
  • [Windows 10] Alt gestures do not work on web pages (VB-39669)
  • [Windows 10][Media] Reddit Videos Freeze Vivaldi (VB-31952)
  • Backported applicable Chromium 66 security patches
  • Updated translations
https://vivaldi.com/blog/minor-update-to-vivaldi-1-15/
Pale Moon 27.9.2
(2018-05-18)
Uns erwartet die dritte ESR-hafte Veröffentlichung.
This is a security and stability update.
Changes/fixes:
  • We changed the language strings for softblocked items so people will cry less when we do our job.
  • (CVE-2018-5174) Prevent potential SmartScreen bypass on Windows 10.
  • (CVE-2018-5173) Fixed an issue in the Downloads panel improperly rendering some Unicode characters, allowing for the file name to be spoofed. This could be used to obscure the file extension of potentially executable files from user view in the panel.
  • (CVE-2018-5177) Fixed a vulnerability in the XSLT component leading to a buffer overflow and crash if it occurs.
  • (CVE-2018-5159) Fixed an integer overflow vulnerability in the Skia library resulting in possible out-of-bounds writes.
  • (CVE-2018-5154) Fixed a use-after-free vulnerability while enumerating attributes during SVG animations with clip paths.
  • (CVE-2018-5178) Fixed a buffer overflow during UTF8 to Unicode string conversion within JavaScript with extremely large amounts of data. This vulnerability requires the use of a malicious or vulnerable extension in order to occur.
  • Fixed several stability issues (crashes) and memory safety hazards.
Seamonkey 2.49.3
(2018-05-04)
ESR Nummer 2, diesmal auf Basis von Firefox ESR 52.7.3 und Thunderbird 52.7.0
https://seamonkey-project.org/
https://ftp.mozilla.org/pub/seamonkey/releases/2.49.3/ (Übersicht aller Plattformen)
https://ftp.mozilla.org/pub/seamonkey/releases/2.49.3/win32/de/seamonkey-2.49.3.zip (Direktlink Windows binary/portable deutsch)
Pale Moon 27.9.3
(2018-06-12)
Die vierte ESR-ähnliche Ausgabe steht ins Haus.
This is a security update.
Changes/fixes:
  • (CVE-2017-0381) Ported a patch from libopus upstream. Note, contrary to that report, the libopus maintainers state they don't believe remote code execution was possible, so this was not a critical patch.
  • Fixed an issue with task counting in JS GC.
  • Fixed a use-after-free in DOMProxyHandler::EnsureExpandoObject (thanks to Berk Cem Göksel for reporting).
  • Portable only: Included the previously omitted registry helper. This may in some cases help with file/type associations.
In einem schmalen Rahmen gibt es experimentelle oder eher inoffizielle Ausgaben für bestimmte macOS-Versionen:
Otter 0.9.99 weekly 231
(2018-06-04)
Nach (PRE) RC 9 sind wir bei Build 232 angelangt. Von diesem gibt es jedoch bislang keine und von 231 nur ausgewählte Packages.
https://sourceforge.net/projects/otter-browser/files/otter-browser-weekly231/
Vivaldi 1.15.1147.47
(2018-06-14)
Es wurde an der Sicherheit nachjustiert.
Today we release a minor update to 1.15 with Chromium security patches.
The following improvements were made since the previous 1.15 stable release:
  • Backported applicable Chromium 67 security patches
https://vivaldi.com/blog/minor-update-to-vivaldi-1-15-2/
Vivaldi 1.15.1147.52
(2018-07-02)
Man beschränkt sich auf Fehlerbehebungen.
Today’s minor update to Vivaldi 1.15 resolves a multi-window crash problem.
  • Crash when closing one of multiple windows VB-36171
  • [Linux] Vivaldi will crash if the user installs a third party libffmpeg.so with unresolved dependencies VB-39825
https://vivaldi.com/blog/minor-update-to-vivaldi-1-15-3/
Pale Moon 27.9.4
(2018-07-17)
ESR-artige Ausgabe Nummer 5 ist verfügbar.
This is a security and usability update.
Changes/fixes:
  • Updated the useragent for addons.mozilla.org to work around their "Only with Firefox" discrimination preventing users from downloading themes, old versions of extensions, and other files with Pale Moon.
  • Restricted web access to the moz-icon:// scheme that could potentially be abused to infringe the user's privacy.
  • Prevented various location-based threats. DiD
  • Fixed a potential vulnerability with plugins being redirected to different origins (CVE-2018-12364).
  • Improved the security check for launching executable files (by association) on Windows from the browser. For users who have (most likely accidentally) granted a system-wide waiver for opening these kinds of files without being prompted, this permission has been reset.
  • Fixed an issue with invalid qcms transforms (CVE-2018-12366).
  • Fixed a buffer overflow using the computed size of canvas elements (CVE-2018-12359).
  • Fixed a use-after-free when using focus() (CVE-2018-12360).
  • Added some sanity checks on nsMozIconURI. DiD
  • Fixed an issue in the case the preferences file in the profile would not be writable (e.g. temporary permission issues due to backup, virus scanning or similar external processes).
https://palemoon.org/releasenotes.shtml-> https://palemoon.org/releasenotes-archived.shtml
[STRIKE]https://linux.palemoon.org/download/mainline/
https://palemoon.org/palemoon-win32.shtml[/STRIKE]
==> https://palemoon.org/archived.shtml
Seamonkey 2.49.4
(2018-07-27)
dritte ESR, und zwar auf Basis von Firefox ESR 52.9 und Thunderbird 52.9.1
  • Among the general platform and mail fixes this release contains backported fixes from Thunderbird for the EFAIL security vulnerability.
  • SeaMonkey now uses gtk3 on Linux. If you experience a problem because of this please file a bug and link it to Switch Linux builds to GTK3 with SeaMonkey 2.49. Pleae try another OS theme first. Some of them are buggy and cause problems with SeaMonkey, Thunderbird and Firefox.
https://ftp.mozilla.org/pub/seamonkey/releases/2.49.4/ (Übersicht aller Plattformen)
https://ftp.mozilla.org/pub/seamonkey/releases/2.49.4/win32/de/seamonkey-2.49.4.zip (Direktlink Windows binary/portable deutsch)
Vivaldi 1.15.1147.64
(2018-08-07)
Es werden Sicherheitsflicken serviert.
Today we release a minor update to 1.15 with security fixes.
  • Backported applicable Chromium 68 security patches.
