Projektnews MilkyWay@home: Standalone screensaver test available for Linux
- Ersteller P3D-Bot
P3D-Bot
Bot von P3D
Testing applications are now available for Linux now that a major timing bug issue has been taken care of. Windows applications are also updated in the windows thread. Mac applications have been forwarded to the appropriate team members for compilation/testing and should be available soon.
Please feel free to leave suggestions/comments here and bug reports in this thread.
The demo is computationally expensive and will not run sufficiently fast on some machines (runs a bit choppy on a Pentium I5 2.4ghz CPU). The "cube_test" application has a much faster demo that uses the same graphics engine. If either works, the final screensaver should run smoothly on the same machine. The final screensaver will have precalculated paths and images, taking care of the speed issue.
mwdemo_linux.tar.gz (v2)
cube_test_linux.tar.gz (v2)
To use the application, download it and extract it to a folder on the desktop or in another folder if you prefer. Then run either of the two executable files that are extracted. As a precaution, it may be a good idea to save any data in other applications before running the full-screen version. For those that do not have Windows XP or later, a zip utility such as 7-zip or WinZip can be used to open the file. The controls listed below are similar to those of Celestia with a few more added in.
Source for all files can be found here.
CONTROLS
ESC - Exit application
Tab : Start over
Shift-Tab : save new start-point
Alt-tab : leave application temporarily when in full-screen mode
Prtsc or Print-screen: saves a screenshot
MOVEMENT
< / > : accelerate backwards /forwards
F1-F9 : change acceleration (each step is 10 times faster than the previous)
Arrow : look around
Ctrl-arrow : rotate view
Shift-arrow : revolve camera around galaxy center (inverted)
Alt-arrow : accelerate up/down/left/right
Spacebar : stop motion
Backspace : focus on center of galaxy
Shift-backspace : focus on Sol
Enter : travel to center of galaxy
Shift-enter : travel to Sol (gives an Earth view of the wedge)
APPEARANCE
1 / 2 / 3 : select object 1-3 (wedge, stream, galaxy)
+ / - : increase/decrease luminosity of object
Shift- + / - : increase/decrease star blur radius
Alt- + / - : increase, decrease number of stars visible
A : toggle axes view
C : toggle camera view
Notes:
If the application runs a little choppy, then it may help to hold keys a little longer if they do not activate every time, esp 1 / 2 / 3 when choosing an object.
(Alt-minus) and (Shift-minus) will quickly increase the frame-rate since they require fewer screen-writes.
As you move away from the stars, they will combine and brighten. The brightness can be reduced manually (see above).
Update: fixed broken links
Update: added replacement keys for foreign keyboards:
p and m keys replace + / -
b and f keys replace < / >
Lese weiter bei MilkyWay@home....
CONTROLS
Tab : Start over
MOVEMENT
Arrow : look around
APPEARANCE
Notes:
