Allg. [Vorstellung] foobar2000 v2.24 preview 2024-10-11 wurde veröffentlicht
- Ersteller Jimi
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- G.Skill RipJaws V schwarz DIMM Kit 32GB, DDR4-3600, CL18-22-22-42
- Palit GeForce GTX 1650 KalmX (passiv)
- AOC Q3277PQU, 32" @ 2560x1440
- Western Digital WD_BLACK SN850 500GB, M.2, Kühlkörper & Lexar NM790 4TB, M.2
- Hitachi-LG Data Storage GP57EB40 schwarz, USB 2.0
- MOTU M2 & Topping L30
- NZXT H7 Flow Black @ 6x ENDORFY Fluctus 140 PWM @ ~600 rpm
- Seasonic Focus GX 550W
- Logitech K310
- Sharkoon FireGlider
- Windows 10 Home x64 @ WinReducer
- Fluid Audio F5 Speaker & Fluid Audio DS 5 Stands, Hifiman Arya Organic, Sennheiser HD 560S
- ▼275 ▲55
foobar2000 v2.2 Preview 2024-06-20 wurde veröffentlicht.
Version v2.2 Preview Change Log:
Download foobar2000 v2.2 Preview 2024-06-20
2024-02-05:
- Implemented Ogg chapter support. Converter can write multichapter Ogg files after disabling Ogg chaining support.
- New major revision of bitcompare code, improved performance of 64-bit build.
- Allow local M3U referencing remote M3U to be both read as playlists, prevent HLS reader being used on non-HLS content.
- Updated File Operations recycle bin detection logic, mitigating lag/lockup occurring for some users.
- Made network encryption error messages more useful.
- Stop decoding ADTS AAC when running into APE tags, instead of reporting errors.
- Report zero-length WAV files as broken.
- Wine compatibility fixes.
2024-02-12:
- Improved ReFacets performance.
- Fixed erratic behavior if ID3v2 tag contains multiple date fields.
- Suppressed advancing to the next playlist item if internet radio playback stops due to a network error.
- File Operations: Added an option to overwrite existing files.
- Suppressed repeating console messages about decoder shims used.
- More thorough error reporting for blank WAV files.
- Added video_codec info for Windows Media Video.
- Added stream_count info for formats that support multiple streams.
2024-02-19:
- Fixed regression preventing internet radio album covers from being shown.
- Applied dark mode to component license popup.
- Updated zlib to 1.3.1.
2024-02-28:
- Playback CPU usage optimizations.
- Small chunks returned by decoder are merged into one to reduce amount of wakeup cycles during playback.
- Made possible to store peak information in Opus files.
2024-03-04:
- Worked around audio glitches with very low output buffer size introduced in previous build.
- Fixed glitchy seekbar movement in certain scenarios.
- Prevented nonsensical video codec names from being reported for certain MP4 files.
- Fixed regressions in ASX playlist loader.
- Converter: More detailed error messages for specific file creation errors.
2024-03-08:
- Mitigation for Converter failures when writing to Google Drive volume.
- Opus decoder updated to 1.5.1
- WavPack decoder updated to 5.7.0; made WavPack library version shown in components list.
- Monkey's Audio decoder updated to 10.52
- Cleaned up and bugfixed detection of MP4 video codec names.
- Prevented nonsense sample rate & channel count from being shown on MP4 files with no audio track.
- File Operations: Defer info reload to prevent bugged display of cuesheets after moving whole folder.
2024-03-14:
- Playback CPU usage reduced.
- Fixed exclusive output lagging in specific scenarios.
- Add Location now strips extra non-text characters from the entered URL.
- Made Ogg chapters beginning from CHAPTER001 recognized.
- Allowed absolute paths in cue sheets.
- Extended MP4 chapter manipulation commands to work with other formats that support chapterizer interface, such as Ogg or Musepack.
2024-03-18:
- Fixed foobar2000 v2.0 regression causing folder watch events to be dropped without triggering full rescan if there's too many of them pending.
2024-03-21:
- Made stream selector show long codec names.
- Media Library: made track add & remove events triggered in groups, resulting in much faster autoplaylist updates.
2024-03-27:
- Create "disable-foocrash" in install folder to kill crash reporting (dump files still get written).
- Run with /nocrashinfo to suppress generation of crash reports.
- File Operations: Suppressed useless secondary progress bar if renaming files.
2024-03-28:
- Fixed 2024-03-21 regression causing unnecessary Media Library disk access.
2024-04-07:
- Fixed very old and very rare Album List lock up bug.