  • Fixed an issue which could be used to confuse the download dialog and unknowingly run an executable
https://vivaldi.com/blog/minor-update-4-for-vivaldi-1-15/
Pale Moon 28.0.0
(2018-08-16)
Der nächste große Punkt des Umbruchs ist erreicht. Pale Moon baut von nun an auf der UXP (Unified XUL Platform) auf.
We are excited to bring you Pale Moon 28.0. This is a new major milestone in Pale Moon's release history.
Aufgrund der zahlreichen beträchtlichen Änderungen rate ich zu einem Backup des Browserprofils (oder der -profile) vor Aktualisierung des Browsers, ob per Profile backup tool oder händisch oder sonstig.
Überblick über die Änderungen:
We are now building on the Unified XUL Platform which has been forked off from Mozilla's mozilla-central at a point before Rust and Quantum to continue focus on the XUL interface language and traditional browser extensions. Many thousands of things have changed since the v27 (AKA "Tycho") versions, which can't possibly all be listed here. Instead, the most pertinent improvements in this new release are highlighted here:
  • SpiderMonkey update: The JavaScript engine has received a major upgrade and now supports all landmark features from the ECMAScript standards as carried by mainstream browsers. This should put an end to the increasing JavaScript issues we've seen due to web frameworks not being browser-agnostic in that respect, or the browser not supporting what websites expect.
  • Goanna update: The layout and rendering engine (Goanna) has been updated to its 4th generation (version 4.*) which brings with it improved compatibility with "trendy" CSS styling techniques that build on a few very specific features (e.g. CSS Grid). Goanna continues to build on tried-and-tested software fallbacks in case hardware acceleration can't be used, and Linux remote desktop users can continue to leverage xrender for speedy remote screen updates in Pale Moon.
  • DOM enhancements: Enhancements in the Document Object Model provides websites with updated APIs to perform their tasks. (e.g. Fetch, WebAnimations, WebCrypto, HTML Input Element Extensions, etc.)
  • Media enhancements: Our media back-end update is, for all intents and purposes, complete. MSE media streaming (for MP4) should be compatible with all major players on the market now. MSE for WebM is still disabled by default due to some compatibility issues that need to be examined, but you may enable this in preferences to e.g. allow 4k video playback on some sites that only offer UHD in WebM format. We now also support playback of FLAC-encoded audio.
  • New: WebGL2 support! Pale Moon now supports the WebGL2 standard for enhanced graphical experiences in 2D and 3D.
  • Devtools have been given a refresh. Just in case you thought they weren't extensive enough yet, some new categories have been added to inspect and manipulate all aspects of web content.
  • Updates to the login manager: Login credentials can now be stored specifically with or without a user name, and selected individually. This is a behavior change from previous, and clicking a password field can now pop-up a selection list of user names for which passwords are stored (if multiple credentials are saved). Clicking the appropriate login name (or date-stamped version if no name is present) will fill in the accompanying password.
What might be more important for people worrying about upgrading to this milestone is what hasn't changed.
  • We continue to support NPAPI plugins.
  • We continue to support complete themes as well as lightweight themes.
  • We continue to offer a fully customizable interface like before. Australis (like seen in Basilisk) is not used.
  • We continue to support XUL overlay, bootstrapped and (deprecated) Jetpack extensions (collectively called "legacy extensions" by Mozilla).
  • We do not include any DRM in the browser (people needing this can use e.g. the Silverlight plugin to play protected content), even though the platform we build on supports it.
Our primary goal has been to lift Pale Moon up to the new platform and as such most changes are "under the hood" and won't be seen in casual use (aside from more things "just working"). We aim to keep your user experience consistent and logical; but some things will have changed, of course. Browser extensions may need updating or may need a different version, for example.
Of course with such a big change of platform, there are some things that have regressed (worked before but no longer work), and we will work on fixing these regressions over time (hopefully with your help).
Reality check: Even though we have extensively tested the browser in daily use for a few months (also thanks to the brave souls on our unstable channel) we don't expect that the browser will be flawless or bug-free. If you find bugs, regressions or issues with the new release, please discuss them on the forum. Let's work together as a community of users to make this the best browser yet!
https://palemoon.org/download.shtml (Windows allgemein)
Nochmals empfehle ich ein Backup des Browserprofils (oder der -profile) vor Umstieg auf die neue Version. Das erreicht man mit dem Profile backup tool, ist jedoch auch händisch oder mit Backup-Software möglich.
Pale Moon 28.0.1
(2018-08-31)
Zwei Fehlerbehebungen vor allem für 32-Bit-Betriebssysteme wurden bereitgestellt (die vorangegangene nur für Windows).
This is a bugfix point release to address serious performance bottlenecks and general run-time issues (UI slowness, crashes, hangs) with the browser. Once again this impacted 32-bit operating systems more severely than 64-bit ones due to its more limited address space that would get flooded with bogus data.
  • Backed out a Mozilla upstream patch causing issues with IPC and texture allocation for the compositor.
  • Backed out a Mozilla upstream patch causing issues with Javascript memory buffer allocation.
Nochmals empfehle ich ein Backup des Browserprofils (oder der -profile) vor Umstieg von 27.x auf 28.y. Das erreicht man mit dem Profile backup tool, ist jedoch auch händisch oder mit Backup-Software möglich.
Otter (PRE) RC 12
(2018-09-01)
Nach diversen Versionen, für die es meist keine fertigen Builds zum Download gab, ist jetzt (PRE) RC 12 verfügbar.
https://sourceforge.net/projects/otter-browser/files/otter-browser-rc12/
Ich greife diesmal zum Paket otter-browser-win64-0.9.99.3-rc12.7z oder otter-browser-win64-0.9.99.3-rc12-qtwebengine.7z.
Pale Moon 28.1.0
(2018-09-20)
Vor bereits einer Woche wurde uns ein Allrounder vorgestellt:
This major update is focused on performance, security and some regression and bug fixes.
  • Updated NSS to 3.38, removed TLS 1.3 draft version check since it's considered final.
  • Reinstated RC4 as an optional encryption cypher for non-standard environments (e.g. old routing/peripheral networked hardware on LAN). RC4 and 3DES are marked weak and disabled, and will never be used in the first handshake with a site, only as last-ditch fallback when specifically enabled (meaning they won't show up on ssllabs' test, for example).
  • Removed Telemetry accumulation calls, automatic timers and stopwatches. This removes a very noticeable performance sink for all operations on all platforms.
  • Fixed many occurrences of discouraged types of memory access for primarily GCC 8 compatibility. This improves overall code security as a defense-in-depth measure.
  • Re-implemented the pref-controlled custom background color for standalone images.
