Allg. [Vorstellung] foobar2000 v2.2 Preview 2024-03-27 wurde veröffentlicht
- Ersteller Jimi
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- G.Skill RipJaws V schwarz DIMM Kit 32GB, DDR4-3600, CL18-22-22-42
- Palit GeForce GTX 1650 KalmX (passiv)
- AOC Q3277PQU, 32" @ 2560x1440
- Western Digital WD_BLACK SN850 500GB, M.2, Kühlkörper & Lexar NM790 4TB, M.2
- Hitachi-LG Data Storage GP57EB40 schwarz, USB 2.0
- MOTU M2 & Topping L30
- NZXT H7 Flow Black @ 6x ENDORFY Fluctus 140 PWM @ ~600 rpm
- Seasonic Focus GX 550W
- Logitech K310
- Sharkoon FireGlider
- Windows 10 Home x64 @ WinReducer
- Fluid Audio F5 Speaker & Fluid Audio DS 5 Stands, Hifiman Ananda Nano, Sennheiser HD 560S
- ▼275 ▲55
foobar2000 2.0 beta 12 wurde veröffentlicht.
Version 2.0 Beta Change Log:
Download foobar2000 2.0 beta 12
foobar2000 for Mac 2.5 beta 10 wurde veröffentlicht.
Version 2.5 Beta Change Log:
Download foobar2000 for Mac 2.5 beta 10
Beta 2:
- Fixed crash on old configuration import.
Beta 3:
- Component loader no longer probes menu command GUIDs, which was crashing some components. Was meant to prevent specific known incompatible components from loading.
- Now shows CPU architecture (x86 or x64) in about box.
- Fixed Media Library performing unnecessary tag reloads in some scenarios.
- Crash bugs fixed.
- Made Preferences / Output / Devices usable without a mouse.
Beta 4:
- MP4 tagging: do not set Various Artists if itunescompilation is present but set to 0.
- Crash bugs fixed.
- Made installer refuse to upgrade old non-portable installs containing profile data in application folder, which is no longer supported.
- Fixed metadb lock up with large queryInfoMulti() batches.
- Fixed library search by rating not working.
- Added ReFacets to library viewers list.
- Fixed missing double click to fullscreen in Default UI visualisations.
- Fixed disappearing live playback info on playback statistics update.
- Fixed longer-than-necessary gap when reopening exclusive-mode output on format change.
- Fixed seekbar & visualisation glitches when playing very short audio tracks with exclusive-mode output.
Beta 5:
- Fixed various crash bugs.
- Improved rendering performance of very large playlists with grouping & album art enabled.
- Made ReFacets sorting remembered.
- Fixed inverted titles of "Add Files" vs "Open" dialogs.
- Reduced output reopen delay when input format (channel count etc) changes.
- Improved dark mode rendering of checkboxes.
- Suppressed library error log lines about folder.jpg etc inside archive files.
Beta 6:
- Fixed playlist layout glitch regression from beta 5.
Beta 7:
- libFLAC 1.4, made possible to decode 32 bits per sample FLAC files.
- Upgrading from v1.x retains file timestamps of profile folder contents.
- Fixed bad handling of user-components folder in upgraded legacy portable installs without a "profile" folder.
- Playlist rendering and manipulation performance fixes.
- DTS decode_postprocessor now works, for decoding DTS in WAV, FLAC, etc.
- Fixed incorrect behavior after a watched media library folder disappears then reappears.
- Allowed blank meta values in metadb.
- Made possible to enable album art columns in Default UI playlist even without grouping enabled - the old behavior was confusing.
- Added dark mode to Default UI toolbar buttons configuration dialog.
- Made settings of old foo_albumlist & foo_sanitizer imported on startup, if present.
Beta 8:
- Fixed beta 7 regression with wrong handling of blank meta values.
- Fixed some visual glitches in Converter.
- Rare crash bug workarounds.
- Improved crash log writer in 64-bit version.
Beta 9:
- Updated WavPack library to 5.5.0.
- Updated Monkey's Audio library to 8.70.
- Changed replacement for slash character in file naming.
- Fixed a regression that made it impossible to play certain M4A HE-AAC files from remote (HTTP etc) sources.
