Mozilla Firefox 3.0 ist da
- Ersteller Nero24
Nach etlichen <a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=2&id=1212655997" TARGET="_blank">Release Candidates</a> hat Mozilla heute die finale Version des freien Open-Source Internet-Browsers Firefox 3.0 veröffentlicht. Schneller, sicherer und praktischer soll er sein. Laut Release-Notes sind über 14.000 Verbesserungen eingeflossen. So soll vor allem die Geschwindigkeit deutlich erhöht und der Speicherverbrauch massiv gesenkt worden sein:<ul><i><font size="1">Firefox 3 is based on the Gecko 1.9 Web rendering platform, which has been under development for the past 34 months. Building on the previous release, Gecko 1.9 has more than 14,000 updates including some major re-architecting to provide improved performance, stability, rendering correctness, and code simplification and sustainability. Firefox 3 has been built on top of this new platform resulting in a more secure, easier to use, more personal product with a lot more under the hood to offer website and Firefox add-on developers.
More Secure
* One-click site info: Click the site favicon in the location bar to see who owns the site and to check if your connection is protected from eavesdropping. Identity verification is prominently displayed and easier to understand. When a site uses Extended Validation (EV) SSL certificates, the site favicon button will turn green and show the name of the company you're connected to. (Try it here!)
* Malware Protection: malware protection warns users when they arrive at sites which are known to install viruses, spyware, trojans or other malware. (Try it here!)
* New Web Forgery Protection page: the content of pages suspected as web forgeries is no longer shown. (Try it here!)
* New SSL error pages: clearer and stricter error pages are used when Firefox encounters an invalid SSL certificate. (Try it here!)
* Add-ons and Plugin version check: Firefox now automatically checks add-on and plugin versions and will disable older, insecure versions.
* Secure add-on updates: to improve add-on update security, add-ons that provide updates in an insecure manner will be disabled.
* Anti-virus integration: Firefox will inform anti-virus software when downloading executables.
* Vista Parental Controls: Firefox now respects the Vista system-wide parental control setting for disabling file downloads.
* Effective top-level domain (eTLD) service better restricts cookies and other restricted content to a single domain.
* Better protection against cross-site JSON data leaks.
Easier to Use
* Easier password management: an information bar replaces the old password dialog so you can now save passwords after a successful login.
* Simplified add-on installation: the add-ons whitelist has been removed making it possible to install extensions from third-party sites in fewer clicks.
* New Download Manager: the revised download manager makes it much easier to locate downloaded files, and you can see and search on the name of the website where a file came from. Your active downloads and time remaining are always shown in the status bar as your files download.
* Resumable downloading: users can now resume downloads after restarting the browser or resetting your network connection.
* Full page zoom: from the View menu and via keyboard shortcuts, the new zooming feature lets you zoom in and out of entire pages, scaling the layout, text and images, or optionally only the text size. Your settings will be remembered whenever you return to the site.
* Podcasts and Videocasts can be associated with your media playback tools.
* Tab scrolling and quickmenu: tabs are easier to locate with the new tab scrolling and tab quickmenu.
* Save what you were doing: Firefox will prompt users to save tabs on exit.
* Optimized Open in Tabs behavior: opening a folder of bookmarks in tabs now appends the new tabs rather than overwriting.
* Location and Search bar size can now be customized with a simple resizer item.
* Text selection improvements: multiple text selections can be made with Ctrl/Cmd; double-click drag selects in "word-by-word" mode; triple-clicking selects a paragraph.
* Find toolbar: the Find toolbar now opens with the current selection.
* Plugin management: users can disable individual plugins in the Add-on Manager.
* Integration with Windows: Firefox now has improved Windows icons, and uses native user interface widgets in the browser and in web forms.
* Integration with the Mac: the new Firefox theme makes toolbars, icons, and other user interface elements look like a native OS X application. Firefox also uses OS X widgets and supports Growl for notifications of completed downloads and available updates. A combined back and forward control make it even easier to move between web pages.
* Integration with Linux: Firefox's default icons, buttons, and menu styles now use the native GTK theme.
More Personal
* Star button: quickly add bookmarks from the location bar with a single click; a second click lets you file and tag them.
* Tags: associate keywords with your bookmarks to sort them by topic.
* Location bar & auto-complete: type in all or part of the title, tag or address of a page to see a list of matches from your history and bookmarks; a new display makes it easier to scan through the matching results and find that page you're looking for. Results are returned according to their frecency (a combination of frequency and recency of visits to that page) ensuring that you're seeing the most relevant matches. An adaptive learning algorithm further tunes the results to your patterns!
* Smart Bookmarks Folder: quickly access your recently bookmarked and tagged pages, as well as your more frequently visited pages with the new smart bookmarks folder on your bookmark toolbar.
