Asteroids@home
- Ersteller Saenger
Saenger
Captain Special
- Bremen
- Viele
- CPDN, SIMAP, RNA, WCG
- C2Q 9450 @3,0GHz
- Core2Quad 9450 @3,2GHz
- Gigabyte GA-P35C-DS3R
- Scythe Andy Samurai Master
- 2x4 GB Corsair CL9 XMS PC3-12800
- Club 3D GT240 NVidia
- Samsung 24" SyncMaster 2494HS , 1920 x 1080
- Samsung HD321KJ 320GB SATA-2
- LG GSA-H62N, LG GDR H20N
- on board
- Thermaltake Matrix VX silber
- BE Quiet! Straight Power 550
- ubuntu 10.04 64bit
Asteroids@home
Neues Projekt, sogar schon mit Team von Euch und Credits eines Crunchers bei Euch.
Der Beschreibungstext ist der hier:
About Asteroids@home
Asteroids@home is a research project that uses Internet-connected computers to do research in Asteroids@home. You can participate by downloading and running a free program on your computer.
Asteroids are the most numerous objects in the solar system. So far, hundreds of thousands of asteroids are known, with hundres of new discoveries every day. Altough the total number of known asteroids is large, very little is known about the physical properties of individual objects. For a significant part of the population, only the size of the bodies is known. Other physical parameters (the shape, the rotation period, direction of the rotation axis,...) are known only for hundreds of objects.
Because asteroids have in general irregular shapes and they rotate, the amount of sunlight they scatter towards the observer varies with time. This variation of brightness with time is called a lightcurve. The shape of a lightcurve depends on the shape of asteroid and also on the viewing and illumination geometry. If a sufficient number of lightcurves observed under various geometries is collected, a unique physical model of the asteroid can be reconstucted by the lightcurve inversion method.
The project Asteroids@home was started with the aim to significanly enlarge our knowledge of physical properties of asteroids. The BOINC application uses photometric measurements of asteroids observed by professional big all-sky surveys as well as 'backyard' astronomers. The data is processed using the lightcurve inversion method and a 3D shape model of an asteroid together with the rotation period and the direction of the spin axis are derived.
Because the photometric data from all-sky surveys are typically sparse in time, the rotation period is not directly 'visible' in the data and the huge parameter space has to be scanned to find the best solution. In such cases, the lightcurve inversion is very time-consuming and the distributed computation is the only way how to efficiently deal with photometry of hundres of thousands of asteroids. Moreover, in order to reveal biases in the method and reconstruct the real distribution of physical parameters in the asteroid population, it is necessary to process large data sets of 'synthetic' populations.
More info about projects on:
Homepage of the project
DAMIT - Database of Asteroid Models from Inversion Techniques
Articles and math
Major J
Mh würde gern dem Team beitreten, aber der Button wird mir nicht angezeigt beim Planet3DNow-Team
EDIT: Grmpf ... nur Linux-Client -_-
wintermute_3dc
- Simap, Constellation
- Constellation
- Lenovo L520
- Intel Core i3-2310M 2.1 GHz
- Intel
- 8GB
- Intel HD Graphics 3000
- 15,6''
- Fedora
Yeah, Linux!
Wenn Simap vorbei ist werde ich es mal rechnen lassen.
Wer ist denn der Betreiber? Der gleiche wie bei DAMIT?
Saenger
Captain Special
- Bremen
- Viele
- C2Q 9450 @3,0GHz
- on board
Yeah, Linux!
Der Admin heißt Kyong und ist Mitglied vom Tschechischen Nationalteam.
Und da auf der Seite des Tschechischen Projekts DAMIT auch auf A@H verlinkt ist, schient Deine Annahme korrekt zu sein.
wintermute_3dc
- Constellation
- Lenovo L520
- Intel
- 8GB
- 15,6''
- Fedora
Die erste WU ist durch, hat auf meinem kleinen I3 über 11 Stunden benötigt, Credite gabs noch keine.
- 8685x <><
- Spinhenge; Orbit; Milkyway
- Orbit@home; Milkyway@home
- P-
- vollbelegung
- 3x
- (Tower voll!)