- Pause / resume playback on system sleep / resume.
- Installer script update.
2024-04-10:
- ReFacets playlist interaction bug fixes.
- ReFacets added "Last Modified" stats column.
- Removed system sleep / resume handlers, didn't properly suppress errors with internet radio.
- Made disconnected internet radio streams resumed quietly, without showing error popups.
- 32-bit build: Removed tone generator assembly optimizations, tone:// should produce identical output in all versions now.
- Updated to NSIS 3.10.
2024-04-13:
- Fixed crash if freedb/gnudb server returns more tracks than asked for (regression since 2.0).
2024-04-15:
- Fixed stuck drag&drop scrolling mode in various list controls after receiving external drag&drop.
- Made list control obey system drag threshold values, making it easier to register clicks if mouse moves slightly between mouse down and mouse up events.
- Opus decoder updated to 1.5.2.
2024-04-26:
- Cleaned up interaction with what's left of freedb.
- Made more apparent which freedb-compatible service is in use.
- If there are multiple providers configured, you can specifically choose one from CD Ripper dialog.
- Discarded malformed server replies.- Fixed WASAPI Exclusive timing glitches with exotic settings.
- Prevented Media Library search from clearing other playlists with enter key if library selection playlist feature is active.
- Fixed regression in File Operations recycle bin detection, causing unwanted delete prompts when recycling.
2024-04-27:
- Fixed WASAPI exclusive regression from last build.
2024-05-01:
- Removed gnudb from default online tagger settings, as gnudb now demands users to input their actual email addresses.
- If you wish to use gnudb, you can configure it manually, but we strongly recommend against it.
- Online tagger now defaults to freedb.dbpoweramp.com which works once again.
- Changed storage of freedb server list settings, to a text file in profile folder.
- Added toggle to disable tooltips in Album List.
2024-05-13:
- Prevented all MP4 tag fields prefixed with replaygain_ from being treated as technical information, only actual ReplayGain fields are now such.
- Workaround for ReplayGain scanner attempting to scan Audio CD in multiple threads.
- Removed arbitrary denial of reading of cuesheets over FTP/HTTP/etc.
2024-05-17:
- ReFacets & Album List: Improved processing of %<field>% expressions, artist and artist sort should be split together properly.
- Added tweak options for ReplayGain thread counts.
- Made Properties ReplayGain scan not try to scan Audio CD in multiple threads.
- Removed arbitrary limit of items per "apply gain to file content" pass.
2024-05-23:
- Reverted to VS2019 compiler, unintended AVX requirement has been removed.
- Made fact chunk in PCM WAV files ignored.
- Updated VS runtime DLLs to the latest version.
2024-05-31:
- Improved compatibility with multi-value MP4/M4A tags.
- Fixed 2024-05-17 regression causing bad substitution of | character in Album List / ReFacets.
- Fixed JXL/AVIF/HEIC external album covers not being recognized, even if relevant system image codecs are present.
2024-06-17:
- Fixed nonsensical messages in Converter log when copying non audio files over.
- Updated MP4 tmpo tag manipulation, restored ability to write which was lost a few years ago.
2024-06-20:
- Mitigated poor performance of "Visualize with VST" and equivalent features since CPU usage optimizations in previous beta builds.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 v2.2 Preview 2024-06-24 wurde veröffentlicht.
Download foobar2000 v2.2 Preview 2024-06-24
2024-02-05:
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
- No longer drops DLLs for other CPU architectures than the running one when installing components.
- Internal changes to deal with wildcard characters in filenames on filesystems other than standard Windows one. Windows version should not be affected by this.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.5.2 Final für Android wurde veröffentlicht.
Download foobar2000 1.5.2 Final für Android
Bei Problemen mit Google Play: Standalone Android APK downloads
foobar2000 1.5.2 Final für iOS wurde veröffentlicht.
Download foobar2000 1.5.2 Final für iOS
Changelog v1.5.2:
- Unavailable network share folders are grayed but clickable, clicking refreshes their status.
- Fixed crashing on network share test failure.
- Fixed a 1.4 era regression preventing last viewed folder from being restored after app restart.
Changelog v1.5.2:
- Fixed various bugs causing app crashes when closing foobar2000.
- Fixed a bug causing on-screen keyboard to obstruct text being edited in specific scenarios.
- Fixed skin colors not being applied in some places.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 v2.2 Preview 2024-06-30 wurde veröffentlicht.
Download foobar2000 v2.2 Preview 2024-06-30
2024-02-05:
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
2024-06-30:
- Added %channel_mask% title formatting field, on top of on $info(WAVEFORMATEXTENSIBLE_CHANNEL_MASK).
