Download GPU Caps Viewer 1.8.8
- Ersteller KIDH
KIDH
- Pogotopia
- Folding@Home
- Abit AV8 3rd Eye
- Thermaltake Silent Boost K8
- GeForce 6800 GT
- DVD-ROM / DVD-Brenner
- Creative Audigy
- noname
- Enermax Liberty 400W Dual
- Win98SE / WinXP SP3
Das kostenlose Grafikkarten-Tool GPU Caps Viewer ist in der Version 1.8.8 verfügbar. Ähnlich wie <a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?id=1277990516">GPU-Z</a> und der <i>Graphics</i>-Tab von <a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?id=1278700437">CPU-Z</a> liest es Informationen über die Grafikkarte aus, zusätzlich lassen sich auch noch Demos für OpenGL (1.2 / 2.1 / 3.x) und OpenCL (GPU / CPU) abpielen. Für die OpenCL-Demos benötigt man das jeweilige OpenCL SDK.
Das Programm läuft laut Internetseite unter Windows ab Windows XP.
<center><a href="http://www.planet3dnow.de/photoplog/index.php?n=8546"><img src="http://www.planet3dnow.de/photoplog/file.php?n=8546" border="1" alt="GPU Caps Viewer"></a></center>
<b>Changelog:</b>
<ul><li>GPU Caps Viewer 1.8.8:<blockquote><i>* New: added the support of GTX 465 and 460.
* New: a button to launch an advanced GPU monitoring tool has been added in the first panel (GPU/CPU).
* New: in OpenGL panel, the number of GL and WGL extensions is displayed.
* New: added new subvendors: Zotac, Palit and Gigabyte.
* Change: OpenGL extensions are now fetched with the method described <a href="http://www.geeks3d.com/20100722/tips-how-to-get-the-list-of-the-opengl-extensions-with-a-core-profile" target="b">here</a>
* Change: now the max values of CPU, memory and shader (shader: NV only) clocks and VDDC are displayed for Radeon and GeForce cards.
* Change: minor updates in the code of the OpenCL demos for a good working with latest NV and AMD drivers.
* Bugfix: in the first panel, only the features of first OpenCL device are displayed.
* Update: compiled with the latest version of <a href="http://www.geeks3d.com/20100723/gpu-tool-gpu-caps-viewer-1-8-8-available" target="b">ZoomGPU</a> and <a href="http://www.geeks3d.com/20100721/opengl-glew-1-5-5-available" target="b">GLEW</a>.</i></blockquote></li></ul>
<b>Download:</b><ul><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.cgi?20100727220343">GPU Caps Viewer 1.8.8 [Setup] - Lokaler Mirror</a></li></ul>
<b>Links zum Thema:</b>
<ul><li><a href="http://www.ozone3d.net/gpu_caps_viewer" target="b">Offizielle Internetpräsenz</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?id=1277990516">GPU-Z 0.4.4</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?id=1278700437">CPUID CPU-Z 1.55</a></li></ul>
<b>Changelog:</b>
Dr@
- Baden-Württemberg
- Collatz Conjecture
- Zacate E-350 APU
- Details zu meinem Laptop
- E35M1-I DELUXE
- DVD-Brenner
- Firefox 13
Gibts das eigentlich nimmer als zip?
Warum muss man eigentlich alles installieren?
KIDH
- Pogotopia
- Folding@Home
- Abit AV8 3rd Eye
- GeForce 6800 GT
- Creative Audigy
- noname
Hab mich auch schon gewundert, aber .zip hab ich keins gefunden...btw nicht wundern,. wenn der DL nicht klappt, der .net-Server hat ein Problem.
Diapolo
- AMD A8-3850
- ASUS F1A75-V EVO (BIOS 1803)
- Noctua NH-U12P
- 2x2GB OCZ DDR3-1600 (OCZ3P1600LVAM4GK)
- XFX Radeon HD 7970 Core Edition
- OCZ Vertex 4 256GB, OCZ Vertex Turbo 60GB + WD Raptor 150GB
- be quiet! Dark Power PRO P9 550W
- Windows 7 Ultimate SP1 (64-Bit)
Warum muss man eigentlich alles installieren?![]()
Hehe ich hab gerad auch 5 Minuten danach gesucht und dann aufgegeben ... mag auch nix installieren! Wenn wer die Zip findet bitte hier posten, danke!
Dia
KIDH
- Pogotopia
- Folding@Home
- Abit AV8 3rd Eye
- GeForce 6800 GT
- Creative Audigy
- noname
Ich kann höchstens nocht das Installationsverzeichnis gezippt hochladen...hab's auch wieder deinstalliert und das Verzeichnis jetzt einfach so da.
Tja, das Problem kenne ich. Aber auch Programme die nicht installiert werden, hinterlassen des öfteren Registrierungs-Einträge die beim löschen des Programms zurückbleiben. Die muss man dann selber oder durch ein Tool löschen lassen.
Gut, wenn man Programme deinstalliert, werden die Registrierungs-Einträge auch nicht immer gelöscht aber immerhin einige.
Deshalb benutze seit einiger Zeit des öfteren den Installer.
Setsuna
- MSI X570 Unify
- AMD Ryzen 7 3700X
- MSI MEG X570 Unify
- Noctua NH-D15S
- 32GB DDR4-3200
- MSI GeForce RTX 3060 Ventus 3X 12G OC
- EIZO CS 240 BK
- Samsung 870 EVO 4TB
- Pioneer BDR-209
- Asus Strix
- Phanteks Enthoo Pro
- be quiet! Straight Power 11 550W
- Ducky
- Win 7 Pro x64
- Palemoon x64
- ▼100000 ▲40
Diapolo
- AMD A8-3850
- Noctua NH-U12P
Und diese gibts nach 1.8.9 auch wieder als Zip-Datei: http://www.geeks3d.com/wp-content/plugins/download-monitor/download.php?id=152
Dia
Dia
Gast29012019_2
Nicht schlecht, so konnte ch mal kurz antesten wie heiß der Geforce 8200 Chipsatz wird, ohne aktive Kühlung im idle 73 Grad mit aktive Kühlung 54 Grad, mit OpenGL benches 62 Grad.