* Places Organizer: view, organize and search through all of your bookmarks, tags, and browsing history with multiple views and smart folders to store your frequent searches. Create and restore full backups whenever you want.
* Web-based protocol handlers: web applications, such as your favorite webmail provider, can now be used instead of desktop applications for handling mailto: links from other sites. Similar support is available for other protocols (Web applications will have to first enable this by registering as handlers with Firefox).
* Download & Install Add-ons: the Add-ons Manager (Tools > Add-ons) can now be used to download and install a Firefox customization from the thousands of Add-ons available from our community add-ons website. When you first open the Add-ons Manager, a list of recommended Add-ons is shown.
* Easy to use Download Actions: a new Applications preferences pane provides a better UI for configuring handlers for various file types and protocol schemes.
Improved Platform for Developers
* New graphics and font handling: new graphics and text rendering architectures in Gecko 1.9 provides rendering improvements in CSS, SVG as well as improved display of fonts with ligatures and complex scripts.
* Color management: (set gfx.color_management.enabled on in about:config and restart the browser to enable.) Firefox can now adjust images with embedded color profiles.
* Offline support: enables web applications to provide offline functionality (website authors must add support for offline browsing to their site for this feature to be available to users).
* A more complete overview of Firefox 3 for developers is available for website and add-on developers.
Improved Performance
* Speed: improvements to our JavaScript engine as well as profile guided optimizations have resulted in continued improvements in performance. Compared to Firefox 2, web applications like Google Mail and Zoho Office run twice as fast in Firefox 3, and the popular SunSpider test from Apple shows improvements over previous releases.
* Memory usage: Several new technologies work together to reduce the amount of memory used by Firefox 3 over a web browsing session. Memory cycles are broken and collected by an automated cycle collector, a new memory allocator reduces fragmentation, hundreds of leaks have been fixed, and caching strategies have been tuned.
* Reliability: A user's bookmarks, history, cookies, and preferences are now stored in a transactionally secure database format which will prevent data loss even if their system crashes.</font></i></ul>Leider sind momentan aufgrund des Ansturms so gut wie alle Download-Mirrors dicht. Selbst die Mozilla-Hauptseite ist zum aktuellen Zeitpunkt nicht zu erreichen. Insofern ist beim Download etwas Geduld gefragt.
<b>Download:</b><ul><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20080617190337">Mozilla Firefox 3.0 Deutsch [Windows] (Mirror 1)</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20080617190338">Mozilla Firefox 3.0 Deutsch [Windows] (Mirror 2)</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20080617190339">Mozilla Firefox 3.0 Deutsch [Windows] (Mirror 3)</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20080617190340">Mozilla Firefox 3.0 Deutsch [Linux i686]</a></li><li><a href="http://www.mozilla.org/mirrors.html" TARGET="_blank">Mirrorliste</a></li></ul><b>Links zum Thema:</b><ul><li><a href="http://wiki.mozilla.org/Releases/Firefox_3.0" TARGET="_blank">Release-Notes</A></li><li><a href="http://www.spreadfirefox.com/de/worldrecord/" TARGET="_blank">SpreadFirefox (Weltrekordversuch)</a></li><li><a href="http://www.mozilla.com" TARGET="_blank">Mozilla Homepage</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=2&id=1213265386">Opera 9.5</a></li></ul>
More Secure
Easier to Use
More Personal
p4z1f1st
- AMD FX-6300
- Gigabyte GA-970A-UD3
- AMD Radeon RX 480 8GB
- Dell U2312HM
- Crucial m4 SSD 256GB
- Sony Optiarc AD-7260S
- Seasonic X-Series X-660
ERSTER!...*am runterladen*
Wie ist das eigentlich mit der Kompatibilität der Addons?
Die meisten sind als kompatibel bis 2.x.x.x angegeben :/
Phil S.
