Micro BTX für (einigermaßen) aktuelle Prozessoren?
X_FISH
03.02.2006
4.943
2.744
  • BOINC Pentathlon 2017
  • BOINC Pentathlon 2018
  • BOINC Pentathlon 2019
  • SETI@Home Wow!-Event 2019
  • BOINC Pentathlon 2020
  • THOR Challenge 2020
  • BOINC Pentathlon 2021
  • BOINC Pentathlon 2022
  • BOINC Pentathlon 2023
  • BOINC Pentathlon 2024
Ich sitze hier gerade an einem Dell Optiplex 360.
Micro BTX gehört rein - und ist auch drin. :D
Code:
walter@Walters-OptiPlex-360:~$ sudo lshw -short
H/W-Pfad         Gerät      Klasse      Beschreibung
                             system      OptiPlex 360
/0                           bus         0T656F
/0/0                         memory      64KiB BIOS
/0/400                       processor   Pentium(R) Dual-Core  CPU      E5300  @
/0/400/700                   memory      32KiB L1 Cache
/0/400/701                   memory      2MiB L2 Cache
/0/1000                      memory      2GiB Systemspeicher
/0/1000/0                    memory      1GiB DIMM DDR2 Synchron 800 MHz (1,2 ns
/0/1000/1                    memory      1GiB DIMM DDR2 Synchron 800 MHz (1,2 ns
/0/100                       bridge      82G33/G31/P35/P31 Express DRAM Controll
/0/100/1                     bridge      82G33/G31/P35/P31 Express PCI Express R
/0/100/2                     display     82G33/G31 Express Integrated Graphics C
/0/100/2.1                   display     82G33/G31 Express Integrated Graphics C
/0/100/1b                    multimedia  NM10/ICH7 Family High Definition Audio
/0/100/1c                    bridge      NM10/ICH7 Family PCI Express Port 1
/0/100/1c/0      enp2s0      network     NetLink BCM5784M Gigabit Ethernet PCIe
/0/100/1d                    bus         NM10/ICH7 Family USB UHCI Controller #1
/0/100/1d/1      usb2        bus         UHCI Host Controller
/0/100/1d.1                  bus         NM10/ICH7 Family USB UHCI Controller #2
/0/100/1d.1/1    usb3        bus         UHCI Host Controller
/0/100/1d.2                  bus         NM10/ICH7 Family USB UHCI Controller #3
/0/100/1d.2/1    usb4        bus         UHCI Host Controller
/0/100/1d.2/1/1              input       USB OPTICAL MOUSE
/0/100/1d.2/1/2              input       USB Multimedia Keyboard
/0/100/1d.3                  bus         NM10/ICH7 Family USB UHCI Controller #4
/0/100/1d.3/1    usb5        bus         UHCI Host Controller
/0/100/1d.7                  bus         NM10/ICH7 Family USB2 EHCI Controller
/0/100/1d.7/1    usb1        bus         EHCI Host Controller
/0/100/1e                    bridge      82801 PCI Bridge
/0/100/1f                    bridge      82801GB/GR (ICH7 Family) LPC Interface
/0/100/1f.1                  storage     82801G (ICH7 Family) IDE Controller
/0/100/1f.2                  storage     NM10/ICH7 Family SATA Controller [IDE m
/0/100/1f.3                  bus         NM10/ICH7 Family SMBus Controller
/0/1             scsi2       storage
/0/1/0.0.0       /dev/sda    disk        160GB ST3160318AS
/0/1/0.0.0/1     /dev/sda1   volume      27GiB EXT4-Laufwerk
/0/1/0.0.0/2     /dev/sda2   volume      121GiB Extended partition
/0/1/0.0.0/2/5   /dev/sda5   volume      1952MiB Linux swap Laufwerk
/0/1/0.0.0/2/6   /dev/sda6   volume      26GiB EXT4-Laufwerk
/0/1/0.0.0/2/7   /dev/sda7   volume      93GiB EXT4-Laufwerk
/0/2             scsi3       storage
/0/2/0.0.0       /dev/cdrom  disk        DVD+-RW TS-H653G
Those were the days my friend... :D
Da ich das Gehäuse eigentlich nicht übel finde -> gibt es Micro BTX Boards für "etwas" aktuellere Hardware welche man da reinsetzen könnte?
Oder sind die Teile leider nur noch was für den Recyclinghof (oder um als überdimensionierte Gehäuse für einen Raspi zu dienen :D)?
Grüße, Martin
PS: Linux Mint Tricia läuft ganz gut - nur die 2 GB RAM (abzgl. dem was die GPU braucht) sind etwas zu wenig beim Surfen wie ich schon feststellen musste...
BTX gibts heute nicht mehr, evtl. bekommst du ja ITX reingebaut, der Ausschnitt für das IO-Bleck müsste ja noch passen. Allerdings kannst du dann auch keine Steckkarte einstecken.
Deswegen meine ich ITX und nicht µATX ;)
ITX war auch mein erster Gedanke gewesen.
Neue Gewindebolzen könnte man im Zweifel auch noch irgendwie befestigen, falls die doch an den falschen Stellen sein sollten.
Und PCIe-Karten wären auch nur schwer möglich - aber die aktuellen APUs haben ja genug GPU-Power. :)
Das kommt davon wenn man nach mehreren Tagen Linux wieder auf Windows umsteigt. Links sind nicht automatisch kopiert wenn man sie mit der Maus markiert hat. :D
Eigentlich sollte ein Bild rein, was den PCIe-Slot an "der falschen Stelle" zeigt.
APU wäre eine gute Idee... Mal durchrechnen was der Spaß so kostet...
Grüße, Martin
@X_Fish Was wäre mit I/O Panel "Freischneider" und und neuem Gewinde anbringen an geeigneten Positionen für ein ITX oder mATX Mainboard?
Oder ist das dann "Zerstümmelung"? *buck*
Solange man nicht am Board herumschnippelt. *buck*
Das überlebt dann wohl das Gehäuse nicht. Die optiplex Serie besteht aus einer Konstruktion die man fast schon als Leichtbau bezeichnen könnte. Dünnes Blech, welches durch Kunststoff verstärkt wird.
Wenn man da zuviel rum geschnippelt hat, wird es zu instabil.
Den Ausschnitt für die Blende heraustreten mit Popnieten wieder einsetzen wird vermutlich auch nicht funktionieren.
Aber ich glaube dass die Aktion sowieso nicht praktikabel ist, die passende ITX Boards sind doch teurer als gedacht.
Für die Preisdifferenz könnte man auch ein schönes, einfaches, aktuelles Gehäuse kaufen.
Grüße, Martin