- Asus SATA-DVD RW
- o.b.
- vorhanden überall
- ja gibt es jes
- ja
also nur Linux??
Asteroids
http://asteroidsathome.net/boinc/
Anwendungen: zur Zeit nur Linux
Serverstatus: Upload/Download zur Zeit deaktiviert
Da sind/waren auch noch ein paar kleine Scherze eingebaut à la minimum quorum 20. Ist wohl behoben!
Radim Vanco schrieb:News
Releasing windows application
I can finally announce releasing application for windows. I am glad that it is finally done and much more users can start crunching.
Radim Vanco (Kyong)
7 Dec 2012 | 19:51:19 UTC
Seit dem 7. Dezember läuft Asteroids auch auf Windows
http://asteroidsathome.net/boinc/apps.php
Crashtest
- Leipzig
- Collatz, yoyo, radac
- yoyo
- Lenovo IdeaPad 5 14ALC05
- Ryzen 7950X / Ryzen 4750G
- ASRock B650M PGRT / X570D4U
- 27" Samsung LF27T450F
- KINGSTON SNVS2000G
- onboard HD?
- zu kleines für die GPU
- CHERRY SECURE BOARD 1.0
- Logitech RX250
- Windows 10 19045.4355 / Server 20348.2402
- Edge 124.0.2478.51
- U320 SCSI-Controller !!!!
- ▼1000 MBit ▲82 MBit
Gleich mal Wuzen angefordert
Hui, da gibt aber einer mächtig Gase. 8)
@Stiller Cruncher
Huhu, come in.
@Stiller Cruncher
Huhu, come in.
Asteroids ist für Windows freigegeben. Wo bleibst Du?also nur Linux??
- 8685x <><
- P-
- vollbelegung
- 3x
- (Tower voll!)
- Asus SATA-DVD RW
- o.b.
- vorhanden überall
- ja gibt es jes
- ja
moin.... wie dem obigen User geht es mir auch: wieder mal kein "Join this team-Button" ...
Es kann doch nicht so schwer sein, das immer gleich zu posten. Nicht jeder ist Boinc-Crack und nicht jeder hat Lust sich erstmal 3 Stunden durch unzählige Seiten zu klicken.
Solange das nicht langsam Standard wird, ohne mich.
sollte ich das übersehen haben und blind sein, so sorry.
@S.I.
Ruhe bewahren. Hast PN.
Habe es ebend noch mal getestet. Der Button ist da. "Diesem Team beitreten". Geht aber nur über Deinen Asteroidsaccount.
Grüße Pollux
PS: Beim Stillen Cruncher ist es eher Taktik
Grüße Pollux
- 8685x <><
- P-
- vollbelegung
- 3x
- (Tower voll!)
- Asus SATA-DVD RW
- o.b.
- vorhanden überall
- ja gibt es jes
- ja
jo, Danke nochmal Pollux,
bin inzwischen angemeldet und im Team.
Er läuft nun schon so um die 2 Std. (leider nur CPU) - bisher sehe ich aber leider noch keine Resultate, also dass er irgendwas gerechnet haben sollte, obwohl die Kerne auf 100% stehen.
Vllt. dauert es aber einfach ne Zeit, iwie ist das Web eh grad saulangsam.
@S.I.
Ist im Boincmanager die erweiterte Ansicht geöffnet?
Dann sollte der Prozentuale Fortschritt der einzelnen Berechnungen ersichtlich sein.
Die Anwendungen von Asteroids rechnen nur mit der CPU und dürften mit dem 1090 um die 9500 sec liegen. Die WUs haben ein 2er Quorum.
