User-News
Von eratte
MSI Afterburner 4.6.2 Stable/Final Download (guru3d)
Added voltage control for reference design NVIDIA GeForce RTX 20x0 SUPER series graphic cards
Added voltage control for AMD RADEON RX 5700 series graphics cards
Added new MSI Steampunked, MSI Lightning Anniversary and MSI Mystic skins by Drerex design
Improved hardware monitoring module:
Added CPU temperature monitoring support for AMD Ryzen 3X00 processors family
Added thermal offset for CPU temperature monitoring on AMD Ryzen Threadripper 29X0 processors family
Added package CPU power and per-core CPU power monitoring for AMD Ryzen processors family
Improved monitoring plugins architecture:
Added API function for reading host application’s hardware monitoring timestamp from the plugins. The timestamp is updated by host on each hardware polling iteration, so it allows the plugin to precache and reuse some sensor data if the same physical sensor value is being used in multiple data sources exported by plugin. Such approach is demonstrated in updated CPU.dll plugin for duplicating the same temperature sensor value for all cores on AMD CPU
Added optional plugin unititialization callback function, which is called by the host before unloading the plugins. New multithreaded Ping.dll plugin is demonstrating new function usage to shut down ping monitoring thread properly
Improved monitoring plugins:
Updated CPU.dll plugin is demonstating AMD Ryzen CPU temperature monitoring implementation and optimal duplication of the same temperature sensor readback for all CPU cores
Added new Ping.dll plugin for monitoring ping to desired server via ICMP echo requests. Please take a note that the plugin is configured to monitor ping to www.guru3d.com by default, it is up to you to specify target server name or IP address in the plugin properties
Improved skin engine:
Optimized skin rendering performance for skins using multiple overlapped animated indicators
Added position smoothing support to skinned indicators
Now skinned applications can forcibly disable indicator animation if necessary
Skin format reference guide has been updated to v1.8 to document these changes
Updated IO driver provides more secure MMIO and MSR access interface
RivaTuner Statistics Server has been upgraded to v7.2.3
Version 4.6.2
Added new MSI Steampunked skin by Drerex design
