WinRAR 3.60 Beta 2
- Ersteller cruger
Nachdem vor wenigen Wochen die erste Beta der nächsten WinRAR Version 3.60 veröffentlich wurde, ist nun seit kurzem die zweite Beta-Version verfügbar, bei der einige kleinere Probleme behoben wurden.
Mit der Version 3.60 bietet WinRAR erstmals eine Unterstützung für Dual-Core CPUs wie z.B. AMDs Athlon 64 X2.
<b><u>WinRAR - What's new in the latest version</u></b><br><br><font size="1" face="tahoma"><b>Version 3.60 beta 2</b></font><ul><li><font size="1" face="tahoma">Improved Unicode support in the folder tree panel.</font></li><li><font size="1" face="tahoma">Fixed a bug with incorrect font in the volume size list in Japanese Windows 98.</font></li></ul><font size="1" face="tahoma"><b>Version 3.60 beta 1</b></font><ul><li><font size="1" face="tahoma">Multithreaded version of RAR compression algorithm improves the compression speed on computers with several CPU, dual core CPU and processors with hyperthreading technology. Multithreading is enabled by default, but you can disable it in "General" part of "Settings" dialog. In the command line mode you can control multithreading with -mt switch.</font></li><li><font size="1" face="tahoma">WinRAR can display the folder tree panel allowing to navigate in disk and archive folders. Use "Options/Folder tree" submenu to enable the folder tree. It can be configured separately in file and archive management modes.Folder tree replaces "Browse for folder" command previously available in "File" menu and uses its Ctrl+T keyboard shortcut.</font></li><li><font size="1" face="tahoma">Now WinRAR "Rename" command also works with ZIP archives. Previous versions could rename files only in RAR archives.</font></li><li><font size="1" face="tahoma">Added decompression of LZH archives created with "-lh7-" algorithm.</font></li><li><font size="1" face="tahoma">New "Remove duplicate folders from extraction path" option in "Settings/Compression" dialog.If this option is on and you unpack an archive which root folder has no files and only one 'somename' folder and if destination folder is new or empty and also ends with '/somename', WinRAR will exclude one 'somename' from resulting 'somename/somename' path.</font></li><li><font size="1" face="tahoma">New "Define volume sizes..." button in "Settings/Compression". This button activates "Define volume sizes" dialog. Here you can customize the list of predefined volume sizes associated with "Split to volumes, bytes" field in archiving dialog.</font></li><li><font size="1" face="tahoma">Speed of RAR general compression increased for some data types. Depending on data type and size the gain may achieve 5 - 15%.</font></li><li><font size="1" face="tahoma">New "Rename automatically" option in the extraction dialog and command line -or switch to rename extracted files automatically if file with the same name already exists. You can also enable the auto-renaming mode directly from the overwrite confirmation prompt with "Rename All" button.Renamed files will get names like 'filename(N).txt', where 'filename.txt' is the original file name and 'N' is a number.</font></li><li><font size="1" face="tahoma">"Set modification time" option in "Advanced" part of extraction dialog is accessible also for ZIP archives. Previously it could be changed only for RAR archives.</font></li><li><font size="1" face="tahoma">"Multithreading" option added to "Benchmark and hardware test" command, so you can compare performance of usual and multithreaded versions of RAR compression algorithm.</font></li><li><font size="1" face="tahoma">New 'ch' (change archive parameters) command line mode command. Its purpose is to apply switches like -av, -tl and -cl to archive.</font></li><li><font size="1" face="tahoma">New 'cv' command line mode command. It provides the command line interface to WinRAR "Convert archives" command. It is supported only by winrar.exe, not by rar.exe.