NVIDIA GeForce Grafiktreiber 180.48 WHQL
Nero24
Administrator
Teammitglied
01.07.2000
24.058
10.442
  • BOINC Pentathlon 2019
  • BOINC Pentathlon 2020
  • BOINC Pentathlon 2018
  • BOINC Pentathlon 2021
NVIDIA hat einen neuen Grafiktreiber für seine GeForce-8- und 9-Serie veröffentlicht. Hier die wichtigsten Features:<ul><font size="1">Exciting New Features:
* Enables NVIDIA SLI technology on SLI-certified Intel X58-based motherboards with the following GPUs: GeForce GTX 280, GeForce GTX 260, GeForce 9800 GX2, GeForce 9800 GTX+, and GeForce 9800 GTX. Learn more here.
* Enables NVIDIA PhysX acceleration on a dedicated GeForce graphics card. Use one card for graphics and dedicate a different card for PhysX processing for game-changing physical effects. Learn more here. (Note: GPU PhysX is supported on all GeForce 8-series, 9-series and 200-series GPUs with a minimum of 256MB dedicated graphics memory. This driver package automatically installs PhysX System Software version 8.10.13).
Blazing Fast Performance:
* Boosts performance in numerous 3D applications. The following are some examples of improvements measured with Release 180 WHQL drivers vs. Release 178 WHQL drivers (results will vary depending on your GPU, system configuration, and game settings):
o Up to 10% performance increase in 3DMark Vantage (performance preset)
o Up to 13% performance increase in Assassin's Creed
o Up to 13% performance increase in BioShock
o Up to 15% performance increase in Company of Heroes: Opposing Fronts
o Up to 10% performance increase in Crysis Warhead
o Up to 25% performance increase in Devil May Cry 4
o Up to 38% performance increase in Far Cry 2
o Up to 18% performance increase in Race Driver: GRID
o Up to 80% performance increase in Lost Planet: Colonies
o Up to 18% performance increase in World of Conflict
And More:
* Supports single GPU and NVIDIA SLI technology* on DirectX 9 and OpenGL.
* Supports CUDA.
* Supports Folding@home distributing computing application. Download the high performance client for NVIDIA GPUs here and join the NVIDIA team: #131015.
* Supports GPU overclocking and temperature monitoring by installing NVIDIA System Tools software.
* Includes numerous 3D application compatibility fixes. Please read the release notes for more information on product support, features, driver fixes and known compatibility issues.
* Users without US English operating systems can select their language and download the International driver here.
*Note: The following SLI features are only supported on Windows Vista: Quad SLI technology using GeForce 9800 GX2, 3-way SLI technology, Hybrid SLI, and SLI multi-monitor support.
GeForce GTX 280
GeForce GTX 260
GeForce 9800 GX2
GeForce 9800 GTX+
GeForce 9800 GTX
GeForce 9800 GT
GeForce 9600 GT
GeForce 9600 GSO
GeForce 9500 GT
GeForce 9500 GS
GeForce 9400 GT
GeForce 9400
GeForce 9300
GeForce 9200
GeForce 8800 Ultra
GeForce 8800 GTX
GeForce 8800 GTS 512
GeForce 8800 GTS
GeForce 8800 GT
GeForce 8800 GS
</font></ul><b>Download:</b><ul><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20081120092234">NVIDIA GeForce Grafiktreiber 180.48 WHQL Deutsch [Windows XP]</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20081120092235">NVIDIA GeForce Grafiktreiber 180.48 WHQL Deutsch [Windows XP x64]</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20081120092236">NVIDIA GeForce Grafiktreiber 180.48 WHQL Deutsch [Windows Vista 32-Bit]</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20081120092237">NVIDIA GeForce Grafiktreiber 180.48 WHQL Deutsch [Windows Vista 64-Bit]</a></li></ul>
Hach - da isser nun, der neue Treiber, endlich. WHQL und alles wird gut.
Oder nicht?
Gestern habe ich mir den neuen Graka Treiber gesaugt.
Und wie gehabt, den alten entfernt, Drivecleaner drüber laufen lassen und anschliessend den Neuen installiert.