- Utilized proper hashmap for metadb_display_field_provider lookup, should speed title formatting up somewhat on heavy configs.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 v2.2 Preview 2024-07-06 wurde veröffentlicht.
Download foobar2000 v2.2 Preview 2024-07-06
2024-02-05:
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
2024-06-30:
2024-07-06:
- Fixed title formatting regression from build 2024-06-30, causing some fields to disappear.
- Amended AccurateRip log formatting, added track number info to lines where it was missing before.
- Made https:// used for help.foobar2000.org links.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 v2.2 Preview 2024-07-07 wurde veröffentlicht.
Download foobar2000 v2.2 Preview 2024-07-07
2024-02-05:
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
2024-06-30:
2024-07-06:
2024-07-07:
- Amended title formatting regression fix.
Woerns
Benutzt jemand hier die foobar2000 App auf dem Handy?
Ich streame mir damit meine Musik vom NAS.
Wichtig ist mir dabei u.a. das gapless Abspielen von z.B. Lifemusik oder Klassik.
Was mir noch fehlt, ist die Musik via Bluetooth an mein Soundsystem weiterzureichen.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 v2.2 Preview 2024-08-08 wurde veröffentlicht.
Download foobar2000 v2.2 Preview 2024-08-08
2024-02-05:
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
2024-06-30:
2024-07-06:
2024-07-07:
2024-08-08:
- Fixed different builds using different rounding for float >> integer audio conversion, mainly affecting 24-bit output (least significant bit differences only).
- MP4/M4A/M4B: Prefer QT chapters over chpl if more than 255 chapters found.
- MP4/M4A/M4B: Fixed very rare tag update failures if exceeding 4GB boundary. Note that previous versions would just leave the file untouched and report an error if running into this scenario, never corrupt files.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 v2.2 Preview 2024-08-14 wurde veröffentlicht.
Download foobar2000 v2.2 Preview 2024-08-14
2024-02-05:
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
2024-06-30:
2024-07-06:
2024-07-07:
2024-08-08:
2024-08-14:
- Complex mitigation for corrupted config.sqlite - fresh config.sqlite is created, all readable content is transferred over.
- Made refuse to retag MP4/M4A/M4B files with QT chapters if chapter count exceeds 255, to prevent erratic behavior. Please remux such files to another container to allow tagging.
- Made WMA tag writing behave less erratically if fed tags read by FFmpeg decoder wrapper.
- Improved performance of float>>int24 audio conversion.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.5.3 Final für Android wurde veröffentlicht.
Download foobar2000 1.5.3 Final für Android
foobar2000 1.5.3 Final für iOS wurde veröffentlicht.
Download foobar2000 1.5.3 Final für iOS
Changelog v1.5.3:
- Stability improvements.
- This is the final maintenance update for old devices. The next planned update will support Android 8.0 and newer.
Changelog v1.5.3:
- Stability fixes.
- This is the final maintenance update for iOS 12 & 13. THe next planned update will only support iOS 14 and newer.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.6 Final für Android wurde veröffentlicht.
Download foobar2000 1.6 Final für Android
foobar2000 1.6 Final für iOS wurde veröffentlicht.
Download foobar2000 1.6 Final für iOS
foobar2000 mobile v1.6 has been released and will be available through Google Play & Apple App Store shortly.
Main changes include support for SMB network shares and properly usable TV remote navigation of skinned playback controls.
Changelog v1.6:
- Added SMB network share support using libsmb2.
- New network share credentials management system, no more user: password in share address needed.
- Media Servers page now uses new network location picker to add/edit addresses.
- Prettier display of network share names, "share on server" style instead of raw URL.
- Made remember last used browse/playback page across app restarts.
- Implemented TV remote navigation in skinned playback screen.
- Fixed media library merging albums & artists with similar but differently capitalized names. Your library might need rescanning (toggle folders off and back on) for this to take full effect.
- Added toggle for asymmetric search matching.
- Dropped support for very old devices. Lowest supported operating system is Android 7 (API 24).
Changelog v1.6:
- Media Library can now access any folders on your device, content from other apps, USB storage, etc.
- Dropped support for very old devices. Lowest supported operating system is iOS 14.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 v2.2 Preview 2024-08-22 wurde veröffentlicht.
Download foobar2000 v2.2 Preview 2024-08-22
2024-02-05:
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
2024-06-30:
2024-07-06:
2024-07-07:
2024-08-08:
2024-08-14:
2024-08-22:
- Further mitigation for issues caused by corrupted configuration files.
