Download erweiterte Browserrunde: Pale Moon, Vivaldi, Otter, Seamonkey
Pale Moon 28.7.1
(2019-09-12)
Motor-Upgrade und Aufbohrungen:
This is a major development update involving a partial JavaScript engine overhaul and improvement, implementing several website-impacting changes. It should be noted that these changes follow some revisions of specifications (also adopted by mainstream browsers) that are not necessarily backwards compatible for web content as some scripting behavior has changed. If you are targeting Pale Moon specifically (e.g. through ua sniffing) please check and verify the behavior is still as expected.
This is a security and bugfix update.
Liste der Änderungen:
Changes/fixes:
  • Landed a large JavaScript parser tune-up, which as a targeted goal brings our ES6 stringification fully in line with the ES2018 revision for classes, and implements rest/spread parameters for object literals. (Cheers to Luke!)
  • Fixed a crash with the tuned-up parser code when certain error messages were triggered.
  • Aligned browser behavior with mainstream regarding inner window behavior when domain is manipulated.
  • Improved performance dealing with frame properties.
  • Improved performance for handling html5 strings.
  • Improved performance of image content loading.
  • Fixed potential type confusion in array joins.
  • Fixed an issue on some pages causing high CPU usage when wrongly specifying plugin content.
  • Fixed an issue with the add-ons manager "discover" pane if no network connection is present.
  • Fixed an issue with bookmark/history search results offering context menu options that would be invalid without a selection.
  • Fixed the devtools JSON viewer and enabled it by default.
  • Fixed searching from about:home not working for search plugins using the POST method.
  • Fixed an issue with the checkboxes for location bar preferences.
  • Fixed SVG alignment issues if SVG-containing elements fall on odd pixel sizes, causing blurry display of especially small SVGs like icons/glyphs.
  • SVGs will now always be pixel-snapped to provide expected crisp display.
  • Fixed precompilation of Sync client modules when packaging. This also removes the redundant services.sync.enabled pref.
  • Added support for matroska containers and h264-based webm video formats.
  • Added support for AAC audio in matroska and webm video formats.
  • Added support for spaces in the Mac package and application name.
  • Added an exception to the unique file origin policy for font types.
  • Added native file picker support for xdg on Linux.
  • Updated the default bookmark icons.
  • Updated the SQLite lib to 3.29.0.
  • Removed e10s information from about:troubleshooting.
  • Removed hotfix leftovers.
  • Removed the WebIDE developer tool.
  • Removed conditional build-time disabling of the Pale Moon status bar code.
  • Removed "Delete this page" and "Forget about this site" links from live bookmarks (since they make no sense on feeds).
  • Removed the Financial Times' polyfill user-agent override since they updated their detection to work with Pale Moon.
  • Fixed an issue where saving a webpage to disk would sometimes drop tags from the document.
  • Fixed an issue with click-to-play plugin content throwing up a blank notification.
  • Fixed an issue in the renderer where region intersections would sometimes return the wrong result.
  • This fixes a regression caused by the fix for CVE-2016-5252.
  • Fixed security issues: CVE-2019-11744, CVE-2019-11752, CVE-2019-11737, CVE-2019-11746, CVE-2019-11750, CVE-2019-11747 and CVE-2019-11738.
  • Unified XUL Platform Mozilla Security Patch Summary: 7 fixed, 1 DiD, 1 already covered, 22 not applicable.
DiD This means that the fix is "Defense-in-Depth": It is a fix that does not apply to a (potentially) actively exploitable vulnerability in Pale Moon, but prevents future vulnerabilities caused by the same code, e.g. when surrounding code changes, exposing the problem, or when new attack vectors are discovered.
aus https://palemoon.org/releasenotes.shtml
Wie immer werden Windows ab 7 und Linux-Distributionen, jeweils in x64- und x86-Fassung, unterstützt.
https://linux.palemoon.org/download/mainline/
https://palemoon.org/download.shtml (Windows allgemein)
https://addons.palemoon.org/language-packs/
In einem schmalen Rahmen gibt es von Zeit zu Zeit "experimentelle" (eher: inoffizielle) Ausgaben für bestimmte macOS-Versionen:
https://forum.palemoon.org/viewtopic.php?f=41&t=23038#p175794
https://forum.palemoon.org/viewforum.php?f=41&sid=18e45f672bada6b952fc4880f5a9e092 (macOS allgemein)
Vivaldi 2.7.1628.33
(2019-09-04)
Vivaldis tat ebenfalls einige Schritte.