Natürlich nicht ohne vorher einen Systemwiederherstellungspunkt zu setzen.... das sollte sich noch als nützlich erweisen!
Zuerst zickte die Installationsroutine rum - Blackscreen! - OK. - noch mal neu gestartet, dann lief die Installation wunschgemäß ab.
Keinerlei Probleme bis jetzt, die sollten aber noch folgen...
Nachdem mir mein System, nach dem Neustart den Dienst verweigerte, habe ich alles rückgängig gemacht und im abgesicherten Modus alle Treiberreste entfernt und nochmals neu installiert.
Jetzt lief der Rechner auch sauber hoch.
Geschafft! ...
Denkste!
Das Umschalten zwischen Normalbetrieb und SLI klappt nun auch ohne Neustart - feine Sache, da Multimonitoring immer noch nicht im SLI-Modus unterstützt wird.
Die ersten Testläufe waren auch zufriedenstellend.
FarCry hat einen deutlichen Leistungsschub erhalten. Wo im Benchmarktest die Framerate (Innenhof) schon mal auf unter 30 gesunken war, ist mit dem 180.48 davon nichts mehr zu spüren, konstant über 40 Frames, im Schnitt 54 und Max. 72 - fein!
Auch Crysis läuft AVG mit 48 Bildern pro Sekunde. Auch Prima!
Nun ist es an der Zeit, den Rechenknecht neu zu starten um einen Durchlauf mit 3DMurks zu wagen...
Und nun zu meinem ... PROBLEM.
Der Rechner fährt hoch (SLI immer noch aktiviert) und bleibt während des Ladevorganges - schon in der XP-Oberfläche - mit einem Bluescreen stehen.
Die Fehlermeldung ist so eigenartig, dass ich mir keinen Reim drauf machen kann:
DER TREIBER BEFINDET SICH IN EINER ENDLOSSCHLEIFE - DAS SYSTEM WIRD HERUNTERGEFAHREN!
Nur im abgesicherten Modus konnte ich dann mein Sys. wieder herstellen - alle Versuche normal zu starten scheiterten kläglich.
Evtl. hat ja einer von Euch ´nen Tipp, wie ich die Kiste mit dem neuen Treiber zum laufen kriege? Gibts da eine misteriöse BIOS-Einstellung oder einen Trick 17?
Ich meine, das sollte doch alles laufen - von wegen WHQL. Beim Beta hab ich mich auch nicht gewundert - ist ja halt ´n Beta. Aber so? SHIT!
Also Vorsicht - SLI scheint nicht recht mit dem neuen 180.48 zu funktionieren.
Hallo Nero24 - ich habe hier mal was zum neuen Treiber geschrieben - evtl. sollte man das zusammenführen?
Danke!
Lohnt es sich für PhysX eine seperate Grafikkarte in den Rechner zustecken ?
Ich dachte da an eine billige 8400GS für 25 Euro.
Meine Primäre Karte ist eine 9600GT.
gruß
@HulkHagen:
Wenn ich mir so angucke was bei CB geschrieben wird, so scheint der Treiber nicht immer diese Probleme zu verursachen. Es liegt wenn dann wohl an der Physix Unterstützung. Wird diese deaktiviert, dann läufts. Ist zumindest dort der Lösungsvorschlag. Andere User berichten allerdings das es bei ihen auf einem 8er SLI System läuft.
Kannst du ja vielleicht auch noch testen oder mal den Thread hier mitverfolgen: CB Thread
Ahhh - danke Onkel.
Physix habe ich schon deaktiviert.
Ich habe mein N-Tune in Verdacht.
Sobald ich heute hier raus komme, werde ich zu Hause gleich mal testen.
Wo sind denn die ganzen netten Sachen wie Dualview, Clone ect. hin? Nab ne 9600GT und eigentlich sonst keine Probleme mit dem Treiber oder dem PhysX Gedöns aber das man nicht mehr einstellen kann was auf den TV Out soll finde ich schon arg gemein.
