Projektnews MilkyWay@home: Running Modfit on MilkyWay@home
P3D-Bot
Bot von P3D
09.04.2006
76.670
239
Das Boot 3.0
Hello Crunchers,
Now that MilkyWay@home Separation Modfit has been running for a year as a stable application, we are going to be releasing it as the official MilkyWay@home application under our main project. This means we will slowly (over the next month) be phasing out the dedicated Modfit project as it will be redundant. Additionally, this means some extremely old systems may no longer be supported on the MilkyWay@home project. These include Windows 32-bit systems, and very old (CAL) GPUs. If you are noticing compatibility issues with your system after we begin the change next week please post them here.
Thank you all for your continued support.
Jake
[edit]
Modfit is now up and running on the main application. If you are seeing any issues please let me know here.
Thanks.
For instructions on compiling 32-bit MilkyWay@home, please visit http://milkyway.cs.rpi.edu/milkyway/forum_thread.php?id=3957.
[/edit]
Lese weiter bei MilkyWay@home....
