Changelog:
v0.30a
- Aug 15th, 2003 -
bluecow: Added dialog for showing the eD2K meta data for search results,
download files and shared files. The according context menu
item is only in "Advanced mode" available.
- Aug 14th, 2003 -
.: Added some new checks and fixes in order to ban unfair clients
.: Changed the TCP (local) and UDP (global) source search for clients who are
downloading many files, to make some server software
happy one more time and to avoid blacklisting
.: Unused credits are removed after 5 month (to limit the memory usage for
credits)
- Aug 12th, 2003 -
bluecow: Server error messages are no longer displayed in the server info
window, but in the application log window.
bluecow: ED2K file meta data received during a file search is filtered before
adding it to the part.met and eventually to the
known.met file to avoid storing of not needed data.
bluecow: Several changes in the file preview command: The preview command is
enabled, if a minimum of 16 KB (MPEG audio/video) or
256 KB at the beginning of the file is available. The preview command is also
enabled for files of type "CD-ROM image" or if the
ED2K meta data indicates an audio/video file type. To enable the new features of
the preview command specify VideoLAN client as the
video player for preview or (if using some other player) specify the
'PreviewSmallBlocks=1' (section=eMule) setting in the
preferences.ini file and disable the 'Create backup for preview' option.
Ornis: better counting of the stats: saved by ICH, lost due to corruption and
saved by compression
Ornis: little GUI fixes/updates
- Aug 10th, 2003 -
Ornis: Source-swapping cares for download priorities now and is more safe
against useless handing over sources back and forth
Ornis: Alt-Return opens detail dialog for downloads and user
Ornis: added Enhanced Chunk Selection, better selection which part of a file to
download next [Maella & jicxicmic]
- Aug 4th, 2003 -
bluecow: Added extracting of meta data and audio/video characteristics for
MP3,AVI,MPEG and other files. To disable this option use
the "ExtractMetaData" setting (file=preferences.ini, section="eMule",
name=ExtractMetaData, value=0 (disable), value=1 (enable for
MP3 and AVI files), value=2 (default; enable for MP3, AVI, MPEG and other
files).
bluecow: Added sending of extracted meta data and audio/video characteristics
for MP3,AVI,MPEG and other files to servers and
clients. The text meta data (e.g. Title, Author, Album) is not sent to the
servers but to clients when viewing the shared files.
Data sent to servers includes audio/video codec, media length and bitrate.
bluecow: More safety in checking shareable files in temporary directory.
- Aug 2nd, 2003 -
bluecow: Added new Server Info window with optional auto scroll, rotating log,
copy+paste
bluecow: Added new option to specify or to disable the server UDP port
(file=preferences.ini, section=eMule, name=ServerUDPPort,
value=0 (disable server UDP port), value=65535 (default; use random server UDP
port), value= (UDP port)
bluecow: Added some helpful server socket error messages.
bluecow: Fixed some minor focus problems in search window.
bluecow: Added more columns to search list for showing new ed2k meta tags.
bluecow: Format of date/time strings is no longer dependent of the selected
language.
bluecow: Statusbars of paused files are shown in a dimmed colors [SlugFiller
grayPause]
- Aug 1st, 2003 -
bluecow: Splitted the taskbar notification for "Download finished and new add
file added"
- July 30th, 2003 -
bluecow: Fixed some security bugs concerning log messages [thx i0nic]
- July 29th, 2003 -
.: Made some changes and fixes in SecureHash. Also clients with the status
"invalid" will no longer be able to use a Friend Slot
.:Implemented MobileMule protocol 0.4 (visit mobil.emule-project.net for more
info)
bluecow: ED2K protocol: fixed handling of OP_FILESTATUS for files with a size of
PARTSIZE*N
bluecow: Fixed crash at exit bug which occurred when flushing internal file data
buffers to part files
bluecow: Fixed crash bug with clients sending more than one OP_HELLO packet.
- July 27th, 2003 -
bluecow: Fixed handling of hashsets for files with a size of PARTSIZE*N
bluecow: Invalid entries in known.met are deleted at startup
bluecow: ED2K protocol: OP_SETREQFILEID is no longer sent for files <= PARTSIZE
bluecow: ED2K protocol: OP_FILEREQANSNOFIL is no longer sent when receiving
OP_FILEREQUEST
- July 25th, 2003 -
Ornis: manual disable textbox auto-completion in the preferences.ini file, by
setting "UseAutocompletion=0"
Ornis: Webinterface: added sorting of search results
bluecow: searching of listview items for all owner drawn listview controls (just
type the first view characters of the label to
find) [ZZ]
- July 22th, 2003 -
bluecow: Disabled sharing (by accident) of eMule installation folders (config,
lang, webserver) and several files from the temporary
directory.
bluecow: Fixed a rare problem where a client could receive properly compressed
blocks but was though not capable of decompressing
the entire compressed stream.
Ornis: Fixed Drag&Drop-image of downloadfiles
- July 20th, 2003 -
Ornis: IRC- & Message-Windows use closeable tabs now
Ornis: history function in the IRC- & messages-dialog, scroll by cursor up &
down
Ornis: Doubleclick on serverinfo in the statusbar opens a dialog with the
details of the connected server
Ornis: new downloads catched from the browser are now assigned to the current
targetcategory from the search-dialog
Ornis: to reset the popup-history of searchtext/serverlist-URL : press ALT or
CTRL and then DEL
Ornis: Statistics: percent display of successful/failed upload sessions added
Ornis: Fixed count of failed upload sessions [Maella]
- July 19th, 2003 -
bluecow: Fixed bug with downloading of files with a size of 9728000 bytes.
bluecow: Added several parts of SlugFiller's SafeHash [SlugFiller]
- SafeHash: Known file hashing features
- SafeHash: Miscellaneous safety and tweaking features
Ornis: improved update of the downloadlistcontrol, when new sources are added
to an expanded downloadfile
Ornis: Fix of a typo in the webinterface, which could have led to instability
on some systems
Ornis: Webinterface: (re)added two settings in the preferences
bluecow: Upgraded to CTreeOptionsCtrl v1.55 [thx PJ Naughter]
bluecow: New log panes, multiline edit controls with optional auto scroll and
rotating log.
(Note: The previously used "MaxLogMessages" entry in preferences.ini is obsolete
and is replaced with "MaxLogBuff" which
can be used to specify the size of the buffer(s) in KByte. Default size = 64
KByte)
bluecow: Searchresult list: Search results which match files in the download
list are shown in a fixed shade of red.
bluecow: Font for Server-, Message- and IRC-Window can be specified.
bluecow: Timestamp setting for IRC-Chat also applies timestamps to messages from
clients in Message window.
bluecow: Timestamps in IRC-Window and Message-Window localized.
bluecow: Added memory debug statistics for debug builds only [UVman]
- July 18th, 2003 -
Ornis: Added extended control: manual handling of sources, at several requests
to the same client (A4AF) [based on sivka,enkeyDEV]
Ornis: Added: automatic assignment of new Download to categories by filename
filters [HoaX_69]
Ornis: corrected saving position for the scheduler-ini-file (-> \config\ )
- July 16th, 2003 -
bluecow: Fixed bug with downloading of files with a size greater thean 2 GB [thx
Maella]
Ornis: Bugfix: spanish & french translation bugfix. (bug resulted in less
search results)
Ornis: better update of the SecureIdent-statistic
<a href="http://www.planet3dnow.de/cgi-bin/newspub/viewnews.cgi?category=2&id=1061124993">Zurück zum Artikel</a>