https://vivaldi.com/de/blog/minor-update-3-for-vivaldi-2-6 (nur für Linux)
https://vivaldi.com/de/blog/vivaldi-2-7-bring-more-productivity-to-your-day
https://vivaldi.com/de/blog/minor-update-for-vivaldi-2-7 – vgl. https://www.planet3dnow.de/cms/50613-vivaldi-2-7-update-1 und https://vivaldi.com/de/android
https://vivaldi.com/de/download
Seamonkey 2.49.5
(2019-09-04)
Ich hatte ihn schon aufgegeben. Doch nach knapp 14 Monaten gibt es nun erstaunlicherweise – zumal wie Vivaldi am 04.09.2019 – eine Aktualisierung für Seamonkey. Es handelt sich um die vierte ESR-Fassung in Folge, zum zweiten Mal auf Basis von Firefox ESR 52.9 und Thunderbird 52.9.1.
Based on Mozilla Firefox 52.9 ESR and further enhanced, it delivers those same developments in web technologies such as HTML5, hardware acceleration and improved JavaScript speed.
SeaMonkey 2.49.5 is available in 20 languages, for Windows, MacOS x64 and Linux.
This release adds officially supported Windows x64 and Linux x64 versions. If you want to install the Windows x64 version please download the full installer and uninstall the old x86 release first. Your profile data will be kept during an uninstall. Support for the macOS x86 unified binary is dropped because of using a more current macOS development environment.
https://seamonkey-project.org/
https://ftp.mozilla.org/pub/seamonkey/releases/2.49.5/ (Übersicht aller Plattformen)
https://ftp.mozilla.org/pub/seamonkey/releases/2.49.5/win32/de/seamonkey-2.49.5.zip (Direktlink Windows portable binary deutsch)
https://ftp.mozilla.org/pub/seamonkey/releases/2.49.5/win64/de/seamonkey-2.49.5.zip (Direktlink Windows x64 portable binary deutsch)
Vivaldi 2.8.1664.40
(2019-09-26)
Vivaldi eilte voraus.
https://vivaldi.com/de/blog/minor-update-2-for-vivaldi-2-8
https://vivaldi.com/de/blog/minor-update-for-vivaldi-2-8
https://vivaldi.com/de/blog/vivaldi-2-8-inspires-new-desktop-mobile-experiences – vgl. https://www.planet3dnow.de/cms/50939-vivaldi-2-8
Otter 1.0.81 weekly 300
(2019-09-30)
Anlässlich der 300. Projektwoche gehen die ersten vorgefertigten Builds seit gut 6 Monaten an den Start. Das ist Sparta!
https://otter-browser.org/
https://sourceforge.net/projects/otter-browser/files/otter-browser-weekly300
Ich greife diesmal zum Paket otter-browser-win64-weekly300.7z.
Pale Moon 28.7.2
(2019-10-29)
Wie ging es seit dem letzten hiesigen Beitrag weiter?
Changes/fixes:
  • Disabled the use of ICC color profiles for images on Linux by default.
  • Updated timezone data for internationalization functions.
  • Fixed the option to use hardware acceleration over RDP for Windows 8.1 and 10.
  • Fixed an issue with inner window navigation potentially leaking.
  • Fixed a startup crash caused by Qihoo 360 Safeguard/360 Total Security.
  • Ported some expat parser fixes from upstream.
  • Ported several NSS upstream fixes to our build.
  • Aligned handling of U+0000 in the html5 parser with expectations.
  • Added size checks to WebGL data buffering.
  • Fixed build issues with newer glibc versions.
  • Fixed build issues for ARM targets.
  • Worked around a gcc9 compiler issue that would prevent building with it.
  • Sec bug fixes: CVE-2019-15903, CVE-2019-11757, CVE-2019-11763 and several potentially exploitable crashes and memory safety hazards that don't have a CVE number.