- Various ReFacets glitches fixed.
- Made new library search implementation more robust.
- Cleaned up Ogg reader, made possible to seek in remote (HTTP etc) Ogg files.
- Crash bugs fixed.
Beta 10:
- Fixed Ogg seeking regressions from the previous beta.
- Made column order correctly remembered per-playlist.
- libFLAC 1.4.1.
- Rewritten asymmetric library search feature.
- Library search speed optimizations, made more queries utilize search index.
- Restored multi-folder-selection for "add folder".
Beta 11:
- Fixed incorrect MD5 verification of 32-bit FLAC files.
- Fixed non-decoding of DTSHD files.
- Added option to override DRC behavior on AC-3 audio.
- Various crash bugs fixed.
Beta 12:
- Improved behavior when watched library folders are on temporarily unavailable network shares.
- Fixed audio glitching on screen resolution change in certain configurations.
- Improved exclusive output behavior with uncommon channel layouts, 4.1/5.0 would not play on a device expecting 5.1-side.
- Fixed failure to read specific odd FPL files.
Changelog v2.0:
- Now available as x86 32-bit (legacy), x86 64-bit. ARM 64-bit version coming soon. 64-bit versions require updated versions of add-on components.
- Dark mode support on Windows 10 and 11. Add-on components need to be updated to utilize it.
- Entirely new media library engine, backed by SQLite. Much faster startup and shutdown with large libraries, greatly reduced memory usage.
- Greatly improved performance of media library search queries that don't use %patterns%.
- Playback Statistics functionality is now built-in. Old foo_playcount data gets imported on first run. Please remove foo_playcount as instructed.
- Added album art in Default User Interface playlist view.
- Clickable rating stars in Default User Interface playlist view.
- New Default UI element: ReFacets, reimplementing most of Facets functionality. Old Facets component doesn't work with new 64-bit foobar2000.
- Improved Default UI splitter, now allows any number of panes.
- Added 'remember per playlist layout' to Default User Interface playlist view.
- Added 'stream selector' element to Default User Interface toolbar.
- New audio output device management features - unwanted devices can be disabled, bit depth and DSP can be configured per-device.
- New internal playlist format, changes instantly saved to disk, no more recent changes lost on crash.
- New configuration data format, changes instantly saved to disk, no more recent changes lost on crash.
- Can display file creation time (%file_created%) and attributes (%file_attributes%).
- For non-portable installs, profile folder is now %appdata%\foobar2000-v2. There is no need to back up old profile before upgrading, your foobar2000 v1.x profile will be left untouched.
- First run performs import of old configuration data (playlists, library).
- More audio formats supported out of the box: TAK, APE, AC3, DTS.
- Updated FFmpeg to version 5.1.
- Improved Properties behavior if 'reload info' detects a change in number of chapters etc.
- Rewritten built-in visualisations (VU/peak meters, spectrum, oscilloscope), now using hardware accelerated rendering.
- Some Default UI Elements (ReFacets, Equalizer, visualisations) now also accessible as Columns UI panels.
- Internet Radio dialog (File menu), remembers previously played Internet radio streams.
- Modernized Explorer integration, no longer needs separate 32bit/64bit shell extension DLLs.
- Properties dialog now follows theme colors of the active UI.
- Utilized Windows Imaging Component for image parsing, removed libwebp dependency. Album covers in HEIF, AVIF, etc can now be viewed if system codecs are present.
- Added %year% mapping, takes year part of %date%, discarding content past first four digits.
- Changed default Album List patterns to use %year%.
- Added sample rate exclusions to SSRC resampler.
- Added crossfeed DSP from foobar2000 mobile.
- New console logging system, writes per-instance log files to the specified folder.
- New full config reset semantics - now clears profile folder (optionally leaving user-components intact) instead of asking all components to reset themselves.
- These add-on components are now obsolete as their functionality is available out of the box: foo_benchmark, foo_bitcompare, foo_verifier, foo_input_monkey, foo_ac3, foo_sanitizer, foo_input_dts.