MFG
Ich wurde nach der erfolgreich verlaufenen Installation des 180.48 WHQL direkt nach dem Reboot, vor jedem Windows-Desktop, von einem Bluescreen begrüßt, und das mit einer einzelnen 8800 GTX; also an SLI liegt es schonmal nicht.
Irgendwas ist da doch faul. :P
Danke für Eure Erfahrungen. Das reicht mir um vorerst weiter beim alten Treiber zu bleiben. Läuft grad so schön alles...:)
also bei mir läuft der treiber richtig gut mit einer 9800gt.
keine ahnung was ihr da für probs habt aber mit vista 64 habe ich keine probleme mit dem treiber
...so läuft.
Habe im abgesicherten Modus alles was mit Nvidia Display oder ntune zu tun hatte entfernt (Registry, alle Ordner und dll´s).
Jetzt muckt nix mehr, allerdings vermisse ich einige Einstellmöglichkeiten im Treiber.
Die Performance werde ich morgen mal antesten - macht keinen sooo schlechten Eindruck, zumindest nicht in den Games (Crysis, FC2). 3DMurks sagt da aber etwas anderes.
Da ist der Neue ein Stück langsamer...
Werde wieder berichten.
gruß
Unterm Strich: Nein!
Guckst Du hier:
http://www.planet3dnow.de/vbulletin/showthread.php?t=349396
Die Frage hatte ich auch mal.
Zum 180.48 WHQL: Ich habe ihn mir auch gestern installiert und habe ambivalente Erfahrungen gemacht. Bei Far Cry 2 habe ich eindeutige Performance-Zuwächse fetsgestellt. ca. 25-30% performanter als mit dem 178.24. Im 3D Mark 06 ein bißchen geringere Performance. Bei CoD4 habe ich nur mal rein gespielt und meine,daß die Leistung sich auch etwas verbessert habe. Ansonsten erst mal nichts außergewöhnliches bemerkt. Ntunes habe ich allerdings schon früher als unzureichendes Tool getestet und bei meiner letzten Neuinstallation weggelassen. Ich würde den Treiber soweit empfehlen, da er im Alltag schon etwas mehr rausholt und Benchmark Ergebnisse eh nur "Labor"-Werte sind, die nicht exakt auf den täglichen Gebrauch übertragbar sind.
*great*
.... an Deiner Systemkonfiguration? ???
Hier ebenfalls mit einer 8800GTX keinerlei Probleme, läuft (Vistax64) in allen Games hervorragend. *noahnung*
Hallöchen, ich hab ebenfalls ein Problemchen (wahrscheinlich eins von diesen die einer aber sonst keiner hat -.-). Also folgendes: Ich hab mir wie so einige andere Menschen auch GTA IV zugelegt. Installiert, gestartet...keine Texturen (juhu). Hab ich gegoogelt und siehe da es liegt am Grafiktreiber (hab Nvidia Treiber 169.24 drauf). Gut, is ja schon älter denk ich mir lad mir also den neuen 180.48 runter. Alten Treiber deinstalliert registry und kram gecleant neuen installiert, hochgefahrn lief alles. Sobald ich aber in den 3d-modus wechsle (es reicht schon dxdiag durchzuführen) friert mir das Bild ein und nix geht mehr, muss resetten. Ich hab mich schon durch etliche Foren gelesen und im Prinzip schon alles ausprobiert (bis hin zum neu-aufsetzen des windows) nichts funktioniert, sobald ich aber wieder meinen alten 169er treiber draufspiele funktioniert alles wieder. Weiß irgendeiner eine Lösung dafür oder wenigstens die Ursache des Problems, denn GTA würd ich schon gern spielen und gegen nen Leistungsschub bei anderen Games hätt ich prinzipiell auch nix einzuwenden ;D
Kurz noch mein System:
Intel Core 2 Quad Q6700
Windows Vista Ultimate x64
Gigabyte GA-EP43-DS3
4GB DDR2 RAM
Geforce 8800GT
580W Netzteil (Marke weiß ich grad nich)
Danke schonmal im Voraus
PS: den hier empfohlenen 180.84 beta hab ich auch schon probiert, das selbe ergebnis wie beim 180.48
Hi Leute,
also folgendes... seit dem ich gestern mein FarCry2 installiert habe und spiele, habe ich nun das 2te mal Bluescreen mit autom. Restart des Systems.