  • Unified XUL Platform Mozilla Security Patch Summary: 6 fixed, DiD, 1 rejected, 24 not applicable.
https://forum.palemoon.org/viewtopic.php?f=41&t=23189#p177487
Vivaldi 2.9.1705.41
(2019-11-08)
https://vivaldi.com/de/blog/vivaldi-2-9-adding-more-to-the-vivaldi-menu-2
https://vivaldi.com/de/blog/minor-update-for-vivaldi-2-9-windows-only
https://vivaldi.com/de/blog/minor-update-2-for-vivaldi-2-9
https://vivaldi.com/de/blog/minor-update-3-for-vivaldi-2-9
[…Hier fehlen mehrere Monate…]
Pale Moon 28.9.0.2
(2020-03-25)
v28.9.0 schrieb:
This is a major development update.
v28.9.0.1 schrieb:
This is a small update to address a breaking issue with user-agent override strings, causing problems on certain websites for a number of our users.
v28.9.0.2 schrieb:
This is a small bugfix update addressing 2 more important issues in 28.9.0:
New features:
  • Implemented asynchronous iterators (await iterator.next() and for await loops) (ES2018)
  • Implemented promise-based media playback.
  • Implemented non-standard legacy CSSStyleSheet rules functions.
  • Implemented the html5 <dialog> element. To switch this on, flip dom.dialog_element.enabled to true.
  • Implemented the optional hiding of pinned tabs in CtrlTab/AllTab panes. (controlled through the preferences browser.ctrlTab.hidePinnedTabs and browser.allTabs.hidePinnedTabs)
  • Added 1.25x playback speed to html media elements.
  • Added a hidden pref (browser.places.smartBookmarks.max) to control the sizes of default smart bookmarks categories.
Changes/fixes:
  • Aligned document.open() with the overhauled specification.
  • Aligned the way DOM styles are computed with mainstream browser behavior.
  • Removed the (unused) DOM promise implementation.
  • Enabled seeking to next frame in media files.
  • Enabled dynamic UA updates for emergency use.
  • Implemented rule processing stub for font-variation-settings.
  • Increased the maximum XML nesting depth to 2048 levels for extreme corner cases and to conservatively align with other browsers.
  • Improved the privacy of geolocation lookup calls, with thanks to a generous service donation from ip-api.com
  • Improved reporting of the operating system in site-specific user-agent overrides.
  • Improved table drawing performance again after the rewrite for sticky positioning making it slower.
  • Updated CSP processing to allow custom scheme wildcards to be specified without a port.
  • Aligned the behavior of outlines with other browsers when dealing with CSS-repositioned elements.
  • Changed the way hardware acceleration is controlled from the application.
  • Changed the default monospace font for main languages from Courier New to Consolas.
  • This provides a more balanced font for fixed-width text that is slightly more condensed and more in line with the naturally compacter variable-width fonts used everywhere else.
  • Changed the browser's behavior when restoring tabs from previous sessions. To prevent stale pages, it will now by default perform a "soft refresh" of the page instead of drawing it purely from cache without checking if the page needs updating. If you prefer the old behavior, set browser.sessionstore.cache_behavior to 0 in about:config.
  • Updated NSPR to 4.24 and NSS to ~3.48.1-RTM, removing the previous custom patch level with NSS being able to support custom rounds for DBM now.
  • For extensive release notes with all NSS changes, see NSS_Releases
  • Implemented an NSS performance optimization for Master Password use with limited effect.
  • Fixed some potential crashing scenarios with WebGL on Linux.
  • Completely removed showModalDialog.
  • Disabled some logging in production builds.
  • Removed various gadgeteering/redundant/dead DOM APIs (casting/presentation, FlyWeb)
  • Removed support for a number of critical libraries being system-supplied.
  • Removed "Copy raw data" button from the troubleshooting information page, since it's never used by us in that format, and users mistakenly keep using it instead of copying text.
  • Removed a bunch of Android and iOS support code.
  • Fixed an issue with form elements sometimes being incorrectly disabled.
  • Fixed several crashes.
  • Fixed an issue with Captive Portal detection sometimes firing even when disabled by the user.
  • Performed various tree-wide code cleanups.
  • Backed out a large code cleanup patch for causing subtle issues in website operation (e.g. WordPress). This will have to be revisited later; the reintroduced code is not in use in practice.
  • Cleaned up the application updater code.
Security-related fixes:
  • Fixed a potential pointer issue in cubeb. DiD
  • Disabled allowing remote jar: URIs by default for security reasons. If you need this functionality for your non-standard environment, you can enable it with the preference network.jar.block-remote-files, but please consider moving away from this method of providing web-based applications.
  • Removed a potentially dangerous and otherwise ineffective optimization from the JavaScript engine.
  • Fixed unwanted behavior where created/focused pop-up windows could potentially cover the DOM fullscreen notification, hiding it from users. (CVE-2020-6810)
  • Fixed an issue where copying data as a curl request from developer tools would not properly escape parameters. (CVE-2020-6811)
  • Updated our sctp library code with several upstream fixes.