- Fixed bugs with urlencoding in HTTP redirects.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.6.1 Final für Android wurde veröffentlicht.
Download foobar2000 1.6.1 Final für Android
foobar2000 1.6.1 Final für iOS wurde veröffentlicht.
Download foobar2000 1.6.1 Final für iOS
Changelog v1.6.1:
- Fixed Media Servers page regressions.
- Fixed dynamic track title reliability regressions since 1.5 series.
- Fixed album artist not set for albums with multiple album artists, resulting in multiple albums with same names being merged into one.
- If playing Matroska file with chapters as one track, individual chapter titles are now shown.
- Internet radio streaming reliability improvements.
- TV: Fixed longpress crash in some views.
- TV: Fixed radio station [x] not being accessible with remote d-pad.
- Fixed missing permission flags resulting in console errors about foreground modes.
Changelog v1.6.1:
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 v2.2 Preview 2024-08-29 wurde veröffentlicht.
Download foobar2000 v2.2 Preview 2024-08-29
2024-02-05:
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
2024-06-30:
2024-07-06:
2024-07-07:
2024-08-08:
2024-08-14:
2024-08-22:
2024-08-29:
- Internal changes (C++ noexcept specifier) to improve usefulness of crash reports.
- Refactored Matroska chapter handling. If a multichapter Matroska file is played as a whole (from remote URL etc), chapter names will be shown as dynamic track titles.
- Fixed a bug causing dynamic track titles (internet radio etc) to be possibly discarded.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 v2.2 Preview 2024-08-31 wurde veröffentlicht.
Download foobar2000 v2.2 Preview 2024-08-31
2024-02-05:
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
2024-06-30:
2024-07-06:
2024-07-07:
2024-08-08:
2024-08-14:
2024-08-22:
2024-08-29:
2024-08-31:
- Fixed selection tracking regression from 2024-08-29.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 v2.2 Preview 2024-09-02 wurde veröffentlicht.
Download foobar2000 v2.2 Preview 2024-09-02
2024-02-05:
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
2024-06-30:
2024-07-06:
2024-07-07:
2024-08-08:
2024-08-14:
2024-08-22:
2024-08-29:
2024-08-31:
2024-09-02:
- Mitigation for extreme column width causing CListControl (Playlist, Verifier, possibly others) to go off the rails.
- Fixed false MD5 verification errors on exotic bit depth FLAC files.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 v2.2 Preview 2024-09-11 wurde veröffentlicht.
Download foobar2000 v2.2 Preview 2024-09-11
2024-02-05:
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
2024-06-30:
2024-07-06:
2024-07-07:
2024-08-08:
2024-08-14:
2024-08-22:
2024-08-29:
2024-08-31:
2024-09-02:
2024-09-11:
- Fixed opening of webm audio renamed to .opus being very slow to open.
- Fixed more odd behaviors of tag editing on MP4/M4A with QT chapters.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 v2.1.6 Final wurde veröffentlicht.
Download foobar2000 v2.1.6 Final
foobar2000 for Mac 2.6.5 Final wurde veröffentlicht.
Download foobar2000 for Mac 2.6.5 Final
Changelog v2.1.6:
- Fixed ReplayGain scanner attempting to scan Audio CD in multiple threads.
- Fixed webm audio renamed to .opus being very slow to open.
- Fixed FLAC files with exotic bit depths incorrectly failing audio MD5 verification.
- 24-bit rounding issues fixed, performance improved.
- Mitigated very long tag fields causing playlist view to behave erratically.
Changelog v2.6.5:
- Whole lot of cosmetic fixes, monospaced digit font use, etc backported from latest codebase.
- Made accept dropping folders to dock.
- Fixed issues with * and ? characters in filenames.
- Fixed a bug in timestamp formatting routine, causing milliseconds to be cut off, causing all console timestamps ending with ".000".
- UPnP output preferences fixed edited overrides text not always being saved.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 1.6.2 Final für Android wurde veröffentlicht.
Download foobar2000 1.6.2 Final für Android
foobar2000 1.6.2 Final für iOS wurde veröffentlicht.
Download foobar2000 1.6.2 Final für iOS
Changelog v1.6.2:
- Restored ability to manually input UPnP media server URLs.
- When turning console logging on, current backlog is now saved.
- If internet radio stream is stuck at 0:00, clicking same radio station again restarts it rather than doing nothing.
- Fixed skinned playback view showing nonsensical remaining time for internet radio streams.
- Made Media Servers page automatically search local network for SMB and FTP servers.
