Allg. [Vorstellung] foobar2000 v2.24.3 Final wurde veröffentlicht
foobar2000 1.6.4 Final für Android wurde veröffentlicht.
Changelog v1.6.4:
  • Workaround for relative URLs in UPnP server replies.
  • Added option to disable pictures in folder browsing views.
  • Fixed foo_upnp stream looping regression.
  • Fixed various issues with manually-entered UPnP media servers, allowed editing of existing entries, made utilize new user/password system.
  • Fixed UPnP incompatibility with Logitech Music Server.
  • Fixed Ogg VBR bitrate display regression from 1.6.3.
Download foobar2000 1.6.4 Final für Android
Bei Problemen mit Google Play: Standalone Android APK downloads
foobar2000 1.6.4 Final für iOS wurde veröffentlicht.
Changelog v1.6.4:
  • Added tweak option to enable iOS "measurement mode" that minimizes operating system processing of played audio.
  • Fixed crashing if minimizing app while indexing iCloud folders.
Download foobar2000 1.6.4 Final für iOS
foobar2000 v2.24 preview 2024-11-14 wurde veröffentlicht.
Version v2.24 Preview Change Log:
2024-11-14:
  • Updated Monkey's Audio to 10.80.
2024-11-06:
  • Fixed a bug causing foo_upnp internet streams to be treated as radio and unintentionally looped.
2024-10-28:
  • Fixed Internet Radio search not working through a proxy server.
  • SQLite updated to 3.46.1.
  • Fixed Ogg VBR bitrate display regression.
2024-10-18:
  • Fixed specific cases of corrupted configuration data causing foobar2000 to crash.
  • Fixed inconsistent drag&drop behavior when dragging items between playlists.
2024-10-11:
  • Updated RAR extraction code to the latest official code release.
  • Fixed hardware-accelerated visualization crash on settings change.
2024-10-04:
  • New version numbering scheme: 2.24 for planned stable release year of 2024. Stable release will follow soon.
  • Attempted workaround for rapidly restarting playback locking up D2D visualizations on some systems.
  • Internet Radio search & list: clicking a stream that is already playing no longer restarts playback.
  • Fixes for plain WAV files over 4GB in size. Note that WAV file format does not actually support content longer than 4GB.
  • Made current console backlog saved when toggling logging on.
2024-09-11:
  • Fixed opening of webm audio renamed to .opus being very slow to open.
  • Fixed more odd behaviors of tag editing on MP4/M4A with QT chapters.
2024-09-02:
  • Mitigation for extreme column width causing CListControl (Playlist, Verifier, possibly others) to go off the rails.
  • Fixed false MD5 verification errors on exotic bit depth FLAC files.
2024-08-31:
  • Fixed selection tracking regression from 2024-08-29.
2024-08-29:
  • Internal changes (C++ noexcept specifier) to improve usefulness of crash reports.
  • Refactored Matroska chapter handling. If a multichapter Matroska file is played as a whole (from remote URL etc), chapter names will be shown as dynamic track titles.
  • Fixed a bug causing dynamic track titles (internet radio etc) to be possibly discarded.
2024-08-22:
  • Further mitigation for issues caused by corrupted configuration files.
  • Fixed bugs with urlencoding in HTTP redirects.
2024-08-14:
  • Complex mitigation for corrupted config.sqlite - fresh config.sqlite is created, all readable content is transferred over.
  • Made refuse to retag MP4/M4A/M4B files with QT chapters if chapter count exceeds 255, to prevent erratic behavior. Please remux such files to another container to allow tagging.
  • Made WMA tag writing behave less erratically if fed tags read by FFmpeg decoder wrapper.
  • Improved performance of float>>int24 audio conversion.
2024-08-08:
  • Fixed different builds using different rounding for float >> integer audio conversion, mainly affecting 24-bit output (least significant bit differences only).