- These components previously included with the installer are no longer optional (features always enabled): foo_rgscan, foo_cdda, foo_albumlist
- libFLAC 1.4.1, made possible to decode 32 bits per sample FLAC file.
- Fixed incorrect handling of M4A itunescompilation=0.
- WavPack 5.5.0.
- Compiled with Visual Studio 2022.
Beta 2:
- Fixed "Show in Finder" vs old Mac OS.
- Editing 'rating' field no longer alters playback statistics database.
Beta 3:
- Fixed loading DSP presets not applying them in Preferences.
- Crash bugs fixed.
- Switched to 64-bit floating-point for internal processing (was still using 32-bit in beta 1 & 2).
Beta 4:
- ReFacets sorting is now remembered.
- Fixed beta 3 regression with 32 bits per sample output producing noise.
Beta 5:
- Playlist manipulation performance fixes.
Beta 6:
- Shutdown crash regression fix.
Beta 7:
- Fixed playlist sorting not respecting ascending/descending state.
Beta 8:
- libFLAC 1.4.1.
Beta 9:
- Fixed internet radio playlist parsing bug.
Beta 10:
- Fixed race condition crash in module decoder.
- Fixed failure to read specific XM modules (nothing added to playlist).
Changelog v2.5:
- Preferences dialog similar to that of Windows foobar2000.
- Added Media Library with realtime folder monitoring.
- Added Media Library viewers: Album List, ReFacets, Library Search.
- Added all playback order options from Windows foobar2000.
- Added Playlist View columns customizations.
- Added Playlist Search.
- Added Playback Statistics feature (rating, play count, etc).
- Added FFmpeg Decoder Wrapper, enabling decoding of arbitrary audio formats via external FFmpeg program.
- New output device management options.
- Full array of DSPs from Utility DSP Array component.
- Playback Queue feature.
- Tag Sanitizer component (right click menu / tagging).
- Added many other options and features from classic foobar2000.
- Many bugs fixed.
- Game music audio formats currently missing.
- Required Mac OS version is now 10.12 "Sierra".
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.6.13 Final wurde veröffentlicht.
Download foobar2000 1.6.13 Final
This is a maintenance update with latest fixes backported from 2.0 series.
Changelog v1.6.13:
- Maintenance release with changes backported from 2.0 series.
- Fixed an issue that caused audio stutters during screen resolution change in some configurations.
- Fixed incorrect behavior of exclusive mode output when playing files with uncommon channel layout.
- WavPack 5.5.0.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 2.0 beta 13 wurde veröffentlicht.
Download foobar2000 2.0 beta 13
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
- Crash bugs fixed.
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
- Crash bugs fixed.
Beta 10:
- libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
- Fixed poor search performance with asymmetric search enabled.
- Fixed dark mode in Converter overwrite prompt.
- Reverted visualisations to GDI rendering by default. Use advanced preferences toggle to enable D2D. Too many systems fail at D2D rendering.
- Mitigated media indexing crash on Wine by cutting down use of std::current_exception() / std::rethrow_exception().
- libFLAC & zlib update.
- Channel mask display fixes.
- Fixed wrong length reporting in Binary Comparator.
- No longer reports FLAC files with ID3 tags as corrupted.
- Workarounds for poor performance of metadb_index operations compared to v1.x series (affects third party components only).
- Programming interface extensions for components:
- Made possible to apply DSP config changes without reinitializing affected DSPs.
- Allowed DSPs to manipulate their shown name depending on preset data.
- Addded non-blocking DSP configuration popups.
- Added library_manager_v5 with extra status info methods (new SDK needed to utilize).
Changelog v2.0:
- libFLAC 1.4.2, made possible to decode 32 bits per sample FLAC file.
- Worked around FLAC files with ID3 tags being reported as corrupted by new libFLAC.
- zlib 1.2.13.
- WavPack 5.5.0.
- Added mitigations for apparent random crash on Wine (less C++ exceptions thrown when dealing with media indexing errors).
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.6.14 Final wurde veröffentlicht.
Download foobar2000 1.6.14 Final
foobar2000 for Mac 2.5 beta 11 wurde veröffentlicht.
Download foobar2000 for Mac 2.5 beta 11
Changelog v1.6.14:
- zlib 1.2.13.
