Routersicherheitslücken - Sammelthread. Den Anfang macht ASUS
- Ersteller eratte
- Ryzen R9 9950X3D
Neustart und Firmware-Update zwecklos: Tausende Asus-Router kompromittiert (heise)
Das schon übel:
ASUS Routers Vulnerable: Hackers Implant Undetectable Backdoors in NVRAM (guru3d)
9,000 Asus routers compromised by botnet attack and persistent SSH backdoor that even firmware updates can't fix (tom's Hardware)
Das schon übel:
Die Hintertür selbst werde in nicht-flüchtigem NVRAM abgelegt, weshalb sie weder durch einen Neustart noch durch ein Firmware-Update geschlossen werden könne.
Ist ein Gerät kompromittiert, helfe nur das Zurücksetzen auf die Werkseinstellung und die manuelle Neukonfiguration.
- Ryzen R9 9950X3D
ASUS Routers Vulnerable: Hackers Implant Undetectable Backdoors in NVRAM (udated) (guru3d)
Update: Here is the response from ASUS:
In response to recent media reports regarding attempts to exploit vulnerabilities in ASUS routers, ASUS would like to communicate that these vulnerabilities can be fixed. While some have noted that a firmware update alone may not completely address the issue, ASUS would like to emphasize the following recommendations — including updating to the latest firmware, performing a factory reset, and setting strong administrator passwords — to effectively restore and maintain device security.
The steps outlined below are not only essential for mitigating potential risks but also critical for reinforcing long-term protection and responsible device management in today’s evolving cybersecurity environment.
Firmware updates and strong passwords can effectively prevent future risks
These media reports involve security vulnerability (CVE-2023-39780), which was disclosed in 2023. Devices that have been updated with the latest firmware and secured with a strong administrator password can prevent future exploitation of this vulnerability and block similar attack methods.
Users are recommended to use a password at least 10 characters long, and include uppercase and lowercase letters, numbers, and symbols. In addition, ASUS recommends keeping device firmware up to date to ensure ongoing protection.
Devices that may have been affected can be fully restored
If the device was previously using outdated firmware along with a weak password, and users suspect it may have been compromised, please follow the steps below to secure the device:
1. Update the firmware to the latest version
2. Perform a factory reset to clear any unauthorized or abnormal settings
3. Set a strong administrator password as described above
These steps will ensure that the device is fully secured and no residual risk remain.
End-of-Life (EOL) devices can still be safely used
For EOL devices that no longer receive firmware updates, the following best practices are recommended:
1. Install the latest available firmware version for the device
2. Use a strong administrator password
3. Disable all remote access features such as SSH, DDNS, AiCloud, or Web Access from WAN
Completing the above steps will effectively prevent the exploitation methods described in recent reports.
Optional self-checks for suspicious activity
Users may perform the following checks to determine if their device shows signs of unauthorized access:
1. Confirm that the SSH (especially TCP port 53282) is not exposed to the internet
2. Check the System Log for repeated login failures or unfamiliar SSH keys
3. If anything appears suspicious, follow the above recommendations to thoroughly remove any potential threats.
ASUS remains fully committed to ensuring the security of its users. Firmware update notifications and security recommendations have been issued for supported models. For further assistance, please contact the ASUS Customer Service team.
Thank you for your continued trust and support.
RedBaron
- AMD Ryzen 9 9950X
- ASRock B650E PG Riptide WiFi UEFI Ver. 4.43, AGESA: ComboAM5 1.3.0.1b Patch A
- 128 GiB (4x32) Kingston DDR5 4800MHz@1.1V KVR56U46BD8-32 (SK Hynix A-Die, 2R)
- ASrock RX 9070 Challenger 2,8 GHz, -130mV Offset@TBP 220 Watt, 16 GB GDDR6 Hynix
- Seagate Ironwolf ST4000VN006-3CW104 4TB SATA3, gedämmt, Seagate 4TB USB 3.2 extern, WD 1TB USB exte
- Realtek ALC897
- Be Quiet be quiet! Pure Power 12 M 1200W 80+ Gold
- Logitech M500 Corded Mouse
- Linux Mint 22.3 x64 + Kernel 7.0.0-42, Win 11 Pro 26H2 x64
- Firefox 160 in der aktuellen Version
- 3D Connexion SpaceNavigator, HP Color LaserJet Pro MFP M181fw, Fritzbox 7690 & 7530 als Mesh, Creative i-Trigue 330, Speedlink Competition Pro USB, USB-3,5"-Diskettenlaufwerk, USB-RS232-Adapter
- ▼250 ▲40
Vielen Dank für die Eröffnung dieses Thema.