  • Updated session history handling for internal pages. about:logopage is no longer stored in history, and you can choose to store the QuickDial page in history by setting the pref browser.newtabpage.add_to_session_history to true. This is disabled by default (meaning you can't use the "Back" button to go back to the QuickDial page) as a defense-in-depth security measure.
  • Added ui.menu.allow_content_scroll to control whether content can be scrolled if a context menu is open.
  • Fixed incorrect code removal in ipc.
  • Removed support for TLS session caches in TLSServerSocket.
  • Added support for local-ref as SVG xlink:href values.
  • Changed the find bar to be a browser-global toolbar again (like in Pale Moon 27) instead of per-tab. For people who prefer search terms to be saved on a per-tab basis (like with the per-tab findbar previously), this is possible by setting findbar.termPerTab to true. This resolves a number of issues, including styling with lightweight themes not applying to the find bar, and status pop-ups overlapping the find bar.
  • Ported all relevant security fixes from Mozilla's Gecko/62 release, including CVE-2018-12377 and CVE-2018-12379.
  • Restored part of the searchplugin API that was removed by Mozilla, so extensions can provide and save edits to installed search engines.
  • Improved the speed of restoring browsing sessions upon startup.
  • Fixed the "Restore previous session" button sometimes being missing from about:home, while a restorable session would be present.
  • Fixed tab previews in the Windows taskbar (if enabled).
  • Fixed the setting of the new tab page being "My Home Page" so it'll pick up subsequent changes to the home page URL automatically.
  • Removed the Firefox Accounts migrator from Sync.
  • Fixed an issue with the enabled state of number controls if appearances changed.
  • Stopped building ffvpx on 32-bit platforms (except windows) to use the (faster) system-installed lib instead.
  • Re-added a horizontal scroll action option for mouse wheel. (regression)
  • Fixed handling of content language if the locale is changed.
  • Fixed document navigation with the F6 key.
  • Fixed toolbar styling in toolkit themes.
  • Fixed viewing the source of a selection.
https://forum.palemoon.org/viewtopic.php?f=41&t=20503&sid=5765a9c1c363ba9e1b0382aea15183d6#p153137
Ein letztes Mal empfehle ich ein Backup des Browserprofils (oder der -profile) vor Umstieg von 27.x auf 28.y. Das kann man mit dem Profile backup tool anlegen, ist jedoch auch händisch oder mit Backup-Software möglich.
Vivaldi 2.0.1309.29
(2018-09-26)
Vivaldi wurde nach knapp zweieinhalb Jahren auf Version 2.0 gehievt.
Today’s update includes Sync, Resizable Tab Tiling, Floating Web Panels and over 1,500 improvements since the first version of Vivaldi.
This new version of Vivaldi is as flexible as it is robust and reflects how you use the Web today.
Vivaldi 2.0 is a big milestone!
New features
  • Implement Syncing of Bookmarks, settings, etc. (VB-27)
  • Add options to support for floating/overlay panels (VB-18296)
  • Make tiled tabs resizable (VB-5064)
  • List layout for Visual tab cycler (VB-19167)
  • Add predefined shortcuts for moving tabs left and right: Windows/Linux = “Ctrl+Shift+PgUp/PgDn”; macOS = “?+?+?/?” (VB-41415)
  • Tile new tabs in a tab stack (VB-40851)
  • Holding Command/Control opens new tab on history buttons (VB-42075)
  • Web panel suggestions with favicons (VB-42007)
  • More Speed dial suggestions by using favicons (VB-42244)
  • New 2.0 Welcome Page (VB-39395)
  • Updated Default Themes for 2.0: Added “Vivaldi” as our new default theme, replaced “Redmond” with “Beach” (VB-23107)
  • Minimum active tab width setting (VB-42587)
Fixes
Platform
  • Closing and re-opening developer tools causes crash on Windows 7 (VB-40650)
  • Update Installer for 2.0 (VB-40256)
  • Win 8/10 have a feature that allows desktop apps to customise their start menu tiles, make it work in Vivaldi (VB-31931)
  • [Mac][Gestures] Double tap with two fingers to zoom webpage content (VB-7816)
  • [Mac][Media] Treat Mono AAC as Stereo to allow it to work (VB-41624)
  • [Mac][UI] Can’t read information about SSL certificate if address bar is placed at the bottom (VB-11729)
  • [Mac] Change occupied F11 shortcuts to F10 (VB-38180)
  • [Mac] Graphite window controls more graphite (VB-38243)
  • [Mac] Keychain entry has wrong name (VB-9640)
  • [Mac] Tab Stacking settings checkbox remains ticked (VB-39173)
Address bar
  • Localize file size units in address bar (VB-26818)
Bookmarks
  • Bookmarks can be non-reversibly converted to separators (VB-40463)
  • Importing bookmarks from Edge does not work (VB-25227)
  • Saving tabstack with a name as bookmarks doesn’t carry over the name (VB-39426)
Developer tools
  • Allow for local devtools overrides and other confirm infobars to be proxied to the web side (VB-37858)
  • Single key shortcuts triggered when editing in docked devtools (VB-42118)
Downloads
  • Download progress bar round corners (VB-18569)
  • Panel not updating in another window (VB-35892)
  • Panel slows down Vivaldi during startup (VB-40417)
  • Unable to cancel dialog from keyboard (VB-16552)
Extensions
  • Button “options” menu entry missing for options page (VB-27546)
  • Options pages don’t have favicons in tabs (VB-9447)
  • Keyboard shortcuts don’t work (VB-14668)
  • Wrong icon size used for for browser action icon (VB-39808)
History
  • History Manager “Hide info” tooltip (VB-37537)
IME
  • [Address Field] Esc key should close input suggestion list only (VB-40830)
  • [Quick Commands] Esc key should close input suggestion list only (VB-37561)
  • [Search Field] Esc key should close input suggestion list only (VB-40829)
Mouse & Keyboard
  • Add keyboard shortcut handlers to move active tab Left/Right (VB-24572)
  • Esc should close chrome extension (VB-39686)
  • There are some non-reassignable shortcuts (VB-39886)
  • Allow disabling or reassiging the keyboard shortcut (Alt) that opens the Vivaldi menu (VB-12686)
  • It should not be possible to assign same shortcut to two commands (VB-40916)
  • olding (instead of pressing) F1 opens multiple (infinte) “Help-Tabs” (VB-29053)
  • Open next to original tab does not work with mouse gesture (VB-12671)
Notes
  • Copy to Note strips line breaks (VB-9278)
  • Empty after search and adding note (VB-39913)
  • Select note in markdown mode (VB-39360)
  • Separators are still visible in sorted view (VB-39745)
Quick Commands
  • Search does not work if there is a space at the beginning of the line (VB-40199)
Search
  • Add search engine dialog shouldn’t show suggest url (VB-21970)
  • Default search engine in new window (VB-38657)
  • Ensure search engine protocol (VB-37970)
  • Search URL with certain characters crashes settings (VB-28117)
  • Search field history now cleared when Session Only setting in Save Browsing History is selected (VB-34960)
  • Setup only replaces first “%s” (VB-19865)
Settings