  • Unified XUL Platform Mozilla Security Patch Summary: 4 fixed, 3 already mitigated, 1 rejected, 11 not applicable.
  • Fixed an issue with browser migration and initialization code causing various browser run-time problems.
  • Fixed an issue with cache behavior where some users would have trouble having their windows and tabs restored in "soft refresh" mode (see v28.9.0 release notes).
  • To solve this, we reverted to the previous (pull from cache) mode for now while we investigate the cause.
DiD This means that a fix is "Defense-in-Depth": It is a fix that does not apply to a (potentially) actively exploitable vulnerability in Pale Moon, but prevents future vulnerabilities caused by the same code, e.g. when surrounding code changes, exposing the problem, or when new attack vectors are discovered.
https://forum.palemoon.org/viewtopic.php?f=41&t=24052#p186290
Pale Moon 28.9.1
(2020-04-10)
This is a minor security and bugfix release.
  • Re-imported the ExtensionStorage js module for use by browser extensions.
  • Fixed an issue with the WebRequest module having erroneously un-processed build directives in it. This might have caused some subtle breakage.
  • Removed the use of high-resolution Windows system timers from the layout refresh driver; this should help with some performance and battery life issues.
  • Fixed an issue where various parts of hardware acceleration weren't properly linked when changing the option from preferences.
  • If you have changed the preferences option to "use hardware acceleration when available" between 28.9.0 and this release, it is recommended that you go into preferences and toggle the option off/on to the preferred setting to correct any discrepancies.
  • Fixed an issue with building the user-agent string using the build date as ID.
  • Fixed an issue with the release of document content viewers (CVE-2020-6819). DiD
  • Fixed an issue with handling functions with rest parameters. DiD
  • Unified XUL Platform Mozilla Security Patch Summary: 2 Defense-in-depth, 14 not applicable.
https://forum.palemoon.org/viewtopic.php?f=41&t=23071#p176144
Vivaldi 3.0.1874.33
(2020-04-29)
Taufrisch – V3 wurde kürzlich in Stellung gebracht: https://vivaldi.com/de/blog/1-day-2-big-vivaldi-browser-releases
https://vivaldi.com/de/blog/news/minor-update-for-vivaldi-desktop-3-0
https://vivaldi.com/de/blog/news/minor-update-2-for-vivaldi-desktop-3-0
Pale Moon 28.9.2
(2020-04-30)
This is a minor update for stability and compatibility.
  • Re-based the 28.9 version of browsers on a separate development branch that excludes the extensive work being done for Google WebComponents, to avoid potential performance and stability issues caused by as-of-yet incomplete and in-progress code for the new milestone.
  • Enabled DOM High Resolution timestamps for compatibility with websites that strictly rely on them for operation.
  • Added a preference to allow copying the unescaped URL from the address bar (especially useful for internationalized domain names and paths).
  • To enable this, set browser.urlbar.decodeURLsOnCopy to true in about:config
  • Fixed several application crashes (thanks, Fysac!)
https://forum.palemoon.org/viewtopic.php?f=41&t=24305#p188625
Seamonkey 2.53.2
(2020-05-03)
Nach der letzten Version der Linie 2.49.x vom September und der ersten 2.53er-Veröffentlichung vom Februar ist nun eine neue auf Basis von Firefox ESR 60.3 und Thunderbird 60.x (sowie unter Linux gtk3) verfügbar. Die enthaltenen Sicherheitsaktualisierungen sollen sich bis Firefox 74, d. h. Stand April 2020, erstrecken. Also geht es doch voran.
Release Notes:
Release Notes schrieb:
major changes relative to SeaMonkey 2.53.1:
  • Scrollbars have been switched over to the native gtk3 theme in bug 1625754. If your theme does not show scrollbar buttons and you would like to see them try editing ~/.config/gtk-3.0/gtk.css and adding the following:
    -GtkScrollbar-has-backward-stepper: 1;
    -GtkScrollbar-has-forward-stepper: 1;
  • The download progress dialog has been fixed and is now showing the correct status for downloads. Some downloads may not show the transferred count. This problem is under investigation.
  • SeaMonkey is now translated and available in Finnish and Georgian.
  • Because of website compatibility issues and privacy concerns the Lightning version is no longer appended to the user agent string and has been removed from the preferences dialog.
  • Advanced Layers has been activated on Windows. This should boost performance on some websites. If you experience graphics problems please disable it by setting the pref "layers.mlgpu.enabled" to false.
