Projektnews MilkyWay@home: Separation Modified Fit Release
- Ersteller P3D-Bot
P3D-Bot
Bot von P3D
We are releasing a new version of separation! This version of separation will be run under a different application name because it runs a modified fit and we would like to be able to work using both the previous and new fits for the time being. If there are any issues with the work units from milkyway_separation__modified_fit please post them here.
The following platforms are supported with this update:
32-bit Linux: OpenCL devices with double precision and CPU
64-bit Linux: OpenCL devices with double precision and CPU
64-bit Windows: OpenCL devices with double precision and CPU
MacOSX: OpenCL devices with double precision and CPU
We hope to add 32-bit Windows support in the near future.
Thank you,
Jake W
Lese weiter bei MilkyWay@home....
Thank you,
Jake W
