Download Pidgin 2.7.1
KIDH
09.03.2007
4.837
531
Pogotopia
  • Spinhenge ESL
Der freie Multiprotokoll-Messenger Pidgin wurde in der Version 2.7.1 veröffentlicht. Das Programm unterstützt grundsätzlich die Chat-Protokolle von AIM, ICQ, Google Talk, Jabber/XMPP, MSN Messenger, Yahoo!, Bonjour, Gadu-Gadu, IRC, Novell GroupWise Messenger, QQ, Lotus Sametime, SILC, SIMPLE, MySpaceIM, und Zephyr - weitere stehen über Plugins zur Verfügung. Aktuell werden 70 Sprachen unterstützt.
Pidgin läuft unter Windows ab Windows 2000, Mac OS X ab 10.4 und Linux.
<b>Changelog:</b>
<ul><li>version 2.7.1 (05/30/2010):<blockquote><b>General</b><ul>
<li>Build fixes on OpenSolaris. (Brian Lu)</li><li>Add configure option --enable-trayicon-compat which installs tray icons into directories that are compatible with older versions of hicolor-icon-theme (0.9).</li></ul>
<b>Pidgin</b><ul>
<li>Restore the tray icon's blinking functionality</li><li>Fix a crash setting moods when an account is disconnected.</li></ul>
<b>Bonjour</b><ul>
<li>Fix a crash on disconnect.</li></ul>
<b>ICQ</b><ul>
<li>Fix bug that caused HTML to be displayed in incoming messages.</li></ul>
<b>MSN</b><ul>
<li>Fix unnecessary bandwidth consumption for buddy icon requests when buddies have capital letters in their passport addresses.</li><li>Support for direct connections, enabling faster file transfers, smiley and buddy icon loading. (Gábor Szuromi)</li></ul>
<b>XMPP</b><ul>
<li>Allow connecting to servers that advertise EXTERNAL (broken in 2.7.0)</li></ul>
<b>MXit</b><ul>
<li>Replace the MXit-specific mood management with the new standard Moods API.</li><li>Add the standard MXit emoticons.</li><li>Improve the handling of users being kicked from MultiMX rooms.</li><li>MXit doesn't allow you to see your buddy's Email Address or Title, so remove those two fields from the "Buddy Information" page.</li><li>Show buddy's Registration Country in their profile.</li><li>Increment protocol version to v6.0</li><li>If an invite you sent was rejected with a reason, display that message in the buddy tooltip.</li><li>CAPTCHA value is a required field during account activation. (Resolves issue on Maemo)</li><li>When your avatar image is changed, don't forget the user's profile information.</li></ul>
<b>Windows-Specific Changes</b><ul>
<li>Fix a regression introduced in 2.7.0 that caused Window Flashing not to work.</li></ul></blockquote></li></ul>
<b>Download:</b><ul><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.cgi?20100611212528">Pidgin 2.7.1 [Windows]</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.cgi?20100611212529">Pidgin 2.7.1 [Source]</a></li></ul>
<b>Links zum Thema:</b>
<ul><li><a href="http://www.pidgin.im" target="b">Offizielle Internetpräsenz</a></li><li><a href="http://de.wikipedia.org/wiki/Freie_Software" target="b">Was ist Freie Software?</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?id=1276283562">Miranda IM 0.8.25</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?id=1274810751">Trillian Astra 4.2.0.19</a></li></ul>
Hier noch die Vollversion von Pidgin (inklusiv GTK+): SourceForge
geht auch skype ohne das skype im hintergrund läuft?
waah was machen die da fürn mist.
je höher die versionsnummer steigt, desto mehr probleme bekomme ich -.-.
mit 2.6.6 war noch "alles okay".
seit 2.7.X habe ich nur probleme. die hälfte meiner contacts erhält meine messages mittlerweile schön verpackt in html tags.
so wird aus nem "ja" als message eine gut 10 zeilen lange nachricht aus html tags.....