- Mittelfranken
- Schwarzes Macbook
- AMD XP-M 2600+
- ABIT KV7
- 2x512 MB Corsair Pro RAM
- ATI Radeon 9800 pro
- 1x 19" Belinea 106080 und 1x17" Iiyama HM704UTc, beide auf 1152x864
- WD1600BB
- LG Brenner und AOpen DVD-Rom
- Creative Live 1024
- LianLi (das mit dem Aquarium Seitenteil)
- Gentoo
- ...und dann war da noch der quietische iMac G3. :-)
Hat jemand einen noch funktionierenden Link für die Mac Version? Komme gerade nirgendwo drauf…
EiRoGGe
- Leipzig
- IBM Thinkpad T60
- Intel Core i7-2600K @ 4x 4000MHz @ 1,144V
- ASUS P8Z68-V, Sockel 1155
- Thermalright HR-02 Macho (semi-passiv)
- 4x Kingston 4GB DDR3-1333 CL9
- Intel HD 3000
- ASUS PA246Q, 1920x1200
- Crucial m4 128GB, 2x Hitachi Z5K320 320GB
- Pioneer DVR-212BK
- Realtek HD
- Fractal Define R3
- HuntKey Jumper 300G @ Enermax T.B.Silence @ 5V
- Windows 7 Professional x64
Der hier zum Beispiel: http://rebecka.jiddernet.se/firefox/releases/3.0/mac/de/Firefox 3.0.dmg
Einfach nicht von der HTML-Datei ablenken lassen
gast0815
Biete mal wieder meinen FTP an:
[f_d]s[/f_d] Firefox 3.0 Final Deutsch (Windows)
[f_d]s[/f_d] Firefox 3.0 Final Deutsch (Linux)
[f_d]s[/f_d] Firefox 3.0 Final Deutsch (MacOS)
Stimmt es, dass die RC 3 = Final ist?
Die RC3 für Linux und Windows war ja die RC2.
Von daher RC2 = RC3 = Final?
Stonehedge
Thx Rob2k
Phil S.
- Mittelfranken
- Schwarzes Macbook
- AMD XP-M 2600+
- ABIT KV7
- WD1600BB
- Gentoo
danke *runterlad*
HTML Datei?Einfach nicht von der HTML-Datei ablenken lassen![]()
gast0815
Solche Pappnasen. Erst riesentamtam um nen Weltrekordversuch zu machen und dann nichtmal genug leistungsfähige Server anzubieten (oder die Last einfach besser zu verteilen?).
Nicht dass meine Kritik übermäßig ernst zu nehmen wäre, aber n bisschen peinlich sollte es Mozilla wohl schon sein.
Da gings doch sowieso nur um Marketing. Außerdem wird es nur gewertet, wenn man über getfirefox.com saugt, was ja nicht jeder macht oder einige doppelt und dreifach saugen. Solche Rekordversuche sind nicht repräsentativ.
GabbaGandalf
- Block 1 auf der Alm
- Evil Core 2 Duo 4300 @ 2.6 GHZ
- Asrock 4CoreDual VSTA
- Zalman CNPS7700-AlCu
- 2*1GB TeamGroup Team Elite DDR2-800
- Palit 6600GT AGP
- Samsung SyncMaster 950p
- 2*80GB Samsung SATA Raid0
- LG 4163b, LG 8164b
- AL888 HD
- NoName
- LC Power 450W Super Silent
- Windows XP Pro, Ubuntu 7.04 64bit
- Technisat Skystar 2 , VIA Firewire PCI Card
Mirrors:
Windows:
Rapidshare -> sehr schnell
Winfuture -> geht so...
Offizieller Link -> geht gar nicht mehr
Mac OS X:
Offizieller Link
Rapidshare
Windows:
Mac OS X:
Offizieller Link
Rapidshare
Stonehedge
Ich saugs grade mit meiner Ines D. N. Leitung bei Rob2K mit - für mich - verhältnismässig ordentlichem Speed
Gast31082015
Ja RC2 = RC3 = Final mitsamt MD5 Hash aber das RC3 gab es nur wegen MacOS da dort ein kleiner Fehler im Update war und dabei wurde das ganze einfach komplett auf RC3 umbenannt obwohl sich bei allen anderen Versionen nichts änderte. Weiter Fehler etc wurden im RC2 vorerst nicht gefunden oder besser gesagt nicht für "wichtig genug" gehalten. Von daher RC2 = Final.
PuppetMaster
Seit wann ist testen = Zeit schinden? Wären noch Fehler gefunden worden, wäre der RC2/3 eben nicht zur Final geworden.Denn dann ist das mega lustig und pure Zeitschinderei von Mozilla gewesen.
p4z1f1st
- AMD FX-6300
- Dell U2312HM
Ich glaube mir einzubilden, dass FF3 wirklich weniger Speicher frisst (bisher kein einziges mal >100MB) und auch etwas schneller lädt und sogar selber geladen wird...
Sir Ulli
- Bad Oeynhausen
- Seti, Spinhenge
- Seti, Spinhenge, ich war vor Ort
- Athlon64 X2 4.400, Imhell Quad 6.600
- HP 530
- Details zu meinem Laptop
- Imhell Quad 6.600 at 3.240 8 x 405
- Aus P5K Rev 2.1
- Thermalright SI-128 SE Papst 120 at 1.200
- 2 x A-DATA 4 GB DDR2-800 Kit 4,4,4,12
- Asus 8.500 GT SILENT/HTP/256M
- Samsung SyncMaster 2232BW 22 Zoll TFT
- Western Digital WD10EACS 1 TB
- Samsung SH-S203P Sata
- CS601 mit 2extra Päpsten at 9 Volt
- Fortron 350 Watt
- Windows7 Home Premium
Nur mal so als Tipp: in der Meldung unter "Mirror 3" gibt's nen Download vom planet3dgames.de Server. Der sollte eigentlich genügend Kapazitäten haben![]()
ja, der ist schnell genug
Sir Ulli
zapbranigan
irgendwie scrollt der bei mir unter os X leopard total komisch, da war der vorgänger echt angenehmer..
gast0815
Ok, danke! Wie ich vermutet habe.