  • Whether the native app chooser is used in Linux is now controlled via a preference setting in the Helper Applications preference pane.
  • In the Modern theme, popup notifications have improved styling and column headers now display sort direction arrows.
  • The column picker and folder view have been reinstated for the bookmarks panel.
  • Introduced the ability to close all tabs to the right of the current tab.
  • Whether mailnews tabs open in the background is controlled by a separate preference to browser tabs via General Settings section of main Mail & Newsgroups preference pane.
  • Fixed an issue with the recipient being missing when using Reply to Sender and Group button in Newsgroup discussions.
  • SeaMonkey now prevents address books from having duplicate names.
major changes relative to SeaMonkey 2.49.5:
  • The Bookmarks Manager has switched its name to Library, and now also includes the History list. When invoking History, the Library will be shown with the History list selected. The extensive modifications were needed because of Mozilla Gecko platform API changes.
  • Download Manager has been migrated to a new API. Although it looks pretty much the same as before, the search option is missing and some other minor details work differently. The previous downloads history is removed during the upgrade.
  • The layout panel was added to the CSS Grid tools.
  • TLS 1.3 is the default SSL version now.
  • The only NPAPI plugin which will work with SeaMonkey 2.53.2 is Flash. Support for other NPAPI plugins like Java and Silverlight has been removed.
  • SeaMonkey now uses a new api for formatting regional data like time and date. Default is to use the application locale of the current SeaMonkey build. If you use a language pack or a different OS formatting this is usually not desired. You can change the formatting from the application locale to the regional settings locale (OS) in the preferences dialog under "Appearance".
SeaMonkey 2.53.2 uses the same backend as Firefox and contains the relevant Firefox 60.3 security fixes.
SeaMonkey 2.53.2 shares most parts of the mail and news code with Thunderbird. Please read the Thunderbird 60.0 release notes for specific changes and security fixes in this release.
Additional important security fixes up to Current Firefox 74 and a few enhancements have been backported. We will continue to enhance SeaMonkey security in subsequent 2.53.x beta and release versions as fast as we are able to.
SeaMonkey now uses gtk3 on Linux. If you experience a problem because of this please file a bug and link it to bug 1367257. Please try another OS theme first. Some of them are buggy and cause problems with SeaMonkey, Thunderbird and Firefox.
Installationsanweisungen:
Installationsanweisungen schrieb:
Automatic upgrades from previous versions are disabled for this release. Please download the full installer from the downloads section and install SeaMonkey 2.53.2 manually over the previous version.
This version makes changes to your profile that can't be reverted in case you want to go back to a previous version of SeaMonkey. You MUST absolutely do a full backup of your profile before trying SeaMonkey 2.53.2.
The Mozilla backend code SeaMonkey is based on, now usually incorporates breaking changes in every release. This is especially true for the Mozilla Gecko add-ons code and the JavaScript interpreter. Consequently, some older extensions may no longer function properly. If you experience any problems please refer to the troubleshooting section first. Especially try to disable extensions first and check if this makes a difference.
Important only if you upgrade from 2.49.5 or an earlier version: Due to changes in the user profile, if you have set a master password, you will have to remove it before upgrading to SeaMonkey 2.53.2. After a successful upgrade, don't forget to manually remove the files key3.db and cert8.db in your profile afterwards, as they include credentials and passwords no longer protected by a master password. You can find the path to your profile folder entering the special about:support URL in a SeaMonkey browser window.
You can remove you master password by providing an empty password in the "Change Master Password" dialog. Do not use the "Reset Password" function. You will lose all stored passwords this way.
https://ftp.mozilla.org/pub/seamonkey/releases/2.53.2/ (Übersicht aller Plattformen)
https://ftp.mozilla.org/pub/seamonkey/releases/2.53.2/win64/de/seamonkey-2.53.2.de.win64.zip (Direktlink Windows x64 portable binary deutsch)
Vivaldi 3.0.1874.38
(2020-05-07)
https://vivaldi.com/de/blog/news/minor-update-3-for-vivaldi-desktop-3-0
Pale Moon 28.9.3
(2020-05-08)
This is a security update.
  • Fixed a potential vulnerability in the zip file reader. DiD
  • Fixed a potential vulnerability in the JavaScript JIT compiler related to aliases. DiD
  • Ported several upstream devtools fixes (addresses CVE-2020-12392 and CVE-2020-12393).
  • Improved memory safety of some WebAudio calls.