RedBaron
- AMD Ryzen 9 9950X
- Realtek ALC897
- ▼250 ▲40
CVE-2025-34037: Linksys E-Series, back from the dead
Was die Sache kritisch macht: No credentials, no user interaction required.
What is it?
This one is a nightmare for anyone still clinging to an older Linksys E-Series router. CVE-2025-34037 is a critical OS command injection vulnerability affecting the /tmUnblock.cgi and /hndUnblock.cgi endpoints over HTTP port 8080. What makes it so nasty? It's unauthenticated, zero-click, and has a perfect CVSS score of 10.0. This means an attacker can just... do it. No credentials, no user interaction required.
- Ryzen R9 9950X3D
Und wenn ich es richtig verstehe außer Austauschen keine Abhilfe.
- Ryzen R9 9950X3D
Hier geht es auch noch mal um die ASUS Router aber auch um Mainboard/Device Software
- Ryzen R9 9950X3D
RedBaron
- AMD Ryzen 9 9950X
- Realtek ALC897
- ▼250 ▲40
- Ryzen R9 9950X3D
Shearer
- Munich, Germany
- Gaming Rig
- AMD Ryzen 7 5700X
- Gigabyte B550M DS3H
- Noctua NH-D14
- 2x 8 GB DDR4 PC3200
- AMD Radeon RX 6800XT
- 2x HP E273q WQHD
- 256 GB + 2 TB SN580X
- Lian LI Lancool 207
- Gigabyte 650W
- Win11 Pro 64
mein recht alter LTE Router TL-MR100 steht erstmal nicht in der Liste
- Ryzen R9 9950X3D
Nicht zu glauben
Server-Lizenz abgelaufen: Motorola-App streikt (heise)
Die MotoSync+-App dient eigentlich dazu, Motorola-Router zu steuern. Doch App-Probleme machen die Router teilweise sogar unbenutzbar.
MusicIsMyLife
- in der Nähe von Cottbus
- Asteroids@Home
- Alltags-PC
- HP DV7-2225sg
- AMD Ryzen 9 9950X3D
- MSI MPG X870E Edge TI WiFi
- 4x 48 GB G.Skill TridentZ 5 TGB (F5-6400J3239F48GX2-RS5K)
- Sapphire NITRO+ RX 7900 XTX Vapor-X
- WD_Black XN850X 4 TB, Micron 9300 Pro 15,36 TB (U.2)
- keine, SSD only...
- Monster-Cube (2x Little Devil LD-PCV8 - individuell zusammengestellt)
- MSI MPG A1000G PCIE5
- ASUS ROG Strix Flare
- Steelseries Sensei 310
- Windows 11 Professional
- Brave
- ▼950 MBit ▲450 MBit
1. Ich habe durch den Post zum ersten Mal mitbekommen, dass Motorola Router vertreibt.
Das wusste ich tatsächlich nicht.
2. Für eine "lokale" Konfiguration ist eine App mit (offensichtlicher) Cloud-Anbindung notwendig?!
3. WTF?
9. WTF?
Ich bin gerade echt sprachlos, wie man sowas hinbekommen kann - und das sowas tatsächlich von irgendjemandem eingesetzt wird.
Keine lokale Konfigurationsmöglichkeit = kein Einsatz. So ungefähr würde bei mir Punkt 1 der Anforderungsliste aussehen - zumindest im Privatbereich. Dienstlich wäre es etwas differenzierter, solange ich selbst "die cloud sein kann".
Sachen gibts...
Das wusste ich tatsächlich nicht.2. Für eine "lokale" Konfiguration ist eine App mit (offensichtlicher) Cloud-Anbindung notwendig?!
