Version 4.01
1. Added support for file sizes stored in binary format in TAR archives.
Some TAR archives use the binary size format instead of octal
for files larger than 8 GB.
2. Bugs fixed:
a) "Repair" command failed to properly reconstruct structure
of RAR archives, which contained at least one file with packed
size exceeding 4 GB.
This bug did not affect the recovery record based repair.
It happened only if recovery record was not found and WinRAR
performed reconstruction of archive structure;
b) even if "Do not extract paths" option in "Advanced" part of
extraction dialog was set as the default, WinRAR still unpacked
file paths if called from Explorer context menu;
c) after entering a wrong password for encrypted ZIP archive,
sometimes WinRAR ignored subsequent attempts to enter a valid
password;
d) "Wizard" command did not allow to create self-extracting
and multivolume archives, when compressing a single folder
or a file without extension;
e) "Import settings from file" command did not restore multiline
comments in WinRAR compression profiles;
f) when converting RAR volumes having name1.name2.part#.rar name format,
"Convert archives" command erroneously removed ".name2" name part.
So resulting archive had name1.rar file name instead of expected
name1.name2.rar;
g) RAR could crash when creating a new archive with -agNNN switch
if archive number in generated name was 110 or larger;
h) WinRAR failed to display non-English file names in 7-Zip archives
properly if they used a non-default code page. It was the display
only problem, such names were unpacked correctly.
