EPoX EP-8K3A+ BIOS 2326 Final
Nero24
Administrator
Teammitglied
01.07.2000
24.066
10.446
  • BOINC Pentathlon 2019
  • BOINC Pentathlon 2020
  • BOINC Pentathlon 2018
  • BOINC Pentathlon 2021
Für die VIA KT333 Mainboards EPoX EP-8K3A und EP-8K3A+ ist ein neues BIOS vom 26.03.2002 erschienen. Es beinhaltet folgende Fixes:<ul><I>- Improve AGP compatibility
- Add new item 'Write Recovery Time' for DRAM performance
- Solved KT333 cmos conflict issue. That will cause system resume from S4 will hang at POST code C1h. If the procedure is S0->S3->S0->S4->S0
- Solved PS/2 KB power on fail from S3/S4/S5
- Add code to support shutdown temperature check begin POST code C0h
- Patch some motherboard boot from cool power on. System temperature will higher than CPU temp
- Update AWDFLASH.EXE to v8.10am </i></ul><b>Download:</b> <a href="http://www.planet3dnow.de/faq/files/index.shtml#biosupdates">EPoX EP-8K3A(+) BIOS 2326 Final</a> (Planet 3DNow! BIOS-Datenbank)
