Download MSI Afterburner 4.6.1 Final/Stable verfügbar.
User-News
Von eratte
Download bei www.guru3d
We just released MSI Afterburner 4.6.1 Final/Stable available for public download. Our popular graphics card tweaking and monitoring utility has been updated updates to provides a number of new features, options and skins.
MSI Afterburner 4.6.1 final is now raised to build number 15561. For those interested, we added a lovely new skin called Touch of Modern (see below). Also, based on popular request, there now is dual-fan control for reference design NVIDIA GeForce RTX 20x0 series graphics cards
Changelist version 4.6.1 final
Added new MSI Touch of Modern skin by Drerex design
Added asynchronous dual fan controlsupport for reference design NVIDIA GeForce RTX 20x0 series graphics cards. Please take a note that only 100% NVIDIA reference design dual fan control implementations are supported, third party proprietary asynchronous fan control solutions (e.g. EVGA iCX series asynchronous fans) are not supported and will not be supported in future versions. The following asynchronous fan control functionality is available:
Added new “Synchronize fan speeds” button, which is allowing you to switch between synchronous and asynchronours fan control modes. Please take a note that new fan speed controls are available in v4 skins only, v3 and v2 skins are deprecated and no longer receive new functionality
When fan speeds synchronization is enabled, MSI Afterburner’s fan control functionality behaves exactly like in the previous version, i.e. both fans are running asynchronically in default hardware automatic fan speed control mode but become linked synchronically if you enable manual or software automatic fan speed control mode
When fan speeds synchronization is disabled, you may select and adjust each fan speed independently. For software automatic fan speed control mode independent temperature curves are also adjustable for each fan
Improved hardware monitoring module:
Inverted hotkeys handling approach for multiple selected hardware monitoring graphs. Previously single graph settings mode was active by default, but you could apply some settings (e.g. “Show in On-Screen Display”) to multiple selected graphs with <Ctrl> hotkey modifier. Now such settings are applied to multiple selected graphs by default and <Ctrl> hotkey modifier is used to apply settings to single focused graph
Group operation notifier has been moved to hardware monitoring graph properties header
Improved backward compatibility with monitoring profiles created in the previous versions of application. It is no longer necessary to recreate the profiles having guru3d style monitoring settings without On-Screen Display layout
It is no longer necessary to click <Apply> button inside the On-Screen Display layout editor after changing current layout, now the changes are applied properly on closing the editor
The progress of saving multiple graphs’ settings is now displayed in the caption of the application’s property sheet
Optimized handling of “dirty” flag for settings decreases saving time for multiple graph’s settings when using multiple subsequent group operations
Added new “Hide attached monitoring panel” command to the context menu of hardware monitoring window. You may use it to toggle visibility of monitoring window when it is attached to the main application window
Now you may press <Ctrl> + <M> hotkeys to toggle monitoring window attachment
Improved voltage/frequency curve editor for both AMD and NVIDIA GPUs:
Now you may hold <Shift>and press left mouse button on initial desired horizontal position in the editor window to begin fragment selection, then drag mouse cursor to desired final horizontal position and release left mouse button to select a fragment. The following functionality is available for selected fragments:
You may double click the editor window to reset fragment selection
You may adjust the offset for any point inside the selection with mouse cursor to apply the same offset simultaneously to all selected points
You may adjust the offset for any point inside the selection with keyboard cursor keys, <Enter> or <Shift>+<Enter> keys to apply the same offset or specify the same target frequency or voltage for all selected points
Improved skin engine:
Skin engine no longer crashes when switching between the skins having the same site with and without alpha channel
Added thumbless skinned slider controls support
Added alpha path threshold support for skinned slider controls
Improved skin cross-compatibility layer:
Extended list of applications supported by skin cross-compatibility layer
Various compatibility fixes for third party skins supported by cross-compatibility layer
Fixed issue with GUI stopping responding during adjusting skin scaling ratio on the fly in high DPI mode when skin composition mode was set to layered mode with alpha
Updated third party hardware database:
Added new third party voltage control capable graphics cards to the database
Added new third party graphics cards with multichannel GPU, memory and VRM temperature sensors to the database
RivaTuner Statistics Server has been upgraded to v7.2.2