  • Hardware acceleration missing in Vivaldi settings (VB-11517)
  • Privacy settings needs a link to privacy page (VB-39542)
Speed Dial
  • Crash upon remove/adding folder (VB-35180)
  • Fade Speed Dial navigation button text (VB-14171)
  • Suggestion scroll bar missing (VB-40871)
  • Use Foreground instead of accent foreground color on folders (VB-40481)
Tabs
  • Cycling in recently used order breaks without the tab cycler enabled (VB-42002)
  • Add tab to stack gives “random” order (VB-5585)
  • Bring favicon background back to accented tabs (VB-20328)
  • Hovering tab close button causes flicker (VB-42769)
  • Inactive tiled start page does not render (VB-42322)
  • Menu icon cut off in native view (VB-39656)
  • Multiple settings tabs (VB-9762)
  • Prevent tabs from receiving accent color, with window image on (VB-42833)
  • Right mouse button + wheel tab cycler stuck after mouse move (VB-41399)
  • Tab order in stacks is broken (VB-39604)
  • Unread indicator overflows to other side of tab (VB-43042)
  • Pinned tab loses pin status when opened as new window (VB-39512)
Themes
  • Checkboxes in Settings Look Like Radio Buttons if Corner Rounding is High (VB-40243)
  • Remove rounding of Vivaldi menu button hit area (VB-24422)
  • Select colors button improvements (VB-42349)
  • The background of the Menu bar does not match with the Tab bar background (VB-37886)
  • Close button on infobar hardly visible with dark theme (VB-40907)
  • Icons remain black in dark theme (VB-42215)
  • Text on infobar hardly readable with dark theme (VB-40395)
  • Inverted favicons in dark themes (VB-39657)
  • Pinned tab audio icon grey instead of black in dark themes (VB-40587)
User interface
  • Add “ – Vivaldi” to the window title (VB-5401)
  • Capture button icon not vertically centered (VB-40407)
  • Enabling UI after exiting video fullscreen (VB-40590)
  • Menu can’t be accessed when “Alt Key for Main Menu” is disabled (VB-40899)
  • New tab input field locked with about:blank (VB-35016)
  • Bottom part of menu bar in native window is invisible when tab bar is not on top (VB-39656)
  • Change strings “ALT” ? “Alt” (VB-40589)
  • Clarify that deleting storage might also delete extension data (VB-41620)
  • Infobar reappears on tab switching (VB-41060)
  • Page Action “Filter Invert” fails (VB-10695)
  • Scroll bars resilient to corner rounding and more at home on Windows (VB-41576)
  • Status info overlay stays open until you click the page (VB-11943)
  • Text height is different between address field and search field (VB-39967)
  • Wrong font for Traditional Chinese in the bookmarks bar and settings page (VB-42064)
  • Add en-GB locale (VB-34706)
Web Panel
  • Update the mobile user agent (VB-40752)
Other fixes
  • Links from Google Hangouts open in Hangouts pseudo-tab, not in main window tab (VB-37469)
  • Reload image context menu item does not work (VB-43408)
  • Save Capture to File from Menu Always saves as PNG (VB-34841)
  • Simulate browser restart is broken (VB-34851)
  • UA spoof meet.google.com (VB-39784)
  • Update CSS filters to not invert videos (VB-38170)
  • When the UI process crashes, restart the application (VB-40388)
  • Wrong window focus after opening URL from other application (VB-21856)
  • Upgraded to Chromium 69.0.3497.102
https://vivaldi.com/blog/vivaldi-2-0-your-browser-matters/
https://vivaldi.com/changelog-vivaldi-1-15-to-2-0/
Vivaldi 2.1.1337.36
(2018-10-25)
Vivaldi erreichte kürzlich die nächste Haltestelle.
After a phenomenal response to Vivaldi 2.0, we are moving ahead swiftly. […] This time around our focus is squarely on Quick Commands. […]
This update brings video standards to the forefront, supporting Open Media Video 1 (AV1). [Korrektur durch Unbekannter Krieger]
Changelog from 2.0 to 2.1:
New features
  • [Quick Commands] Create new Note ((VB-44612)
  • [Quick Commands] Notes search (VB-36441)
  • [Quick Commands] UI Zoom and support for command line parameters (VB-43080)
  • [Quick Commands] Open items in a new tab via modifier keys (VB-43647
  • [Media] Enable support for AV1 (VB-44942)
Fixes
Platform
  • [Linux] Tab dragging causes flicker and dropping is difficult (VB-44433)
  • [Mac] Facebook voice messages don’t play (VB-43812)
  • [Mac] Overlapped navigation buttons in full-screen mode (VB-3629)
  • [Mac] Tab spacing setting should not apply to maximized window (VB-44300)
  • [Mac] Gray out main menu items when no windows are open (VB-41245)
  • [Mac] Site info popup location sometimes is wrong when the address bar is located at the bottom (VB-44784)
Notes
  • Allow creating a note from dragged text into closed Notes Panel (VB-25864)
  • Double-clicking a note without a URL goes to the start page in the current tab(VB-44645
  • Add notes search option to Quick Commands settings (VB-44619)
  • Focus lost when deleting more than one note (VB-44512)
  • Focus lost when deleting empty note (VB-44781)
Sync
  • Enforce Sync encryption password length (12 symbols) (VB-44791)
  • Impossible to login via proxy (VB-36006)
Tabs
  • Casting of background tabs (VB-43642)
  • Flickering and missing active state in tab stack container (VB-44289)
  • The indicator on the individual grouped tabs is not visible in some themes (VB-44334)
  • Tab added to the stack as first, not last (VB-23311)
Quick Commands
  • Increase visibility of titles (VB-44616)
Extension
  • Wrong about page from extension tray menu (VB-43698)
Search
  • Add keyboard action for searching with selected text in page (VB-26053)
Theme
  • Pages without favicon should fall back to accent color (VB-44490)
User Interface
  • Unify default document icons (VB-44683)
Web Panel
  • Title update enables badges on panel button icons (VB-24130)
Window Panel
  • Reopen doesn’t work for selected window (VB-40745)
Other
  • [Accessibility] Access Keys don’t work (VB-7157)
  • [Accessibility] Search engine context menu doesn’t work when using the keyboard(VB-36814)
  • Crash when deleting bookmarks on the panel (VB-42284)
  • Extension toggle gets hidden by extension icon when the address bar is at the bottom (VB-43809)
  • Incorrect internal pages favicons when hibernated (VB-43313)
  • Settings in the tab can overflow container (VB-43649)
  • Tiling 3 tabs to grid is broken (VB-43198)
  • Cannot close side menu on Gmail (VB-42474)
  • Crash in the ‚Scroll To Top Button‘ extension settings (VB-42128)
  • Settings does not always show the correct section when opened in an external window (VB-43662)
  • Triple-clicking a folder in the bookmarks panel activates edit and expands the folder(VB-38179)
  • Make `vivaldi://restart` and `vivaldi://quit` work (VB-36299)
  • Upgraded Chromium to 70.0.3538.77
https://vivaldi.com/de/blog/vivaldi-2-1-launches-with-improved-quick-commands/
Pale Moon 28.2.1
(2018-11-16)
Fast zwei Monate hielt sich die vorherige Version, Respekt! Nun wird uns ein ausgebesserter neuer Meilenstein geboten:
Version 28.2.0 schrieb:
This is a major development and bugfix release.
