Download VirtualBox 2.1.4
TiKu
Administrator
Teammitglied
16.11.2001
21.706
1.322
München
  • SIMAP Race
  • QMC Race
  • Spinhenge ESL
  • Docking@Home
  • BOINC Pentathlon 2021
Nach einem Monat Entwicklungszeit hat Sun die Version 2.1.4 der kostenlosen Virtualisierungssoftware VirtualBox veröffentlicht. Dabei handelt es sich um ein reines Bugfix-Release; neue Funktionen sind nicht hinzugekommen.
VirtualBox ist für Windows, Mac OS X, Linux und Solaris verfügbar. Zu den unterstützten Gastsystemen zählen neben Windows, Linux und Solaris auch OS/2, DOS und einige BSD-Derivate.
<strong>Changelog 2.1.2 zu 2.1.4</strong><ul><li style="font-size: smaller;">Windows hosts: fixed host crashes/hangs on certain 32 bits Windows systems when running Linux guests (bugs #1606, #2269, #2763)</li><li style="font-size: smaller;">Windows hosts: Fixed network component BSOD issue (bugs #3168, #2916)</li><li style="font-size: smaller;">Windows hosts: Fixed installation issues (bugs #2517, #1730, #3130)</li><li style="font-size: smaller;">Linux hosts: fixed occasional kernel oopses (bug #2556)</li><li style="font-size: smaller;">Linux hosts: fixed module dependency for shipped modules (bug #3115)</li><li style="font-size: smaller;">Linux hosts: moved the udev rules for USB forward so that they don’t override existing system rules (bug #3143)</li><li style="font-size: smaller;">Linux hosts: fixed the issue with guest not being able to communicate with each other when attached via TAP interfaces (bug #3215)</li><li style="font-size: smaller;">Linux hosts: give up probing for USB gracefully if dbus or hal are not available (bug #3136)</li><li style="font-size: smaller;">Linux hosts: fixed warnings in installer when SELinux was disabled (bug #3098)</li><li style="font-size: smaller;">Linux hosts: VirtualBox sometimes failed to start if it had been started using sudo previously (bug #3270)</li><li style="font-size: smaller;">Solaris hosts: fixed high CPU load while running many guests in parallel</li><li style="font-size: smaller;">Solaris hosts: fixed inability to start more than 128 VMs</li><li style="font-size: smaller;">VMM: fixed performance regression for Windows guests (bug #3172)</li><li style="font-size: smaller;">VMM: ignore CPU stepping when restoring a saved state/snapshot</li><li style="font-size: smaller;">REM: fixed inability to use gdb to debug programs in Linux guests with software virtualization (bug #3245)</li><li style="font-size: smaller;">GUI: fixed dead key handling on Solaris hosts (bug #3256)</li><li style="font-size: smaller;">GUI: in the shutdown dialog, disable the action send the shutdown signal if the guest is currently not using ACPI</li><li style="font-size: smaller;">GUI: suppress additional key release events sent by X11 hosts when keys are auto-repeated (bug #1296)</li><li style="font-size: smaller;">API: restore case insensitive OS type name lookup (bug #3087)</li><li style="font-size: smaller;">VBoxHeadless: really don’t start X11 services (clipboard service, 3D acceleration; Solaris & Darwin hosts only; bug #3199)</li><li style="font-size: smaller;">NAT: fixed occasional crashes when the guest is doing traceroute (non-Windows hosts; bug #3200)</li><li style="font-size: smaller;">NAT: fixed crashes under high load (bug #3110)</li><li style="font-size: smaller;">NAT: fixed truncated downloads (Windows hosts only, bug #3257)</li><li style="font-size: smaller;">NAT: don’t intercept TFTP packages with a destination address different from the builtin TFTP server (bug #3112)</li><li style="font-size: smaller;">USB: several fixes for USB passthrough on Linux hosts</li><li style="font-size: smaller;">USB: reduced host CPU utilization if EHCI is active</li><li style="font-size: smaller;">VRDP: fixed VRDP server black screen after a client reconnect (bug #1989)</li><li style="font-size: smaller;">VRDP: modified rdesktop client (rdesktop-vrdp) now uses NumLock state synchronization (bug #3253)</li><li style="font-size: smaller;">LsiLogic: make FreeBSD guests work (bug #3174)</li><li style="font-size: smaller;">ATA: fixed deadlock when pausing VM due to problems with the virtual disk (e.g. disk full, iSCSI target unavailable)</li><li style="font-size: smaller;">iSCSI: fixed possible crash when pausing the VM</li><li style="font-size: smaller;">3D support: added missing GL_MAX_TEXTURE_COORDS_ARB (bug #3246)</li><li style="font-size: smaller;">Windows Additions: fixed ERROR (e0000101) error during installation (bug #1923)</li><li style="font-size: smaller;">Windows Additions: fixed Windows Explorer hang when browsing shared folders with 64 bit guests (bug #2225)</li><li style="font-size: smaller;">Windows Additions: fixed guest screen distortions during a video mode change</li><li style="font-size: smaller;">Windows Additions: fixed the Network drive not connected message for mapped shared folders drives after the guest startup (bug #3157)</li><li style="font-size: smaller;">Linux Additions: fixed occasional file corruption when writing files in O_APPEND mode to a shared folder (bug #2844)</li><li style="font-size: smaller;">Linux Additions: the mouse driver was not properly set up on X.Org release candidates (bug #3212)</li><li style="font-size: smaller;">Linux Additions: fixed installer to work with openSUSE 11.1 (bug #3213)</li><li style="font-size: smaller;">Linux Additions: disable dynamic resizing if the X server is configured for fixed resolutions</li><li style="font-size: smaller;">Linux/Solaris Additions: handle virtual resolutions properly which are larger than the actual guest resolution (bug #3096)</li></ul><strong>Download:</strong><ul><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20090218003720">VirtualBox 2.1.4 (Windows, 32 Bit)</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20090218003721">VirtualBox 2.1.4 (Windows, 64 Bit)</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20090218003722">VirtualBox 2.1.4 (Mac OS X, Intel-CPU)</a></li><li><a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20090218003723">VirtualBox 2.1.4 (Solaris/OpenSolaris)</a></li><li><a href="http://www.virtualbox.org/wiki/Linux_Downloads" target="_blank">VirtualBox 2.1.4 für verschiedene Linuxdistributionen</a></li></ul>
<strong>Link zum Thema:</strong> <a href="http://www.virtualbox.org/" target="_blank">VirtualBox Webseite</a>
Das mag ein Problem mit dem frisch wiederhergestellten Windows XP liegen, aber bei mir erkennt xVM eine Windows7-Maschine nicht mehr sauber bzw. bootet sie nicht mehr.
Halbwegs frustrierend *buck*
