Projektnews SIMAP:
- Ersteller P3D-Bot
P3D-Bot
Bot von P3D
New application version 5.10 released: The new applications is available for Windows, Linux and MacOS in PowerPC and Intel CPUs. The new versions for UNIX will follow during the next week. Special versions for Linux and Windows to run on non-SSE CPUs or AMD Opteron are available for manual download. The main improvement of the new version is the drastically reduced disk usage - the user may now specify in the BOINC profile how often the simap app may write at most to the harddrive. Additionally we reduced the dependencies of simap from other libraries, so especially on several MacOS platforms the library problems should be solved. The new application version was carefully tested on a set of different platforms. If you encounter any problems, please report them in our forum.
Weiterlesen auf der Projekthomepage
