Foxit Reader 2.3 Build 3201
- Ersteller cruger
Der PDF-Betrachter Foxit Reader, eine Alternative zu dem weit verbreiteten <a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=2&id=1214954278">Adobe Reader</a>, ist in der Version 2.3 mit der Buildnummer 3201 erschienen und beseitigt diverse Fehler der Vorgängerversion.
<blockquote cite="http://www.foxitsoftware.com/bbs/showpost.php?p=18656&postcount=1"><i><b>Fixed in Foxit Reader 2.3 Build 3201</b>
1. Several crash issues.
Foxit Reader crashes when users are viewing some certain PDF files with images.
Foxit Reader crashes sometimes when users are clicking on the "Print" option.
2. Toolbars go out of place and rearrange themselves vertically.
3. Slow printing of PDF files that have complex images.
4. Font and Image rendering improved.
5. Combo Box tool not working correctly.
6. The menu item "FDF Document" needs to be removed from desktop context menu.
7. Always remember the last printer you select
8. Foxit Reader (free version) may not be responding after you save a PDF document.
9. Bookmark view cannot be disabled permanently in Internet Explorer.
10. Print command needs to be updated.
11. Certain bookmark displaying issues.
12. Many other bug fixes and feature enhancement.</i></blockquote>
<b>Download:</b><ul><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20080806103921">Foxit Reader 2.3 Build 3201 [Windows Installer]</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20080806103922">Foxit Reader 2.3 Build 3201 [Windows ZIP-Version]</a></li></ul>Die neue Version kann man demnächst auch über die intergrierte Update-Funktion des Foxit Reader beziehen.
<b>Links zum Thema:</b><ul><li><a href="http://www.foxitsoftware.com/pdf/reader_2/whatsnew23.htm" target="b">What's new in Version 2.3?</a></li></ul>
haarald
- Sony Vaio VGN-NW21ZF
- X2 3800+
- MSI K9N Ultra
- Thermaltake TMG
- 2 GB DDR2 667 Mhz
- GigaByte HD 5570 1GB
- 22" Fujitsu-Siemens
- WD Caviar 320 GB
- LG
- Chieftec
- be quiet 450W
- WinXP Home
- Pinnacle PCTV Sat
Wenn schon sonst niemand was schreibt...
Ich find ihn nett, resourcenschonend, schnell (v.a. wenn man mit nem PIII mit 192 MB Ram arbeiten darf
) und die Tabs bei mehreren geöffneten Dokumenten sind auch extrem konfortabel. Mal schaun, ob das mit der Stabilität besser geworden ist...
) und die Tabs bei mehreren geöffneten Dokumenten sind auch extrem konfortabel. Mal schaun, ob das mit der Stabilität besser geworden ist...TAL9000
- nähe Giessen
- Ryzen 3700X; 4650G; Radeon RX6950XT; RX6500XT
- 28" Samsung UE590 LU28E590DSEN
- OnBoard
- VERTI WM25
- Danke thorsam & JagDoc, KVM ATEN CS1764 4-fach Desktop , USV APC BR900GI, NAS QNAP TS-431P2-8G + TS-462-16G je 4x4TB
▼50 MBit
▲10 MBit
Hatte unter Win98se massive Stabilitätsprobleme mit den letzten Versionen so das ich sogar bis auf den Acrobat 5.01 zurück gesprungen bin. Denke ich werde ihn wieder ausprobieren. Er ist wirklich schön schnell gewesen, aber leider auch oft abgeschmiert. Das System läuft entsprechend des alters stabil...
TAL9000
TAL9000
- München
- World Community Grid
- Folding@Home
- be quiet! Shadow Rock 3
- LG 27UL850-W, 27"
- Logitech G613 Lightspeed
- Logitech MX Master 3S
- Ubuntu Linux 24.04
- Vivaldi
▼100 MBit
▲40 MBit
Aus irgendeinem Grund braucht Foxit bei mir seit einigen Versionen sehr lange um eine PDF anzuzeigen. Er öffnet sich zwar sehr schnell, aber bis die PDF zu sehen ist, dauerts dann eine ganze Weile.
Beini86
- Hamburg
- AMD Ryzen™ 5 3600
- MSI b450m Mortar Max
- Arctic Freezer 34 eSports DUO
- 32GB DDR4 3600
- AMD RX6800 XT 16GB
- Crucial MX500 1TB
- Fractal Design Define Mini C
- 550W Seasonic Focus GX
- Cherry Stream Wireless
- Logitech G305
- Windows 10 Pro 64-Bit
- Edge
Ich habe eig. noch nie irgendwelche Kompatibilitäts-, oder Stabilitätsprobleme gehabt. Ich kann einfach nur die Meinung wiedergeben, dass das Tool schön schnell und schlank ist
gast0815
Foxit hat bei mir einige PDF Dateien falsch dargestellt.
Da ja der Adobe Reader 9 genauso schnell ist wie der Foxit, bin ich vor kurzem auf den umgestiegen und bereue es nicht.
[P3D] Crazy_Chris
- Gigabyte GA-P55M-UD2
- Scythe Mugen 2 Rev. B
- Dell UltraSharp 2407WFP
- LG GGC-H20L SATA *Blu-ray*
- Windows 7 und Ubuntu (x64)
- guckguck :-P
Bin auch wieder beim Adobe Reader seit der neunten Version gelandet.