+ (drei Tage später, also flott unschädlich gemacht)
Version 28.2.1 schrieb:
This is a bugfix release to address critical usability issues with the bookmarks/history window.
  • Fixed a major performance issue with web workers.
  • Fixed a rare crash on local networks with HTTP basic auth and unsupported cipher suites.
  • Fixed a performance/timer issue when leaving the browser idle.
  • Fixed an issue causing an empty dialog when launching executable files from the browser.
  • Fixed an issue preventing making entries to disallow sites to store data for off-line use.
  • Removed code to prevent extensions with binary components.
  • Fixed an issue with common dialogs being sized incorrectly for their content.
  • Fixed an issue with event handling on the tab bar that would cause frustrating behavior when trying to open/close tabs in rapid succession.
  • Switched default behavior for scrolling when a context or pop-up menu is open to allow scrolling, like in v27. This also affects scrolling in very long menus, e.g. bookmarks.
  • Added experimental Asynchronous Panning and Zooming (APZ) for desktop use.
  • Re-enabled the use and parsing of ICC v4 color profiles.
  • Removed telemetry code from the caching subsystem.
  • Improved full-screen detection for suppressing status messages.
  • Made all arguments passed to Init*Event() optional except the first for parity with other browsers.
  • Cleaned up some internal installer code.
  • Fixed making caret width configurable when dealing with CJK characters (regression).
  • Fixed drawing of table borders consistently when zooming a page (regression).
  • Exposed the "Save download location per site" pref in about:config.
  • Improved media handling (ongoing).
  • Added experimental support for AV1 in WebM videos (disabled by default).
  • Note: this is for WebM only for now, so MP4 and MSE AV1 streams (e.g. YouTube) will not (yet) play.
  • Removed the (defunct and incomplete) in-browser translation code.
  • Fixed an issue with CSS Grid layouts unnecessarily shrinking element blocks.
  • Fixed notification settings menu entry (opes about:permissions with relevant data now).
  • Fixed the launching of an undesirable background content process for capturing page thumbnails.
  • Fixed a focus issue in the bookmark properties dialog.
  • Changed the setting for reporting CSS errors to the console to false by default, to prevent unnecessary performance loss for recording this data.
  • Added control mechanisms for Opportunistic Encryption (both for alternative services and upgrade-insecure-requests) in preferences, and disabled this by default due to potential security and privacy issues with this transitional technology.
  • Updated the default reported Firefox version in Firefox Compatibility Mode to prevent "too old Firefox" complaints on websites.
  • Updated libnestegg, ffvpx, reader view components and several other modules from upstream.
  • Implemented security fixes for CVE-2018-12381, CVE-2017-7797, a better fix for CVE-2018-12386 (DiD), CVE-2018-12401 (DiD), CVE-2018-12398, CVE-2018-12392, several Skia bugs, and several crashes and memory safety hazards that do not have a CVE number.
https://forum.palemoon.org/viewforum.php?f=41&sid=18e45f672bada6b952fc4880f5a9e092
https://forum.palemoon.org/viewtopic.php?f=41&t=20928&sid=6616bf13169982993d53ea8c0d6cad9a#p156670
Vivaldi 2.1.1337.47
(2018-11-13)
Today we release a minor update to 2.1 to address some known regressions and Chromium security fixes.
  • [Regression] Progress bar is not visible VB-44482
  • [Regression] Quick Command type ahead hint garbled VB-45363
  • [Regression] Right clicking a link from a popup window causes Vivaldi to crash VB-45571
  • [Quick Commands] Localized keywords VB-45491
  • Upgraded Chromium to 70.0.3538.103
https://vivaldi.com/blog/minor-update-for-vivaldi-2-1/
Pale Moon 28.2.2
(2018-12-06)
Vor bald anderthalb Wochen – ich bin furchtbar spät dran – wurde mit der nächsten Ausbesserung nachgelegt:
This is a minor update to address a few pertinent issues.
  • Changed the about:feeds icon for external applications to a generic icon, since that kind of access to executables is no longer allowed for security reasons.
  • Fixed issues with copying/pasting bookmarks in the Library View.
  • Fixed a crash occurring when using HTTP pipelining over some (broken) proxies.
  • Fixed several issues with animated WebP display (animations stopping, corrupted frames on lossy images, etc.)
  • Fixed an issue with the display of truncated GIF images.
  • Fixed an issue with deleting recent history not working properly.
  • Fixed incorrect duplicate compatibility mode preferences in about:config.
Vivaldi 2.2.1388.34
(2018-12-13)
siehe https://www.planet3dnow.de/cms/42579-vivaldi-2-2/
https://vivaldi.com/de/blog/vivaldi-update-focus-on-details/
https://vivaldi.com/de/download/
Pale Moon 28.3.0
(2019-01-15)
Die erste Version des Jahres 2019 steht zu unser aller Nutzen bereit.
  • Added AV1 support for MP4/MSE videos. Please note that this is a reference library implementation and the upstream decoding lib currently has poor performance for higher resolutions (720p+). This is disabled by default; use the about:config preference media.av1.enabled to enable this codec.
  • Changed the API used for video playback with FFmpeg 58+. This should solve performance issues with VPx.Redesigned the main toolbar icons as SVG images to make them HiDPI compliant.
  • Fixed the sync notification (infobar) icon.