  • MP4/M4A/M4B: Prefer QT chapters over chpl if more than 255 chapters found.
  • MP4/M4A/M4B: Fixed very rare tag update failures if exceeding 4GB boundary. Note that previous versions would just leave the file untouched and report an error if running into this scenario, never corrupt files.
2024-07-07:
  • Amended title formatting regression fix.
2024-07-06:
  • Fixed title formatting regression from build 2024-06-30, causing some fields to disappear.
  • Amended AccurateRip log formatting, added track number info to lines where it was missing before.
  • Made https:// used for help.foobar2000.org links.
2024-06-30:
  • Added %channel_mask% title formatting field, on top of on $info(WAVEFORMATEXTENSIBLE_CHANNEL_MASK).
  • Utilized proper hashmap for metadb_display_field_provider lookup, should speed title formatting up somewhat on heavy configs.
2024-06-24:
  • No longer drops DLLs for other CPU architectures than the running one when installing components.
  • Internal changes to deal with wildcard characters in filenames on filesystems other than standard Windows one. Windows version should not be affected by this.
2024-06-20:
  • Mitigated poor performance of "Visualize with VST" and equivalent features since CPU usage optimizations in previous beta builds.
2024-06-17:
  • Fixed nonsensical messages in Converter log when copying non audio files over.
  • Updated MP4 tmpo tag manipulation, restored ability to write which was lost a few years ago.
2024-05-31:
  • Improved compatibility with multi-value MP4/M4A tags.
  • Fixed 2024-05-17 regression causing bad substitution of | character in Album List / ReFacets.
  • Fixed JXL/AVIF/HEIC external album covers not being recognized, even if relevant system image codecs are present.
2024-05-23:
  • Reverted to VS2019 compiler, unintended AVX requirement has been removed.
  • Made fact chunk in PCM WAV files ignored.
  • Updated VS runtime DLLs to the latest version.
2024-05-17:
  • ReFacets & Album List: Improved processing of %<field>% expressions, artist and artist sort should be split together properly.
  • Added tweak options for ReplayGain thread counts.
  • Made Properties ReplayGain scan not try to scan Audio CD in multiple threads.
  • Removed arbitrary limit of items per "apply gain to file content" pass.
2024-05-13:
  • Prevented all MP4 tag fields prefixed with replaygain_ from being treated as technical information, only actual ReplayGain fields are now such.
  • Workaround for ReplayGain scanner attempting to scan Audio CD in multiple threads.
  • Removed arbitrary denial of reading of cuesheets over FTP/HTTP/etc.
2024-05-01:
  • Removed gnudb from default online tagger settings, as gnudb now demands users to input their actual email addresses.
  • If you wish to use gnudb, you can configure it manually, but we strongly recommend against it.
  • Online tagger now defaults to freedb.dbpoweramp.com which works once again.
  • Changed storage of freedb server list settings, to a text file in profile folder.
  • Added toggle to disable tooltips in Album List.
2024-04-27:
  • Fixed WASAPI exclusive regression from last build.
2024-04-26:
  • Cleaned up interaction with what's left of freedb.
    - Made more apparent which freedb-compatible service is in use.
    - If there are multiple providers configured, you can specifically choose one from CD Ripper dialog.
    - Discarded malformed server replies.
  • Fixed WASAPI Exclusive timing glitches with exotic settings.
  • Prevented Media Library search from clearing other playlists with enter key if library selection playlist feature is active.
  • Fixed regression in File Operations recycle bin detection, causing unwanted delete prompts when recycling.
2024-04-15:
  • Fixed stuck drag&drop scrolling mode in various list controls after receiving external drag&drop.
  • Made list control obey system drag threshold values, making it easier to register clicks if mouse moves slightly between mouse down and mouse up events.
  • Opus decoder updated to 1.5.2.
2024-04-13:
  • Fixed crash if freedb/gnudb server returns more tracks than asked for (regression since 2.0).
