Allg. [Vorstellung] foobar2000 v2.2 Preview 2024-03-28 wurde veröffentlicht
foobar2000 1.6.5 Final wurde veröffentlicht.
Changelog v1.6.5:
  • Rewritten internal 7-zip support - now opens large files without running out of memory.
  • Updated ReplayGain scanner: improved speed, added classic ReplayGain scanning mode as an option.
  • Converter now warns about conversion of float32 to integer format, as it is not lossless if the source file isn't peak-normalized.
  • "Remove Tags" now retains Apple gapless (iTunSMPB) information on MP3 files.
  • Rationale: tag manipulation should not cause the file to decode differently.
  • Opt-out of this behavior in Advancd Preferences.
  • Fixed some M4A chapter titles not reading correctly.
  • Added support for itunescatalogid for M4A files.
  • Fixes for instability from extreme 7-zip reader memory usage.
  • Fixed a glitch in ReplayGain scanner preferences.
Download foobar2000 1.6.5 Final
foobar2000 1.6.6 beta 1 wurde veröffentlicht.
New features include improved Matroska format support and searchable Advanced Preferences.
Changelog v1.6.6:
  • Made Advanced Preferences searchable.
  • Added support for attaching pictures to Matroska files; fixed Matroska tag editing bugs.
  • More accurate reporting of Matroska bitrate (actual content is probed if needed).
  • Added itunesadvisory tag support for M4A.
  • Updated embedded cuesheet handling code.
  • Replaced PPHS resampler with much faster libretro resampler.
  • Added support for internet radio album art.
  • Converter: Encoded FLAC files are now updated with proper FLAC seektables, if FLAC.exe doesn't write them by itself.
  • Converter: Workarounds for clashes when writing to a Media Library indexed folder.
  • Converter: Added built-in profile for exhale AAC encoder.
  • Converter: Fixed some warning prompts not being possible to permanently disable.
  • Fixed slightly inaccurate bitrate reporting for Musepack and WavPack. Tags are now excluded from file size used to calculate the bitrate.
  • Now compiled with Visual Studio 2019 (was 2017 before).
Download foobar2000 1.6.6 beta 1
foobar2000 1.6.6 beta 2 wurde veröffentlicht.
Changelog v1.6.6:
  • Album art related regressions fixed. (beta 2)
  • Worked around 7-zip reading crash. (beta 2)
Download foobar2000 1.6.6 beta 2
foobar2000 1.2.17 für Android wurde veröffentlicht.
Changelog v1.2.17:
  • Fixed a bug causing duplicate display of albums, artists, genres, etc with international characters in them.
  • Worked around wrong M4A mime type served by Gerbera UPnP server.
  • Improved ReplayGain scanning speed.
Download foobar2000 1.2.17 für Android
Bei Problemen mit Google Play: Standalone Android APK downloads
foobar2000 1.2.17 für iOS wurde veröffentlicht.
Changelog v1.2.17:
Download foobar2000 1.2.17 für iOS
foobar2000 1.6.6 beta 3 wurde veröffentlicht.
Changelog v1.6.6:
  • Fixed missing no-artwork pic in some scenarios. (beta 3)
  • Fixed slower playlist & library search regression from earlier betas, apparently VS2019 compiler related. (beta 3)
Download foobar2000 1.6.6 beta 3
foobar2000 for Mac 2.2.17 wurde veröffentlicht.
Changelog v2.2.17:
  • Reworked Equalizer panel, added preset load/save capability.
Download foobar2000 for Mac 2.2.17
foobar2000 1.6.6 beta 4 wurde veröffentlicht.
Changelog v1.6.6:
  • Fixed slower playlist & library search regression from earlier betas. (beta 4)
Download foobar2000 1.6.6 beta 4
foobar2000 1.6.6 beta 5 wurde veröffentlicht.
Changelog v1.6.6:
  • Fixed failure to read some rare MP4/M4A files. (beta 5)
  • Converter: Added a toggle for FLAC seektable fix. (beta 5)
Download foobar2000 1.6.6 beta 5
foobar2000 1.2.18 für iOS wurde veröffentlicht.
Changelog v1.2.18:
  • Improved FTP compatibility.
  • Improved visual feedback when some of indexed library folders could not be scanned completely.
  • Fixed failure to play certain MP4/M4A files.
  • Fixed failure to play high-definition audio on Android 4.x devices.
Download foobar2000 1.2.18 für iOS
foobar2000 1.6.6 beta 6 wurde veröffentlicht.
Changelog v1.6.6:
  • Fixed Default UI playlist rendering glitches with millions of items. (beta 6)
Download foobar2000 1.6.6 beta 6
foobar2000 1.6.6 beta 7 wurde veröffentlicht.
Changelog v1.6.6:
  • Fixed decoding of 7-channel FLAC files. (beta 7)
  • Made FLAC channel mask not cleared with 'remove tags'. (beta 7)
  • Improved compatibility with badly configured HLS radio servers. (beta 7)
Download foobar2000 1.6.6 beta 7
Changelog v1.2.18:
  • Restored network discovery capability (media servers, TuneFUSION) on iOS 14.
foobar2000 1.6.6 beta 8 wurde veröffentlicht.