- Updated invalid filename character criteria; uploading unsupported filenames via FTP should fail more gracefully.
- Fixed Matroska embedded cover display.
- Fixed inaccurate timestamps (milliseconds zero'd) in console logs.
- Reverted 1.6 "share on server" naming of shares in Media Library, to show network protocol (SMB or FTP or other) used.
Changelog v1.6.2:
- Updated invalid filename character criteria; uploading unsupported filenames via FTP should fail more gracefully; allowed question marks in file names.
- Moved console logs location, no longer creates "Console Logs" in music folder.
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 v2.24 preview 2024-10-04 wurde veröffentlicht.
Version v2.24 Preview Change Log:
Download foobar2000 v2.24 preview 2024-10-04
2024-10-04:
- New version numbering scheme: 2.24 for planned stable release year of 2024. Stable release will follow soon.
- Attempted workaround for rapidly restarting playback locking up D2D visualizations on some systems.
- Internet Radio search & list: clicking a stream that is already playing no longer restarts playback.
- Fixes for plain WAV files over 4GB in size. Note that WAV file format does not actually support content longer than 4GB.
- Made current console backlog saved when toggling logging on.
2024-09-11:
2024-09-02:
2024-08-31:
2024-08-29:
2024-08-22:
2024-08-14:
2024-08-08:
2024-07-07:
2024-07-06:
2024-06-30:
2024-06-24:
2024-06-20:
2024-06-17:
2024-05-31:
2024-05-23:
2024-05-17:
2024-05-13:
2024-05-01:
2024-04-27:
2024-04-26:
2024-04-15:
2024-04-13:
2024-04-10:
2024-04-07:
2024-03-28:
2024-03-27:
2024-03-21:
2024-03-18:
2024-03-14:
2024-03-08:
2024-03-04:
2024-02-28:
2024-02-19:
2024-02-12:
2024-02-05:
2024-09-02:
2024-08-31:
2024-08-29:
2024-08-22:
2024-08-14:
2024-08-08:
2024-07-07:
2024-07-06:
2024-06-30:
2024-06-24:
2024-06-20:
2024-06-17:
2024-05-31:
2024-05-23:
2024-05-17:
2024-05-13:
2024-05-01:
2024-04-27:
2024-04-26:
- Discarded malformed server replies. - Fixed WASAPI Exclusive timing glitches with exotic settings.
2024-04-15:
2024-04-13:
2024-04-10:
2024-04-07:
2024-03-28:
2024-03-27:
2024-03-21:
2024-03-18:
2024-03-14:
2024-03-08:
2024-03-04:
2024-02-28:
2024-02-19:
2024-02-12:
2024-02-05:
Jimi
- Hamburg
- Klöterkasten
- AMD Ryzen 7 5700X
- MSI B550-A Pro
- ENDORFY Fortis 5
- Logitech K310
- ▼275 ▲55
foobar2000 v2.24 preview 2024-10-11 wurde veröffentlicht.
Download foobar2000 v2.24 preview 2024-10-11
2024-10-11:
- Updated RAR extraction code to the latest official code release.
- Fixed hardware-accelerated visualization crash on settings change.
2024-10-04:
2024-09-11:
2024-09-02:
2024-08-31:
2024-08-29:
2024-08-22:
2024-08-14:
2024-08-08:
2024-07-07:
2024-07-06:
2024-06-30:
2024-06-24:
2024-06-20:
2024-06-17:
2024-05-31:
2024-05-23:
2024-05-17:
2024-05-13:
2024-05-01:
2024-04-27:
2024-04-26:
2024-04-15:
2024-04-13:
2024-04-10:
2024-04-07:
2024-03-28:
2024-03-27:
2024-03-21:
2024-03-18:
2024-03-14:
2024-03-08:
2024-03-04:
2024-02-28:
2024-02-19:
2024-02-12:
2024-02-05:
2024-09-11:
2024-09-02:
2024-08-31:
2024-08-29:
2024-08-22:
2024-08-14:
2024-08-08:
2024-07-07:
2024-07-06:
2024-06-30:
2024-06-24:
2024-06-20:
2024-06-17:
2024-05-31:
2024-05-23:
2024-05-17:
2024-05-13:
2024-05-01:
2024-04-27:
2024-04-26:
2024-04-15:
2024-04-13:
2024-04-10:
2024-04-07:
2024-03-28:
2024-03-27:
2024-03-21:
2024-03-18:
2024-03-14:
2024-03-08:
2024-03-04:
2024-02-28:
2024-02-19:
2024-02-12:
2024-02-05:
- 7K