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
- libFLAC 1.4.1.
Beta 9:
Beta 10:
Beta 1:
- Fixed window position remembering bugs.
- Closing main window now exits foobar2000.
- Added Audio Unit DSP support.
- Verifier: do not report ID3 tags in FLAC as corrupted file errors.
- Fixed lockup bug with stale/dead net shares in Media Library.
Changelog v2.5:
- Many bugs fixed.
- Apple Audio Unit DSP support.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 for Mac 2.5 beta 12 wurde veröffentlicht.
Download foobar2000 for Mac 2.5 beta 12
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
- libFLAC 1.4.1.
Beta 9:
Beta 10:
Beta 11:
- Required Mac OS version is now 10.13.
Beta 12:
- Fixed a beta 11 regression causing "open...", "add folder..." etc to fail.
Changelog v2.5:
- Many bugs fixed.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 2.0 beta 14 wurde veröffentlicht.
Download foobar2000 2.0 beta 14
foobar2000 for Mac 2.5 beta 13 wurde veröffentlicht.
Download foobar2000 for Mac 2.5 beta 13
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
- Crash bugs fixed.
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
- Crash bugs fixed.
Beta 10:
- libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
- Enabled search indexing of file paths by default.
- Because this somewhat affects performance and some people just don't care, an advanced option to turn it off has been added.- WavPack library update.
- More compatible reading of exotic AIFF files.
- Fixed a very old bug in 8-bit AU writer.
- Added sanitization of internet radio metadata as certain station was serving nonsensical sample rate info.
- Improved compatibility with MP4 files made with yt-dlp.
- Improved compatibility with stripped down Windows 10 distributions.
Changelog v2.0:
- zlib 1.2.13.
- WavPack 5.5.0.
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
- libFLAC 1.4.1.
Beta 9:
Beta 10:
Beta 11:
Beta 12:
Beta 13:
- Audio Unit support improvements.
Changelog v2.5:
- Many bugs fixed.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 2.0 beta 15 wurde veröffentlicht.
Download foobar2000 2.0 beta 15
foobar2000 for Mac 2.5 beta 14 wurde veröffentlicht.
Download foobar2000 for Mac 2.5 beta 14
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
- Crash bugs fixed.
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
- Crash bugs fixed.
Beta 10:
- libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
- Fixed various library search expression handling bugs.
- Made FLAC tag updater remove ID3v2 garbage prefixing FLAC stream.
- Made ERROR_BAD_LENGTH condition crash to debug specific network share compatibility issue.
- Made MP3 reader report MP3 frame count not matching Xing/LAME header info when verifying integrity.
Changelog v2.0:
- zlib 1.2.13.
- WavPack 5.5.0.
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
- libFLAC 1.4.1.
Beta 9:
Beta 10:
Beta 11:
Beta 12:
Beta 13:
Beta 14:
- Made FLAC tag updater kill ID3v2 garbage prefixing FLAC stream.
- Mac: Continuous dragging of Audio Unit sliders.
Changelog v2.5:
- Many bugs fixed.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 2.0 beta 16 wurde veröffentlicht.
Download foobar2000 2.0 beta 16
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
- Crash bugs fixed.
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
- Crash bugs fixed.
Beta 10:
- libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
- Improved compatibility with network shares - worked around specific server refusing GetFileInformationByHandle() resulting in previous foobar2000 v2.0 betas being unable to play or index media from such.
- More search regression fixes.
- Fixed missing ES_AUTOHSCROLL in ReFacets search box - was limiting length of typed search pattern to size of the editbox.
- Added lock toggle to Default UI splitter.
- Rating field handling fixes - %rating% now looks up rating meta if no rating is present in the database.
- Reverted larger font in Properties tabs as everyone seems to hate it.
- Fixed 64-bit setup being unable to close running foobar2000 instance before updating.
- Fixed archive content being invisible in Album List's folders view, possibly in other components too (library_manager::get_relative_path).
Changelog v2.0:
- zlib 1.2.13.
- WavPack 5.5.0.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 2.0 beta 17 wurde veröffentlicht.
