Download Foxit Reader 3.0 Build 1222
cruger
Senior Moderator
Teammitglied
25.05.2002
29.389
1.579
  • QMC Race
  • BOINC Pentathlon 2014
Der PDF-Betrachter Foxit Reader, eine Alternative zu dem weit verbreiteten <a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=2&id=1214954278">Adobe Reader</a>, ist in der Version 3.0 mit der Buildnummer 1222 erschienen und beseitigt diverse Fehler der Vorgängerversion.
<blockquote cite"http://www.foxitsoftware.com/pdf/reader_2/bugfix.htm"><i><b>Fixed in Foxit Reader 3.0 Build 1222</b>
1. The annotations added by the typewriter tool will be rotated along with the page.
2. Popup "Mozilla Firefox is not installed." when users failed to install Firefox plug-in.
3. May take a long time to open a file in Windows Vista Home version.
4. This updated version allows users to delete the advertisements.
5. The Auto-Rotate feature may be unavailable when printing with Snapshot tool.
6. Go back to the default settings of the printer properties when users reopen the PDF files.
7. This updated version will choose to print documents in actual size mode or fit to paper mode based on the default settings in the print dialog box with Command lines.
8. Page numbers are printed in a disorderly way when printing multiple copies in double-side mode.
9. The slow launch speed when running Foxit Reader for the first time after the system startup.</i></blockquote>
<b>Download:</b><ul><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20081226130808">Foxit Reader 3.0 Build 1222 [Windows Installer]</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20081226130809">Foxit Reader 3.0 Build 1222 [Windows ZIP-Version]</a></li></ul>Die neue Version kann man demnächst auch über die intergrierte Update-Funktion des Foxit Reader beziehen.
<b>Links zum Thema:</b><ul><li><a href="http://www.foxitsoftware.com/pdf/reader_2/bugfix.htm" target="b">Changelog Build 1222</a></li><li><a href="http://foxitsoftware.com/pdf/reader_2/whatsnew30.htm" target="b">What's new in Version 3.0?</a></li></ul>
Irgendwie scheinen die aber noch ein paar Probleme zu haben - momentan ist keine andere Sprache als englisch möglich da andere Sprachen wohl noch nicht übersetzt wurden.
Mittlerweile ist build 1301 erschienen.
Immernoch ist nur ein Teil der Menüs in deutsch der Rest in englisch. :(