Die Fehlermeldung war glaube ich NOT_LESS_OR_EQUAL... ob davor nun DRIVER stand weiss ich net mehr. Nun frage ich mich, woran das liegt.
Ich hatte vorher den 178.24 NVidia Treiber drauf und nun den neuen 180.48 installiert.
Bei beiden Versionen hatte ich jeweils einen Bluescreen. Ich bin mir nicht sicher wie das jetzt läuft, nur habe ich statt der Ageia PhysX die von nVidia drauf; soweit ich weiss ist die PhysX-Engine im 180.48 integriert.
Da ich mein System mit 2 XFX GeForce 8800GTS 512MB AlphaDog im SLI laufen habe, frage ich mich doch was es nun auf sich hat.
Vielleicht könnt Ihr mir helfen. Ich setze unter meine Systemdaten noch die letzten 5 Speicherabbilder rein.
Danke schon mal für eure Hilfe
Gruß Marc
Computer:
Computertyp ACPI-Multiprocessor-PC
Betriebssystem Microsoft Windows XP Professional
OS Service Pack Service Pack 3
Internet Explorer 6.0.2900.5512
DirectX 4.09.00.0904 (DirectX 9.0c)
Computername ZEROCOOL
Benutzername Administrator
SMTP E-Mailadresse marc@stellmacherstrasse18.de
Domainanmeldung ZEROCOOL
Datum / Uhrzeit 2008-12-10 / 05:54
Motherboard:
CPU Typ DualCore AMD Athlon 64 X2, 2700 MHz (11 x 245)
Motherboard Name Asus A8N-SLI Premium (3 PCI, 1 PCI-E x1, 1 PCI-E x4, 2 PCI-E x16, 4 DDR DIMM, Audio, Dual Gigabit LAN, IEEE-1394)
Motherboard Chipsatz nVIDIA nForce4 SLI, AMD Hammer
Arbeitsspeicher 2048 MB (PC3200 DDR SDRAM)
BIOS Typ Award (08/10/06)
Anschlüsse (COM und LPT) Kommunikationsanschluss (COM1)
Anschlüsse (COM und LPT) ECP-Druckeranschluss (LPT1)
Anzeige:
Grafikkarte NVIDIA GeForce 8800 GTS 512 (512 MB)
Monitor Plug und Play-Monitor [NoDB] (SCDABUS2792)
Multimedia:
Soundkarte Realtek ALC850 @ nVIDIA nForce4 SLI (CK8-04) - Audio Codec Interface
Datenträger:
IDE Controller Standard-Zweikanal-PCI-IDE-Controller
Massenspeicher Controller NVIDIA nForce RAID Controller
Massenspeicher Controller NVIDIA nForce RAID Device
Massenspeicher Controller NVIDIA nForce Serial ATA Controller
Massenspeicher Controller VAXSCSI Controller
Floppy-Laufwerk Diskettenlaufwerk
Festplatte Maxtor Basics Desktop USB Device (931 GB, USB)
Festplatte NVIDIA STRIPE 465.77G (465 GB)
Optisches Laufwerk HL-DT-ST DVDRAM GSA-4163B (DVD+R9:4x, DVD+RW:16x/8x, DVD-RW:16x/6x, DVD-RAM:5x, DVD-ROM:16x, CD:40x/24x/40x DVD+RW/DVD-RW/DVD-RAM)
Optisches Laufwerk LITE-ON LTR-52327S (52x/32x/52x CD-RW)
Optisches Laufwerk SP6156P ZZV804Y SCSI CdRom Device
S.M.A.R.T. Festplatten-Status Unbekannt
Partitionen:
C: (NTFS) 80003 MB (54520 MB frei)
F: (NTFS) 99998 MB (62167 MB frei)
G: (NTFS) 35000 MB (11672 MB frei)
H: (NTFS) 261934 MB (790 MB frei)
I: (NTFS) 953867 MB (767372 MB frei)
Speicherkapazität 1397.3 GB (875.5 GB frei)
Eingabegeräte:
Tastatur HID-Tastatur
Maus HID-konforme Maus
Maus Logitech HID-compliant G5 Laser Mouse
Game Controller Microsoft-PC-Joysticktreiber
Netzwerk:
Primäre IP-Adresse 192.168.1.22
Primäre MAC-Adresse 00-15-F2-D3-10-98
Netzwerkkarte NVIDIA nForce 10/100/1000 Mbps Ethernet (192.168.1.22)
Peripheriegeräte:
Drucker An OneNote 2007 senden
Drucker HP LaserJet 4 Plus
Drucker Microsoft XPS Document Writer
USB1 Controller nVIDIA nForce4 SLI (CK8-04) - OHCI USB 1.1 Controller
USB2 Controller nVIDIA nForce4 SLI (CK8-04) - EHCI USB 2.0 Controller
USB-Geräte CanoScan LiDE 20/N670U/N676U
USB-Geräte Logitech RumblePad 2 USB
USB-Geräte Standard-USB-Hub
USB-Geräte USB-HID (Human Interface Device)
USB-Geräte USB-Massenspeichergerät
USB-Geräte USB-Verbundgerät
DMI:
DMI BIOS Anbieter Phoenix Technologies, LTD
DMI BIOS Version ASUS A8N-SLI Premium ACPI BIOS Revision 1303
DMI Systemhersteller System manufacturer
DMI Systemprodukt System Product Name
DMI Systemversion System Version
DMI Systemseriennummer System Serial Number
DMI System UUID 0009C507-CB5BD911-A67D0015-F2D3303D
DMI Motherboardhersteller ASUSTeK Computer INC.
DMI Motherboardprodukt A8N-SLI Premium
DMI Motherboardversion 1.02
DMI Motherboardseriennummer 123456789000
DMI Gehäusehersteller Chassis Manufacture
DMI Gehäuseversion Chassis Version
DMI Gehäuseseriennummer EVAL
DMI Gehäusekennzeichnung 123456789000
DMI Gehäusetyp Desktop Case
DMI gesamte / freie Speichersockel 4 / 2
Fehler nach reset in Ereignisanzeige
BCCode : 100000d1 BCP1 : B0E1D000 BCP2 : 00000002 BCP3 : 00000000
BCP4 : AB9CB793 OSVer : 5_1_2600 SP : 3_0 Product : 256_1
C:\DOKUME~1\ADMINI~1\LOKALE~1\Temp\WERe7dc.dir00\Mini121008-02.dmp
C:\DOKUME~1\ADMINI~1\LOKALE~1\Temp\WERe7dc.dir00\sysdata.xml
-----------------------------------------------Speicherabbildung---------------------------------------------------------
Übrigens, ich habe bereits .NET FRAMEWORK 3.5 geupdated vorletzten Monat und FarCry hatte was mit .NET FRAMEWORK 2.0 konfiguriert oder so...
Produkt: Microsoft .NET Framework 2.0 -- Setup cannot continue because this version of the .NET Framework is incompatible with a previously installed one. For more information, see http://support.microsoft.com/support.../q312/5/00.asp
Weitere Informationen über die Hilfe- und Supportdienste erhalten Sie unter http://go.microsoft.com/fwlink/events.asp.
Die Ereignisskennung MSInstaller EVENT-ID: 1013
Das ist wohl der Bluescreen
Systemerror: Typ: Fehler Kategorie 102 Ereignis 1003
Fehlercode 100000d1, 1. Parameter b914b000, 2. Parameter 00000002, 3. Parameter 00000000, 4. Parameter ab334793.
----------------------------------------------------------------------------------EDIT--------------------------------------------------------------------------------------------------------------------------------------------------
Da ich jetzt eine Crashdump Analyse gemacht habe kann man sehr schön sehen das es sich eventuell um den nVidia Treiber handelt. Vielleicht könnt Ihr damit ja was anfangen. Ich hatte im Treiber vorhin die PhysX-Funktion abgeschaltet und eine Reset gemacht. Mein Rechner ist hochgefahren, kam auf den Desktop und beim laden der letzten Treiber und anwendungen direkt Bluescreen und automatisch restart und das zweimal hintereinander.