Download foobar2000 2.0 beta 17
foobar2000 for Mac 2.5 beta 15 wurde veröffentlicht.
Download foobar2000 for Mac 2.5 beta 15
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
- Crash bugs fixed.
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
- Crash bugs fixed.
Beta 10:
- libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
- libvorbis is once again used for decoding Vorbis format instead of FFmpeg, as some rare files continue to cause compatibility issues.
- Default Playlist View: Fixed column size remembering bugs.
- Updated Properties / Automatically Fill Values logic, better results if searched pattern appears more than once.
- Fixed missing quotation mark recognition in new library search system.
- Fixed bad import of old foo_playcount ratings (0.5 added), made first run clean up existing database and badly imported values from the old version.
- Fixed Console not obeying color settings.
Changelog v2.0:
- zlib 1.2.13.
- WavPack 5.5.0.
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
- libFLAC 1.4.1.
Beta 9:
Beta 10:
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
- libvorbis is now used for decoding Vorbis format instead of FFmpeg, as some rare files continue to cause compatibility issues.
- Fixed archive content being invisible in Album List's folders view.
Changelog v2.5:
- Many bugs fixed.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 2.0 beta 18 wurde veröffentlicht.
Download foobar2000 2.0 beta 18
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
- Crash bugs fixed.
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
- Crash bugs fixed.
Beta 10:
- libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Beta 18:
- Made all track info cached in memory like it was in old foobar2000 versions. The performance loss from keeping all info in SQLite only was not acceptable.
- Rewritten search index. If you find a case where new foobar2000 search is slower than 1.x series, please let us know.
- Removed internal playback statistics, made Playback Statistics component (foo_playcount) operational again. First run of new foo_playcount imports foobar2000 v2.0 beta database back.
- 64-bit version no longer moves user-components folder to user-components-x64 on first run.
- Fixed playback of 8-channel Vorbis, beta 17 regression.
Changelog v2.0:
- zlib 1.2.13.
- WavPack 5.5.0.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 2.0 beta 19 wurde veröffentlicht.
Download foobar2000 2.0 beta 19
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
- Crash bugs fixed.
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
- Crash bugs fixed.
Beta 10:
- libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Beta 18:
Beta 19:
- Crash regression fix.
Changelog v2.0:
- zlib 1.2.13.
- WavPack 5.5.0.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 for Mac 2.5 beta 16 wurde veröffentlicht.
Download foobar2000 for Mac 2.5 beta 16
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
- libFLAC 1.4.1.
Beta 9:
Beta 10:
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
- Rewritten search index for better performance.
- Playback statistics feature is now powered by foo_playcount code, ratings & statistics pinned to metadata instead of location.
- Fixed playback of 8-channel Vorbis, beta 15 regression.
- Fixed various UI glitches.
Changelog v2.5:
- Many bugs fixed.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 2.0 beta 20 wurde veröffentlicht.
Download foobar2000 2.0 beta 20
foobar2000 for Mac 2.5 beta 17 wurde veröffentlicht.
Download foobar2000 for Mac 2.5 beta 17
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
- Crash bugs fixed.
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
- Crash bugs fixed.
Beta 10:
- libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Beta 18:
Beta 19:
Beta 20:
- Added "low memory mode" in 32-bit build, restoring pre-beta18 style tag caching semantics.
- Located in advanced preferences / general.
- If foobar2000 cannot start up due to memory usage, it can be emergency-enabled by putting "enable_low_mem_mode" file in the profile folder.- Misc search bug fixes.
- Playlist group layout optimizations reverted (no more scrollbar jumping around stupidly), unless in the new low memory mode.
- Fixed various RIFF64 WAV reading bugs.
- Fixed blank edit menu shown when no items are enabled.
Changelog v2.0:
- zlib 1.2.13.
- WavPack 5.5.0.
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
- libFLAC 1.4.1.
Beta 9:
Beta 10:
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
- Fixed beachballing on app shutdown when indexed network shares cannot be resolved.
- Improved Playback Statistics XML import/export, made possible to import XML written by old betas.
Changelog v2.5:
- Many bugs fixed.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 2.0 beta 21 wurde veröffentlicht.
