Download FahMon 2.3.99
TiKu
Administrator
Teammitglied
16.11.2001
21.708
1.323
München
  • SIMAP Race
  • QMC Race
  • Spinhenge ESL
  • Docking@Home
  • BOINC Pentathlon 2021
Das Tool FahMon, welches der Überwachung von <a href="http://dc.planet3dnow.de/wiki/index.php?title=Portal:Folding%40Home">Folding@Home</a>-Clients dient, wurde in der Version 2.3.99 veröffentlicht. Es wurden umfangreiche Änderungen vorgenommen.
<strong>Changelog 2.3.4 zu 2.3.99:</strong><ul><li>General<ul><li>GUI<ul><li style="font-size: smaller;">Fixed total PPD value not updating unless a client is clicked.</li><li style="font-size: smaller;">Allow about and benchmark dialogs to be closed with escape key (thanks to smartcat99s).</li><li style="font-size: smaller;">Added columns for client type (determined from the core type) and core version number.</li><li style="font-size: smaller;">Main progress bar now hides along with the WU Info panel.</li><li style="font-size: smaller;">Total PPD display moved into the status bar.</li><li style="font-size: smaller;">Improved sorting of inaccessible or disabled clients.</li><li style="font-size: smaller;">Removed "zebra" background colour scheme from benchmarks list.</li><li style="font-size: smaller;">Added IRC channel link to help menu and First Time Dialog.</li><li style="font-size: smaller;">Removed info panel from default view, and replaced with extra columns.</li><li style="font-size: smaller;">Added informative tooltips to a number of controls.</li><li style="font-size: smaller;">Window stays maximised after hiding the FAHlog if it was maximised initially.</li></ul></li><li>Monitoring<ul><li style="font-size: smaller;">Improved handling of clients within Virtual Machines.</li><li style="font-size: smaller;">Prevented FahMon from crashing when the FAH client produces excessively large unitinfo.txt files.</li><li style="font-size: smaller;">Fixed miscalculation of frame count when step count is a non-standard number.</li><li style="font-size: smaller;">Limited FAHlog parsing to last 16KiB.</li><li style="font-size: smaller;">Added ability to reload client in series rather than launching a thread for each client. Will improve memory usage with large numbers of clients.</li><li style="font-size: smaller;">Significantly reduced CPU usage while reloading.</li><li style="font-size: smaller;">Added support for monitoring clients over http.</li><li style="font-size: smaller;">Added limited support for monitoring clients over ftp.</li><li style="font-size: smaller;">Added slower, configurable timer for reloading http/ftp clients. This is also used for web output.</li><li style="font-size: smaller;">Added support for saving web output to an ftp server.</li><li style="font-size: smaller;">Added support for additional cores.</li><li style="font-size: smaller;">Web output is now sorted in the same way as the client list.</li></ul></li><li>Other<ul><li style="font-size: smaller;">Added crash reporter to help debugging.</li><li style="font-size: smaller;">Fixed non-fatal bug in single-instance handler.</li><li style="font-size: smaller;">Fixed internal queue.dat/wx character conversion.</li><li style="font-size: smaller;">FahMon messages are now logged with millisecond timestamps.</li><li style="font-size: smaller;">Added partial Norwegian translation.</li><li style="font-size: smaller;">Plugged several memory leaks.</li><li style="font-size: smaller;">Message Manager now only logs errors by default.</li><li style="font-size: smaller;">Replaced internal inet protocol handling with libcurl.</li><li style="font-size: smaller;">Added "stress test" mode. Start with -s or --stress</li><li style="font-size: smaller;">New user manual.</li></ul></li></ul></li><li>Windows<ul><li style="font-size: smaller;">Reduced executable size by aggressively optimising MSVC linking and padding boundaries.</li><li style="font-size: smaller;">Reduced executable size by aggressively stripping unneeded options from wxWidgets.</li><li style="font-size: smaller;">Added --local option to allow config to be managed from local directory.</li><li style="font-size: smaller;">Fixed main window location behaviour.</li></ul></il></ul>
<strong>Download:</strong><ul><li><a href="http://fahmon.net/download.html" target="_blank">FahMon 2.3.99</a></li></ul>
<strong>Links zum Thema:</strong><ul><li><a href="http://fahmon.net/" target="_blank">FahMon</a></li></ul>
Danke an KIDH für den Hinweis!
Wer kann mir sagen in welchem Verzeichnis ich die ausführbare Datei in der Linux-Version finde?
Bei der alten Version war sie im src-Verzeichnis.
thorsam
