News SETI.Germany : BOINC Pentathlon 2024: 1st project in the discipline Marathon
P3D-Bot
Bot von P3D
09.04.2006
54.180
195
Das Boot 3.0
Back to the Pentathlon pages​
PrimeGrid
Marathon
Announcement of the 1st project of the BOINC Pentathlon in the discipline Marathon​
The first project of the fifteenth BOINC Pentathlon in the discipline Marathon is:
PrimeGrid: only subproject Cullen Prime Search LLR (CUL) (http://www.primegrid.com/)
All credits granted between
05 May 2024, 00:00 (UTC) and
19 May 2024, 00:00 (UTC) will be taken into account for the BOINC Pentathlon statistics. Please note that pending credits cannot be taken into account! The statistics for this project can be found at
https://www.seti-germany.de/boinc_pentathlon/statistiken/challenge.php?challengeid=1&lang=en.
Note: Only work units of the subproject Cullen Prime Search LLR (CUL) are considered! You can select the subprojects in your project preferences: https://www.primegrid.com/prefs.php?subset=project. It is recommended to use the setting Multi-threading: Max # of threads for each task to allow several CPU cores to work on the same work unit. The result of a work unit is checked in a separate, significantly shorter work unit (Proof task) that can only be generated after the result has been reported. Reporting a large number of work units late in the race is therefore at your own risk.
Good luck to all Pentathlon participants! Have fun crunching this project and chasing these medals:
Annonce du 1er projet dans la discipline Marathon du BOINC Pentathlon​
Le premier projet du quinzième BOINC Pentathlon dans la discipline Marathon est le suivant:
PrimeGrid: uniquement le sous-projet Cullen Prime Search LLR (CUL) (http://www.primegrid.com/)
Tous les crédits de ce projet qui seront accordés entre le
05/05/2024 à 00h00 (UTC) et le
19/05/2024 à 00h00 (UTC) entrent dans le résultat du BOINC Pentathlon. Noubliez pas que les crédits en suspens («pending») ne pourront pas être pris en compte! Vous trouverez les statistiques pour ce projet sur cette page:
https://www.seti-germany.de/boinc_pentathlon/statistiken/challenge.php?challengeid=1&lang=fr
Remarque: Uniquement des UT du sous-projet Cullen Prime Search LLR (CUL) sont comptabilisées! Le sous-projet peut être sélectionné dans les préférences du projet: https://www.primegrid.com/prefs.php?subset=project. Il est recommandé de faire travailler plusieurs curs CPU sur la même unité de travail grâce au paramètre Multi-threading: Max # of threads for each task (nombre max de threads par tâche). Le résultat d'une unité de travail est vérifié à l'aide d'une unité de travail séparée, nettement plus petite («Proof task») qui ne peut être créée qu'une fois le résultat initial renvoyé. Le renvoi d'un grand nombre d'unités de travail à un moment ultérieur s'effectue donc à vos risques et périls.
Bonne chance à tous les participants du Pentathlon! Amusez-vous bien à cruncher sur ce projet et à chasser ces médailles:
Bekanntgabe des 1. Projekts in der Disziplin Marathon beim BOINC Pentathlon​
Das erste Projekt des fünfzehnten BOINC Pentathlon in der Disziplin Marathon ist:
PrimeGrid: nur das Subprojekt Cullen Prime Search LLR (CUL) (http://www.primegrid.com/)
In die Wertung des BOINC Pentathlon gehen alle Credits ein, die zwischen dem
05.05.2024 um 00:00 Uhr (UTC) und
19.05.2024 um 00:00 Uhr (UTC) gutgeschrieben werden. Beachtet bitte, dass ausstehende (pending) Credits nicht berücksichtigt werden können! Die Statistik zu diesem Projekt ist zu finden auf
https://www.seti-germany.de/boinc_pentathlon/statistiken/challenge.php?challengeid=1&lang=de.
Hinweis: Nur Workunits des Subprojekts Cullen Prime Search LLR (CUL) werden gewertet! Das Subprojekt kann in den Projekteinstellungen ausgewählt werden: https://www.primegrid.com/prefs.php?subset=project. Es wird empfohlen, mittels der Einstellung Multi-threading: Max # of threads for each task mehrere CPU-Kerne an derselben Workunit arbeiten zu lassen. Die Überprüfung des Ergebnisses einer Workunit erfolgt mit einer separaten, deutlich kleineren Workunit (Proof task), welche erst nach dem Melden des Ergebnisses erzeugt werden kann. Das Melden einer größeren Anzahl Workunits zu einem späten Zeitpunkt erfolgt daher auf eigene Gefahr.
Wir wünschen allen Teilnehmern viel Glück beim Pentathlon! Viel Spaß beim Crunchen dieses Projekts und der Jagd nach diesen Medaillen:
Lese weiter bei SETI.Germany....
