Download Foxit Reader 3.2
KIDH
09.03.2007
4.837
531
Pogotopia
  • Spinhenge ESL
Der kostenlose PDF-Betrachter Foxit Reader ist in der neuen Version 3.2 für Windows erschienen. Das Programm stellt eine Alternative zum geläufigen Adobe Reader dar. In der neuen Version wurden einige Fehler beseitigt.
Das Programm läuft unter Windows ab Windows 2000.
<b>Was ist neu?</b>
<ul><li>Undo and Redo
<small>Allows users to easily correct mistakes by cancelling their previous actions and quickly adding back in changes made with the Undo option, this makes it convenient for users to revoke their performances and enables better editing requirements.</small></li><li>Expand Current Bookmark
<small>Click the Expand Current Bookmark icon to expand nested bookmarks and highlight the bookmark of the current page.</small></li><li>Grayscale Printing
<small>Reader 3.2 supports to print in grayscale, using many shades of gray to represent subtle variations in color and light.</small></li><li>Speed Up Printing
<small>Foxit Reader has optimized the printing feature, improving the speed of printing dramatically.</small></li><li>Logical Page Number Support
<small>Display the physical and logical page number on the status bar at the bottom of the working area, enabling you to go right to the desired page fast and accurately.</small></li><li>Hundreds Bugs Fixed</li></ul>
<b>Changelog:</b><blockquote><i> 1. Better JavaScript support.
2. Fixed the crash issue when double clicking to open certain PDFs.
3. Fixed the issue where cannot correctly display the content copied from Text Viewer mode on popup dialog box.
4. Better support saving PDF as text.
5. Fixed the issue where pop multiple message boxes when clicking the bookmarks several times continuously.
6. Fixed the issues where some PDF documents cannot be associated with Foxit Reader.
7. Fixed the issue where space may disappear when copying text.
8. Fixed the crash issue when occasional use of arrow keys on keyboard to turn pages.
9. Fixed the issue where the text may not be highlighted.
10. Fixed the issue where the text string starting with a space cannot be searched.
11. Fixed the issue with vertical text selection and text highlight.</i></blockquote>
<b>Download:</b><ul><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.cgi?20100312024144">Foxit Reader 3.2 [Setup] - Lokaler Mirror</a></li></ul>
<b>Links zum Thema:</b>
<ul><li><a href="http://www.foxitsoftware.com" target="b">Offizielle Internetpräsenz</a></li></ul>
wie immer hinkt die Lokalisierung des Foxit Reader etwas hinterher. So kann man über die im Programm integrierte Funktion derzeit noch keine passende deutsche Sprachdatei herunterladen.
Für die wichtigsten Funktionen funktioniert aber diese hier recht gut. Einfach ins Programmverzeichnis des Foxit Reader entpacken, den Reader anschließend neu starten und ggf. noch über Tools, Options, Languages die Sprache einstellen.
Beste Grüße
DAC324
