Allg. [Vorstellung] foobar2000 v2.2 Preview 2024-04-15 wurde veröffentlicht
foobar2000 1.6.2 beta 4 wurde veröffentlicht.
Changelog v1.6.2:
  • HLS radio bug fixes.
  • Double clicking album covers in Default User Interface shows full-size picture.
  • Archive reader optimizations; much more efficient handling of uncompressed (store-mode) archives.
  • Drag-and-drop or copy-to-clipboard of large number of tracks no longer copies their plaintext titles.
  • Fixed unresponsive Album List when selecting lots of items. (beta 2).
  • Added workarounds for wrong audio mix format reported by certain buggy soundcard drivers. (beta 3, beta 4)
  • Added workaround for too quiet playback since removal of Windows Mixer volume slider synchronization in previous versions. (beta 4)
Download foobar2000 1.6.2 beta 4
foobar2000 1.6.2 beta 5 wurde veröffentlicht.
Changelog v1.6.2:
  • Fixed crashing when attempting to read from 7-ziup archive that does not exist. (beta 5)
  • Increased playback queue length limit to 256 tracks. (beta 5)
Download foobar2000 1.6.2 beta 5
foobar2000 1.6.2 beta 6 wurde veröffentlicht.
Version 1.6.2 beta change log (Thread im offiziellen Forum):
Beta 2:
  • Fixed missing .webp in stub image picker.
  • Fixed bugs in new image viewer window.
  • Improved Album List performance when selecting lots of item.s
Beta 3:
  • Attempted fixes for new default output not working on some machines.
  • Additional output status logging to console.
Beta 4:
  • More fixes for new default output not working on some machines,
  • Correct too quiet Windows Mixer volume on first run.
Beta 5:
  • Fixed crash when trying to open a non-existent 7-zip archive.
  • Playback queue item limit increased to 256.
Beta 6:
  • Fixed wrong error message/status when trying to open a non-existent RAR archive.
  • More default output error logging.
  • Crash if stuck trying to update tags of now playing file for more than one minute, in order to generate crash reports of an apparent rare bug. This change will be reverted for the final version.
Changelog v1.6.2:
Download foobar2000 1.6.2 beta 6
foobar2000 1.6.2 beta 7 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
  • Fixed incompatibilities with certain bluetooth headsets introduced in 1.6.1.
  • Fixed incorrect handling of embedded pictures in Speex tags.
  • Fixed incorrect info shown for IMA ADPCM in Matroska.
  • Fixed no error message on failure to update embedded pictures if embedding of pictures is not supported for this file type. (beta 7)
Changelog v1.6.2:
  • Fixed incompatibilities with certain bluetooth headsets introduced in 1.6.1. (beta 7)
  • Fixed incorrect handling of embedded pictures in Speex tags. (beta 7)
  • Fixed incorrect info shown for IMA ADPCM in Matroska. (beta 7)
Download foobar2000 1.6.2 beta 7
foobar2000 1.6.2 Stable wurde veröffentlicht.
Changelog v1.6.2:
  • Removed nonsensical bit depth info shown with some Matroska files. (final)
  • Cleaned up listed file types in various "import picture" dialogs. (final)
  • Workaround for stuck process if attempting to update foobar2000 while running foobar2000 is busy. (final)
Download foobar2000 1.6.2 Stable
foobar2000 for Mac 2.2.11 wurde veröffentlicht.
Changelog v2.2.11:
  • Latest decoder codebase fixes.
  • Fixed Properties dialog bug that would overwrite specific field on all selected files with "«multiple values» ..." even if the editbox was dismissed with no changes.
Download foobar2000 for Mac 2.2.11
foobar2000 for Mac 2.2.14 wurde veröffentlicht.
Changelog v2.2.14:
  • Made album covers visible in menu bar playback controls.
  • Added ARM Neon optimizations for reduced CPU usage / improved battery life.
  • Fixed Decoding Speed Test discarding last edit when pressing "Run" immediately after.
  • Fixed toggled playlist columns not being reliably remembered.
Download foobar2000 for Mac 2.2.14
foobar2000 1.2.14 für Android wurde veröffentlicht.
Changelog v1.2.14:
  • Fixed crashing on Android 11.
  • Fixed a bug causing reappearing notification after manual dismiss.
Download foobar2000 1.2.14 für Android
Bei Problemen mit Google Play: Standalone Android APK downloads
foobar2000 1.2.14 für iOS wurde veröffentlicht.
Changelog v1.2.14:
  • Increased smooth playback buffer length to mitigate reported glitches.
Download foobar2000 1.2.14 für iOS
foobar2000 1.6.3 beta 2 wurde veröffentlicht.