  • Fixed a potential cycle collector resource leak.
  • Added icons and controls to tabs to indicate if sound is playing the tab and if so, allowing the user to mute it with a click.
    This is a native implementation of the API in use in Basilisk and performs the same function as the "expose noisy tabs" extension, although the extension may still be preferred by some for e.g. skinning capabilities. The feature may be disabled with browser.tabs.showAudioPlayingIcon.
  • Removed support for VR hardware.
  • Fixed out-of-bounds sizes for CSS calculation strings.
  • Removed the DirectShow component since it is no longer necessary.
  • Removed Firefox Accounts integration, phase 1:
    Changed the Sync client to the one from Tycho.
    Made Sync optional at build time.
  • Stopped trying to cater to addons.mozilla.org since they no longer offer anything useful to Pale Moon after the Great XUL Extension Purge™.
  • Added an option to process favicons for optimal sized display and removing animations. Enable this with browser.chrome.favicons.process
  • Fixed an incorrect preference reference in feed reader.
  • Fixed an issue with lazy frame construction on display:contents elements. This should solve e.g. the use of mathjax in comments on stackoverflow.
  • Media code improvements and cleanup (ongoing).
  • Updated the DropBox useragent override to solve login issues.
  • Fixed potential crashes due to shutdown observers in VTT and font lists. DiD
  • Enabled some mistakingly-disabled optimizations in the JS JIT compiler.
  • Fixed several potential crashes in JS. DiD
  • Fixed several potential crashes in WebCrypto. DiD
  • Fixed a potential crash in JS Range Analysis. DiD
  • Fixed a potential crash in the layout engine due to combo boxes. DiD
  • Fixed a potential shutdown crash in non-standard environments related to 2D Canvas. DiD
  • Fixed a potential overflow in the PNG writer. DiD
  • Fixed a potential double-free in the MAR signing utility. DiD
  • Fixed an issue where URLs could be extracted cross-origin (CVE-2018-18494).
  • Updated NSPR to v4.20.
  • Updated NSS to 3.41, providing (among other things) full compatibility with the final version of TLS 1.3 on websites.
  • Updated location.protocol to the latest spec.
  • Updated Intersection Observers to the latest spec and enabled them by default.
  • Updated the SQLite lib to 3.26.0.
  • Fixed errors about the login manager's recipeManager not being available (yet).
  • Switched status bar download arrow to SVG.
  • Fixed a crash in IntersectionObservers.
  • Fixed initialization of the Search service from browser code to avoid synchronous init.
  • Added logging of performance warnings to devtools consoles.
  • Fixed favicons in taskbar tab preview listings.
  • Blocked Comodo IS dll < version 6.3 to prevent startup crashes.
  • Fixed issues in the HTML form submit observer module.
  • Limited resolving depth of CSS variables to a sane maximum (fixes cras.sh issue).
  • Removed Mozilla's proprietary constructor on WebAudio's AudioContext, aligning it with the standard specification.
  • Exposed the previously hidden preference in about:config for page thumbnail generation (some people prefer this for local privacy).
  • Aligned Element.ScrollIntoView with the DOM specification. This improves, among other things, compatibility with the React framework.
    DiD This means that the fix is "Defense-in-Depth": It is a fix that does not apply to a (potentially) actively exploitable vulnerability in Pale Moon, but prevents future vulnerabilities caused by the same code, e.g. when surrounding code changes, exposing the problem, or when new attack vectors are discovered.
In einem schmalen Rahmen gibt es von Zeit zu Zeit experimentelle oder eher inoffizielle Ausgaben für bestimmte macOS-Versionen:
Pale Moon 28.4.0
(2019-02-19)
Nach einer kleinen Ausbesserung in Form von Version 28.3.1 wird nun folgende Dicke Berta aus dem Hangar gerollt.
This is a major development, stability and security release.
Changes/fixes:
  • Removed more telemetry code from the platform.
  • Fixed implementation of the IntersectionObserver API to avoid crashes, and enabled it by default.
  • Switched to the new ffmpeg decode API to avoid dropping of frames.
  • Fixed a buffering issue in the WebP decoder that caused intermittent browser crashes.
  • Improved resource-efficiency for internal stopwatch timers.
  • Improved handling of incorrectly-encoded CTTS in media files, resolving some playback issues of videos.
  • Improved the Cycle Collector and Garbage Collector.
  • Improved fullscreen navigation bar handling in the situation it has focus when switching to full screen.
  • Aligned instanceof with the final ES6 spec.
  • Improved Windows DIB (bitmap) clipboard data handling.
  • Exposed TLS 1.3 cipher suite prefs in about:config in case people want to disable them individually.
  • Allowed empty string on the location.search setter to clear URL query parameters from JS.
  • Added a potential fix for external links not opening in the current window/tab (untested).
  • Enabled C++11 thread-safe statics in the entire application.
  • Updated several preferences for integration with the new add-ons site.
Security fixes:
  • Fixed a potential use-after-free in IndexedDB code. (DiD)
  • Improved proxy handling to avoid localhost getting proxied. (CVE-2018-18506)
  • Ported upstream Skia fixes. (CVE-2018-18356, CVE-2018-18335)
  • Fixed an additional Skia issue. (CVE-2019-5785)
  • Fixed several potentially-exploitable memory safety hazards and crashes. (DiD)
  • Fixed a possible data race when performing compacting GC.
aus: https://palemoon.org/releasenotes.shtml
Vivaldi 2.3.1440.61
(2019-03-14)
siehe https://www.planet3dnow.de/cms/44276-vivaldi-2-3
https://vivaldi.com/blog/auto-stacking-tabs
https://vivaldi.com/blog/minor-update-2-for-vivaldi-2-3
https://vivaldi.com/blog/minor-update-3-for-vivaldi-2-3/
https://vivaldi.com/blog/minor-update-4-for-vivaldi-2-3/
https://vivaldi.com/de/blog/minor-update-5-for-vivaldi-2-3/
Otter 1.0.81 weekly 272
(2019-03-18)
Auf die erste "richtig öffentliche" Version 1.0.01 vom 01.01.2019 (nach Build 261) folgten etliche Aktualisierungen, von denen keine fertigen Pakete zum Herunterladen zur Verfügung gestellt wurden. Allerdings wurde nun der Build 272 in die Freiheit entlassen.
https://sourceforge.net/projects/otter-browser/files/otter-browser-weekly272/
Ich greife diesmal zum Paket otter-browser-win64-weekly272.7z.
Pale Moon 28.4.1
(2019-03-27)
Es gibt neue Flicken.
This is a security and bugfix update.