2024-04-10:
  • ReFacets playlist interaction bug fixes.
  • ReFacets added "Last Modified" stats column.
  • Removed system sleep / resume handlers, didn't properly suppress errors with internet radio.
  • Made disconnected internet radio streams resumed quietly, without showing error popups.
  • 32-bit build: Removed tone generator assembly optimizations, tone:// should produce identical output in all versions now.
  • Updated to NSIS 3.10.
2024-04-07:
  • Fixed very old and very rare Album List lock up bug.
  • Pause / resume playback on system sleep / resume.
  • Installer script update.
2024-03-28:
  • Fixed 2024-03-21 regression causing unnecessary Media Library disk access.
2024-03-27:
  • Create "disable-foocrash" in install folder to kill crash reporting (dump files still get written).
  • Run with /nocrashinfo to suppress generation of crash reports.
  • File Operations: Suppressed useless secondary progress bar if renaming files.
2024-03-21:
  • Made stream selector show long codec names.
  • Media Library: made track add & remove events triggered in groups, resulting in much faster autoplaylist updates.
2024-03-18:
  • Fixed foobar2000 v2.0 regression causing folder watch events to be dropped without triggering full rescan if there's too many of them pending.
2024-03-14:
  • Playback CPU usage reduced.
  • Fixed exclusive output lagging in specific scenarios.
  • Add Location now strips extra non-text characters from the entered URL.
  • Made Ogg chapters beginning from CHAPTER001 recognized.
  • Allowed absolute paths in cue sheets.
  • Extended MP4 chapter manipulation commands to work with other formats that support chapterizer interface, such as Ogg or Musepack.
2024-03-08:
  • Mitigation for Converter failures when writing to Google Drive volume.
  • Opus decoder updated to 1.5.1
  • WavPack decoder updated to 5.7.0; made WavPack library version shown in components list.
  • Monkey's Audio decoder updated to 10.52
  • Cleaned up and bugfixed detection of MP4 video codec names.
  • Prevented nonsense sample rate & channel count from being shown on MP4 files with no audio track.
  • File Operations: Defer info reload to prevent bugged display of cuesheets after moving whole folder.
2024-03-04:
  • Worked around audio glitches with very low output buffer size introduced in previous build.
  • Fixed glitchy seekbar movement in certain scenarios.
  • Prevented nonsensical video codec names from being reported for certain MP4 files.
  • Fixed regressions in ASX playlist loader.
  • Converter: More detailed error messages for specific file creation errors.
2024-02-28:
  • Playback CPU usage optimizations.
  • Small chunks returned by decoder are merged into one to reduce amount of wakeup cycles during playback.
  • Made possible to store peak information in Opus files.
2024-02-19:
  • Fixed regression preventing internet radio album covers from being shown.
  • Applied dark mode to component license popup.
  • Updated zlib to 1.3.1.
2024-02-12:
  • Improved ReFacets performance.
  • Fixed erratic behavior if ID3v2 tag contains multiple date fields.
  • Suppressed advancing to the next playlist item if internet radio playback stops due to a network error.
  • File Operations: Added an option to overwrite existing files.
  • Suppressed repeating console messages about decoder shims used.
  • More thorough error reporting for blank WAV files.
  • Added video_codec info for Windows Media Video.
  • Added stream_count info for formats that support multiple streams.
2024-02-05:
  • Implemented Ogg chapter support. Converter can write multichapter Ogg files after disabling Ogg chaining support.
  • New major revision of bitcompare code, improved performance of 64-bit build.
  • Allow local M3U referencing remote M3U to be both read as playlists, prevent HLS reader being used on non-HLS content.
  • Updated File Operations recycle bin detection logic, mitigating lag/lockup occurring for some users.
  • Made network encryption error messages more useful.
  • Stop decoding ADTS AAC when running into APE tags, instead of reporting errors.
  • Report zero-length WAV files as broken.