3. WTF?
9. WTF?
Sachen gibts...
- Ryzen R9 9950X3D
Ich mir war das auch nicht bewusst, so etwas würde ich auch nicht kaufen.
Aber die Richtung gibt es auch bei anderen, z.b. manche Funktionen nur per App und einem Abo dazu.
Ich kaufe nur Router/Netzwerkgeräte die sich auch komplett per lokaler Webseite konfigurieren lassen und ohne Abo.
Da scheiden dann schon einige Hersteller/Geräte aus.
Mente
- constalation astroids yoyo
- yoyo doking
- Ryzen 3950x
- My Home
- AMD 9800x3D
- Asrock X870 Taichi
- Headkiller IV, Alphacool Eisball, 2*420+2*240Radi
- Patriot Viper Elite 5 48Gb 6400 CL32
- AMD Radeon RX 6900 XT Ref. @Alphacool Eisblock Aurora
- MSI Optix MAG27CQ
- n/a
- n/a
- Soundblaster X4
- Seasonic Prime GX-850 850W
- Mountain Everest Max, DE, Logitech G19
- Logitech G903 Lightspeed, USB
- Win 11 pro, Linux Ubuntu
- IE 11 Mozilla Opera
- Logitech PRO RENNLENKRAD DD
- ▼500Mbit ▲55Mbit
Hi wie ich gehört habe ist das App Zwang Thema nicht exklusiv und sehr viel Größer als ich bisher dachte (TP-Link Deco, Netgear Orbi, Google Nest WiFi, Amazon Eero) lassen sich alle ohne App nicht einrichten, ok viele davon gibs nicht bei uns aber der Trend scheint gestartet zu sein......
MusicIsMyLife
- Asteroids@Home
- Alltags-PC
- HP DV7-2225sg
- Brave
Ja, das ist leider wahr. Und dieser leidige Trend beschränkt sich auch nicht auf Router.
Zuletzt hatte ich irgendeine News von Tesla gelesen, dass unter bestimmten Konstellationen Funktionen, die man "früher" (TM) gekauft hat, jetzt nachträglich zu einem kostenpflichtigen Abo werden sollen. Man hat es also schonmal bezahlt und bekommt es jetzt entweder wieder weggenommen oder muss per Abo löhnen.
Dürfte eine News zu Full-Self-Driving gewesen sein. Feature gekauft, bisher nicht aktiv - künftig aber wahrscheinlich nur nutzbar, wenn monatlich gezahlt wird.
In manchen Fällen ist das fast schon grotesk, was da so abgeht.
Wenn man sich das mal genauer überlegt:
Bei dem obigen Motorola-Beispiel benötige ich quasi einen Internetzugang, um mir eine App runterzuladen, damit ich den Router für meinen Internetzugang zu Hause konfigurieren kann - damit ich einen Internetzugang habe.
Klar, heutzutage hat jeder mobile Daten oder irgendeine Möglichkeit, über offene WLANs eine App zu laden. Aber wenn ich z.B. umziehe und mir einen neuen Motorola-Router zulegen würde - ich müsste scheinbar für die Ersteinrichtung des Routers über einen anderen Weg eine App laden, damit ich mit dem Router ins Internet kommen kann.
Verrückt, wie weit die Menschheit stellenweise gekommen ist...
- Ryzen R9 9950X3D
- Ryzen R9 9950X3D
- Ryzen R9 9950X3D
Wendell mag die Apps auch nicht
- Ryzen R9 9950X3D
- Ryzen R9 9950X3D
Minion-Router Kevin & Bob: Deshalb sollten Sie die Finger davon lassen (heise)
Social Media Lemming hypen aber auch jeden Mist.
- Ryzen R9 9950X3D
- Ryzen R9 9950X3D
ASUS mal wieder, kommen aber noch andere. Genug Argumente auch gegen die Einstellungs APPs auf Smartphones.
Unauthenticated RCE affecting 35 million ASUS routers (MrBruh's Epic Blog)
- Ryzen R9 9950X3D
- Ryzen R9 9950X3D
- Ryzen R9 9950X3D