Changes/fixes:
  • Fixed hover state arrows on some controls.
  • Fixed potential denial-of-service issues involving FTP (loading of subresources and spamming errors).
  • Disabled Microsoft Family Safety (Win 8.1) by default. This prevents security issues as a result of a local MitM setup.
  • Added several site-specific overrides (Firefox Send and polyfill.io) to work around website UA-sniffing isues.
  • Implemented the origin-clean algorithm for controlling access to image resources.
  • Cleaned up the helper application service code.
  • Ported applicable security fixes from Mozilla (CVE-2019-9791, CVE-2019-9792, CVE-2019-9796, CVE-2019-9801, CVE-2019-9793, CVE-2019-9794, CVE-2019-9808 and ZDI-CAN-8368).
  • Implemented several defense-in-depth measures (for CVE-2019-9790, CVE-2019-9797, CVE-2019-9804, and a JavaScript issue).
  • Fixed several memory safety hazards and crashes.
  • Binaries are now code-signed again (including the setup program for the installer).
Vivaldi 2.4.1488.36
(2019-04-04)
Diesmal dreht sich fast alles um Vivaldis Bedienung (GUI, Anpassbarkeit, Gesten) und Fehlerbehebungen, siehe https://vivaldi.com/de/blog/vivaldi-2-4-next-level-toolbar-customisation.
https://vivaldi.com/blog/minor-update-for-vivaldi-2-4
Pale Moon 28.5.0
(2019-04-30)
Vor gut einer Woche ging es einen gehörigen Schritt voran.
This is a major development and bugfix update.
Changes/fixes:
  • Redesigned the about box.
  • Added "Check for updates" menu entries to the AppMenu and classic menu (since the About box redesign no longer has application update in it).
  • Restored the app.update.url.override pref for AUS testing/override.
  • Added "Loop" control to html5 video.
  • Fixed a crash with frames (e.g. when using Tile Tabs).
  • Fixed an issue with textarea placeholders (spec compliance).
  • Removed the Windows Maintenance Service one last time.
  • Improved http basic auth DoS heuristics.
  • Fixed an issue on big-endian machines (e.g. PPC64/linux).
  • Removed e10s code from widgets.
  • Preffed the various http "Accept" headers and aligned with the Fetch spec (except for image requests).
  • Aligned URLSearchParams with the spec.
  • Updated several site-specific UA overrides.
  • Fixed "Yet Another special case of a flex frame being the absolute containing block"™
  • Fixed border drawing when the tab bar is hidden.
  • Pref-controlled and disabled the use of unboxed plain objects in JavaScript's JIT compiler.
  • Improved handling of interrupted connections through proxies and pseudo-VPN extensions.
  • Removed contextual identity.
  • Updated the 7zip installer stub to a much more recent code version.
  • Fixed an issue with applying percentages to 0 in layout sizes.
  • Fixed an issue with calculating linear sums in JS JITed code.
  • Added default value feature to get*Pref() preference functions.
  • Fixed an issue that would occasionally overwrite the new tab custom URL.
  • Updated the SQLite library to 3.27.2
  • Killed the crashreporter toolkit files and exception handler hooks.
  • Fixed an issue with a missing border on the tab bar when on the bottom.
  • Fixed a crash with badly-formatted SVG files.
  • Showed the robots to the exit after squatting in the browser for decades.
  • JavaScript: Implemented TC39 toString() revision proposal.
  • Rearchitectured the JavaScript front-end parser to provide better and more logical parsing of JS code.
  • Removed support code and leftovers for unsupported SunOS, AIX, BEOS, HPUX and OS/2 operating systems.
  • Fixed a scrollbar arrow issue on OS X.
  • Removed all Firefox Accounts code.
  • Made the CSS parser more robust and aligned url() behavior with the CSS3 spec in case of bad input.
  • Fixed an issue with blocklist updates not actually dynamically applying due to a wrong URL.
  • Updated the embedded emoji font to the TweMoji v11.4.0 equivalent.
  • Fixed an issue with async/deferred scripts preventing page loads from completing.
In einem schmalen Rahmen gibt es von Zeit zu Zeit "experimentelle" (eher: inoffizielle) Ausgaben für bestimmte macOS-Versionen:
https://forum.palemoon.org/viewtopic.php?f=41&t=21998#p166005
https://forum.palemoon.org/viewforum.php?f=41&sid=18e45f672bada6b952fc4880f5a9e092 (macOS allgemein)
Vivaldi 2.5.1525.48
(2019-05-29)
Vivaldi springt heute offiziell auf Version 2.5 und… RGB?!
https://vivaldi.com/de/blog/vivaldi-browser-enables-razer-chroma
https://vivaldi.com/blog/minor-update-2-for-vivaldi-2-5 (Chromium-Aktualisierung)
https://vivaldi.com/de/blog/minor-update-3-for-vivaldi-2-5 (nächste Chromium-Aktualisierung)
https://vivaldi.com/de/blog/minor-update-4-for-vivaldi-2-5 (Fehlerbehebung)
Pale Moon 28.5.2
(2019-06-05)
Jüngste Fortschritte: ein Rundum-Putz und ein Gerade-Biegen.
28.5.2 schrieb:
This is a minor update to fix a breaking problem in 28.5.1.
Changes/fixes:
  • Restored a global getBoolPref() function shortcut for extension compatibility with old extensions.
  • If you are currently using this global function, please change it to Services.prefs.getBoolPref()
  • Fixed an issue with the UI when the address bar was removed from the navigation toolbar.
  • Fixed an issue with scripting of the Help menu.
  • Fixed a crash resulting from non-standard manipulation of XML stylesheets by extensions.
  • Fixed Aero Peek (taskbar previews) on Windows.
  • Fixed browser.link.open_newwindow functionality.
  • Removed the default handler for webcal since the site doesn't seem to be properly maintained.
  • Prevented some ways smart places queries could be abused for social engineering attacks.
  • Ported an upstream Skia fix.
  • Improved the origin-clean algorithm for canvases.
  • Improved the efficiency of certain types of memory allocations in the JavaScript compiler.
  • Changed the way the application update checker code is hooked up so it will not require a user to go idle before being activated.
  • This solves the primary issue with application updates not notifying users as promptly as they should; more improvements are slated for the next major release.
  • Applicable security issues fixed: CVE-2019-7317, CVE-2019-11701, CVE-2019-11698, CVE-2019-9817 (DiD), CVE-2019-11700, CVE-2019-11696, CVE-2019-11693, and several potentially exploitable crashes and memory safety hazards that do not have a CVE number assigned to them.
