Projektnews MilkyWay@home: Users Auto-Aborting Work Units
- Ersteller P3D-Bot
P3D-Bot
Bot von P3D
Hello all,
It has come to our attention that some users have been setting their BOINC clients to auto abort work units from specific applications. Doing this sends an error results back to our server which then causes some work units to be unable to validate. Essentially, it prevents some of our hard working crunchers from getting their due credits. The proper way to prevent yourself from getting work units from a specific applications such as our beta applications N-Body or Modified Fit, is to go to your account page on our website (http://milkyway.cs.rpi.edu/milkyway/home.php). Under the Preferences section please select the link for your preferences for this project. There will then be a link to edit these preferences on this page. Halfway down your preferences, there will be some check boxes in the "Run only the selected applications" section. You will only receive work units for the applications you have check marks next to. For reference: Milkyway@home is our flagship application and is considered stable and in its final released state; Milkyway@home N-body Simulation is our beta version N-body simulation and orbit fit program; Milkyway@home Separation is an, as of now, unused application; Milkyway@home Separation (Modified Fit) is our beta version separation code testing new models for both streams and background in the Milky Way Halo. As usual if you have any issues with this method or questions about it please post them here. We appreciate your cooperation and understanding in this.
Thank you,
Jake W.
TL
R: If you are auto-aborting work units please stop and use the method above to prevent users from losing credits and to prevent problems in our algorithms.
Lese weiter bei MilkyWay@home....
Thank you,
Jake W.
TL
R: If you are auto-aborting work units please stop and use the method above to prevent users from losing credits and to prevent problems in our algorithms.Lese weiter bei MilkyWay@home....