Laut Deiner Taskliste wurde aber noch nichts fertig gerechnet:
http://asteroidsathome.net/boinc/results.php?hostid=13918
Für GPU-Arbeiten (z. B. Einstein/Poem) bitte mindestens den Boincmanager 7.0.28
http://boinc.berkeley.edu/download_all.php
http://asteroidsathome.net/boinc/Kyong schrieb:New models of asteroids published
There are new models of asteroids published in section scientific results
Radim Van?o (Kyong)29 Mar 2013, 14:29:53 UTC
orpheus2k
- Altkreis Lübbecke
- POEM@HOME, SIMAP
- MacBook Air 13" (2012)
- Intel Core i7-3770K
- Gigabyte GA-Z77X-UD5H
- Noctua NH-D14
- Dell UltraSharp U2913WM
- LG Electronics GH22LS30
- Antec P182
Wir nehmen morgen an einem kleinen Race teil.
Aufgrund des Pendings dort, sollte man am besten sofort anfangen!
News : Internet connection repairing
Problems and bug reports : Validation inconclusive
http://asteroidsathome.net/boinc/forum_thread.php?id=126
http://asteroidsathome.net/boinc/forum_thread.php?id=125Kyong schrieb:On Tuesday 30.04.2013 our ISP is going to be repairing our internet connection due to some failures and slowing down so server will be offline on that day approximately from 08:00 to 14:00 UTC.
Geschrieben: 28 Apr 2013, 8:09:41 UTC
Mente
- constalation astroids yoyo
- yoyo doking
- Ryzen 3950x
- AMD 5800X3D
- Headkiller IV
- MSI Optix MAG27CQ
- n/a
- n/a
- Soundblaster X4
- Seasonic Prime GX-850 850W
- Logitech G19
- Logitech G703
- Win 10 pro
- IE 11 Mozilla Opera
- Logitech PRO RENNLENKRAD DD
hi,
kann es sein das seit 12uhr das Projekt down ist?
wintermute_3dc
- Constellation
- Lenovo L520
- Intel
- 8GB
- 15,6''
- Fedora
Funktionieren bei euch die Projektseiten?
Crashtest
- Leipzig
- yoyo
- onboard HD?
- Logitech RX250
Nope - Feeder fehler & Co.
wintermute_3dc
- Constellation
- Lenovo L520
- Intel
- 8GB
- 15,6''
- Fedora
Ich hoffe das funktioniert bald wieder, auf meinem Handy warten noch WUs auf den Upload.
Senn
- bei Aachen
- POEM
- Help Conquer Cancer / POEM / yoyo
- Intel i5-3570K - AMD HD7850 2GB (GDDR5), AMD FX-4100 - HD7750 1GB (GDDR5)
- HP 15-g204ng Notebook - AMD Quad Core A8-6410 - 8 GB RAM
- Intel XEON E3-1231v3
- ASUS B85M-E, Sockel 1150, mATX, B85
- Be Quiet Dark Rock Advanced
- 16 GB [2x 8GB] DDR3-1866 Corsair Vengeance
- Palit GeForce GTX 980 Super Jetstream, 4GB DDR5
- Acer Predator G246HLF 61 cm (24")
- SanDisk Ultra II SSD 240GB / 120 GB Samsung EVO 850
- 500GB Seagate 7.200 rpm
- DVD-Brenner
- ATX-Midi Bitfenix Shadow, schwarz
- 600 Watt beQuiet System Power 7, 12cm
- Windows 10 - 64-Bit
- Chrome die aktuellste Version
- - NAS QNAP TS-251 Pro mit SSD´s
es wird doch gerade ein Server Umzug gemacht so wie es am Freitag im Forum stand.
Es sollte eigentlich "nur" 6-8 Stunden dauern.......am Freitag!.
Bin gespannt wann es endlich weitergeht, da die Deadline ziemlich nahe kommt und ich gerne knapp 200 fertige WU´s hochladen möchte
wintermute_3dc
- Constellation
- Lenovo L520
- Intel
- 8GB
- 15,6''
- Fedora
@Sennanke für die Info!
Senn
- bei Aachen
- POEM
- DVD-Brenner
es tut sich was Dauert nicht mehr lang!
Senn
- bei Aachen
- POEM
- DVD-Brenner
Ich verbessere mich: bei den ersten 100 WU´s ist die Deathline überschritten. Werden die nicht gutgeschrieben, verbanne ich das Projekt auf Lebzeit.....
