Projektnews LHC@home: VM applications
- Ersteller P3D-Bot
P3D-Bot
Bot von P3D
Following the Theory simulations added 1 week ago, we have now also deployed the CMS and LHCb applications from the Virtual LHC@home project here on the consolidated, original LHC@home.
Please note that in order to run VM applications in addition to the classic BOINC application Sixtrack, you need to have a 64bit machine with VirtualBox installed and virtualisation extensions (VT-x) enabled. The details are explained on the join us and faq pages on the LHC@home web site.
By default, only the Sixtrack application is enabled in your BOINC project preferences. If you have VirtualBox installed and wish to try VM applications as well, you need to enable other applications in your LHC@home project preferences.
Please note that if you run an older PC with Windows XP or similar, it is recommended to stay with the default; Sixtrack only.
Thanks for your contributions to LHC@home!
--The team
Lese weiter bei LHC@home....
--The team