  • Fixed issues with image/texture allocation incorrectly being marked as insecure.
https://forum.palemoon.org/viewtopic.php?f=41&t=22256#p168510
Pale Moon 28.6.0.1
(2019-07-04)
großes Reinemachen und wieder ein Stück vorwärts:
This is a major development update, focusing on under-the-hood improvements and bugfixes, code cleanup, and performance.
geringfügiges Zurechtrücken zwei Tage später:
This is an out-of-band update to fix some pressing issues with the latest release.
Changes/fixes:
  • Implemented String.prototype.trimStart and String.prototype.trimEnd (ES2019)
  • Implemented Array.prototype.flat and Array.prototype.flatMap (ES2019)
  • Implemented Symbol.prototype.description (ES2019)
  • Added support for gzip-compressed SVG-in-Opentype fonts.
  • Updated official branding.
  • Updated reader view components.
  • Added a preference to control the setting of cookies through meta header information (non-standard feature) and disabled by default.
  • Updated ES6 Atomics and re-enabled them.
  • Updated internationalization code to support updated time zones and the Japanese Reiwa era.
  • Updated NSS to a custom version to have better encryption strength for master passwords.
    IMPORTANT: To use this strong encryption and re-key the password database with it, change your master password (can be changed to the same one you already had if desired, but you have to go through the change password process). Depending on your computer and the number of stored passwords, this encryption update may take some time, so please be patient. Please be aware that once re-keyed, the password store will be locked to the new encryption and will no longer be accessible with the master password in older versions of Pale Moon.
  • Restored "Release notes" in the help menu.
  • Rearchitectured the application/extension update code.
  • Added several performance improvements to DOM and the parser.
  • Improved JavaScript garbage collection of dead compartments.
  • Fixed a performance issue with painting on some pages.
  • Improved performance of some websites with complex event regions.
  • Fixed a potential performance issue in display lists on some pages.
  • Fixed a rendering bottleneck for the use of XRender when using a remote session.
  • Fixed graphical artifacts/flickering when using XRender on Intel or Intel-hybrid GPU setups.
  • Added a DiD fix for potential future issues with inlining array natives.
  • Fixed a potential UAF situation in the HTML5 parser (DiD)
  • Fixed an origin-clean bypass issue.
  • Changed the way permissions for predefined sites are loaded.
  • Reverted the 28.5.1 change to treat *.jnlp files as executables (CVE-2019-11696) after input from an Oracle representative. Java Web Start files are not executable and should not be treated any different than regular documents handled by external applications.
  • Removed SecurityUI telemetry.
  • Removed some other dead telemetry code.
  • Removed geo-specific selection of default search engines.
  • Deprecated the use of FUEL.
  • Removed the unused code for "enhanced tiles" in the new tab page.
  • Removed preference to brute-force e10s to on.
  • Removed Unboxed Array code.
  • Removed Unboxed Object code.
  • Fixed failure to print if a page contains a 0-sized <canvas> element.
  • Fixed an issue with tab-modal dialogs being presented in the wrong order.
  • Fixed an issue with the tab bar remaining collapsed in customize mode if normally hidden.
  • Fixed an issue with Sync when choosing to overwrite data with synced data.
  • Fixed an issue with tab previews on the taskbar.
  • Fixed an issue with IntersectionObserver viewport accuracy.
  • Fixed Scroll bar orientation on Mac OS X.
  • Fixed an issue with anchor/link targets not re-using a named target.
  • Fixed a build issue with Gnu-CC on PPC64.
  • Updated the application icon to provide better visuals on Windows classic and other grey backgrounds.
  • Reduced the Master Password hashing rounds to prevent issues with stored password retrieval while still sufficiently strengthening the encryption.
  • If you have previously re-keyed the database after the update to 28.6.0, you should do so again by going through the change master password process to reduce access times.
  • Updated the WhatsApp Web site-specific user-agent override to respond to Google refusing access based on the old string.
  • Updated the branding for the portable launcher.
https://forum.palemoon.org/viewtopic.php?f=41&t=22484&sid=18f74af090845a3fce683ddd24f9e2c3#p170395
Vivaldi 2.6.1566.44
(2019-06-24)
Vivaldi schippert auf Versionszweig 2.6 weiter. Maßnahmen bzgl. Sicherheit, Werbeblockade und Oberflächenpolitur bilden ein nettes Gesamtpaket.
https://vivaldi.com/de/blog/vivaldi-browser-blocks-abusive-ads-improves-profile-management-and-more
https://vivaldi.com/de/blog/minor-update-for-vivaldi-2-6 (Chromium-Aktualisierung u. Anziehen der Schrauben)
Pale Moon 28.6.1
(2019-07-25)
Es gibt Absicherungen und Reparaturen:
This is security and bugfix update.
Liste der Änderungen:
Changes/fixes:
  • Improved handling of FTP resource loading (allow save-as and cater to some FTP-based browsing).
  • Added a preference (security.block_ftp_subresources) to allow users to completely bypass the blocking of FTP subresources if required for their environment, if the improvements made in this release do not suffice.
  • Added blocking of authentication-locked cross-origin image subresources by default to prevent spurious auth prompts.
  • A preference (network.auth.subresource-http-img-XO-auth) was added to allow users to bypass this blocking if required for their environment.
  • Changed the behavior of file: URIs to treat each URI as a unique origin. This prevents cross-file access from scripting.
  • A preference (security.fileuri.unique_origin) was added to allow users to relax this restriction if required for their environment.
  • Implemented a revised version of http2PushedStream to address some thread safety issues.
  • Aligned browser behavior with mainstream regarding inner window behavior when domain is manipulated.
  • Backed out a 28.5.* patch for causing multiple issues in the UI and web content.
  • Updated NSS to 3.41.2 (custom) to pick up several upstream fixes.
  • Fixed a type confusion issue in JavaScript Arrays. (DiD)
  • Added a fix for cross-thread access of Necko. (DiD)
  • Added a port safety check for Alternative Services.
  • Implemented fixes for applicable security issues: CVE-2019-11719, CVE-2019-11711, CVE-2019-11715, CVE-2019-11717, CVE-2019-11714 (DiD), CVE-2019-11729 (DiD), CVE-2019-11727 (DiD), CVE-2019-11730 (DiD), CVE-2019-11713 (DiD) and several networking and memory-safety hazards that do not have CVE numbers.
aus https://palemoon.org/releasenotes.shtml
Vivaldi 2.6.1566.49
(2019-07-19)
Mal wieder wurde Vivaldis Chrom(e) aufpoliert.
https://vivaldi.com/de/blog/minor-update-2-for-vivaldi-2-6