Changelog v1.6.6:
  • Fixed odd samplerate autoresampling regression from earlier betas. (beta 8)
Download foobar2000 1.6.6 beta 8
foobar2000 1.6.6 Final wurde veröffentlicht.
Changelog v1.6.6:
Download foobar2000 1.6.6 Final
foobar2000 1.6.7 beta 1 wurde veröffentlicht.
Introducing out-of-the-box exclusive playback capability, making various addon output components obsolete.
Changelog v1.6.7:
  • Built-in WASAPI exclusive output.
  • Added 'smart stop' option in Advanced Preferences; press stop key once to stop-after-current, twice to stop now.
  • Fixed WavPack lossy not working regression from 1.6.6.
Download foobar2000 1.6.7 beta 1
foobar2000 for Mac 2.2.20 wurde veröffentlicht.
Changelog v2.2.20:
  • Fixed WavPack lossy not working regression from 2.2.18.
Download foobar2000 for Mac 2.2.20
foobar2000 1.6.7 beta 2 wurde veröffentlicht.
Changelog v1.6.7:
Download foobar2000 1.6.7 beta 2
foobar2000 1.6.7 beta 3 wurde veröffentlicht.
Changelog v1.6.7:
Download foobar2000 1.6.7 beta 3
foobar2000 1.6.7 beta 4 wurde veröffentlicht.
Changelog v1.6.7:
Download foobar2000 1.6.7 beta 4
foobar2000 1.6.7 beta 5 wurde veröffentlicht.
Changelog v1.6.7:
  • Made Output preferences reflect output device changes made by output picker toolbar (beta 5).
Download foobar2000 1.6.7 beta 5
foobar2000 1.2.22 für Android wurde veröffentlicht.
Changelog v1.2.22:
  • Improved UPnP browsing performance, last open UPnP folder is now remembered.
  • Fixed wrong album being shown after app restart if two albums from different artists have the same title.
Changelog v1.2.21:
  • Reworked TuneFUSION sync, can pair by passcode if network discovery fails; no longer runs in background with foobar2000 - initiate sync by opening the TuneFUSION page.
  • Improved performance on old 32-bit ARM devices.
  • Improved first run screens.
  • Added support for FLAC content in MP4/M4A container.
Download foobar2000 1.2.22 für Android
foobar2000 1.2.22 für iOS wurde veröffentlicht.
Changelog v1.2.22:
  • Added an option to disable animated page transitions for faster browsing.
Changelog v1.2.21:
Download foobar2000 1.2.22 für iOS
foobar2000 1.6.7 beta 6 wurde veröffentlicht.
Changelog v1.6.7:
  • Allowed per-track REM COMMENT in cuesheets. (beta 6)
  • HLS radio bug fixes. (beta 6)
  • Fixed crashing on failed paste operations in Properties dialog. (beta 6)
  • Fixed incorrect handling of UTF-8 file names inside ZIP archives. (beta 6)
Download foobar2000 1.6.7 beta 6
foobar2000 1.6.7 beta 7 wurde veröffentlicht.
Changelog v1.6.7:
  • Rewritten entirely in beta 7, old beta1-6 bugs should be gone.
  • Made Output preferences reflect output device changes made by output picker toolbar. (beta 5)
  • Removed 8-bit output option. (beta 7)
  • Fixed inaccurate preamp decibel formatting in Converter setup dialog. (beta 7)
Download foobar2000 1.6.7 beta 7
foobar2000 1.6.7 beta 8 wurde veröffentlicht.
Changelog v1.6.7:
Download foobar2000 1.6.7 beta 8
foobar2000 1.6.7 beta 9 wurde veröffentlicht.
Changelog v1.6.7:
Download foobar2000 1.6.7 beta 9
foobar2000 1.6.7 beta 10 wurde veröffentlicht.
Version 1.6.7 beta change log (Thread im offiziellen Forum):
Beta 2:
  • Exclusive mode fixes.
Beta 3:
Beta 4:
  • Workaround for tag update errors if the the tags contain a malformed attached picture.
Beta 5:
Beta 6:
  • Added a Monty Python easter egg.
Beta 7:
  • Rewritten exclusive-mode WASAPI output from scratch.
Beta 8:
  • Exclusive-mode output fixes.
Beta 9:
  • Exclusive-mode output fixes; fixed "unsupported format" error regression.
Beta 10:
  • Exclusive-mode output fixes; fixed high CPU usage when paused regression.
Changelog v1.6.7:
Download foobar2000 1.6.7 beta 10
foobar2000 1.6.7 beta 12 wurde veröffentlicht.
Beta 2:
Beta 3:
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
Beta 10:
Beta 11:
  • Fixed a beta 7 regression causing glitched audio after a change of parameters (such as sample rate or channel count).
  • Re-enabled 32-bit floating-point output with exclusive mode, some devices seem to accept it.
Beta 12:
  • Fixed beta 11 regression which caused errors with some 24-bit devices.
Changelog v1.6.7:
Download foobar2000 1.6.7 beta 12