Habe dann beim dritten Restart erst mal ausgeschaltet un 30 Sekunden gewartet, danach fuhr er ganz normal hoch. Dieser Fehler trat erst auf, als ich FarCry2 installiert habe und gespielt habe.
1: kd> !analyze -v
* Bugcheck Analysis *
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 008d2580, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000001, value 0 = read operation, 1 = write operation
Arg4: f7831a79, address which referenced memory
Debugging Details:
WRITE_ADDRESS: 008d2580
CURRENT_IRQL: 2
FAULTING_IP:
nvrd32+3a79
f7831a79 ab stos dword ptr esedi]
CUSTOMER_CRASH_COUNT: 5
DEFAULT_BUCKET_ID: COMMON_SYSTEM_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: Idle
LAST_CONTROL_TRANSFER: from f78346ae to f7831a79
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
f78aeb40 f78346ae 8a2c5818 8a2c5648 a287d884 nvrd32+0x3a79
f78aeb64 f7832b52 8a2c5648 a287d884 f7843134 nvrd32+0x66ae
f78aeb8c f7833d98 00000001 8a0b10d8 f7843134 nvrd32+0x4b52
f78aeba8 f7833e20 ffffffff ffffffff 89c8d7c4 nvrd32+0x5d98
f78aebdc f7837c81 8a2c5648 8a0b10d8 f78431a4 nvrd32+0x5e20
f78aec14 f783b418 00000000 f78aec30 f7837c28 nvrd32+0x9c81
f78aec20 f7837c28 00000000 89d65c88 f78aec44 nvrd32+0xd418
f78aec30 f7831814 89f836e0 89d65d67 89d65c88 nvrd32+0x9c28
f78aec44 804e18ff 00000000 89d65c88 89f836e0 nvrd32+0x3814
f78aec74 f74f28f8 8a2eeaf0 89d65c88 f78aecb8 nt!`string'+0x13
f78aec84 f74f2436 88a52700 00000001 00000000 SPTD4685+0x48f8
f78aecb8 f74f26f7 8a2eeaf0 88a52700 f78aed27 SPTD4685+0x4436
f78aed28 804dcd22 8a2eeaac 8a2eea38 00000000 SPTD4685+0x46f7
f78aed2c 8a2eeaac 8a2eea38 00000000 00000000 nt!Magic86400000+0x2da
f78aed30 8a2eea38 00000000 00000000 80561f20 0x8a2eeaac
f78aed34 00000000 00000000 80561f20 f7721e20 0x8a2eea38
STACK_COMMAND: kb
FOLLOWUP_IP:
nvrd32+3a79
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nvrd32+3a79
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nvrd32
IMAGE_NAME: nvrd32.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 48aa2789
FAILURE_BUCKET_ID: 0xD1_W_nvrd32+3a79
Followup: MachineOwner
---------------------------------------------------------WICHTIG-----------------------------------------------------------
Nach google Suche habe ich folgende Hinweise gefunden:
-FC2 und Crysis soll empfindlich auf Overclocking reagieren, also erstmal alles rückgängig machen.
-Virtuelle Beschleunigung des Sounds auf Basis stellen in der Systemsteuerung.
-Emulationslaufwerke wie in Alkohol 120% deaktivieren
-mal memcheck laufen lassen für 24Stunden Dauerbelastungstest des RAM (defekte?)
---------------------------------------------------FORENEINTRÄGE---------------------------------------------------
also fehler hat sich behoben. an sich hat wohl scheinbar das game probleme mit einigen soundkarten. sobald man die soundkarte deaktiviert startet das game auch.
Versuch mal ein anderes Cd-Rom Laufwerk, ich glaub es steht sogar auf der Verpackung von Far Cry2, dass der Kopierschutz unter Umständen mit bestimmten Laufwerken Probleme verursacht. Wobei ich mir nicht vorstellen kann, dass das zu nem Bluescreen führen kann.