</font></li><li><font size="1" face="tahoma">New command line -sl and -sm switches to set size limits of processing files.</font></li><li><font size="1" face="tahoma">New command line -fcu[file] switch allows to read archive comments from Unicode files. It also modifies behavior of "cw" command, setting the comment output format to Unicode.</font></li><li><font size="1" face="tahoma">7Z added to list of formats stored without compression when using -ms switch without a parameter.</font></li><li><font size="1" face="tahoma">Switch -e[+] is now supported by most of command line operations including extracting and deleting files. Previously it was supported by only archiving command.</font></li><li><font size="1" face="tahoma">It is allowed to use environment variables in archive name in archiving dialog, in destination path in extraction dialog, in folder names on "Compression" and "Paths" pages in WinRAR settings. For example, you can enter '%temp%' in "Folder for temporary files" field.</font></li></ul>
<b>Download:</b><ul><li><img src="/images/englisch.gif" border="1" height="10" width="15"> <a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20060419201345">WinRAR 3.60 beta 2 - Trial Version [Windows]</a></li>
<li><img src="/images/englisch.gif" border="1" height="10" width="15"> <a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20060419201346">RAR 3.60 beta 2 - Free Version [Pocket PC]</a></li><li><img src="/images/englisch.gif" border="1" height="10" width="15"> <a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20060419201347">RAR 3.60 beta 2 - Trial Version [DOS, Command line only]</a></li><li><img src="/images/englisch.gif" border="1" height="10" width="15"> <a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20060419201348">RAR 3.60 beta 2 - Trial Version [Linux, Command line only]</a></li><li><img src="/images/englisch.gif" border="1" height="10" width="15"> <a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20060419201349">RAR 3.60 beta 2 - Trial Version [FreeBSD, Command line only]</a></li><li> <img src="/images/englisch.gif" border="1" height="10" width="15"> <a href="http://www.planet3dnow.de/cgi-bin/file/get.pl?20060419201350">RAR 3.60 beta 2 - Trial Version [MacOS X, Command line only]</a></li></ul>
<b>Links zum Thema:</b><ul><li><a href="http://www.rarlabs.com/rarnew.htm" target="b">WinRAR Changelog</a></li></ul>
Gast29012019_2
Intels Pentium D und Pentium 4 mit HT ebenfalls.
[MTB]JackTheRipper
- Reutlingen
- Folding@Home
- 2x X2 3800+
- HP NC2400
- Samsung SyncMaster 305T
- Antec P180B
Da steht ja auch "z.B."
klein van
- Raum Hessen
- Spinhenge@home
- Spinhenge
- i7-860, Q6600, Q6600, E6600, T7400, Athlon4000, i5-560M
- Lenovo R60
- Intel i7-860
- GA-P55A-UD6
- Noctua P12 mit 2x120/35
- 2x2GB DDR3 1600 OCZ
- ATI HD6850
- 19 TFT
- 1xWDC15 als System; 2x500er Samsung
- GGC-H20L, LG GSA-H55N
- Chieftec Mesh LCX-01BL-BL-B, blau
- Enermax 485W Noisetaker (EG495AX-VE(W)-SFMA)
- Windows7 Ultimate 64 bit
- IE8, FireFox3.6xx
Naja ich bin momentan auf 7-Zip umgestiegen das an sich sehr gut läuft und kostenlos ist. Frage mich aber ob Dualcore wirklich viel besser unterstützt wird in den neuen Versionen.
Hey,
kannst doch mit 7-Zip zufrieden sein
http://www.hartware.de/review_575_2.html
Auch 7-Zip wurde bereits optimal auf Dualcore abgestimmt, wie im Test deutlich zu sehen ist. Ein Core mehr verringert die Kompressionszeit spürbar, 200 MHz mehr dagegen machen keinen großen Vorsprung aus.
Gruß "klein van"
manolo
- vorhanden
- AMD BE-2400
- Gigabyte GA-MA78GM-S2H
- Scythe Ninja mini
- A-DATA DDR II 800 (CL4)
- Ati Radeon HD 4xxx
- Toshiba 46" LCD
- 500GB Seagate Barracuda ES.2
- LG DVD-Brenner / HD DVD
- OnBoard
- Antec Fusion Black
- VISTA MCE
- HTPC
Gibts es zu WinRAR schon Benchmarks?
http://www.computerbase.de/news/software/packprogramme/2006/maerz/winrar_360_dual-core-support/Gibts es zu WinRAR schon Benchmarks?