Changelog v1.6.3:
  • Fixed RAR reading crash bug introduced in 1.6.2.
  • Improved WASAPI compatibility with specific audio devices.
  • Fixed playback queue being flushed when playing a song from library search result. (beta 2)
  • Now complains on startup if mixing files from different foobar2000 releases. (beta 2)
Download foobar2000 1.6.3 beta 2
foobar2000 1.6.3 beta 3 wurde veröffentlicht.
Changelog v1.6.3:
  • Fixed wrong stream labels in "Select Stream" on Matroska if not all streams were readable by installed decoders. (beta 3)
  • Made "Select Stream" dialog show more info about each stream. (beta 3)
  • Fixed enter key behavior in "Select Stream" dialog list. (beta 3)
  • Various obscure Matroska PCM configurations now decode correctly. (beta 3)
  • Converter: Improved long filename support. (beta 3)
Download foobar2000 1.6.3 beta 3
foobar2000 1.6.3 Final wurde veröffentlicht.
Changelog v1.6.3:
  • Fixed incorrect behavior of playlist_execute_default_action() method. (final)
Download foobar2000 1.6.3 Final
foobar2000 1.6.4 beta 2 wurde veröffentlicht.
Changelog v1.6.4:
  • Fixed playback queue display glitch regression from 1.6.3 final.
  • Added mouse previous/next navigation in Preferences.
  • Fixed ctrl+backspace working incorrectly in some edit boxes. (beta 2)
Download foobar2000 1.6.4 beta 2
foobar2000 1.6.4 beta 3 wurde veröffentlicht.
Changelog v1.6.4:
  • Standard DSP Array is now loaded in safe mode - otherwise basic playback would fail. (beta 3)
  • Fixed a crash when decoding certain AAC streams introduced in 1.6.3. (beta 3)
  • Updated WavPack decoder to version 5.4.0. (beta 3)
Download foobar2000 1.6.4 beta 3
foobar2000 1.5.7 Final (old) wurde veröffentlicht.
Bug-fix update for Windows XP users.
Changelog v1.5.7:
  • Bug fix update with latest fixes from 1.6 series.
  • Fixed various cases of Matroska/PCM files not playing.
Download foobar2000 1.5.7 Final(old)
foobar2000 1.6.4 Final wurde veröffentlicht.
Changelog v1.6.4:
Download foobar2000 1.6.4 Final
gips eine timer function oder plugin
es gibt die Komponente Scheduler.
LG
foobar2000 for Mac 2.2.16 wurde veröffentlicht.
Changelog v2.2.16:
  • Fixed volume knob clipping.
  • Fixed erratic behaviors of some file/folder picker dialogs on Mac OS Big Sur.
  • Improved perforamnce of SSRC resampler and Equalizer.
  • Added DSP configuration to Decoding Speed Test.
Download foobar2000 for Mac 2.2.16
foobar2000 1.6.5 beta 1 wurde veröffentlicht.
Highlights: improved ReplayGain scanner, bugfixed 7-zip reading.
Changelog v1.6.5:
  • Rewritten internal 7-zip support - now opens large files without running out of memory.
  • Updated ReplayGain scanner: improved speed, added classic ReplayGain scanning mode as an option.
  • Converter now warns about conversion of float32 to integer format, as it is not lossless if the source file isn't peak-normalized.
  • "Remove Tags" now retains Apple gapless (iTunSMPB) information on MP3 files.
  • Rationale: tag manipulation should not cause the file to decode differently.
  • Opt-out of this behavior in Advancd Preferences.
  • Fixed some M4A chapter titles not reading correctly.
Download foobar2000 1.6.5 beta 1
foobar2000 1.6.5 beta 2 wurde veröffentlicht.
Changelog v1.6.5:
  • Added support for itunescatalogid for M4A files. (beta 2)
Download foobar2000 1.6.5 beta 2
foobar2000 1.6.5 beta 3 wurde veröffentlicht.
Changelog v1.6.5:
  • Restricted 7-zip reader memory usage to prevent instability. (beta 3)
Download foobar2000 1.6.5 beta 3
foobar2000 1.6.5 beta 4 wurde veröffentlicht.
Changelog v1.6.5:
  • Fixes for instability from extreme 7-zip reader memory usage. (beta 3, beta 4)
Download foobar2000 1.6.5 beta 4
foobar2000 1.6.5 beta 5 wurde veröffentlicht.
Changelog v1.6.5:
    Fixed a glitch in ReplayGain scanner preferences. (beta 5)
Download foobar2000 1.6.5 beta 5