  • Wine compatibility fixes.
Download foobar2000 v2.24 preview 2024-11-14
foobar2000 v2.24 Final wurde veröffentlicht.
foobar2000 v2.24 has been released, for Windows and Mac OS.
This release changes the version numbering scheme, minor number for the intended release year.
While Windows version is mostly a maintenance/bugfix update, Mac version implements lots of previously-missing functionality, such as user interface layout customization.
Windows: Download | Release Notes
Mac: Download | Release Notes
Changelog v2.24:
  • Internet radio bug fixes & reliability improvements.
  • Codec & audio format fixes, most notably:
    - Implemented Ogg chapter support.
    - MP4/M4A/M4B tagging & chapter manipulation fixes.
    - WAV compatibility fixes; made zero-length WAV files reported as broken.
    - Cuesheet compatibility improvements - allowed absolute path, allowed playback over network.
  • Usability improvements, most notably:
    - Fixed inconsistent drag&drop behavior when dragging items between playlists.
    - Made current console backlog saved when toggling logging on.
    - Prevented Media Library search from clearing other playlists with enter key if library selection playlist feature is active.
  • General improvements, most notably:
    - New major revision of bitcompare code, improved performance of 64-bit build.
    - Improved stability of hardware-accelerated visualizations.
    - Improved recovery of corrupted configuration data.
  • Converter
    - Mitigation for Converter failures when writing to a Google Drive volume.
    - More detailed error messages for specific file creation errors.
    - Can write multichapter Ogg files after disabling Ogg chaining support.
  • File Operations
    - Suppressed useless secondary progress bar if renaming files.
    - Defer info reload to prevent bugged display of cuesheets after moving whole folder.
    - Added an option to overwrite existing files.
    - Updated recycle bin detection logic, mitigating lag/lockup occurring for some users.
  • Third party code libraries updated.
  • Various other tweaks & fixes, see release notes for full list of changes.
Download foobar2000 v2.24 Final
foobar2000 for Mac 2.24 Final wurde veröffentlicht.
Changelog v2.24:
  • Lowest supported Mac OS version is now Mac OS 11 "Big Sur".
  • Entirely new Mac user interface, allowing various panels to be embededd in main foobar2000 window.
  • Lots of appearance & usability improvements, reworked various windows to look more consistently with modern Mac OS.
    - Added update checks - checks for last public beta/stable build, same as Windows version.
    - Added menu commands to configure Audio Units without going through Preferences.
    - Utilized monospace digit font in for most of user interface.
    - Implemented meta autocomplete in Properties dialog.
    - Implemented Advanced Preferences search.
    - Made possible to keep running after closing main window.
    - Made File menu dynamic-generated properly, made various previously-hidden commands accessible, including "Reset Configuration", "Browse Configuration Folder", etc.
    - Cleaned up title capitalization in menu commands.
    - Implemented Cmd+F search in Playlist.
    - Fixed whole lot of bugs related to wildcard characters (*, ?) in file names.
  • File Operations
Download foobar2000 for Mac 2.24 Final
foobar2000 v2.24.1 Final wurde veröffentlicht.
Changelog v2.24.1:
  • Fixed 2.24 regression causing certain visualizations, most notably VST adapter, to be jumpy.
  • Corrected some cases of unnecessary UI flickering on resize/redraw.
  • Made "sanitize tags" command respect "preserve file times" option.
Download foobar2000 v2.24.1 Final
foobar2000 for Mac 2.24.1 Final wurde veröffentlicht.
Changelog v2.24.1:
  • Fixed 2.24 regression causing certain visualizations, most notably Audio Unit adapter, to be jumpy.
Download foobar2000 for Mac 2.24.1 Final
foobar2000 1.6.5 Final für Android wurde veröffentlicht.
Changelog v1.6.5:
  • Fixed startup lockup when last browsed location was an inaccessible SMB network share.
