Allg. [Vorstellung] foobar2000 v2.2 Preview 2024-07-07 wurde veröffentlicht
foobar2000 v2.2 Preview 2024-06-20 wurde veröffentlicht.
Version v2.2 Preview Change Log:
2024-02-05:
  • Implemented Ogg chapter support. Converter can write multichapter Ogg files after disabling Ogg chaining support.
  • New major revision of bitcompare code, improved performance of 64-bit build.
  • Allow local M3U referencing remote M3U to be both read as playlists, prevent HLS reader being used on non-HLS content.
  • Updated File Operations recycle bin detection logic, mitigating lag/lockup occurring for some users.
  • Made network encryption error messages more useful.
  • Stop decoding ADTS AAC when running into APE tags, instead of reporting errors.
  • Report zero-length WAV files as broken.
  • Wine compatibility fixes.
2024-02-12:
  • Improved ReFacets performance.
  • Fixed erratic behavior if ID3v2 tag contains multiple date fields.
  • Suppressed advancing to the next playlist item if internet radio playback stops due to a network error.
  • File Operations: Added an option to overwrite existing files.
  • Suppressed repeating console messages about decoder shims used.
  • More thorough error reporting for blank WAV files.
  • Added video_codec info for Windows Media Video.
  • Added stream_count info for formats that support multiple streams.
2024-02-19:
  • Fixed regression preventing internet radio album covers from being shown.
  • Applied dark mode to component license popup.
  • Updated zlib to 1.3.1.
2024-02-28:
  • Playback CPU usage optimizations.
  • Small chunks returned by decoder are merged into one to reduce amount of wakeup cycles during playback.
  • Made possible to store peak information in Opus files.
2024-03-04:
  • Worked around audio glitches with very low output buffer size introduced in previous build.
  • Fixed glitchy seekbar movement in certain scenarios.
  • Prevented nonsensical video codec names from being reported for certain MP4 files.
  • Fixed regressions in ASX playlist loader.
  • Converter: More detailed error messages for specific file creation errors.
2024-03-08:
  • Mitigation for Converter failures when writing to Google Drive volume.
  • Opus decoder updated to 1.5.1
  • WavPack decoder updated to 5.7.0; made WavPack library version shown in components list.
  • Monkey's Audio decoder updated to 10.52
  • Cleaned up and bugfixed detection of MP4 video codec names.
  • Prevented nonsense sample rate & channel count from being shown on MP4 files with no audio track.
  • File Operations: Defer info reload to prevent bugged display of cuesheets after moving whole folder.
2024-03-14:
  • Playback CPU usage reduced.
  • Fixed exclusive output lagging in specific scenarios.
  • Add Location now strips extra non-text characters from the entered URL.
  • Made Ogg chapters beginning from CHAPTER001 recognized.
  • Allowed absolute paths in cue sheets.
  • Extended MP4 chapter manipulation commands to work with other formats that support chapterizer interface, such as Ogg or Musepack.
2024-03-18:
  • Fixed foobar2000 v2.0 regression causing folder watch events to be dropped without triggering full rescan if there's too many of them pending.
2024-03-21:
  • Made stream selector show long codec names.
  • Media Library: made track add & remove events triggered in groups, resulting in much faster autoplaylist updates.
2024-03-27:
  • Create "disable-foocrash" in install folder to kill crash reporting (dump files still get written).
  • Run with /nocrashinfo to suppress generation of crash reports.
  • File Operations: Suppressed useless secondary progress bar if renaming files.
2024-03-28:
  • Fixed 2024-03-21 regression causing unnecessary Media Library disk access.
2024-04-07:
  • Fixed very old and very rare Album List lock up bug.
  • Pause / resume playback on system sleep / resume.
  • Installer script update.
2024-04-10:
  • ReFacets playlist interaction bug fixes.
  • ReFacets added "Last Modified" stats column.
  • Removed system sleep / resume handlers, didn't properly suppress errors with internet radio.
  • Made disconnected internet radio streams resumed quietly, without showing error popups.
  • 32-bit build: Removed tone generator assembly optimizations, tone:// should produce identical output in all versions now.
  • Updated to NSIS 3.10.
2024-04-13:
  • Fixed crash if freedb/gnudb server returns more tracks than asked for (regression since 2.0).
2024-04-15:
  • Fixed stuck drag&drop scrolling mode in various list controls after receiving external drag&drop.
  • Made list control obey system drag threshold values, making it easier to register clicks if mouse moves slightly between mouse down and mouse up events.
  • Opus decoder updated to 1.5.2.
2024-04-26:
  • Cleaned up interaction with what's left of freedb.
    - Made more apparent which freedb-compatible service is in use.
    - If there are multiple providers configured, you can specifically choose one from CD Ripper dialog.
    - Discarded malformed server replies.
  • Fixed WASAPI Exclusive timing glitches with exotic settings.