Hm, hast Du vielleicht vorher schon ein anderes Spiel mit SecuRom-Kopierschutz installiert? Hab mal gelesen dass das überbügeln von verschiedenen Versionen zu solchen Fehlern führen kann. Das vollständige entfernen & anschließende Installation der aktuellsten Version kann zur Besserung führen.
hmm, ich hab das hier im netz gefunden, gilt zwar nur für die demo, aber ich probiers trotzdem mal aus:
Ich bekomme beim spielen oder laden von der Farcry Demo einen Bluescreen, was kann ich tun? Zum Anfang der Seite
Die momentan einzige Möglichkeit die bei (fast) allen funktioniert ist in den OpenGL Modus umzuschalten. Dieser bringt zwar ein paar Grafikfehler mitsich aber diese sind nicht unbedingt als schlimm oder spasshämmend anzusehen. Um in den OpenGL Modus umzuschalten ist folgendes zu tun:
* Öffne die systemcfg.lua im Hauptverzeichnis der Demo mit einem Texteditor
* Suche den Eintrag r_driver = "Direct3D9"
* Ersetze diesen Eintrag durch r_driver = "OpenGL"
* Speichere die Datei wieder ab
Das wars, jetzt kannst du in OpenGL spielen. Der OpenGL Modus ist noch nicht fertig programmiert, weswegen es auch zu Grafikfehlern kommt, dies wird sich bis zur Vollversion aber noch ändern. Bei NVIDIA-Usern kann es im OpenGL Modus zu verfälschter Farbdarstellung & zu hohem Kontrast kommen!
Mögliche Lösung für ATI-User:
Ich weis zwar nicht ob das bei jedem hilft:
* Das ATI Control Panel öffnen
* In das Tab "3D" wechseln
* Direct3D auswählen (Falls das nicht schon der Fall ist)
* Auf Benutzerdefinierte Einstellungen klicken
* Den Regler bei Einstellungen für Textur und Mipmap Detailebene zurückschieben bis Leistung dort steht
* Auf übernehmen klicken und das Control Panel schließen
Mögliche Lösung für NVIDIA-User:
* Aktuellen Treiber aufspielen
* Unter Direct3D-Einstellungen den Punkt Nebentabellen(-Emulation) aktivieren
Evlt. helfen auch andere Treiber.
bytheway: also diesen bluescreen fehler scheinen extrem viele zu haben, hab auch ganz viel topics dazu in irgendwelchen ami/UK foren gefunden, also bin ich zuversichtlich dass die ne lösung finden
So geht man vor :
1. Systemsteuerung
2. Sounds und Audiogeräte
3. Audio
4. Soundwiedergabe --> Erweitert --> Systemleistung
5. Hardwarebeschleunigung --> Schieberegler ganz nach LINKS !!!
6. OK drücken
7. Far Cry starten und zocken !
bei mir hat es nun bestens geklappt
Also für die Bluescreens hab ich nen Tip hat bei mir jedenfalls geklappt...
Wenn ihr Virtuelle Laufwerke habt schmeisst die mal runter.
Und NET Framework 3.0 drauf.
So hab ich es zumindest mal zum laufen bekommen nun bleibt der bei der Taxifahrt hängen.
Werde mal den Boardtreiber neu drauf werfen und weiter versuchen.
Hoffe das euch der Tip etwas geholfen hat.
EDIT: Evt hilft euch auch das UBI Soft SAN Tool
http://support.ubisoft.de/home.php
-----------------------------------------------------------FAZIT--------------------------------------------------------------
Ich würde erst mal versuchen alle Treiber also:
-BIOS Update
-Mainbordtreiber bzw. Chipsatztreiber updaten (alle vorher entfernen, wenn Treiber auf Festplatte ist)
-Eventuell SP3 mit.NET Framework 3.5
-Graka-Treiber neu
und bei vielen hat es sich mit der Virtuellen Beschleunigung des Sounds beim herunterstufen in der Systemsteuerung auf Basisbeschleunigung gegessen(Steht auch im Handbuch)
Ich werde jetzt mal einen 6 Stunden Dauertest des Spiels durchführen nach dem nächsten Neustart und danach werde ich Bescheid geben.
Gruß BadStranger