Download foobar2000 2.0 beta 21
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
- Crash bugs fixed.
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
- Crash bugs fixed.
Beta 10:
- libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Beta 18:
Beta 19:
Beta 20:
Beta 21:
- Fixed accidental twin Peak Meters.
- Fixed a bug resulting in nonsensical channel mask being passed around.
- No longer recreates all DSPs when manually cycling tracks in playlist.
- Removed untested code for float16 & float24 audio reading. If you run into actual samples of such files, please let me know.
- Worked around ages old problem with external changes to file tags causing loss of foo_playcount data (needs new foo_playcount).
- Added 'icon' column in default playlist view.
Changelog v2.0:
- zlib 1.2.13.
- WavPack 5.5.0.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 2.0 beta 22 wurde veröffentlicht.
Download foobar2000 2.0 beta 22
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
- Crash bugs fixed.
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
- Crash bugs fixed.
Beta 10:
- libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Beta 18:
Beta 19:
Beta 20:
Beta 21:
Beta 22:
- Fixed total playback time not being remembered since beta 18.
- Fixed problems with accessing some non-UTF8-compliant FTP servers.
- DSP bug fixes.
- Fixed FPL writer regression causing some of written playlists to be unreadable.
- Fixed a bug that prevented some internet radio station names from being shown.
Changelog v2.0:
- zlib 1.2.13.
- WavPack 5.5.0.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.6.15 Final wurde veröffentlicht.
Download foobar2000 1.6.15 Final
foobar2000 2.0 beta 23 wurde veröffentlicht.
Download foobar2000 2.0 beta 23
foobar2000 for Mac 2.5 beta 18 wurde veröffentlicht.
Download foobar2000 for Mac 2.5 beta 18
Changelog v1.6.15:
- Less DSP reinitializing when cycling played tracks etc.
- Fixed crash after loss of audio output device while playing.
- RIFF64 format reading bug fixes.
- Fixed playlist column layout changes not being remembered in certain scenarios.
- Converter: Fixed very old bugs in AU writer.
- Less strict reading of AIFF format.
- Media Library: Don't report non-audio files (such as pictures or text) inside archives as indexing errors.
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
- Crash bugs fixed.
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
- Crash bugs fixed.
Beta 10:
- libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Beta 18:
Beta 19:
Beta 20:
Beta 21:
Beta 22:
- DSP bug fixes.
Beta 23:
- Fixed missing CListControl accessibility support in 64-bit version.
- Fixed random shutdown crash when using Album List or ReFacets with filters.
- Fixed wrong content shown in left pane of File Operations pattern picker.
Changelog v2.0:
- zlib 1.2.13.
- WavPack 5.5.0.
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
- libFLAC 1.4.1.
Beta 9:
Beta 10:
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Beta 18:
- Fixed incorrect behavior when adding Media Library folders via drag&drop from Finder.
- Fixed total playback time not being remembered since beta 16.
- Made error message shown when an Audio Unit cannot be loaded, instead of appearing stuck.
- Properties dialog blank value crash fixed.
Changelog v2.5:
- Many bugs fixed.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.6.16 Final wurde veröffentlicht.
Download foobar2000 1.6.16 Final
A problematic optimization from v1.6.15 has been reverted as it breaks third party DSP components.
Changelog v1.6.16:
- Reverted 1.6.15 optimization with fast DSP reinitialization on manual track change.
This behavior breaks many third party components and can't be enabled by default.
It's now available as an option because it improves performance when using heavy-to-initialize DSPs such as new VST adapter.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 2.0 beta 24 wurde veröffentlicht.
Download foobar2000 2.0 beta 24
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
- Crash bugs fixed.
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
- Crash bugs fixed.
Beta 10:
- libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Beta 18:
Beta 19:
Beta 20:
Beta 21:
Beta 22:
- DSP bug fixes.
Beta 23:
Beta 24:
- Made fast DSP reset (introduced in previous version) opt-in, as it breaks certain third party DSPs.
- File Operations: Dark mode bug fixes.
- Preferences / Shell: changed default target playlist name.
- Fixed outdated info shown after editing tags in low-memory mode.