  • Fixed a bug that caused authentication errors when using new network credentials system with FTP folders.
  • Slightly updated TV dim screen formatting, no more "unknown artist" prefix.
foobar2000 1.6.5 Final für iOS wurde veröffentlicht.
Changelog v1.6.5:
  • Reverted use of system SQLite library introduced a few versions ago which was causing issues; using internal SQLite again.
Download foobar2000 1.6.5 Final für iOS
foobar2000 1.6.6 Final für Android wurde veröffentlicht.
Changelog v1.6.6:
  • Made media indexing use less system resources.
Download foobar2000 1.6.6 Final für Android
foobar2000 1.6.6 Final für iOS wurde veröffentlicht.
Changelog v1.6.6:
  • Fixed crash when rapidly opening then minimizing the app.
  • Fixed various bugs related to external music folders.
Download foobar2000 1.6.6 Final für iOS
foobar2000 v2.24.2 Final wurde veröffentlicht.
Changelog v2.24.2:
  • FLAC/WavPack/Monkey decoder update.
  • Fixed Album List crash on specific patterns or too many nested folders.
  • Made certain low-latency output configurations stutter less.
  • Updated Visual C++ runtime.
  • Installer now code-signed with Illustrate certificate.
Download foobar2000 v2.24.2 Final
foobar2000 for Mac 2.24.2 Final wurde veröffentlicht.
Changelog v2.24.2:
  • Fixed album art viewer not following internet radio live covers.
  • Removed spurious Album List menu item.
  • Fixed erratic behaviors of playlist undo.
Download foobar2000 for Mac 2.24.2 Final
foobar2000 v2.24.3 preview 2025-02-28 wurde veröffentlicht.
Changelog v2.24.3:
  • Fixed a bug that caused HLS radio streams to start playing past segments instead of current live segment.
  • Dark mode: fixed checkboxes not being drawn correctly with specific custom themes.
  • Dark mode: fixed specific icons being drawn in wrong size.
Download foobar2000 v2.24.3 preview 2025-02-28
foobar2000 for Mac 2.24.3 Final wurde veröffentlicht.
Changelog v2.24.3:
  • Updated FFmpeg adapter code to version 0.8.2 with CPU usage bug fix.
Download foobar2000 for Mac 2.24.3 Final
foobar2000 v2.24.3 Final wurde veröffentlicht.
Changelog v2.24.3:
  • Fixed incorrect seeking in chained Ogg streams.
  • Fixed specific instances of crashing with malformed configuration data.
Download foobar2000 v2.24.3 Final
Changelog v2.24.3:
foobar2000 1.6.7 Final für Android wurde veröffentlicht.
Changelog v1.6.7:
  • Fixed crashing on malformed playlists.
  • Fewer HTTP requests per internet radio stream open.
  • Fixed HLS radio starting playback at wrong timestamp.
  • Made printer objects not show in SMB shares.
  • Fixed incorrect seeking in chained Ogg files.
  • Fixed a bug causing spurious "library indexing in progress" prompts.
Download foobar2000 1.6.7 Final für Android
foobar2000 1.6.7 Final für iOS wurde veröffentlicht.
Changelog v1.6.7:
  • Implemented iOS voiceover interaction with playback controls screen.
Download foobar2000 1.6.7 Final für iOS
foobar2000 1.6.8 Final für Android wurde veröffentlicht.
Changelog v1.6.8:
  • Fewer library indexing prompts.
  • Fixed missing HTTPS connect timeout, improved internet radio error recovery.
  • Made now-playing album artist info reported to the system.
  • Utilized new Android 11+ methods to detect mass storage, should fix issues with external disks on Android TV.
Download foobar2000 1.6.8 Final für Android
foobar2000 1.6.8 Final für iOS wurde veröffentlicht.
Changelog v1.6.8:
  • Cleaned up voiceover interaction.
Download foobar2000 1.6.8 Final für iOS
