• In dieser Sektion des Forums werden Pressemitteilungen der Hersteller 1:1 veröffentlicht. Planet 3DNow! übernimmt weder für die Richtigkeit der Angaben noch für die Art der Formulierung jedwede Verantwortung. Oft sind Pressemitteilungen mit typischen Marketing-Floskeln wie "einer der bedeutendsten Herstellern von XY" versetzt. Diese Aussagen sind subjektiv und geben nicht notwendigerweise die Meinung der auf Planet 3DNow! schreibenden Autoren wieder.
Fanless Embedded Systems with AMD Ryzen V1000/R1000 SoCs
Pressemitteilung
Taipei, Taiwan, September 4, 2020 – IBASE Technology Inc. (TPEx: 08050), a world leader in the manufacture of industrial motherboards and embedded systems, has unveiled the ASB200-918 series based on the IB918 3.5-inch form factor SBC supporting AMD Ryzen SoCs (V1605B/V1202B/R1606G/R1505G). The four models in the series bring together the powerful performance of the "Zen" CPU and "Vega" GPU architectures to deliver a new class of embedded solutions.
IBASE leverages the high performance and stunning graphics capabilities of AMD Ryzen Embedded processors with its own manufacturing flexibility to design the fanless ASB200-918 that runs two simultaneous HDMI 2.0a displays at Ultra HD 4K resolution (3840 x 2160) with a frame rate of 60 fps. Measuring 240mm x 162mm x 42mm, it is equipped with rugged components to ensure a reliable and uninterrupted operation in industrial control, factory, kiosks and other space-critical applications.
The robust design of the ASB200-918 comes with 16GB of DDR4-2666 memory with ECC and up to 32GB support. The unit features a 64GB TLC SSD storage, 12V~24V DC wide power input and optional 90W power adaptor. Versatile I/O connectivity is provided by 4x COM, 4x USB 3.1, 1x USB 2.0, 2x GbE and an external GPIO, while expansion is supplied by two M.2 slots for NVMe storage and WiFi or Bluetooth connections. Supported operating systems include Win10, Win10 IoT Enterprise, Win Embedded Standard 8, and Ubuntu 16.04. For more information, please visit www.ibase.com.tw.
ASB200-918 FEATURES:
  • <li>Fanless system with IBASE IB918 3.5’’ Disk-Size SBC</li>
    <li class="Arial_p2">AMD Ryzen™ Embedded V1000/R1000 on board</li>
    <li class="Arial_p2">2x DDR4 SO-DIMM, Max. 32GB, supports ECC</li>
    <li class="Arial_p2">Supports 2x M.2 sockets (E-Key / M-Key, NVMe)</li>
    <li class="Arial_p2">2x HDMI(2.0a), 2x Intel® Gigabit LAN</li>
    <li class="Arial_p2">4 x COM ports, External GPIO</li>
    <li class="Arial_p2">4 x USB3.1, 1x USB2.0</li>
    <li class="Arial_p2">12V(-10%) ~ 24V(+10%) DC-in Power Input</li>
    <li class="Arial_p2">Operating temperature 0°C~45°C (32°F~113°F)</li>
About IBASE Technology
IBASE Technology (TPEx: 8050) specializes in the design and manufacturing of robust industrial PC products and ODM/JDM services, delivering high quality products and excellent service since its establishment in 2000. IBASE carries out manufacturing and quality control at its own facilities in Taiwan that are certified with ISO 9001, ISO 13485 and ISO 14001 standards. Current product offerings comprise of x86- and RISC-based industrial motherboards, embedded systems, panel PCs, digital signage players and network appliances for applications in the automation, retail, transportation, gaming, healthcare and smart factory sectors. For more information, please visit www.ibase.com.tw.