- Properties Autofill logic amended.
- Album List & ReFacets: improved handling of | character in tags.
Changelog v2.0:
- zlib 1.2.13.
- WavPack 5.5.0.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 for Mac 2.5 beta 19 wurde veröffentlicht.
Download foobar2000 for Mac 2.5 beta 19
foobar2000 2.0 beta 25 wurde veröffentlicht.
Download foobar2000 2.0 beta 25
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
- libFLAC 1.4.1.
Beta 9:
Beta 10:
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Beta 18:
Beta 19:
- Made FFmpeg from homebrew etc auto-detected.
- Fixed bad MD5 verification of AIFF sourced WavPacks.
- Made Audio Units grouped by vendor.
- Mitigated buggy ftruncate() on Windows network shares.
- Reworked fb2k::configStore, now less prone to silly errors saving random configuration bits, should recover from momentary problems with the configuration file instead of crashing.
- Better console logging if internet stream reconnect events.
- Added zoom to cover picture viewer.
- Fixed ugly downscaled version of image being shown after double clicking attached picture in Properties.
- Fixed ugly scaling of cover art in playback controls bar.
- Ported classic MP3 utilities (tag types, header editor, stream rebuild etc).
- Module renderer update, fixed nonsensical looping behaviors.
- Replaced "Scale" DSP with "Gain / Scale", made possible to edit gain value.
Changelog v2.5:
- Many bugs fixed.
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
- Crash bugs fixed.
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
- Crash bugs fixed.
Beta 10:
- libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Beta 18:
Beta 19:
Beta 20:
Beta 21:
Beta 22:
- DSP bug fixes.
Beta 23:
Beta 24:
Beta 25:
- Fixed portable mode relative paths not being respected by playlist load/save operations.
- Slightly better communication between output device checkboxes vs output picker toolbar.
- Workaround for disappearing windows when dismissing certain DSP dialogs.
- Dark Mode: Fixed some prompt headers having odd color.
- Dark Mode: Fixed tri-state checkboxes.
- Darkened classic MP3 utility dialogs.
- Reworked first run & import of old foobar2000 settings. Import of old foobar2000 configuration is now optional.
Changelog v2.0:
- zlib 1.2.13.
- WavPack 5.5.0.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 2.0 beta 26 wurde veröffentlicht.
Download foobar2000 2.0 beta 26
foobar2000 for Mac 2.5 beta 20 wurde veröffentlicht.
Download foobar2000 for Mac 2.5 beta 20
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
- Crash bugs fixed.
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
- Crash bugs fixed.
Beta 10:
- libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Beta 18:
Beta 19:
Beta 20:
Beta 21:
Beta 22:
- DSP bug fixes.
Beta 23:
Beta 24:
Beta 25:
Beta 26:
- Portable install playlist save lag regression from beta 25 fixed.
- Made more edit boxes recognize ctrl+backspace.
- Better info reporting for lossless DTS files.
Changelog v2.0:
- zlib 1.2.13.
- WavPack 5.5.0.
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
- libFLAC 1.4.1.
Beta 9:
Beta 10:
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Beta 18:
Beta 19:
Beta 20:
- Audio Unit UI fixes, added reset button.
Changelog v2.5:
- Many bugs fixed.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 for Mac 2.5 beta 21 wurde veröffentlicht.
Download foobar2000 for Mac 2.5 beta 21
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
Beta 5:
Beta 6:
Beta 7:
Beta 8:
- libFLAC 1.4.1.
Beta 9:
Beta 10:
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Beta 18:
Beta 19:
Beta 20:
Beta 21:
- Exclusive audio output support.
- Misc bug fixes.
Changelog v2.5:
- Many bugs fixed.
- Required Mac OS version is now 10.13 "High Sierra".
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 2.0 beta 27 wurde veröffentlicht.
Download foobar2000 2.0 beta 27
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
- Crash bugs fixed.
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
- Crash bugs fixed.
Beta 10:
- libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Beta 18:
Beta 19:
Beta 20:
Beta 21:
Beta 22:
- DSP bug fixes.
Beta 23:
Beta 24:
Beta 25:
Beta 26:
Beta 27:
- Fixed playlist layout glitch causing unwanted scrolling during certain events.
- Implemented fb2k:laylistColumnProvider::flag_alignCenter, was missing until now.
- Disabled slow meta autocomplete in low-memory mode.
- Properties: Log tag update errors to console.
- Dark mode: fixed listbox scrollbars.
- Worked around foo_input_dvda bugs, no longer crashes on null album art data returned.
- Disabled behind-the-scenes unicode normalization of metadata, caused bugs with playback statistics pinning.
- First run will rebuild index for playback statistics, might stall for a few seconds on startup. This is due to the above, corrects potential bad data.
- New API: metadb_pre_update_callback, mainly intended to reliably notify foo_playcount about meta changes preventing data loss in corner cases.
- ReFactes: Added multi value columns similar to original Facets.
- ReFacets: Enter key in search box sends results to playlist.
Changelog v2.0:
- zlib 1.2.13.
- WavPack 5.5.0.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 2.0 beta 28 wurde veröffentlicht.
Download foobar2000 2.0 beta 28
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
- Crash bugs fixed.
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
- Crash bugs fixed.
Beta 10:
- libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Beta 18:
Beta 19:
Beta 20:
Beta 21:
Beta 22:
- DSP bug fixes.
Beta 23:
Beta 24:
Beta 25:
Beta 26:
Beta 27:
Beta 28:
- Native foobar2000 for ARM is finally available.
- Supports ARM builds of components but doesn't actually require them, can transparently load x64 code.
- Native ARM version requires Windows 11. If you run Windows 10, you can still run legacy 32-bit foobar2000 through x86 emulation.
- FFmpeg updated to 6.0.
- Built-in Monkey's Audio support now uses FFmpeg. As Monkey's Audio is under rapid development, it's once again available as a separate component that can be updated separately from foobar2000 itself. The component has just been updated to latest Monkey's Audio library and fully supports modern CPU architectures.
- Added extra sanity checks to tag update operations in built-in codecs: made sure that attempts to remove covers from files that didn't have them in first place don't alter files at all.
Changelog v2.0:
- Now available as x86 32-bit (legacy), x86 64-bit, ARM 64-bit.
- Updated FFmpeg to version 6.0.
- zlib 1.2.13.
- WavPack 5.5.0.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 2.0 beta 29 wurde veröffentlicht.
Download foobar2000 2.0 beta 29
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
- Crash bugs fixed.
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
- Crash bugs fixed.
Beta 10:
- libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Beta 18:
Beta 19:
Beta 20:
Beta 21:
Beta 22:
- DSP bug fixes.
Beta 23:
Beta 24:
Beta 25:
Beta 26:
Beta 27:
Beta 28:
Beta 29:
- Converter fixes in 64-bit build, made possible to write 32-bit fixed-point and 64-bit floating-point output.
- Converter vs LAME: allowed 32-bit floating-point pass-thru, as current LAME version supports it.
- Fixed Windows logoff/shutdown causing foobar2000 not to save playback position.
- Fixed main window position/size not respecting system DPI settings.
- Updated exclusive output device-specific workarounds.
Changelog v2.0:
- zlib 1.2.13.
- WavPack 5.5.0.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 2.0 beta 30 wurde veröffentlicht.
Download foobar2000 2.0 beta 30
Beta 2:
Beta 3:
- Crash bugs fixed.
Beta 4:
- Crash bugs fixed.
Beta 5:
Beta 6:
Beta 7:
Beta 8:
Beta 9:
- Crash bugs fixed.
Beta 10:
- libFLAC 1.4.1.
Beta 11:
Beta 12:
Beta 13:
Beta 14:
Beta 15:
Beta 16:
Beta 17:
Beta 18:
Beta 19:
Beta 20:
Beta 21:
Beta 22:
- DSP bug fixes.
Beta 23:
Beta 24:
Beta 25:
Beta 26:
Beta 27:
Beta 28:
Beta 29:
Beta 30:
- Fixed beta 29 regression, maximized main window state is remembered again.
Changelog v2.0:
- zlib 1.2.13.
- WavPack 5.5.0.
- 7K