  • Prevented Media Library search from clearing other playlists with enter key if library selection playlist feature is active.
  • Fixed regression in File Operations recycle bin detection, causing unwanted delete prompts when recycling.
2024-04-27:
  • Fixed WASAPI exclusive regression from last build.
2024-05-01:
  • Removed gnudb from default online tagger settings, as gnudb now demands users to input their actual email addresses.
  • If you wish to use gnudb, you can configure it manually, but we strongly recommend against it.
  • Online tagger now defaults to freedb.dbpoweramp.com which works once again.
  • Changed storage of freedb server list settings, to a text file in profile folder.
  • Added toggle to disable tooltips in Album List.
2024-05-13:
  • Prevented all MP4 tag fields prefixed with replaygain_ from being treated as technical information, only actual ReplayGain fields are now such.
  • Workaround for ReplayGain scanner attempting to scan Audio CD in multiple threads.
  • Removed arbitrary denial of reading of cuesheets over FTP/HTTP/etc.
2024-05-17:
  • ReFacets & Album List: Improved processing of %<field>% expressions, artist and artist sort should be split together properly.
  • Added tweak options for ReplayGain thread counts.
  • Made Properties ReplayGain scan not try to scan Audio CD in multiple threads.
  • Removed arbitrary limit of items per "apply gain to file content" pass.
2024-05-23:
  • Reverted to VS2019 compiler, unintended AVX requirement has been removed.
  • Made fact chunk in PCM WAV files ignored.
  • Updated VS runtime DLLs to the latest version.
2024-05-31:
  • Improved compatibility with multi-value MP4/M4A tags.
  • Fixed 2024-05-17 regression causing bad substitution of | character in Album List / ReFacets.
  • Fixed JXL/AVIF/HEIC external album covers not being recognized, even if relevant system image codecs are present.
2024-06-17:
  • Fixed nonsensical messages in Converter log when copying non audio files over.
  • Updated MP4 tmpo tag manipulation, restored ability to write which was lost a few years ago.
2024-06-20:
  • Mitigated poor performance of "Visualize with VST" and equivalent features since CPU usage optimizations in previous beta builds.
Download foobar2000 v2.2 Preview 2024-06-20
foobar2000 v2.2 Preview 2024-06-24 wurde veröffentlicht.
2024-02-05:
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
  • No longer drops DLLs for other CPU architectures than the running one when installing components.
  • Internal changes to deal with wildcard characters in filenames on filesystems other than standard Windows one. Windows version should not be affected by this.
Download foobar2000 v2.2 Preview 2024-06-24
foobar2000 1.5.2 Final für Android wurde veröffentlicht.
Changelog v1.5.2:
  • Unavailable network share folders are grayed but clickable, clicking refreshes their status.
  • Fixed crashing on network share test failure.
  • Fixed a 1.4 era regression preventing last viewed folder from being restored after app restart.
Download foobar2000 1.5.2 Final für Android
Bei Problemen mit Google Play: Standalone Android APK downloads
foobar2000 1.5.2 Final für iOS wurde veröffentlicht.
Changelog v1.5.2:
  • Fixed various bugs causing app crashes when closing foobar2000.
  • Fixed a bug causing on-screen keyboard to obstruct text being edited in specific scenarios.
  • Fixed skin colors not being applied in some places.
Download foobar2000 1.5.2 Final für iOS
foobar2000 v2.2 Preview 2024-06-30 wurde veröffentlicht.
2024-02-05:
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
2024-06-30:
  • Added %channel_mask% title formatting field, on top of on $info(WAVEFORMATEXTENSIBLE_CHANNEL_MASK).
  • Utilized proper hashmap for metadb_display_field_provider lookup, should speed title formatting up somewhat on heavy configs.
Download foobar2000 v2.2 Preview 2024-06-30
foobar2000 v2.2 Preview 2024-07-06 wurde veröffentlicht.
2024-02-05:
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
2024-06-30:
2024-07-06:
  • Fixed title formatting regression from build 2024-06-30, causing some fields to disappear.
  • Amended AccurateRip log formatting, added track number info to lines where it was missing before.
  • Made https:// used for help.foobar2000.org links.
Download foobar2000 v2.2 Preview 2024-07-06
foobar2000 v2.2 Preview 2024-07-07 wurde veröffentlicht.
2024-02-05:
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
2024-06-30:
2024-07-06:
2024-07-07:
  • Amended title formatting regression fix.
Download foobar2000 v2.2 Preview 2024-07-07
Benutzt jemand hier die foobar2000 App auf dem Handy?
Ich streame mir damit meine Musik vom NAS.
Wichtig ist mir dabei u.a. das gapless Abspielen von z.B. Lifemusik oder Klassik.
Was mir noch fehlt, ist die Musik via Bluetooth an mein Soundsystem weiterzureichen.
