Projektnews MilkyWay@home: testing new validator
- Ersteller P3D-Bot
P3D-Bot
Bot von P3D
I've started up the new validator, so please be patient as I get all the kinks worked out over the next few days. Validation will now work as follows: Every result that could improve one of our searches will be validated (with a min quorum of 3 -- and the accuracy of the fitness reported must be within 10e-11 of the quorum results, this means that single precision GPU results will be flagged invalid). Results that won't improve a search will be validated 50% of the time until the error rates of hosts stabilizes in the database (this will probably take a couple weeks). Afterwards, for the results that don't improve our searches, we'll be using BOINC's adaptive validation based on hosts error rates (which will be between 10% and 100% depending on how many errors the host typically has).
On a side note, we'll also be updating the applications this week. We've made new background models for the milky way that we want to test. Additionally, there are some server related performance improvements that should help the server response time. I'm hoping to have the source code available by tuesday so people can compile their own applications, then make the full swap over to the new application sometime early next week.
Lese weiter bei MilkyWay@home....