  • Improved memory safety in the XUL window destructor. DiD
  • Unified XUL Platform Mozilla Security Patch Summary: 3 fixed, 3 Defense-in-depth, 16 not applicable.
https://forum.palemoon.org/viewtopic.php?f=41&t=24357#p189303
Otter 1.0.81 weekly 333
(2020-05-18)
Anlässlich der 333. Projektwoche gehen die ersten vorgefertigten Builds seit 8 Monaten an den Start. Das ist Sparta!
https://sourceforge.net/projects/otter-browser/files/otter-browser-weekly333
Ich greife diesmal zum Paket otter-browser-win64-weekly333.7z.
Pale Moon 28.10.0
(2020-06-05)
This is a development, bugfix and security update.
  • Implemented URLSearchParams' sort() function
  • Implemented ES2020 globalThis for web compatibility
  • Improved our WebM media parser to be more tolerant to different encoding styles.
  • Improved our MP3 media parser to be more tolerant to different encoding styles and particularly tiny files/stream chunks.
  • Improved performance of table drawing for more corner cases
  • Changed the way images without a src are handled in page layouts to align with the Chrome-pushed spec.
  • Added modern MIPS support
  • Split out the ICU data file from xul.dll on Windows
  • Fixed a regression in WebAudio channel handling due to a landed security fix.
  • Fixed a regression preventing scripting from properly disabling input controls
  • Fixed an issue with border radius sometimes not being honored in tables
  • Fixed some build issues in non-standard configurations.
  • Removed more telemetry code
  • Removed the in-browser speech recognition engine and API
  • Removed support for the obsolete and unmaintained NVidia 3DVision stereoscopic interface.
  • Changed handling of braille blanks in the ui (CVE-2020-12409) DiD
  • Mitigated a potential timing attack against DSA keys in NSS (CVE-2020-12399)
  • Unified XUL Platform Mozilla Security Patch Summary: 1 fixed, 1 defense-in-depth, 8 not applicable.
https://forum.palemoon.org/viewtopic.php?f=41&t=24529#p191321
Vivaldi 3.1.1929.45
(2020-06-24)
https://vivaldi.com/de/blog/vivaldi-gets-notes-manager-and-configurable-menus
https://vivaldi.com/blog/news/minor-update-for-vivaldi-desktop-browser-3-1
https://vivaldi.com/blog/news/minor-update-2-for-vivaldi-desktop-3-1
https://vivaldi.com/blog/news/minor-update-3-for-vivaldi-desktop-browser-3-1
Pale Moon 28.11.0
(2020-07-14)
  • Tidied up front-end browser JavaScript.
  • Changed the way sources are compiled (on-going de-unification).
  • Improved compatibility with gcc v10
  • Fixed wrong positions when calculating the position for position:absolute child inside a table.
  • Aligned file name extension of saved url files with other applications (lower case)
  • Fixed building with --disable-webspeech (to disable speech synthesis)
  • Added global menubar support for GTK.
  • Implemented node.getRootNode
  • Implemented AbortController (Abort API)
  • Improved the uninstaller to use elevation when prudent and actually remove program files.
  • Fixed a rare issue with editable page content.
  • Fixed a crash related to ES module scripts.
  • Aligned ES module scripting better with the current spec and removed eager instantiation.
  • Fixed a potential issue with the JPEG encoder. (CVE-2020-12422) DiD
  • Fixed a potential issue with AppCache manifests. DiD
  • Fixed a potential crash in JavaScript date parsing.
  • Fixed a problem with RSA key generation that would make it potentially vulnerable to side-channel attacks. (CVE-2020-12402)
  • Fixed a potential crash due to multithread race condition. DiD
  • Fixed a correctness issue in URL handling. (CVE-2020-12418) DiD
  • Unified XUL Platform Mozilla Security Patch Summary: 2 fixed, 4 defense-in-depth, 10 not applicable.
https://forum.palemoon.org/viewtopic.php?f=41&t=24773&sid=67ec664cf41925044c33dec5bc5b8729#p194148
Seamonkey 2.53.3
(2020-07-07)
Der nächste Seamonkey des ESR-Versionszweiges 2.53 steht in den Startlöchern.
https://ftp.mozilla.org/pub/seamonkey/releases/2.53.3/ (Übersicht aller Plattformen)
https://ftp.mozilla.org/pub/seamonkey/releases/2.53.3/win64/de/seamonkey-2.53.3.de.win64.zip (Direktlink Windows x64 portable binary deutsch)