Aber die Option "sanfter Bildlauf" hat nichts damit zu tun oder?
SPINA
- AMD Ryzen 7 5700X3D (100-100001503)
- ASUS ProArt B550-Creator
- AMD Wraith Prism
- Sapphire Pulse Radeon RX 7600 8GB (11324-01-20G)
- LG Electronics 27UD58P-B
- Western Digital SN850X (WDS400T2XHE)
- HL Data Storage BH16NS55
- Lian Li PC-7NB
- Seasonic PRIME Gold 650W
- Debian 12.x (x86-64) Xfce
- ASUS TPM-SPI (Nuvoton NPCT750A)
Haben sie schon im Vorfeld. Jetzt haben sie es wohl nicht mehr erwähnt, weil der ACID3 raus ist und dort der Opera 9.5 weiter ist.Er schafft den ACID2 Test. Wusste ich gar nicht. Komisch, dass sie damit nicht angeben gegangen sind.
JohnnyFu2006
Und hier:
Findet ihr übrigens jeweils die nightly build von Firefox, derzeitige Vesionsnummer ist 3.1a1pre. Also der Vorläufer von Firefox 3.1.
Ich habe bei Mozilla die Erfahrung gemacht das die nightly builds extrem gut laufen, benutze seit über einem Jahr jeweils die nightly build. Im durchschnitt hat man alle 30 Tage mal einen gröberen Fehler, der ist aber am nächsten Tag behoben. Wirkliche Produktionsausfälle hatte ich noch nie.
ftp.mozilla.org/pub/mozilla.org/firefox/nightly/latest-trunk/
Bozol
- MUC
- Mac Studio M1 Ultra (2022)
- iPad 2 white 64 GB Wifi+3G
- Apple 20-Core CPU / M1
- Apple
- Apple / Luftkühlung mit zwei Lüfter
- Apple 64 GB MT/L
- Apple 48-Core GPU / M1
- LG UltraFine 5K Display 27"
- Apple OEM 1TB NVME / 2x Crucial P3 NVME @ 4TB, 4x Crucial MX500 @ 1TB, 1x WD Red SA500 @ 4TB
- 8x WD 4000FYYZ, 4x WD RED 8 TB, 2x WD Passport 5TB
- Archgon Externer Blu-Ray Brenner USB 3.0
- Apple bzw. KH-Verstärker IFI Signature DAC + IFI CAN HD6xx Bundle (Sennheiser optimiert)
- Apple Voll-Aluminium Gehäuse / https://de.wikipedia.org/wiki/Mac_Studio
- Apple, intern verbaut
- Apple Bluetooth Tastatur V1
- Microsoft Modern Mouse
- macOS 15.3.2 Sequoia
- Firefox 136.0
- Harman Kardon Soundsticks III / die 8 FYYZ sind im Qnap TS-859 verbaut / die 4 Crucial SSD 1TB sind als Raid 0 in der Areca 8050 Thunderbolt verbaut, die 4x verbauten 8TB WD Red sind fürs Backup da
- ▼200 MBit ▲40 MBit
Nö, kann bis jetzt nix negatives feststellen, außer das von meinen Lieblings-Add-Ons fast alle nicht kompatibel sind.irgendwie scrollt der bei mir unter os X leopard total komisch, da war der vorgänger echt angenehmer..
Was mich mehr nervt ist die Tatsache das ich mich überall wieder neu einloggen muss.
DoC_HoLLiDaY
- Neuburg a. d. Donau
- AMD Ryzen 5 3600
- MSI B450M PRO-VDH MAX
- AMD Wraith Prism
- 48GB Patriot DDR4 3200MHz VIPER4
- 8GB ASROCK RX 5700XT Challenger
- 500GB Samsung SSD 850 EVO
- 512GB Intel 660p M.2 PCIe 3.0 x4 NVME
- 500W be quiet! Pure Power 11
Also, bei mir frisst er gerade mal die Hälfte an Speicher als meine Vorgängerversion...als schneller hingegen empfinde ich Ihn nivht unbedingt... was mich extrem stört ist die komische Darstellung der besuchten Seiten...
